Select case function
+ Reply to Thread
Results 1 to 17 of 17
    Feb 2022
    Default Select case function
    Hello everyone,
    I'm looking for some tips, to enhance the code listed here to simplify with less code the "Select case'.
    This code is for a PIC18F25K22 using PortC as a 64 switches matrix scan and PortB as the receiver and decoder and PortA to send the data.
    Thanks for any comments.
    ' PIC18F25K22 64 Keys Encoder
    ' File :"D:\PIC\PBP3\18F25K22\64 Keys Encoder\64 Keys Encoder.pbp"
    ' Date : Feb 13 2025
    ' WPUB : p152 PORTB only
    ' PORTA : Flags
    ' PORTB : Row Input
    ' PORTC : Column Out
    ;----[18F25K22 Hardware Configuration]------------------------------------------
      CONFIG  FOSC = INTIO67     ; Internal oscillator block
      CONFIG  PLLCFG = ON        ; Oscillator used directly
      CONFIG  PRICLKEN = OFF     ; Primary clock can be disabled by software
      CONFIG  FCMEN = OFF        ; Fail-Safe Clock Monitor disabled
      CONFIG  IESO = OFF         ; Oscillator Switchover mode disabled
      CONFIG  PWRTEN = OFF       ; Power up timer disabled
      CONFIG  BOREN = SBORDIS    ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
      CONFIG  BORV = 190         ; VBOR set to 1.90 V nominal
      CONFIG  WDTEN = ON         ; WDT is always enabled. SWDTEN bit has no effect
      CONFIG  WDTPS = 32768      ; 1:32768
      CONFIG  CCP2MX = PORTC1    ; CCP2 input/output is multiplexed with RC1
      CONFIG  PBADEN = OFF       ; PORTB<5:0> pins are configured as digital I/O on Reset
      CONFIG  CCP3MX = PORTB5    ; P3A/CCP3 input/output is multiplexed with RB5
      CONFIG  HFOFST = ON        ; HFINTOSC output and ready status are not delayed by the oscillator stable status
      CONFIG  T3CMX = PORTC0     ; T3CKI is on RC0
      CONFIG  P2BMX = PORTB5     ; P2B is on RB5
      CONFIG  MCLRE = INTMCLR    ; MCLR pin enabled, RE3 input pin disabled
      CONFIG  STVREN = ON        ; Stack full/underflow will cause Reset
      CONFIG  LVP = OFF          ; Single-Supply ICSP disabled
      CONFIG  XINST = OFF        ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
      CONFIG  DEBUG = OFF        ; Disabled
      CONFIG  CP0 = OFF          ; Block 0 (000800-001FFFh) not code-protected
      CONFIG  CP1 = OFF          ; Block 1 (002000-003FFFh) not code-protected
      CONFIG  CP2 = OFF          ; Block 2 (004000-005FFFh) not code-protected
      CONFIG  CP3 = OFF          ; Block 3 (006000-007FFFh) not code-protected
      CONFIG  CPB = OFF          ; Boot block (000000-0007FFh) not code-protected
      CONFIG  CPD = OFF          ; Data EEPROM not code-protected
      CONFIG  WRT0 = OFF         ; Block 0 (000800-001FFFh) not write-protected
      CONFIG  WRT1 = OFF         ; Block 1 (002000-003FFFh) not write-protected
      CONFIG  WRT2 = OFF         ; Block 2 (004000-005FFFh) not write-protected
      CONFIG  WRT3 = OFF         ; Block 3 (006000-007FFFh) not write-protected
      CONFIG  WRTC = OFF         ; Configuration registers (300000-3000FFh) not write-protected
      CONFIG  WRTB = OFF         ; Boot Block (000000-0007FFh) not write-protected
      CONFIG  WRTD = OFF         ; Data EEPROM not write-protected
      CONFIG  EBTR0 = OFF        ; Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTR1 = OFF        ; Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTR2 = OFF        ; Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTR3 = OFF        ; Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTRB = OFF        ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    define OSC 64                ' OSC 64Mhz
    ANSELA = 0                   ' Set all digital
