PIC18F45K22 Not working
Results 1 to 4 of 4
    Default PIC18F45K22 Not working
    Simple LED test but no joy. Cannot see why it is not working.
    On PortB(0-3) there are 4 LEDs connected to ground and LED1 and LED2 are faint ON, rest OFF.
        CONFIG  FOSC = INTIO67        ; Internal oscillator block
        CONFIG  PLLCFG = ON           ; PLL Control
        CONFIG  PRICLKEN = OFF        ; Primary clock can be disabled by software
        CONFIG  PWRTEN = OFF          ; Power up timer disabled
        CONFIG  BOREN = SBORDIS       ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
        CONFIG  BORV = 190            ; VBOR set to 1.90 V nominal
        CONFIG  WDTEN = OFF            ; WDT is always enabled. SWDTEN bit has no effect
        CONFIG  WDTPS = 32768         ; 1:32768
        CONFIG  CCP2MX = PORTC1       ; CCP2 input/output is multiplexed with RC1
        CONFIG  PBADEN = OFF          ; PORTB<5:0> pins are configured as digital I/O on Reset
        CONFIG  CCP3MX = PORTB5       ; P3A/CCP3 input/output is multiplexed with RB5
        CONFIG  HFOFST = ON           ; HFINTOSC output and ready status are not delayed by the oscillator stable status
        CONFIG  T3CMX = PORTC0        ; T3CKI is on RC0
        CONFIG  P2BMX = PORTD2        ; P2B is on RD2
        CONFIG  MCLRE = INTMCLR       ; MCLR pin disabled, RE3 input pin enabled
        CONFIG  STVREN = ON           ; Stack full/underflow will cause Reset
        CONFIG  DEBUG = OFF           ; Disabled
        CONFIG  CP0 = OFF             ; Block 0 (000800-001FFFh) not code-protected
        CONFIG  CP1 = OFF             ; Block 1 (002000-003FFFh) not code-protected
        CONFIG  CP2 = OFF             ; Block 2 (004000-005FFFh) not code-protected
        CONFIG  CP3 = OFF             ; Block 3 (006000-007FFFh) not code-protected
        CONFIG  CPB = OFF             ; Boot block (000000-0007FFh) not code-protected
        CONFIG  WRT0 = OFF            ; Block 0 (000800-001FFFh) not write-protected
        CONFIG  WRT1 = OFF            ; Block 1 (002000-003FFFh) not write-protected
        CONFIG  WRT2 = OFF            ; Block 2 (004000-005FFFh) not write-protected
        CONFIG  WRT3 = OFF            ; Block 3 (006000-007FFFh) not write-protected
        CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
        CONFIG  WRTB = OFF            ; Boot Block (000000-0007FFh) not write-protected
        CONFIG  EBTR0 = OFF           ; Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR1 = OFF           ; Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR2 = OFF           ; Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR3 = OFF           ; Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTRB = OFF           ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    ' Setup PLL for 64 MHZ
    OSCCON = %01110000 ; 16 mhz (NOTE: SCS=0 so PLL works)
    OSCCON2 = %00000100
    OSCTUNE = %01000000 ; PLL enable Mhz * 4
    DEFINE OSC 64
    ANSELA = 0
    ANSELB = 0
    ANSELC = 0
    ANSELD = 0
    ANSELE = 0
    WPUB= 255
    'Initializing Registers
      porta=0:portb = 255:portc=0:portd=0:porte=0
      trisa = 0
      trisb.5=%00100000
      portc.6=1
      trisc.6=0
      trisd = 0
      trise = 0
    'Variable set
    but     var portb.5
    latb=0
    while 1
    latb.0=1:pause 100:latb.0=0:pause 100
    wend
    Default Re: PIC18F45K22 Not working
    Do not bother... Found the embarrasing stupid mistake that blew the Port B all together!
    Marked with bold red on the code above.
    That was enough to damage the port?
    I don't think this is something dangerous. It just did not setup the port properly and of course did not work as an output.
    No damage at all.
    Still very stupid mistake, not easy to see.
  1. Replies: 8
    Last Post: - 6th February 2014, 18:36
  2. PIC18F45K22, Pbp and 16*16 rgb led matrix, will speed be enough?
    Last Post: - 19th May 2013, 03:45
  3. "Simon Says" the game code for PIC18F45K22
    By Tamirbm in forum General
    Last Post: - 12th May 2013, 01:29
  4. @goto not working please help
    By cluster in forum mel PIC BASIC Pro
    Last Post: - 31st October 2011, 18:45
  5. SERIN Not Working, SEROUT Working
    By cc1984 in forum Serial
    Last Post: - 26th October 2010, 19:16
