codelock with touch screen Pixxi25P4CT and PIC18F26K22
Results 1 to 4 of 4
    Oct 2010
    Default codelock with touch screen Pixxi25P4CT and PIC18F26K22
    Dear all its being long time since my last post. I had so many things lately. Just realised that i had a small project that i havent completed.
    Not this is almost done and working up to now.
    Take your time to check it out if you have a PixxiLCD25P4CT together with a PIC18F26K22.
    '*  Name    : CODELOCK.BAS                                         *
    '*  Author  : [LB]                                                 *
    '*  Notice  : Copyright (c) 2024 [14 April 2024]                   *
    '*          : All Rights Reserved                                  *
    '*  Date    : 14-Apr-24                                            *
    '*  Version : 1.0                                                  *
    '*  Notes   : This is a codelock based on the following components *
    '*          : PIC18F26K22 @ 64Mhz                                  *
    '*          : 4D Systems Pixxi LCD 25P4                            *
    ' ======= Key Mapping (last 4 bytes of response codes) =======
    'NUM_KEYS CON 12
    ' Hex Codes & Corresponding Key Values
    'keyCodes DATA $313A, 1  ' Number 1 "07 0D 01 00 31 3A"
    'keyCodes DATA $3239, 2  ' Number 2 "07 0D 01 00 32 39"
    'keyCodes DATA $3338, 3  ' Number 3 "07 0D 01 00 33 38"
    'keyCodes DATA $343F, 4  ' Number 4 "07 0D 01 00 34 3F"
    'keyCodes DATA $353E, 5  ' Number 5 "07 0D 01 00 35 3E"
    'keyCodes DATA $363D, 6  ' Number 6 "07 0D 01 00 36 3D"
    'keyCodes DATA $373C, 7  ' Number 7 "07 0D 01 00 37 3C"
    'keyCodes DATA $3833, 8  ' Number 8 "07 0D 01 00 38 33"
    'keyCodes DATA $3932, 9  ' Number 9 "07 0D 01 00 39 32"
    'keyCodes DATA $2A21, 10 ' Number * "07 0D 01 00 2A 21"  (unused)
    'keyCodes DATA $303B, 0  ' Number 0 "07 0D 01 00 30 3B"
    'keyCodes DATA $0803, 11 ' Go     # "07 0D 01 00 08 03"
    #IF __PROCESSOR__ = "18F26k22"
    @ ERRORLEVEL -306 ; this command prevents the compiler to give you a notice of   *
                      ; crossing page boundary - make sure bits are set              *
      #CONFIG       ; The PBP configuration for the PIC18F26K22 is:                  *
      CONFIG  FOSC=INTIO67, PLLCFG=ON, PRICLKEN=OFF, FCMEN=OFF, IESO=OFF
      CONFIG  PWRTEN=OFF, BOREN=SBORDIS, BORV=190, WDTEN=ON, WDTPS=32768
      CONFIG  CCP2MX=PORTC1, PBADEN=OFF, CCP3MX=PORTB5, HFOFST=ON, T3CMX=PORTC0
      CONFIG  P2BMX=PORTB5, MCLRE=EXTMCLR, STVREN=ON, LVP=OFF, XINST=OFF, DEBUG=OFF
      CONFIG  CP0=OFF, CP1=OFF, CP2=OFF, CP3=OFF, CPB=OFF, CPD=OFF, WRT0=OFF
      CONFIG  WRT1=OFF, WRT2=OFF, WRT3=OFF, WRTC=OFF, WRTB=OFF, WRTD=OFF, EBTR0=OFF
      CONFIG  EBTR1=OFF, EBTR2=OFF, EBTR3=OFF, EBTRB=OFF
      #ELSE
        #MSG "Wrong Processor selected!"