    ANSELB = 0                   ' Set all digital
    ANSELC = 0                   ' Set all digital
    WPUB = $FF                   ' Set Weak PullUP PORTB only
    'CMCON0 = 7
    TRISA = 000000            ' PORTA Key Output
    TRISB = 111111            ' PORTB Intput Keypad Rows in
    TRISC = 000000            ' PORTC Output Keypad Column out
    TRISE = 001000            ' PORTE.3 MCLRE as input '1' other output '0'
    OSCCON = $70                 ' Internal OSC p:30
    OSCTUNE = $40                ' for 64Mhz FOSC p:35
    Latch1 var byte              ' Latch1 Flag
    Latch1 = 0
    LRShift VAR BIT              ' Shift Direction Flag
    LRSHIFT = 0
    TTL VAR WORD                  'Key val
    TTL = 0
    TTLadd var word              ' adding to PORTC val
    ttladd = 0
    PORTKey var byte             ' Key data
    portkey = 0
    Baud var word                ' Serout2 Baud Rate
    Baud = 84
    'Baud =  16468
    PORTB = 0                    ' PORTB set to 0 Keypad Row
    PAUSE 10
    PORTC = 000001            ' Keypad Column out to Row PORTB
    PORTA.0 = 1                  ' serial port = 1 'avoid random data'
    PORTA.1 = 0                  ' Data Available
    MAIN:                        ' Main Routine
    PAUSE 1                     ' needed for PORTC > PORTB Data transfert
    LATB = PORTB                ' Needed to use the value of PORTB
    ' Output Data to PORTC
    IF PORTB > 0 AND Latch1 = 0 THEN
        Latch1 = 1
        LATC = LATB
        PAUSE 5
    ' prevent duplicate
    IF PORTC = 1 THEN
        TTLADD = 0
    IF PORTC = 2 THEN
        TTLADD = 128
    IF PORTC = 4 THEN
        TTLADD = 384
    IF PORTC = 8 THEN
        TTLADD = 512
    IF PORTC = 16 THEN
        TTLADD = 640
    IF PORTC = 32 THEN
        TTLADD = 758
    IF PORTC = 64 THEN
        TTLADD = 896
    IF PORTC = 128 THEN
        TTLADD = 1024
    ' prevent duplicate
    TTL = TTLADD + PORTB
    ' Select PORTKkey val
    Select Case ttl
        case 1
        portkey = 1 : goto P
        case 2
        portkey = 2 : goto P
        case 4
        portkey = 3 : goto P
        case 8
        portkey = 4 : goto P
        case 16
        portkey = 5 : goto P
        case 32
        portkey = 6 : goto P
        case 64
        portkey = 7 : goto P
        case 128
        portkey = 8 : goto P
        case 129
        portkey = 9 : goto P
        case 130
        portkey = 10 : goto P
        case 132
        portkey = 11 : goto P
        case 136
        portkey = 12 : goto P
        case 144
        portkey = 13 : goto P
        case 160
        portkey = 14 : goto P
        case 192
        portkey = 15 : goto P
        case 256
        portkey = 16 : goto P
        case 385
        portkey = 17 : goto P
        case 386
        portkey = 18 : goto P
        case 388
        portkey = 19 : goto P
        case 392
        portkey = 20 : goto P
        case 400
        portkey = 21 : goto P
        case 416
        portkey = 22 : goto P
        case 448
        portkey = 23 : goto P
        case 512
        portkey = 24 : goto P
        case 513
        portkey = 25 : goto P
        case 514
        portkey = 26 : goto P
        case 516
        portkey = 27 : goto P
        case 520
        portkey = 28 : goto P
        case 528
        portkey = 29 : goto P
        case 544
        portkey = 30 : goto P
        case 576
        portkey = 31 : goto P
        case 640
        portkey = 32 : goto P
        case 641
        portkey = 33 : goto P
        case 642
        portkey = 34 : goto P
        case 644
        portkey = 35: goto P
        case 648
        portkey = 36 : goto P
        case 656
        portkey = 37 : goto P
        case 672
        portkey = 38 : goto P
