Losing data when extracting bytes from words - 16F18855
Results 1 to 26 of 26
Threaded View
  1. #14
    Default Re: Losing data when extracting bytes from words - 16F18855
    Very convenient indeed!
    Yup, now confirmed. It's faster to use aliases than Richard's module strcpy.
    Shared TX pgm:
    - loads array with 80 characters (DEC 43 to DEC 122),
    - Hserout 80 bytes
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_OFF & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    DEFINE OSC 32
    DEFINE  HSER_RXREG PORTC
    DEFINE  HSER_RXBIT 7
    DEFINE  HSER_TXREG PORTC
    DEFINE  HSER_TXBIT 6
    DEFINE  HSER_RCSTA 90h              ' Enable serial port & continuous receive
    DEFINE  HSER_TXSTA 24h              ' Enable transmit, BRGH = 1
    Define  HSER_BAUD 115200
    DEFINE  HSER_CLROERR 1              ' Clear overflow automatically
    DEFINE  HSER_SPBRGH  0
    DEFINE  HSER_SPBRG  68
    define  CCP1_REG     0              ' Must clear unused CCP pins or else unpredictable results
    DEFINE  CCP1_BIT     0
    define  CCP2_REG     0
    DEFINE  CCP2_BIT     0
    define  CCP3_REG     0
    DEFINE  CCP3_BIT     0
    define  CCP4_REG     0
    DEFINE  CCP4_BIT     0
    define  CCP5_REG     0
    DEFINE  CCP5_BIT     0
    ;--- Setup registers -----------------------------------------------------------
    BAUDCON.3 = 1                       ' Enable 16 bit baudrate generator
    WPUA = %00100000                        ' Pin A7 = Error code 2
                                            ' Pin A6 = Error code 1
                                            ' Pin A4 = ADC-A4 (B10K)
                                            ' Pin A3 = SW             external pull-down
                                            ' Pin A2 = Vref-
                                            ' Pin A1 = ADC-A1 (B5K w/SW)
                                            ' Pin A0 = ADC-A0 (B5K)
    WPUB = %00111111                        ' Pin B7 = ...not available, ICSPDAT
                                            ' Pin B6 = ...not available, ICSPCLK
    WPUC = %00100111                        ' Pin C7 = RX
                                            ' Pin C6 = TX
                                            ' Pin C4 = ADC-C4 (B10K)
                                            ' Pin C3 = ADC-C3 (B10K)
    ANSELA = %00000000                      ' Pin A7 = Error code 2
    ANSELB = %00000000
    ANSELC = %00000000                      ' Pin C7 = RX
                                            ' Pin C6 = TX
    TRISA = %00011011                       ' Pin A7 = Error code 2
                                            ' Pin A3 = SW
    TRISB = %00000000                       ' Pin B7 = ...not available, ICSPDAT
    TRISC = %11011000                       ' Pin C7 = RX      *** Datasheet requirement, INPUT ***
                                            ' Pin C6 = TX      *** Datasheet requirement, INPUT ***
    Marker1     var LatA.6                  ' Pin A7 = Marker 1
    Marker2     var LatA.7                  ' Pin A6 = Marker 2
    MsgData     var byte[80]
    MsgLoop     var byte
    MsgLength   var byte
      Marker1 = 0
      Marker2 = 0
        MsgLength = 80
        Pause 500                                       ' Let PIC and LCD stabilize
      Marker1 = 1
        for MsgLoop = 0 to MsgLength - 1
            MsgData [MsgLoop] = MsgLoop + 43
        next MsgLoop
      LatA = %10000000
        hserout [   str MsgData\MsgLength   ]           ' Transmit data
        while TX1STA.1 = 0                              ' Check TRMT bit
        wend
      LatA = %00000000
    EndlessLoop:
        goto EndlessLoop
    RX pgm using aliases:
    - Hserin 80 bytes
    - displays array on LCD
    ;--- Interrupts ----------------------------------------------------------------
    include "I:\Project_v2\PBP\PBP_Includes\DT_INTS-14_16F1885x-7x.bas"
    include "I:\Project_v2\PBP\PBP_Includes\ReEnterPBP.bas"