      #ENDIF
    define  OSC 64
            INCLUDE "modedefs.bas"
            INCLUDE "ALLDIGITAL.pbp"
    OSCCON    = %01110000   ; 16Mhz
    OSCTUNE.6 = 1     ; Enable 4x PLL
    '*----------------------- | EUART 2 Configuration  | --------------------------|
    ' for debuging PLL if it is ready or not
    ' EUART 1 is configured later in the code
            DEFINE HSER2_RCSTA 90h ' Enable serial port & continuous receive
            DEFINE HSER2_TXSTA 24h ' Enable transmit, BRGH = 1
            DEFINE HSER2_CLROERR 1 ' Clear overflow automatically
            DEFINE HSER2_SPBRG 160 ' 38400 Baud @ 64MHz, -0.08%
            SPBRGH2 = 1
            BAUDCON2.3 = 1         ' Enable 16 bit baudrate generator
    ' Debug loop to check PLLRDY status
    WHILE !OSCCON2.7           ' Wait until PLL is stable
        HSEROUT2 ["PLL not ready...", 13, 10]  ' Send message to terminal
        PAUSE 500              ' Wait 500ms before checking again
    WEND
        HSEROUT2 ["PLL is ready!", 13, 10]  ' Confirm PLL is stable
    '                            INITIALIZE RAM                                    |
    initialize:
    	CLEAR
    TRISA = %00000000   'use TRISA to specify which pin is (1 = input) and which (0 = output)  (ALL pins are output)
    TRISB = %10000000   'use TRISB to specify which pin is (1 = input) and which (0 = output)  (RB7 PORTB.7 is the RX input pin of the EUART, the rest are output)
    TRISC = %10000000   'use TRISC to specify which pin is (1 = input) and which (0 = output)  (RC7 PORTC.7 is the RX input pin of the EUART, the rest are output)
                        'in PORTC the RC3 attached is an LED.
    '--------------------------- TRIS A B C ---------------------------------|
    ' PORTA.7  PORTA.6  PORTA.5  PORTA.4  PORTA.3  PORTA.2  PORTA.1  PORTA.0 |
    '  bit7     bit6     bit5     bit4     bit3     bit2     bit1     bit0   |
    '   1        0        0        0        0        0        0        0     |
    ' PORTB.7  PORTB.6  PORTB.5  PORTB.4  PORTB.3  PORTB.2  PORTB.1  PORTB.0 |
    '   0        0        0        0        0        0        0        0     |
    ' PORTC.7  PORTC.6  PORTC.5  PORTC.4  PORTC.3  PORTC.2  PORTC.1  PORTC.0 |
    '   1        0        0        0        0        0        0        0     |
    '----------------------- At start all PORTS LOW -------------------------|
    PORTA = 0            'make low all ports at A range                      |
    PORTB = 0            'make low all ports at B range                      |
    PORTC = 0            'make low all ports at C range                      |
    '-------------------------- COMPARATORS OFF -----------------------------|
    CM1CON0.7 = 0 'Disable comparator1                                       |
    CM2CON0.7 = 0 'Disable comparator2                                       |
    '*----------------------- | EUART 1 Configuration  | --------------------------|
            DEFINE HSER_SPBRG 160 ' 38400 Baud @ 64MHz, -0.08%
            SPBRGH = 1
    Red           var LATC.3
    Blue          var LATA.2
    Green         var LATC.1
    ' ======= Buffers and Variables =======
    passcode VAR BYTE[4]       ' Stores the correct passcode
    inputCode VAR BYTE[4]      ' Stores user input
    passIndex VAR BYTE         ' Index for passcode entry
    receivedByte VAR BYTE[6]   ' Array to store received bytes from LCD
    keyCode VAR BYTE           ' Stores the decoded key value
    keyCodeHigh VAR BYTE       ' High byte of the key code
    keyCodeLow VAR BYTE        ' Low byte of the key code
    keyCodeCombined VAR WORD   ' Combined 16-bit key code
    i VAR BYTE                 ' Loop counter
    ' Initialize Variables
    passIndex = 0              ' Initialize passcode index
    keyCode = $FF              ' Initialize keyCode as undefined
    failCount VAR BYTE  ' Tracks failed attempts
    MAX_FAILS CON 5     ' Maximum allowed failed attempts before lockout
    Timeout VAR WORD     ' Timeout counter for automatic reset
    CurrentIndex VAR BYTE
    '                            VAR for Contrast                                  '
    command     var byte
    contrast    var byte
    CS          var byte
    NUM_KEYS CON 5
    ' Corrected Key Mapping
    keyCodes VAR WORD[NUM_KEYS]  ' Store received hex codes
    keyValues VAR BYTE[NUM_KEYS] ' Corresponding key values
    ' Initialize keyCodes and keyValues arrays
    FOR i = 0 TO NUM_KEYS - 1
        READ keyCodes[i], keyValues[i]
    NEXT i
    ' Manually define keys (matching Pixxi LCD response)
    keyCodes[0] = $3239  ' Number 2
    keyValues[0] = "2"
    keyCodes[1] = $373C  ' Number 7
    keyValues[1] = "7"
    keyCodes[2] = $3833  ' Number 8
    keyValues[2] = "8"
    keyCodes[3] = $343F  ' Number 4
    keyValues[3] = "4"
    keyCodes[4] = $0803  ' Go button
    keyValues[4] = "G"
    ' ==== Set Correct Passcode ====
    passcode[0] = "2"   ' Passcode digit 2
    passcode[1] = "7"   ' Passcode digit 7
    passcode[2] = "8"   ' Passcode digit 8
    passcode[3] = "4"   ' Passcode digit 4
    ' Debugging: Print the contents of keyCodes and keyValues arrays
        hserout2 ["Key Code ", DEC i, ": ", HEX keyCodes[i], " | Key Value: ", keyValues[i], 13,10]
    NEXT i
    'checking the LEDs.