        case 704
        portkey = 39 : goto P
        case 768
        portkey = 40 : goto P
        case 759
        portkey = 41 : goto P
        case 760
        portkey = 42 : goto P
        case 762
        portkey = 43 : goto P
        case 766
        portkey = 44 : goto P
        case 774
        portkey = 45 : goto P
        case 790
        portkey = 46 : goto P
        case 822
        portkey = 47 : goto P
        case 886
        portkey = 48 : goto P
        case 897
        portkey = 49 : goto P
        case 898
        portkey = 50 : goto P
        case 900
        portkey = 51 : goto P
        case 904
        portkey = 52 : goto P
        case 912
        portkey = 53 : goto P
        case 928
        portkey = 54 : goto P
        case 960
        portkey = 55 : goto P
        case 1024
        portkey = 56 : goto P
        case 1025
        portkey = 57 : goto P
        case 1026
        portkey = 58 : goto P
        case 1028
        portkey = 59 : goto P
        case 1032
        portkey = 60 : goto P
        case 1040
        portkey = 61 : goto P
        case 1056
        portkey = 62 : goto P
        case 1088
        portkey = 63 : goto P
        case 1152
        portkey = 64 : goto P
    end select
    P:
    pause 10
    PORTA.1 = 1  ' Data Available
    'SEROUT2 PORTA.0,Baud,[dec3 LATC," PORTC Bin: ", bin8 LATC,13,10]  ' SW PORTC Column to PORTB Row
    'SEROUT2 PORTA.0,Baud,[dec3 LATB," PORTB Bin: ", bin8 LATB," DEC TTL : ",DEC5 TTL," BIN TTL: ",BIN16 TTL,13,10]  '  SW PORTB Row from PORTC Column
    sEROUT2 PORTA.0,Baud,[" PORTB Dec :",dec3 LATB," PORTB Bin: ", bin8 LATB," TTL Dec : ",DEC4 TTL," TTL Bin : ",BIN16 TTL," Port Key: ",dec2 portkey," Port Key Bin : ",bin8 portkey,13,10]
    ' Wait for Key Release
    WHILE PORTB > 0
    WEND
    ' Reset Flag
    latch1 = 0                   ' Latch1
    LATC = 0                     ' LATC
    TTL = 0
    pause 50                     ' Debounce pause
    IF PORTC = 1 THEN
        lrshift = 0
    IF PORTC = 128 THEN
        lrshift = 1
    ' Shift PORTC
    if lrshift = 0 then
        PORTC = PORTC << 1       ' Shift Left
    if lrshift = 1 then
        PORTC = PORTC >> 1       ' Shift Right
    goto main                    ' restart loop
    Attachment 0
    Name:  keypad value rpt.jpg
    Attachment 0
    Name:  64 keys circuit diagram.jpg
    Default Re: Select case function
    just need to keep ONE GoTo P @ the end of your Select case's after the End Select
    your syntax is " not so good "
    ' prevent duplicate
    IF PORTC = 1 THEN
        TTLADD = 0
    IF PORTC = 2 THEN
       TTLADD = 128
    IF PORTC = 4 THEN
       TTLADD = 384
    One more good reason to use " select case " ...
    I think you should read carefully the select case page of your Holy Manual ... ( not a C Compiler manual ... )
    Feb 2022
    does the Select function case has to read every case before end select , or it's getting out when found the right one
    the Goto P it's there so when a case is match then Goto P, to avoid reading all the case
    0 out of 1 members found this post helpful. Did you find this post helpful? Yes | No
    Quote Originally Posted by jackberg1 View Post
    for a 8x8 keypad there are 64 possible results
    that's an extraordinary convoluted way to get a result
    why not
    key var byte    ; high nibble column  low nibble row
      if portb then    'look for a 1
          key = ncd portb  'row    look for a 1
          key = key + (ncd portc )<<4
          WHILE PORTB >0 :wend
    Feb 2022
    Thank you richard
    the reason I had to add a value to the portc, was the fact in the 64 key matrix some code were duplicate.
    so 2 different key had the same value.