            INT_Handler    RX_INT,      _RXinterrupt,   PBP,  no
    DEFINE OSC 32
    DEFINE  LCD_DREG      PORTB         ' Set LCD data port
    DEFINE  LCD_DBIT      0             ' Set starting data bit
    DEFINE  LCD_RSREG     PORTC         ' Set LCD register select port
    DEFINE  LCD_RSBIT     4             ' Set LCD register select bit
    DEFINE  LCD_EREG      PORTC         ' Set LCD enable port
    DEFINE  LCD_EBIT      5             ' Set LCD enable bit
    DEFINE  LCD_BITS      4             ' Set LCD bus size
    DEFINE  LCD_LINES     4             ' Set number of lines on LCD
    DEFINE  LCD_COMMANDUS 1000          ' Set command delay time in microseconds
    DEFINE  LCD_DATAUS    50            ' Set data delay time in microseconds
    DEFINE  CCP1_BIT     0
    define  CCP2_REG     0
    DEFINE  CCP2_BIT     0
    define  CCP3_REG     PORTB          ' PWM Pulse out to LCD backlight
    DEFINE  CCP3_BIT     5
    define  CCP4_REG     0              ' Must clear unused CCP pins or else unpredictable results
    DEFINE  CCP4_BIT     0
    define  CCP5_REG     PORTA          ' PWM Pulse out to LED strips
    DEFINE  CCP5_BIT     4
    DEFINE  HSER_RXBIT 7
    DEFINE  HSER_TXBIT 6
    INTCON = %11000000                  ' INTERRUPT CONTROL REGISTER
    '   bit 7   GIE: Global Interrupt Enable bit
    '               1 = Enables all active interrupts
    '               0 = Disables all interrupts
    '   bit 6   PEIE: Peripheral Interrupt Enable bit
    '               1 = Enables all active peripheral interrupts
    '               0 = Disables all peripheral interrupts
    PIE3 = %00100000                    ' PERIPHERAL INTERRUPT ENABLE REGISTER 3
    '   bit 5   RCIE: USART Receive Interrupt Enable bit
    '               1 = Enables the USART receive interrupt
    '               0 = Enables the USART receive interrupt
    CCP3CON = %10001111                 ' CCP3 CONTROL REGISTER
    '   bit 7   EN: CCPx Module Enable bit
    '               1 = CCPx is enabled
    '   bit 4   FMT: CCPW (Pulse Width) Alignment bit
    '       MODE = PWM mode
    '               0 = Right-aligned format
    '   bit 3-0 MODE<3:0>: CCPx Mode Select bits(1)
    '               1111 = PWM mode
    CCP5CON = %10001111                 ' CCP5 CONTROL REGISTER
    '       MODE = PWM mode
    '               1111 = PWM mode
    ADCON0 = %00000000                      ' Value CONTROL REGISTER 0
    WPUA = %00001111                        ' Pin A7 = LCDout 2
                                            ' Pin A6 = LCDout 1
                                            ' Pin A5 = RX Int
                                            ' Pin A4 = PWM to LED strips
    WPUB = %11011111                        ' Pin B7 = ...not available, ICSPDAT
                                            ' Pin B5 = PWM to LCD backlight
    WPUC = %00111111                        ' Pin C7 = RX      *** Datasheet requirement, INPUT ***
    ANSELA = %00000000                      ' Pin A6 = LCDout 1
                                            ' Pin A5 = RX Int
    ANSELB = %00000000                      ' Pin B7 = ...not available, ICSPDAT
    ANSELC = %00000000                      ' Pin C7 = RX      *** Datasheet requirement, INPUT ***
    TRISA = %00000000                       ' Pin A7 = LCDout 2
                                            ' Pin A6 = LCDout 1
                                            ' Pin A5 = RX Int
    TRISC = %11000000                       ' Pin C7 = RX      *** Datasheet requirement, INPUT ***
    Marker2           var LATA.7
    Marker1               var LATA.5
    Value0        VAR MsgData[0]              ' LCD row 1
    Value1        VAR MsgData[1]
    Value2        VAR MsgData[2]
    Value3        VAR MsgData[3]
    Value4        VAR MsgData[4]
    Value5        VAR MsgData[5]
    Value6        VAR MsgData[6]
    Value7        VAR MsgData[7]
    Value8        VAR MsgData[8]
    Value9        VAR MsgData[9]
    Value10       VAR MsgData[10]