    high red
    low RED
    high Green
    hserout2 ["Red LED flashes once", 13,10]
    hserout2 ["Green LED shows that PIC is powered up", 13,10]
    pause 3000  ' wait for the LCD to power up.
    '=========================== CONTRAST checksum commands=====================
    gosub checksum
    hserout [command,contrast,CS]      ' Contrast settings
    hserin  [wait(6)]
    ' Main Program
    ' ==== Main Program ====
    START:
        LOW Blue
        LOW Red
        GOSUB ReadKey                           ' Read key pressed
        hserout2 ["Key Read Complete", 13, 10]  ' debug serial out on 2 via PICKIT2
        IF keyCode <> "G" THEN                  ' this operator <> checks If not equal to the Go button
            IF passIndex < 4 THEN
                inputCode[passIndex] = keyCode  ' Store key in inputCode
                passIndex = passIndex + 1       ' Increment index
            ' If "Go" button pressed, check passcode
            IF passIndex = 4 THEN
                GOSUB CheckPasscode
        GOTO START
    ' ==== Read Key ====
    ReadKey:
        ' Ensure buffer is cleared before receiving new data
        FOR i = 0 TO 5
            receivedByte[i] = 0
        NEXT i
        HSERIN [receivedByte[0], receivedByte[1], receivedByte[2], receivedByte[3], receivedByte[4], receivedByte[5]]
        'debug serial out on 2 via PICKIT2
        hserout2 ["Packet: ", HEX receivedByte[0], " ", HEX receivedByte[1], " ", HEX receivedByte[2], " ", HEX receivedByte[3], " ", HEX receivedByte[4], " ", HEX receivedByte[5],13,10]
        ' Extract the key code (last 2 bytes from the received data)
        keyCodeHigh = receivedByte[4]  ' Get the high byte of the key code from the received data
        keyCodeLow = receivedByte[5]   ' Get the low byte of the key code from the received data
        ' Combine the high and low bytes into a single 16-bit value
        keyCodeCombined = (keyCodeHigh << 8) | keyCodeLow
        ' (keyCodeHigh << 8)Shift the high byte 8 bits to the left making room for the lowbyte and (| keyCodeLow) perform a bitwise OR with the low byte.
        ' This forms a 16-bit value where keyCodeHigh is the upper 8 bits and keyCodeLow is the lower 8 bits.