    I'll have to test this code.
    Feb 2022
    Hello Richard
    by inverting portb / portc I found no duplicate
    If I may ask, how to know the time it took from the start to end of a for/next loop or select case in a program
    Many thanks for your support.
    Depends on what's available. I usually just set a pin high at the start and low again at the end of the routine I want to measure and then look at the pin using a scope or logic analyzer. Another option is to use one of the hardware timers and send the result to the PC using whatever serial connection is available (DEBUG, SEROUT, HSEROUT) but for longer routines one has to be little bit careful as to not overflow the timer and therefor get misleading values.
    Feb 2022
    Thank you HenrikOlsson
    This is a very usefull solution since I got on hand a logic analyzer + scope.
    Feb 2022
    Hello HenrikOlsson,
    I did some timing test for the 'Select case' for key # 1 ~ key # 64
    case # 1 : 3.48us and the last of the case key # 64 : 134.9us
    Thanks again for this clever trick.
    the PBP soft way : https://dt.picbasic.co.uk/CODEX/CodeTimer
    Feb 2022
    Hello Richard,
    I rewrote my keypad program with the NCD function that you recomended, that help a lot
    I changed the column value to the range from 1 ~ 64 with this I'm able to get an
    average of 10~12us for the data available output signal.
    The project served as a replacement of the old MM74C922/3.
    Thanks again Richard for your great help.
    ' File      : "D:\PIC\PBP3\18F25K22\64 Keys Encoder\64 Keys Encoder V2.pbp"
    ' Date      : Feb 16 2025
    ' Benchmark : PortKey 1~64:~12us
    ' Used      : 543 bytes
    ' PORTA     : Data Available D/A PORTA.7:High
    ' PORTB     : Row Input
    ' PORTC     : Column Output
    '----[18F25K22 Hardware Configuration]------------------------------------------
      CONFIG  PLLCFG = ON        ; Oscillator multiplied by 4
      CONFIG  WDTEN = OFF        ; Watch dog timer is always disabled. SWDTEN has no effect.
      CONFIG  MCLRE = INTMCLR    ; RE3 input pin enabled; MCLR disabled
    'WPUB = $FF                  ' Set Weak PullUP PORTB only
    'CMCON0 = 7
    TRISA = 000000            ' PORTA Key Data available output
    ' Var for Key & Port
    Latch1 = 0
    LRSHIFT = 0
    NCDB VAR BYTE                ' NCD PORTB
    NCDC VAR BYTE                ' NCD PORTC
    PORTKey var byte             ' Key# data
    portkey = 0
    ' Serial Terminal
    Baud = 84
    'Baud =  16468
    PAUSE 100
    PORTA.7 = 0                  ' Data Available
    PORTB = 000000            ' PORTB set to 0 Keypad Row
        Latch1 = 1
        'PORTA.1 = 1             ' Benchmark
        ' Get bit position 1~8
        NCDB = NCD PORTB         ' PORTB Row 'in'
        NCDC = NCD PORTC         ' PORTC Column 'out'
        ' Assign new value for PORTC Column
        SELECT CASE NCDC
            CASE 1
            NCDC = 0
            CASE 2
            NCDC = 8
            CASE 3
            NCDC = 16
            CASE 4
            NCDC = 24
            CASE 5
            NCDC = 32
            CASE 6
            NCDC = 40
            CASE 7
            NCDC = 48
            CASE 8
            NCDC = 56
        END SELECT
        PORTKey = NCDC + NCDB    ' Key# Data 1~64
        PORTA = PORTKEY          ' Data output
        pause 1                  ' Mandatory pause > 0  for PORTA to set
        PORTA.7 = 1              ' Data available
        'sEROUT2 PORTA.0,Baud,[" PORTB NCD: ",dec1 NCDB," PORTC NCD:",DEC1 NCDC," PORTKey :",DEC2 PORTKey,13,10]
    WHILE PORTB > 0
    WEND
    pause 5                      ' Key release debounce
    ' Reset Flag
    latch1 = 0                   ' Latch1
    PORTA.7 = 0                  ' Data available
    PORTA.1 = 0                  ' Benchmark
    PORTKey = 0
    IF PORTC = 1 THEN
        lrshift = 0
    IF PORTC = 128 THEN
        lrshift = 1
    ' Shift PORTC
    if lrshift = 0 then
    if lrshift = 1 then
    PAUSE 1                      ' Mandatory pause > 0  wait for Shift to set
    With these errors, I think it cannot work...