    Value11       VAR MsgData[11]
    Value12       VAR MsgData[12]
    Value13       VAR MsgData[13]
    Value14       VAR MsgData[14]
    Value15       VAR MsgData[15]
    Value16       VAR MsgData[16]
    Value17       VAR MsgData[17]
    Value18       VAR MsgData[18]
    Value19       VAR MsgData[19]
    Value20       VAR MsgData[20]             ' LCD row 2
    Value21       VAR MsgData[21]
    Value22       VAR MsgData[22]
    Value23       VAR MsgData[23]
    Value24       VAR MsgData[24]
    Value25       VAR MsgData[25]
    Value26       VAR MsgData[26]
    Value27       VAR MsgData[27]
    Value28       VAR MsgData[28]
    Value29       VAR MsgData[29]
    Value30       VAR MsgData[30]
    Value31       VAR MsgData[31]
    Value32       VAR MsgData[32]
    Value33       VAR MsgData[33]
    Value34       VAR MsgData[34]
    Value35       VAR MsgData[35]
    Value36       VAR MsgData[36]
    Value37       VAR MsgData[37]
    Value38       VAR MsgData[38]
    Value39       VAR MsgData[39]
    Value40       VAR MsgData[40]             ' LCD row 3
    Value41       VAR MsgData[41]
    Value42       VAR MsgData[42]
    Value43       VAR MsgData[43]
    Value44       VAR MsgData[44]
    Value45       VAR MsgData[45]
    Value46       VAR MsgData[46]
    Value47       VAR MsgData[47]
    Value48       VAR MsgData[48]
    Value49       VAR MsgData[49]
    Value50       VAR MsgData[50]
    Value51       VAR MsgData[51]
    Value52       VAR MsgData[52]
    Value53       VAR MsgData[53]
    Value54       VAR MsgData[54]
    Value55       VAR MsgData[55]
    Value56       VAR MsgData[56]
    Value57       VAR MsgData[57]
    Value58       VAR MsgData[58]
    Value59       VAR MsgData[59]
    Value60       VAR MsgData[60]             ' LCD row 4
    Value61       VAR MsgData[61]
    Value62       VAR MsgData[62]
    Value63       VAR MsgData[63]
    Value64       VAR MsgData[64]
    Value65       VAR MsgData[65]
    Value66       VAR MsgData[66]
    Value67       VAR MsgData[67]
    Value68       VAR MsgData[68]
    Value69       VAR MsgData[69]
    Value70       VAR MsgData[70]
    Value71       VAR MsgData[71]
    Value72       VAR MsgData[72]
    Value73       VAR MsgData[73]
    Value74       VAR MsgData[74]
    Value75       VAR MsgData[75]
    Value76       VAR MsgData[76]
    Value77       VAR MsgData[77]
    Value78       VAR MsgData[78]
    Value79       VAR MsgData[79]
    MsgLength           var byte
    HPWMlcdBL           var BYTE
    HPWMledstrip        var BYTE
    RXoccurred          var BYTE
        MsgLength = 80
      Marker1 = 0
      Marker2 = 1
        HPWMlcdBL = 150                                 ' low intensity
        HPWMledstrip = 15                               ' low intensity
        HPWM 3, HPWMlcdBL, 1953
        HPWM 5, HPWMledstrip, 1953
      Marker2 = 0
        RXoccurred = 0                                  ' Clear RX flag
        goto Start                                      ' Jump over sub-routines
    RXinterrupt:
      Marker1 = 1
        hserin [ STR MsgData\MsgLength]
        while BAUDCON1.6 = 0                            ' Check RCIDL bit
        wend
        RXoccurred = 1                                  ' Set flag
      Marker1 = 0
    @ INT_RETURN
    ;--- Subroutines ---------------------------------------------------------------
    Start:
    @   INT_ENABLE   RX_INT             ; Enable USART Receive interrupts
        while RXoccurred = 0                            ' Wait for message
        wend
      Marker2 = 1
        LCDOUT $FE, 1
        LCDOUT $FE, $80,    Value0,  Value1,  Value2,  Value3,  Value4,  _
                            Value5,  Value6,  Value7,  Value8,  Value9,  _
                            Value10, Value11, Value12, Value13, Value14, _
                            Value15, Value16, Value17, Value18, Value19
        LCDOUT $FE, $C0,    Value20, Value21, Value22, Value23, Value24, _
                            Value25, Value26, Value27, Value28, Value29, _
