PWM, H-Bridge and NCO - PIC16F18446
+ Reply to Thread
Results 1 to 27 of 27
    Default Re: PWM, H-Bridge and NCO - PIC16F18446
    The main task is to drive a load (this is a big coil of around 19mH of thick 2mm wire at 60cm diameter) with:
    1. Unipolar, 0-20 volts, pulsating power of 0-50Hz
    2. Bipolar 0-20 Volts, pulsating power of 0-50Hz
    Because of 2. a full bridge is needed.
    But because of the high currents at low frequency (below say 30Hz) the MosFets of the Bridge are not in the SOA and decided to use PWM to adjust the mean voltage driven to load along with the On/Off period just to cool the MosFets.
    That PWM signal will drive the one of the upper transistors of the bridge while the NCO low frequency of 0-50Hz will drive one of the lower transistor of the same bridge.
    In other words, say I want to drive with unipolar signal the load:
    1. Upper right MosFet is modulated with PWM 1KHz 30% DC signal
    2. Lower left Mosfet is modulated with NCO of say 10Hz
    If I want to drive bipolar signal to the load:
    2. Lower left Mosfet is ON for x msec.
    3. Lower left MosFet is OFF
    4. Upper right MosFet is OFF
    5. Upper left Mosfet is modulated with PWM 1KHz 30% DC signal
    6. Lower right MosFet is ON for x msec
    7. Lower right MosFet is OFF
    8. Upper left MosFet is OFF
    9. Loop from step 1
    Alternatively, as the simulator shows:
    1. Upper right MosFet and lower left MosFet is modulated with PWM 1KHz 30% DC signal for 1/2 of NCO signal
    2. Upper left Mosfet and lower right MosFet is modulated with PWM 1KHz 30% DC signal for 1/2 of NCO signal
    3. Loop from step 1
    Simple, right? Well no. Cannot figure how this can be done...
    On the Simulator file this is shown on two cycles of the 1Hz signal modulating the PWM of 1KHz signal.
    I do understand that there is great danger of shoot through current and have to be very carefull.
    P.S. Maybe add a 5th MosFet on the lower side of the H-Bridge and modulate that one with the PWM signal? Then how will the pairs in the bridge change according to the NCO signal?
    I'm probably missing something...
    Why not simply turn on the lower MOSFET in question, apply your 1kHz PWM signal to the (correct) upper MOSFET and then modulate it using your 0-50Hz signal. In other words, turn the 1kHz carrier on/off at whatever rate you want.
    If that's possible or not at the hardware level, ie "route" the NCO output to the enable bit of the PWM carrier is beyond my knowledge at the moment but at such low frequency (0-50Hz) a software (perhaps interrupt driven) aproach sounds more than reasoanble.
    or use the clc module to steer the low freq osc,
    should be shoot through proof if 1khz osc had adequate dead time
    Henrik, I like your idea if can be handled by hardware as I am afraid of software that may hang. Also it gets complicated when you want to control the output as bipolar and have to switch all transistors both at PWM and low freq. signal.
    Do not know if or how NCO can be steered PWM/CWG module.
    Richard, also nice idea about CLC module. I suppose the low freq signal is external of the PIC. Or may be the NCO signal too.
    Ah, I didn't quite get you wanted locked antiphase PWM, ie the polarity of bridge is "reversed" every PWM cycle.
    I thought you wanted to run it "forward" for x ms and then "in reverse" for x ms while also modulating the 1kHz PWM frequency with 0-50Hz.
    I guess I still don't quite understand what you want...
    Henrik, for a while forget the PWM.
    Just think of an H-Bridge that drives a load in two modes:
    1. Unipolar voltage on the load with a rate of 0-50 Hz
    2. Bipolar voltage on the load with a rate of 0-50 Hz
    The mode 2 obviously doubles the power consumed by the load.
    Because of the low frequency, I ended to the NCO as Richard proposed. But have not found a way to drive this to an H-Bridge yet.
    The second problem is that at very low frequencies (0 to say 20 Hz) the power loss on the bridge transistors is high enough to destroy them because of violation of the SOA. I have to either put in parallel more devices or use a PWM signal to lower the losses and give time to the transistors to cool.
    So, the NCO signal needs to be modulated with PWM.
    Easy and complicated at the same time...
    Sorry, mode 2 still isn't clear to me.... "2. Bipolar voltage on the load with a rate of 0-50 Hz"
    Do you mean...
    A) That polarity of the voltage across to the load is switched at 0-50Hz (and power is regulated by the dutycycle of the 1kHz PWM signal) or
    B) That polarity of the voltage across to the load is switched at 1kHz (the PWM frequency) and the 1kHz carrier is turned on/off at a rate of 0-50Hz or
    C) None of the above meaning I still don't get it :-)
  1. Enhanced PWM Full-Bridge Mode
    By Zapman in forum mel PIC BASIC Pro
    Last Post: - 14th September 2022, 20:08
  2. Replies: 4
    Last Post: - 7th June 2011, 06:02
  3. Need guidance with DC motor controller - PWM & H-Bridge
    By rfetech in forum mel PIC BASIC Pro
    Last Post: - 12th November 2010, 04:33
  4. PWM with PIC16F88 controlling h-bridge
    By deimantas in forum mel PIC BASIC Pro
    Last Post: - 20th May 2010, 23:03
  5. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
Members who have read this thread : 12