    Have marked with red the errors.
    You should use percent character followed by binary values.
    ' Used      : 543 bytes
    ' PORTB     : Row Input
    'CMCON0 = 7
    Latch1 = 0
    LRSHIFT = 0
    portkey = 0
    ' Serial Terminal
    Baud = 84
    'Baud =  16468
    PAUSE 100
        Latch1 = 1
        SELECT CASE NCDC
            CASE 1
            NCDC = 0
            CASE 2
            NCDC = 8
            CASE 3
            NCDC = 16
            CASE 4
            NCDC = 24
            CASE 5
            NCDC = 32
            CASE 6
            NCDC = 40
            CASE 7
            NCDC = 48
            CASE 8
            NCDC = 56
        END SELECT
    WHILE PORTB > 0
    WEND
    ' Reset Flag
    latch1 = 0                   ' Latch1
    PORTKey = 0
    IF PORTC = 1 THEN
        lrshift = 0
    IF PORTC = 128 THEN
        lrshift = 1
    ' Shift PORTC
    if lrshift = 0 then
    if lrshift = 1 then
    Feb 2022
    Thanks Ioannis for pointing this, the % are in fact on my program.
    when uploading to the site something I select 'Courrier New' font append, and it's look they just vannish.
    here's the upload.
    '2nd upload seem to work fine this time'
    ' Used      : 543 bytes
    ' PORTB     : Row Input
    'CMCON0 = 7
    TRISA = %00000000            ' PORTA Key Data available output
    TRISB = %11111111            ' PORTB Intput Keypad Rows in
    TRISC = %00000000            ' PORTC Output Keypad Column out
    TRISE = %00001000            ' PORTE.3 MCLRE as input '1' other output '0'
    Latch1 = 0
    LRSHIFT = 0
    portkey = 0
    ' Serial Terminal
    Baud = 84
    PORTA.0 = 1                  ' Avoid garbage on serial
    PAUSE 100
    PORTC = %00000001            ' Keypad Column out to Row PORTB
    PORTB = %00000000            ' PORTB set to 0 Keypad Row
        Latch1 = 1
        SELECT CASE NCDC
            CASE 1
            NCDC = 0
            CASE 8
            NCDC = 56
            CASE 2
            NCDC = 8
            CASE 7
            NCDC = 48
            CASE 3
            NCDC = 16
            CASE 6
            NCDC = 40
            CASE 4
            NCDC = 24
            CASE 5
            NCDC = 32
        END SELECT
        'PORTA = PORTKEY          ' Data output
       'PORTA.1 = 0              ' Benchmark
        pause 2                  ' Mandatory pause > 0  for PORTA to set
    WHILE PORTB > 0
    WEND
    ' Reset Flag
    latch1 = 0                   ' Latch1
    PORTKey = 0
    IF PORTC = 1 THEN
        lrshift = 0
    IF PORTC = 128 THEN
        lrshift = 1
    ' Shift PORTC
    if lrshift = 0 then
    if lrshift = 1 then
    Feb 2022
    Default Re: Select case function Last update (Benchmark : PortKey 1~64: 3.988us ~ 6.25us)
    This is the lasted update, some changes the 'Select case' as been move down
    this alone is reducing the response time from 11us to 6us to the data available.