                            Value30, Value31, Value32, Value33, Value34, _
                            Value35, Value36, Value37, Value38, Value39
        LCDOUT $FE, $94,    Value40, Value41, Value42, Value43, Value44, _
                            Value45, Value46, Value47, Value48, Value49, _
                            Value50, Value51, Value52, Value53, Value54, _
                            Value55, Value56, Value57, Value58, Value59
        LCDOUT $FE, $D4,    Value60, Value61, Value62, Value63, Value64, _
                            Value65, Value66, Value67, Value68, Value69, _
                            Value70, Value71, Value72, Value73, Value74, _
                            Value75, Value76, Value77, Value78, Value79
      Marker2 = 0
    EndlessLoop:
        goto EndlessLoop
    RX pgm using strcpy:
    - Hserin 80 bytes
    - strcpy array
    include    "I:\Project_v2\PBP\PBP_Includes\USARTarray.bas"
    DEFINE OSC 32
    DEFINE  CCP1_BIT     0
    define  CCP2_REG     0
    DEFINE  CCP2_BIT     0
    DEFINE  CCP3_BIT     5
    DEFINE  CCP4_BIT     0
    DEFINE  CCP5_BIT     4
    DEFINE  HSER_RXBIT 7
    DEFINE  HSER_TXBIT 6
    '       MODE = PWM mode
    '               1111 = PWM mode
    '       MODE = PWM mode
    '               1111 = PWM mode
                                            ' Pin A6 = LCDout 1
                                            ' Pin A5 = RX Int
                                            ' Pin A5 = RX Int
                                            ' Pin A6 = LCDout 1
                                            ' Pin A5 = RX Int
    Marker2           var LATA.7
    Marker1               var LATA.5
    asm
    Value0     = _MsgData
    Value1     = _MsgData + 1
    Value2     = _MsgData + 2
    Value3     = _MsgData + 3
    Value4     = _MsgData + 4
    Value5     = _MsgData + 5
    Value6     = _MsgData + 6
    Value7     = _MsgData + 7
    Value8     = _MsgData + 8
    Value9     = _MsgData + 9
    Value10    = _MsgData + 10
    Value11    = _MsgData + 11
    Value12    = _MsgData + 12
    Value13    = _MsgData + 13
    Value14    = _MsgData + 14
    Value15    = _MsgData + 15
    Value16    = _MsgData + 16
    Value17    = _MsgData + 17
    Value18    = _MsgData + 18
    Value19    = _MsgData + 19
    Value20    = _MsgData + 20
    Value21    = _MsgData + 21
    Value22    = _MsgData + 22
    Value23    = _MsgData + 23
    Value24    = _MsgData + 24
    Value25    = _MsgData + 25
    Value26    = _MsgData + 26
    Value27    = _MsgData + 27
    Value28    = _MsgData + 28
    Value29    = _MsgData + 29
    Value30    = _MsgData + 30
    Value31    = _MsgData + 31
    Value32    = _MsgData + 32
    Value33    = _MsgData + 33
    Value34    = _MsgData + 34
    Value35    = _MsgData + 35
    Value36    = _MsgData + 36
    Value37    = _MsgData + 37
    Value38    = _MsgData + 38
    Value39    = _MsgData + 39
    Value40    = _MsgData + 40
    Value41    = _MsgData + 41
    Value42    = _MsgData + 42
    Value43    = _MsgData + 43
    Value44    = _MsgData + 44
    Value45    = _MsgData + 45
    Value46    = _MsgData + 46
    Value47    = _MsgData + 47
    Value48    = _MsgData + 48
    Value49    = _MsgData + 49
    Value50    = _MsgData + 50
    Value51    = _MsgData + 51
    Value52    = _MsgData + 52
    Value53    = _MsgData + 53
    Value54    = _MsgData + 54
    Value55    = _MsgData + 55
    Value56    = _MsgData + 56
    Value57    = _MsgData + 57
    Value58    = _MsgData + 58
    Value59    = _MsgData + 59
    Value60    = _MsgData + 60
    Value61    = _MsgData + 61
    Value62    = _MsgData + 62
    Value63    = _MsgData + 63
    Value64    = _MsgData + 64
    Value65    = _MsgData + 65
    Value66    = _MsgData + 66
    Value67    = _MsgData + 67
    Value68    = _MsgData + 68
    Value69    = _MsgData + 69
    Value70    = _MsgData + 70
    Value71    = _MsgData + 71
    Value72    = _MsgData + 72
    Value73    = _MsgData + 73
    Value74    = _MsgData + 74