        ' Debugging: Print the combined key code
        hserout2 ["Combined Key Code: ", HEX keyCodeCombined, 13, 10]
        ' Look up the combined key code in the keyCodes table
        keyCode = "?"  ' Default to undefined keycode for debugging
        ' Debugging: Output the keycodes and compare
            hserout2 ["Checking: ", HEX keyCodeCombined, " against ", HEX keyCodes[i], 13, 10]
            IF keyCodeCombined = keyCodes[i] THEN
                keyCode = keyValues[i]  'Retrieve corresponding key value
                hserout2 ["Match Found: ", keyCode, 13, 10]
                EXIT
        NEXT i
        ' Debugging: Output the detected key value
        hserout2 ["Key Value: ", keyCode, 13, 10]
    ' ==== Check Passcode ====
    CheckPasscode:
        'debug serial out on 2 via PICKIT2: Print the inputCode array
        hserout2 ["Input Code: ", inputCode[0], inputCode[1], inputCode[2], inputCode[3], 13, 10]
        FOR i = 0 TO 3
            IF inputCode[i] <> passcode[i] THEN
                hserout2 ["Passcode Mismatch at Index ", DEC i, 13, 10] ' Debugging mismatch
                GOSUB Fail
        NEXT i
         ' If all characters match, passcode is correct
        hserout2 ["Passcode is Correct open the door ", 13, 10]
        GOSUB Unlocked
    ' ======= Passcode Unlocked =======
    Unlocked:
        ' Reset failed attempts counter
        failCount = 0
        ' Blink Blue LED to indicate success
        FOR i = 1 TO 3
            HIGH Blue
            PAUSE 100
            LOW Blue
            PAUSE 50
        NEXT i
        GOSUB ResetInputCode  ; Reset input code
    ' ======= Passcode Failed =======
    Fail:
        failCount = failCount + 1
        hserout2 ["Incorrect code. Attempts: ", DEC failCount, 13, 10]
        ' Lockout check
        IF failCount >= MAX_FAILS THEN
            hserout2 ["LOCKED OUT! Too many failed attempts.", 13, 10]
            GOSUB Lockout
        ' Blink Red LED
            HIGH Red
            PAUSE 100
            LOW Red
            PAUSE 50
    ' ======= System Lockout =======
    Lockout:
        FOR i = 1 TO 10
            HIGH Red
            HIGH Blue
            PAUSE 50
            LOW Red
            LOW Blue
            PAUSE 50
        NEXT i
        ' Disable Serial Reception
        RCSTA.4 = 0  ' Disable continuous receive
        hserout2 ["System Serial port is disabled.", 13, 10]
        hserout2 ["System in Lockout Mode. Auto-reset in 60 seconds.", 13, 10]
        ' Automatic timeout reset (wait 60s)
        FOR Timeout = 1 TO 60
            PAUSE 1000
        NEXT Timeout
        failCount = 0
        ' Clear the entered code buffer
        FOR i = 0 TO 3
            InputCode[i] = 0
        NEXT i
        ' Reset input index
        CurrentIndex = 0
        ' Enable Serial Reception again
        RCSTA.4 = 1  ' Re-enable continuous receive
        hserout2 ["System Serial port is enabled.", 13, 10]
        hserout2 ["Lockout reset. You may try again.", 13, 10]
    ' ======= Reset Input Code =======
    ResetInputCode:
        FOR i = 0 TO 3
            inputCode[i] = 0   ; Reset input code array
        NEXT i
        passIndex = 0         ; Reset passIndex
        keyCode = $FF         ; Reset keyCode
    '========== Contrast Checksum commmands ============
    checksum:
    command = $04
    contrast = $01
    cs = 0
    cs = cs ^command ^ contrast
    ' ======= End of Program =======
    Default Re: codelock with touch screen Pixxi25P4CT and PIC18F26K22
    Thanks for posting. I have been playing with the 4D systems ulcd-32ptu. Which method are you programming the display with? ViSi-Genie? Another question. Is your pic18f26k22 running on 3.3v or 5v? I have been learning the display setup with Visi-Genie and communicating with a terminal. Now I want to connect it to a 5V processor. Apparently you can put a 330ohm resistor in series with the pic Tx pin and the display Rx is 5v tolerant. Any thoughts
    Oct 2010
    im using Visi Genie for this particular setup. No other coding in 4D Systems's platoform.
    Also im using the PIC18F265K22 at 5V. I do not use any resistor in betten as the circuit board is coming with the 4D Systems display has the resistors in on board.
    Name:  Screenshot 2025-02-23 000710.png
    I will also try to impove the code as i just found a small bug. (not really a bug but just needs a fine tune)
    Thanks, I will study your code.
  1. Digital touch Screen Combination lock
    By astanapane in forum PBP3
    Last Post: - 19th August 2020, 14:41
  2. 4 Wire resistive touch screen, Need help
    Last Post: - 16th February 2012, 17:28
  3. Touch screen 4-wire interface
    By Demon in forum General
    Last Post: - 31st December 2011, 18:02
  4. touch screen
    By micro in forum General
    Last Post: - 13th January 2006, 03:39
  5. Touch Screen Wish List!!!
    By Amity in forum PBP Wish List
    Last Post: - 15th September 2005, 14:40
