more robust demand/response handshaking
;pic18f26k22
  CONFIG  FOSC = INTIO67     ; Internal oscillator block
  CONFIG  PLLCFG = OFF        ; Oscillator used directly
  CONFIG  PRICLKEN = OFF     ; Primary clock can be disabled by software
  CONFIG  FCMEN = OFF        ; Fail-Safe Clock Monitor disabled
  CONFIG  IESO = OFF         ; Oscillator Switchover mode disabled
  CONFIG  PWRTEN = OFF       ; Power up timer disabled
  CONFIG  BOREN = SBORDIS    ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
  CONFIG  BORV = 190         ; VBOR set to 1.90 V nominal
  CONFIG  WDTEN = ON         ; WDT is always enabled. SWDTEN bit has no effect
  CONFIG  WDTPS = 32768      ; 1:32768
  CONFIG  CCP2MX = PORTC1    ; CCP2 input/output is multiplexed with RC1
  CONFIG  PBADEN = OFF       ; PORTB<5:0> pins are configured as digital I/O on Reset
  CONFIG  CCP3MX = PORTB5    ; P3A/CCP3 input/output is multiplexed with RB5
  CONFIG  HFOFST = ON        ; HFINTOSC output and ready status are not delayed by the oscillator stable status
  CONFIG  T3CMX = PORTC0     ; T3CKI is on RC0
  CONFIG  P2BMX = PORTB5     ; P2B is on RB5
  CONFIG  MCLRE = INTMCLR    ; MCLR pin enabled, RE3 input pin disabled
  CONFIG  STVREN = ON        ; Stack full/underflow will cause Reset
  CONFIG  LVP = OFF          ; Single-Supply ICSP disabled
  CONFIG  XINST = OFF        ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
  CONFIG  DEBUG = OFF        ; Disabled
  CONFIG  CP0 = OFF          ; Block 0 (000800-001FFFh) not code-protected
  CONFIG  CP1 = OFF          ; Block 1 (002000-003FFFh) not code-protected
  CONFIG  CP2 = OFF          ; Block 2 (004000-005FFFh) not code-protected
  CONFIG  CP3 = OFF          ; Block 3 (006000-007FFFh) not code-protected
  CONFIG  CPB = OFF          ; Boot block (000000-0007FFh) not code-protected
  CONFIG  CPD = OFF          ; Data EEPROM not code-protected
  CONFIG  WRT0 = OFF         ; Block 0 (000800-001FFFh) not write-protected
  CONFIG  WRT1 = OFF         ; Block 1 (002000-003FFFh) not write-protected
  CONFIG  WRT2 = OFF         ; Block 2 (004000-005FFFh) not write-protected
  CONFIG  WRT3 = OFF         ; Block 3 (006000-007FFFh) not write-protected
  CONFIG  WRTC = OFF         ; Configuration registers (300000-3000FFh) not write-protected
  CONFIG  WRTB = OFF         ; Boot Block (000000-0007FFh) not write-protected
  CONFIG  WRTD = OFF         ; Data EEPROM not write-protected
  CONFIG  EBTR0 = OFF        ; Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
  CONFIG  EBTR1 = OFF        ; Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
  CONFIG  EBTR2 = OFF        ; Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
  CONFIG  EBTR3 = OFF        ; Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
  CONFIG  EBTRB = OFF        ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
define OSC 64
    ANSELC = 0
    OSCCON = $70
    OSCTUNE.6 = 1
    RCSTA = $90   ' Enable serial port & continuous receive
    TXSTA = $24   ' Enable transmit, BRGH = 1
    SPBRG = 21    ' 57600 Baud @ 64MHz, -0.08%
    SPBRGH = 1
    BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
asm
ADCcode = _MsgData
Num0    = _MsgData + 1
Num1    = _MsgData + 3
Num2    = _MsgData + 5
Num3    = _MsgData + 7
Num4    = _MsgData + 9
Num5    = _MsgData + 11
Num6    = _MsgData + 13
Num7    = _MsgData + 15
Num8    = _MsgData + 17
Num9    = _MsgData + 19
endasm
    MsgOK               var byte[2]
    MsgLoop             VAR WORD
    MsgData             var byte[21]
    ADCcode             var BYTE ext
    Num0                VAR WORD ext
    Num1                VAR WORD ext
    Num2                VAR WORD ext
    Num3                VAR WORD ext
    Num4                VAR WORD ext
    Num5                VAR WORD ext
    Num6                VAR WORD ext
    Num7                VAR WORD ext
    Num8                VAR WORD ext
    Num9                VAR WORD ext
Mainloop:
    ADCcode = 2
    for MsgLoop = 0 to 390 step 10                         ' loop by multiples of 10
        tol:
        hserin 50,tol,[ wait("<OK>") ]
        gosub TransmitData
    next MsgLoop
goto mainloop
TransmitData:
    Num0 = MsgLoop
    Num1 = MsgLoop + 1
    Num2 = MsgLoop + 2
    Num3 = MsgLoop + 3
    Num4 = MsgLoop + 4
    Num5 = MsgLoop + 5
    Num6 = MsgLoop + 6
    Num7 = MsgLoop + 7
    Num8 = MsgLoop + 8
    Num9 = MsgLoop + 9
    hserout [   "[",21,str MsgData\21]
rx
;pic18f26k22
  CONFIG  PLLCFG = ON        ; Oscillator used directly
define OSC 64
ANSELC = 0
include    "strtok.pbpmod"
    OSCCON = $70
    OSCTUNE.6 = 1
SPBRGH = 1
asm
ADCcode = _MsgData
Num0    = _MsgData + 1
Num1    = _MsgData + 3
Num2    = _MsgData + 5
Num3    = _MsgData + 7
Num4    = _MsgData + 9
endasm
    incoming            var byte[21]
    Num0                VAR WORD ext
    Num1                VAR WORD ext
    Num2                VAR WORD ext
    Num3                VAR WORD ext
    Num4                VAR WORD ext
    Num5                VAR WORD ext
    Num6                VAR WORD ext
    Num7                VAR WORD ext
    Num8                VAR WORD ext
    Num9                VAR WORD ext
    Pause 1000                           ' Let PIC stabilize and start after RX PIC
Mainloop:
    hserout [   "<OK>"]
    hserin 50,mainloop,[ wait("[",21), STR incoming \21]
    if incoming[0]   = 2 then
        strcpy  MsgData , incoming ,21
        hserout [   "[", dec4 Num0, _
                    " ", dec4 Num1, " ", dec4 Num2, " ", dec4 Num3, _
                    " ", dec4 Num4, " ", dec4 Num5, " ", dec4 Num6, _
                    " ", dec4 Num7, " ", dec4 Num8, " ", dec4 Num9, "]",13,10]
        hserout [   10]                 ' this is just to maintain alignment on Serial Communicator
  GOTO Mainloop
