Hello everyone,
I'm looking for some tips, to enhance the code listed here to simplify with less code the "Select case'.
This code is for a PIC18F25K22 using PortC as a 64 switches matrix scan and PortB as the receiver and decoder and PortA to send the data.
Thanks for any comments.
' PIC18F25K22 64 Keys Encoder
' File :"D:\PIC\PBP3\18F25K22\64 Keys Encoder\64 Keys Encoder.pbp"
' Date : Feb 13 2025
' WPUB : p152 PORTB only
' PORTA : Flags
' PORTB : Row Input
' PORTC : Column Out
;----[18F25K22 Hardware Configuration]------------------------------------------
  CONFIG  FOSC = INTIO67     ; Internal oscillator block
  CONFIG  PLLCFG = ON        ; Oscillator used directly
  CONFIG  PRICLKEN = OFF     ; Primary clock can be disabled by software
  CONFIG  FCMEN = OFF        ; Fail-Safe Clock Monitor disabled
  CONFIG  IESO = OFF         ; Oscillator Switchover mode disabled
  CONFIG  PWRTEN = OFF       ; Power up timer disabled
  CONFIG  BOREN = SBORDIS    ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
  CONFIG  BORV = 190         ; VBOR set to 1.90 V nominal
  CONFIG  WDTEN = ON         ; WDT is always enabled. SWDTEN bit has no effect
  CONFIG  WDTPS = 32768      ; 1:32768
  CONFIG  CCP2MX = PORTC1    ; CCP2 input/output is multiplexed with RC1
  CONFIG  PBADEN = OFF       ; PORTB<5:0> pins are configured as digital I/O on Reset
  CONFIG  CCP3MX = PORTB5    ; P3A/CCP3 input/output is multiplexed with RB5
  CONFIG  HFOFST = ON        ; HFINTOSC output and ready status are not delayed by the oscillator stable status
  CONFIG  T3CMX = PORTC0     ; T3CKI is on RC0
  CONFIG  P2BMX = PORTB5     ; P2B is on RB5
  CONFIG  MCLRE = INTMCLR    ; MCLR pin enabled, RE3 input pin disabled
  CONFIG  STVREN = ON        ; Stack full/underflow will cause Reset
  CONFIG  LVP = OFF          ; Single-Supply ICSP disabled
  CONFIG  XINST = OFF        ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
  CONFIG  DEBUG = OFF        ; Disabled
  CONFIG  CP0 = OFF          ; Block 0 (000800-001FFFh) not code-protected
  CONFIG  CP1 = OFF          ; Block 1 (002000-003FFFh) not code-protected
  CONFIG  CP2 = OFF          ; Block 2 (004000-005FFFh) not code-protected
  CONFIG  CP3 = OFF          ; Block 3 (006000-007FFFh) not code-protected
  CONFIG  CPB = OFF          ; Boot block (000000-0007FFh) not code-protected
  CONFIG  CPD = OFF          ; Data EEPROM not code-protected
  CONFIG  WRT0 = OFF         ; Block 0 (000800-001FFFh) not write-protected
  CONFIG  WRT1 = OFF         ; Block 1 (002000-003FFFh) not write-protected
  CONFIG  WRT2 = OFF         ; Block 2 (004000-005FFFh) not write-protected
  CONFIG  WRT3 = OFF         ; Block 3 (006000-007FFFh) not write-protected
  CONFIG  WRTC = OFF         ; Configuration registers (300000-3000FFh) not write-protected
  CONFIG  WRTB = OFF         ; Boot Block (000000-0007FFh) not write-protected
  CONFIG  WRTD = OFF         ; Data EEPROM not write-protected
  CONFIG  EBTR0 = OFF        ; Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
  CONFIG  EBTR1 = OFF        ; Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
  CONFIG  EBTR2 = OFF        ; Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
  CONFIG  EBTR3 = OFF        ; Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
  CONFIG  EBTRB = OFF        ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
define OSC 64                ' OSC 64Mhz
ANSELA = 0                   ' Set all digital
ANSELB = 0                   ' Set all digital
ANSELC = 0                   ' Set all digital
WPUB = $FF                   ' Set Weak PullUP PORTB only
'CMCON0 = 7
TRISA = 000000            ' PORTA Key Output
TRISB = 111111            ' PORTB Intput Keypad Rows in
TRISC = 000000            ' PORTC Output Keypad Column out
TRISE = 001000            ' PORTE.3 MCLRE as input '1' other output '0'
OSCCON = $70                 ' Internal OSC p:30
OSCTUNE = $40                ' for 64Mhz FOSC p:35
Latch1 var byte              ' Latch1 Flag
Latch1 = 0
LRShift VAR BIT              ' Shift Direction Flag
LRSHIFT = 0
TTL VAR WORD                  'Key val
TTL = 0
TTLadd var word              ' adding to PORTC val
ttladd = 0
PORTKey var byte             ' Key data
portkey = 0
Baud var word                ' Serout2 Baud Rate
Baud = 84
'Baud =  16468
PORTB = 0                    ' PORTB set to 0 Keypad Row
