Any chances for HPWM to generate 50Hz output?
Results 1 to 2 of 2
    Default Any chances for HPWM to generate 50Hz output?
    Hello.
    As PBP manual says, there are some limitations for HPWM lowest frequency.
    Are these PBP limitations or hardware limitations?
    I want to have two 50% duty cycle, 50Hz pulses generated with dead time, using built in hardware PWM module (16/18 series midrange)
    Is this possible?
    Default Re: Any chances for HPWM to generate 50Hz output?
    Is this possible?
    yes a PIC16F18446 or similarly equipped chip @fosc=4MHz can do that by combining the PWM module output with the CWG module.
    unfortunately fosc/4 is the only acceptable clock source for pwm generation for 8 bit pic's so options are limited a bit for overall accuracy and dead time resolution.
  1. How to set HPWM to generate 38khz signal? (16F870)
    Last Post: - 5th July 2016, 09:39
  2. Replies: 3
    Last Post: - 23rd October 2011, 12:53
  3. 50hz sync for light dimmer
    By tirithen in forum General
    Last Post: - 6th September 2008, 19:29
  4. Redefining HPWM as output
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 21st September 2005, 08:18
  5. Xin & Xout Europe (50hz) vs US (60hz)
    Last Post: - 2nd May 2005, 11:49
Members who have read this thread : 5