    While the propagation time at the D/A of the MM74C922 is 60ns ~ 150ns max.
    It will be hard to even get close to 500ns with the PIC18F25K22 unless someone has an idea to share.
    I searched the internet for an affordable / alternative solution is to get into the CPLD or FPGA but it's not cost effective + VHDL learning process.
    Any constructive comments is welcome.
    Name:  Key Sheet.jpg
    Feb 2022
    Here's the updated code (when using the '#" Wrap code, if I edit my post and save it, after the '%' or other characters are remove from the listing)
    ' PIC18F25K22 64 Keys Encoder V3
    ' File : "D:\PIC\PBP3\18F25K22\64 Keys Encoder\64 Keys Encoder V3.pbp"
    ' Date : Feb 19 2025
    ' Benchmark : PortKey 1~64: 3.988us ~ 6.25us
    ' Used : 621 bytes
    ' PORTB : Row Input
    'CMCON0 = 7
    Latch1 = 0
    LRSHIFT = 0
    NCDC VAR BYTE ' PORTC Bit Position 1~8
    portkey = 0
    Baud = 84
    PORTA.0 = 1 ' Avoid random char on serial
    PAUSE 100
    PORTC = %00000001 ' Keypad Scan Column out to PORTB
    PORTA.7 = 0 ' Data available / Benchmark
    PORTB = %00000000 ' PORTB Keypad Row
    IF PORTB > 0 AND Latch1 = 0 THEN ' Detect Press Switch and Latch
    Latch1 = 1
    ' PORTA.7 = 1 ' Benchmark Start
    PORTKey = NCDC + NCD PORTB ' add bit position 1~8
    'PORTA = PORTKEY ' Set PORTA / Disable for SEROUT2
    ' PORTA.7 = 0 ' Benchmark End
    PAUSE 5 ' pause before D/A PORTA.7
    PORTA.7 = 1 ' Data available / Disable for Benchmark
    SEROUT2 PORTA.0,Baud,[" PORTB NCD: ",dec1 NCD PORTB," PORTC NCD:",DEC1 NCD PORTC," D/A PORTKey :",DEC2 PORTKey,13,10]
    WHILE PORTB > 0
    WEND
    ' Reset Flag
    latch1 = 0 ' Latch1
    PORTA.7 = 0 ' Data available after Key release
    PORTKey = 0
    IF PORTC = 1 THEN
    lrshift = 0
    IF PORTC = 128 THEN
    lrshift = 1
    ' Shift PORTC
    if lrshift = 0 then
    if lrshift = 1 then
    PAUSEUS 20 ' pauseus wait for Shift to set
    SELECT CASE NCD PORTC ' Assign new value for PORTC Column
    CASE 1
    NCDC = 0
    CASE 8
    NCDC = 56
    CASE 2
    NCDC = 8
    CASE 7
    NCDC = 48
    CASE 3
    NCDC = 16
    CASE 6
    NCDC = 40
    CASE 4
    NCDC = 24
    CASE 5
    NCDC = 32
    END SELECT
    Feb 2022
    While trying to correct my previous listing the 'Administrator is preventing me to edit after 30 minutes'
    Dear Administrator read my previous post about the characters missing or changes after uploading to your site.
    thank you
    \ (when using the '#" Wrap code, if I edit my post and save it, after the '%' or other characters are remove from the listing
    even some characters are show in lower case instead of upper case
  1. Select Case Weirdness
    By rocket_troy in forum mel PIC BASIC Pro
    Last Post: - 19th June 2014, 01:33
  2. Changing from If..Then to Select Case
    By BobK in forum mel PIC BASIC Pro
    Last Post: - 27th March 2013, 12:06
  3. About Select Case
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 28th February 2010, 12:54
  4. Select case...Just wondering....
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 30th December 2006, 00:23
  5. Select Case
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 20th June 2005, 20:18
Members who have read this thread : 14