PAUSE 10
PORTC = 000001            ' Keypad Column out to Row PORTB
PORTA.0 = 1                  ' serial port = 1 'avoid random data'
PORTA.1 = 0                  ' Data Available
MAIN:                        ' Main Routine
PAUSE 1                     ' needed for PORTC > PORTB Data transfert
LATB = PORTB                ' Needed to use the value of PORTB
' Output Data to PORTC
IF PORTB > 0 AND Latch1 = 0 THEN
    Latch1 = 1
    LATC = LATB
    PAUSE 5
' prevent duplicate
IF PORTC = 1 THEN
    TTLADD = 0
IF PORTC = 2 THEN
    TTLADD = 128
IF PORTC = 4 THEN
    TTLADD = 384
IF PORTC = 8 THEN
    TTLADD = 512
IF PORTC = 16 THEN
    TTLADD = 640
IF PORTC = 32 THEN
    TTLADD = 758
IF PORTC = 64 THEN
    TTLADD = 896
IF PORTC = 128 THEN
    TTLADD = 1024
' prevent duplicate
TTL = TTLADD + PORTB
' Select PORTKkey val
Select Case ttl
    case 1
    portkey = 1 : goto P
    case 2
    portkey = 2 : goto P
    case 4
    portkey = 3 : goto P
    case 8
    portkey = 4 : goto P
    case 16
    portkey = 5 : goto P
    case 32
    portkey = 6 : goto P
    case 64
    portkey = 7 : goto P
    case 128
    portkey = 8 : goto P
    case 129
    portkey = 9 : goto P
    case 130
    portkey = 10 : goto P
    case 132
    portkey = 11 : goto P
    case 136
    portkey = 12 : goto P
    case 144
    portkey = 13 : goto P
    case 160
    portkey = 14 : goto P
    case 192
    portkey = 15 : goto P
    case 256
    portkey = 16 : goto P
    case 385
    portkey = 17 : goto P
    case 386
    portkey = 18 : goto P
    case 388
    portkey = 19 : goto P
    case 392
    portkey = 20 : goto P
    case 400
    portkey = 21 : goto P
    case 416
    portkey = 22 : goto P
    case 448
    portkey = 23 : goto P
    case 512
    portkey = 24 : goto P
    case 513
    portkey = 25 : goto P
    case 514
    portkey = 26 : goto P
    case 516
    portkey = 27 : goto P
    case 520
    portkey = 28 : goto P
    case 528
    portkey = 29 : goto P
    case 544
    portkey = 30 : goto P
    case 576
    portkey = 31 : goto P
    case 640
    portkey = 32 : goto P
    case 641
    portkey = 33 : goto P
    case 642
    portkey = 34 : goto P
    case 644
    portkey = 35: goto P
    case 648
    portkey = 36 : goto P
    case 656
    portkey = 37 : goto P
    case 672
    portkey = 38 : goto P
    case 704
    portkey = 39 : goto P
    case 768
    portkey = 40 : goto P
    case 759
    portkey = 41 : goto P
    case 760
    portkey = 42 : goto P
    case 762
    portkey = 43 : goto P
    case 766
    portkey = 44 : goto P
    case 774
    portkey = 45 : goto P
    case 790
    portkey = 46 : goto P
    case 822
    portkey = 47 : goto P
    case 886
    portkey = 48 : goto P
    case 897
    portkey = 49 : goto P
    case 898
    portkey = 50 : goto P
    case 900
    portkey = 51 : goto P
    case 904
    portkey = 52 : goto P
    case 912
    portkey = 53 : goto P
    case 928
    portkey = 54 : goto P
    case 960
    portkey = 55 : goto P
    case 1024
    portkey = 56 : goto P
    case 1025
    portkey = 57 : goto P
    case 1026
    portkey = 58 : goto P
    case 1028
    portkey = 59 : goto P
    case 1032
    portkey = 60 : goto P
    case 1040
    portkey = 61 : goto P
    case 1056
    portkey = 62 : goto P
    case 1088
    portkey = 63 : goto P
    case 1152
    portkey = 64 : goto P
end select
P:
pause 10
PORTA.1 = 1  ' Data Available
'SEROUT2 PORTA.0,Baud,[dec3 LATC," PORTC Bin: ", bin8 LATC,13,10]  ' SW PORTC Column to PORTB Row
'SEROUT2 PORTA.0,Baud,[dec3 LATB," PORTB Bin: ", bin8 LATB," DEC TTL : ",DEC5 TTL," BIN TTL: ",BIN16 TTL,13,10]  '  SW PORTB Row from PORTC Column
sEROUT2 PORTA.0,Baud,[" PORTB Dec :",dec3 LATB," PORTB Bin: ", bin8 LATB," TTL Dec : ",DEC4 TTL," TTL Bin : ",BIN16 TTL," Port Key: ",dec2 portkey," Port Key Bin : ",bin8 portkey,13,10]
' Wait for Key Release
WHILE PORTB > 0
WEND
' Reset Flag
latch1 = 0                   ' Latch1
LATC = 0                     ' LATC
TTL = 0
pause 50                     ' Debounce pause
IF PORTC = 1 THEN
    lrshift = 0
IF PORTC = 128 THEN
    lrshift = 1
' Shift PORTC
if lrshift = 0 then
    PORTC = PORTC << 1       ' Shift Left
if lrshift = 1 then
    PORTC = PORTC >> 1       ' Shift Right
goto main                    ' restart loop
Attachment 0
Name:  keypad value rpt.jpg
Attachment 0
Name:  64 keys circuit diagram.jpg
