ina226 code for current with r100 resistor
+ Reply to Thread
Results 1 to 5 of 5
    Feb 2025
    Default ina226 code for current with r100 resistor
    Can't get accurate current readings. VBUS voltage is correct but I can't figure out the code for current. All voltages will be <36 volts and current <0.8 amps. Any help would be greatly appreciated. Have tried for 4 weeks before I found this forum.
    Default Re: ina226 code for current with r100 resistor
    Post your code, your PIC, your setup, maybe a video too.
    Sep 2009
    ABS reading times 2.5uV divided by 100. Is current in uAmps.
    ABS readings time 25 is current in nA. If I didn't make some mistake...
    EDIT: max current is 0.84mA...
    I think your resistor is too large, and leakage current will give you bad measurements.
    Feb 2025
    What value is appropriate for the CALIBRATION number in the settings?
    I've never touched this device.
    I assume you've read everything in here:
    https://www.ti.com/lit/ds/symlink/ina226.pdf
    Section 6.5 seems to be where the main action starts.
    EDIT: when I get caught up with a mystery device, I go look at what they're doing on arduino. Sometimes you gets hints in the code, sometimes your eyes just glaze over.
    But at least it's a start.
  1. Replies: 23
    Last Post: - 25th June 2011, 23:27
  2. Replies: 6
    Last Post: - 12th August 2010, 10:33
  3. Can I drive a 5v LED without a current resistor?
    By Fredrick in forum Schematics
    Last Post: - 11th September 2009, 14:42
  4. Current Sensing Resistor
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 17th February 2007, 16:04
  5. NTC resistor
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 29th September 2005, 18:16
Members who have read this thread : 10