    Value75    = _MsgData + 75
    Value76    = _MsgData + 76
    Value77    = _MsgData + 77
    Value78    = _MsgData + 78
    Value79    = _MsgData + 79
    endasm
    Value0     VAR BYTE ext                  ' LCD row 1
    Value1     VAR BYTE ext
    Value2     VAR BYTE ext
    Value3     VAR BYTE ext
    Value4     VAR BYTE ext
    Value5     VAR BYTE ext
    Value6     VAR BYTE ext
    Value7     VAR BYTE ext
    Value8     VAR BYTE ext
    Value9     VAR BYTE ext
    Value10    VAR BYTE ext
    Value11    VAR BYTE ext
    Value12    VAR BYTE ext
    Value13    VAR BYTE ext
    Value14    VAR BYTE ext
    Value15    VAR BYTE ext
    Value16    VAR BYTE ext
    Value17    VAR BYTE ext
    Value18    VAR BYTE ext
    Value19    VAR BYTE ext
    Value20    VAR BYTE ext                  ' LCD row 2
    Value21    VAR BYTE ext
    Value22    VAR BYTE ext
    Value23    VAR BYTE ext
    Value24    VAR BYTE ext
    Value25    VAR BYTE ext
    Value26    VAR BYTE ext
    Value27    VAR BYTE ext
    Value28    VAR BYTE ext
    Value29    VAR BYTE ext
    Value30    VAR BYTE ext
    Value31    VAR BYTE ext
    Value32    VAR BYTE ext
    Value33    VAR BYTE ext
    Value34    VAR BYTE ext
    Value35    VAR BYTE ext
    Value36    VAR BYTE ext
    Value37    VAR BYTE ext
    Value38    VAR BYTE ext
    Value39    VAR BYTE ext
    Value40    VAR BYTE ext                  ' LCD row 3
    Value41    VAR BYTE ext
    Value42    VAR BYTE ext
    Value43    VAR BYTE ext
    Value44    VAR BYTE ext
    Value45    VAR BYTE ext
    Value46    VAR BYTE ext
    Value47    VAR BYTE ext
    Value48    VAR BYTE ext
    Value49    VAR BYTE ext
    Value50    VAR BYTE ext
    Value51    VAR BYTE ext
    Value52    VAR BYTE ext
    Value53    VAR BYTE ext
    Value54    VAR BYTE ext
    Value55    VAR BYTE ext
    Value56    VAR BYTE ext
    Value57    VAR BYTE ext
    Value58    VAR BYTE ext
    Value59    VAR BYTE ext
    Value60    VAR BYTE ext                  ' LCD row 4
    Value61    VAR BYTE ext
    Value62    VAR BYTE ext
    Value63    VAR BYTE ext
    Value64    VAR BYTE ext
    Value65    VAR BYTE ext
    Value66    VAR BYTE ext
    Value67    VAR BYTE ext
    Value68    VAR BYTE ext
    Value69    VAR BYTE ext
    Value70    VAR BYTE ext
    Value71    VAR BYTE ext
    Value72    VAR BYTE ext
    Value73    VAR BYTE ext
    Value74    VAR BYTE ext
    Value75    VAR BYTE ext
    Value76    VAR BYTE ext
    Value77    VAR BYTE ext
    Value78    VAR BYTE ext
    Value79    VAR BYTE ext
    Incoming            var byte[80]
    MsgLength           var byte
    HPWMlcdBL           var BYTE
    RXoccurred          var BYTE
        MsgLength = 80
      Marker1 = 0
      Marker2 = 1
      Marker2 = 0
    RXinterrupt:
      Marker1 = 1
        hserin [ STR Incoming\MsgLength]
        wend
      Marker1 = 0
    @ INT_RETURN
    Start:
        wend
      Marker2 = 1
        strcpy  MsgData , Incoming , 80
        pause 50
      Marker2 = 0
      Marker1 = 1
        LCDOUT $FE, 1
      Marker1 = 0
    EndlessLoop:
        goto EndlessLoop
    Both RX programs used same base code, only changed array and added strcpy.
    Saleae probe timings from before Load Array in TX to after Lcdout in RX
    TX/RX using aliases, 35.4 mSec:
    Name:  Load alias v4.png
    TX/RX using strcpy, now 85.2 mSec, adds 50.0 mSec step during strcpy:
    Name:  Load strcpy v4.png
    LCD displayed properly "+" to "z":
  1. Decoding serial data bytes and nibbles.
    Last Post: - 18th January 2018, 09:22
  2. Bits, Bytes Words and Arrays
    Last Post: - 14th June 2016, 08:55
  3. ORing / ANDing bytes or words
    By mmargolis in forum mel PIC BASIC Pro
    Last Post: - 19th March 2011, 21:12
  4. Success! Are they 'words' or are they 'bytes'?
    By BitHead in forum mel PIC BASIC Pro
    Last Post: - 27th December 2009, 17:54
  5. Codespace Saving Tip... Don't mix Words and Bytes
    Last Post: - 18th June 2004, 11:23
Members who have read this thread : 5
