Is it possible to use HPWM and DT's MIBAM at the same time?
Results 1 to 5 of 5
    Default Is it possible to use HPWM and DT's MIBAM at the same time?
    Hello.
    PIC16F1936.
    Say I run DT's MIBAM on PORTB pins, but I also want to use existing HPWM module to generate something on PORTC pins.
    Will it work?
    https://www.picbasic.co.uk/forum/con...le-Modulation)
    As said there,
    The module uses Timer1, and it cannot be used for any other purposes.
    Consequently, the PIC being used must have a Timer1.
    As I understand, while Timer1 and CCP1 share same pins, these are different hardware modules and can operate separately and independently?
    Default Re: Is it possible to use HPWM and DT's MIBAM at the same time?
    for hpwm timers 2,4 or 6 can be used so there is no conflict for pwm
    Yes, thanks, I've checked some datasheets.
    For 16F1939 default timer for HPWM1 is Timer1, but it can be changed via registers.
    For 16F722 default timer for HPWM1 is Timer2, so no change is needed.
    However, it should be noted that these PICs have only Timer1 16 bit, others are 8 bit, so certain bytes of resolution will be lost...
    Incorrect , timer1 is not an option for hpwm1 ever
    timer2 is the default for ccp1 on 16F1939
    see CCPTMRS0: PWM TIMER SELECTION CONTROL REGISTER
    I'm assembling test circuit with PIC16F722 today and will give it a try
  1. MIBAM blinky on 16f628
    By ShoKre in forum mel PIC BASIC Pro
    Last Post: - 11th December 2013, 08:58
  2. Replies: 3
    Last Post: - 23rd October 2011, 12:53
  3. MIBAM and 12F1822...
    By alesniak in forum mel PIC BASIC Pro
    Last Post: - 17th September 2011, 06:45
  4. MIBAM resolution
    By david parish in forum mel PIC BASIC Pro
    Last Post: - 8th October 2009, 23:04
  5. MIBAM on 16F628
    By idtat in forum mel PIC BASIC Pro
    Last Post: - 18th February 2009, 12:42
