1Wire conversion
Results 1 to 9 of 9
    Default Re: 1Wire conversion
    This one could be useful ...
    '* Universal thermostat -25/+75 C.  by R.T.G. van Steenis                  *
    '* Compiler : PicBasic Pro 2.45                                            *
    '* B0 = Mode switch in (In)            A0 = LCD Enable    (Out)            *
    '* B1 = + switch in    (In)            A1 = LCD RS        (Out)            *
    '* B2 = - switch in    (In)            A2 = "Warm" Output (Out)            *
    '* B3 = Not connected  (Out)           A3 = "Cold" Output (Out)            *
    '* B4 = LCD Bit 4      (Out)           A4 = DQ DS1820     (In)             *
    '* B5 = LCD Bit 5      (Out)                                               *
    '* B6 = LCD Bit 6      (Out)                                               *
    '* B7 = LCD Bit 7      (Out            PIC16F877A Code size = 1966 Words   *
    '* Oscillator XT (4 MHz.) - Power up timer enabled - MCR enable            *
    '*                  LCD Defines for EasyPic5 & 16F877A                                *
    '@ ERRORLEVEL -306
    '@ __config _HS_OSC & _WDT_ON & _PWRTE_ON & _BODEN_ON & _LVP_OFF & _CP_OFF
    '    DEFINE LCD_DREG PORTB               ' I/O port where LCD is connected
    '    DEFINE LCD_DBIT 0
    '    DEFINE LCD_RSREG PORTB
    '    DEFINE LCD_RSBIT 4                  ' Register select pin
    '    DEFINE LCD_EREG PORTB
    '    DEFINE LCD_EBIT 5                   ' Enable pin
    '    DEFINE LCD_BITS 4                   ' 4-bit data bus
    '    DEFINE LCD_LINES 2                  ' LCD has 2 character lines
    '    DEFINE OSC 8
    '    DEFINE BUTTON_PAUSE 100
    ''Pinout for EasyPic5
    '	Heat			Var PORTC.0
    '	Cool 			Var PORTC.2
    '	Waitbit			Var PortC.4
    '    DQ				Var	PORTE.2		' One-wire data pin
    '    Mode_B			Var PORTA.0		'Pullups ...
    '    UP_B			Var PORTA.1
    '    DOWN_B			Var PORTA.2
    ''Configs EasyPic5
    'ADCON1 = 7			          	' Set PORTD and PORTE to digital
    'CMCON  = 7						' Comparators OFF
    'PORTA = %00000111
    'PORTB = 0
    'PORTC = 0
    'PORTD = 0
    'PORTE = 0
    'TRISA = %00000111
    'TRISB = 0
    'TRISC = 0
    'TRISD = 0
    'TRISE = %00000100
    ' Elektor LCD Defines
    @ __CONFIG _XT_OSC & _WDT_ON & _PWRTE_ON & _MCLRE_ON & _BODEN_OFF & _LVP_OFF & _CP_OFF
    DEFINE LCD_DREG PORTB                   ' LCD on port B
    DEFINE LCD_DBIT 4                       ' Data bits B4..B7
    DEFINE LCD_RSREG PORTA                  ' RS on PORTA
    DEFINE LCD_RSBIT 1                      ' RS on A1
    DEFINE LCD_EREG PORTA                   ' E on PORTA
    DEFINE LCD_EBIT 0                       ' E on A0
    DEFINE LCD_BITS 4                       ' LCD 4 bit mode
    DEFINE LCD_LINES 2                      ' 2 line LCD display
    'Pinout for Elektor
    Heat			Var PORTA.2
    Cool 			Var	PORTA.3
    DQ				Var	PORTA.4		' One-wire data pin
    Mode_B			Var PORTB.0
    UP_B			Var PORTB.1
    DOWN_B			Var PORTB.2
    ' I/o Settings
    PORTA = 0
    PORTB = 0
    TRISA= %11110000                        ' RA0..3=Outputs RA4=Input
    TRISB= %00000111 			' RB0..RB2=Inputs, RB3..RB7=Outputs
    CMCON=7                                 ' Disable comparators
    ' Variables
    Temperature 	Var	Word		' Temperature storage
    TempC			Var Word
    Float			Var Word
    TargetTemp		Var	Word		' Desired Temperature
    Hyst			Var	Word		' Hystereris
    V				Var	Word		' Var. for display
    Cadence 		Var Word
    B1              Var Byte            ' Byte for TargetTemp calculation
    B2              Var Byte            ' Byte for TargetTemp calculation
    Sign			Var	Byte		' +/- sign
    Mode 			Var	Byte		' 0=Temp. display, 1=Set Temp, 2=Set Hysteresis
    DS18B20_Bit		Var Byte
    FAM				Var Byte
    CRC				Var Byte
    ID				Var Byte[7]
    Twist			Var Bit
    Busy			Var Bit
    Disable_out		Var Bit
    ' Resolution
    'DS18B20_9bit  	CON %00011111   	' 93.75ms, 0.5°C
    'DS18B20_10bit 	CON %00111111   	' 187.5ms, 0.25°C  <-- My favorite
    'DS18B20_11bit 	CON %01011111   	' 375ms,   0.125°C
    'DS18B20_12bit 	CON %01111111   	' 750ms,   0.0625°C  (default)
    Resolution  CON 12
    Offset		CON 300
    'Initialization
     SELECT CASE Resolution
     	Case 9
     		 DS18B20_bit = %00011111   	' 93.75ms, 0.5°C
     		 Cadence = 900
     	Case 10
    		 DS18B20_bit = %00111111   	' 187.5ms, 0.25°C  <-- My favourite
    		 Cadence = 810
    	Case 11
    		 DS18B20_bit = %01011111   	' 375ms,   0.125°C
    		 Cadence = 625
    	Case 12
    		 DS18B20_bit = %01111111   	' 750ms,   0.0625°C  (default)
    		 Cadence = 250
    END SELECT
    DATA 46, 224, 20                        ' Temp MSB, TEMP LSB, Hysteresis DIV 10
    Heat=0                               ' Warm Output Low
    Cool=0                               ' Cold Output Low
    Disable_out = 1
    Mode=0                                  ' Temperature display mode
    Twist = 0
    ' Program start
    PAUSE 500
    READ 0, B1                              'READ TargetTemp MSB
    READ 1, B2                              'READ TargetTemp LSB
    TargetTemp=B1*256+B2                    ' Calculate TargetTemp value (Default=20.0 C.)
    READ 2, B1                              'READ Hysteresis
    Hyst=10*B1                              ' Calculate Hysteresis value (Default= 2.0 C.)
    LCDOUT $FE, 1, $FE, $0C                 ' Clear display, cursor off
    PAUSE 250
    SensID:' Sensor Identification
      OWOUT DQ, 1, [ $33 ]								'READ Chip Family code
      OWIN  DQ, 2, [ FAM,ID[6],ID[5],ID[4],ID[3],ID[2],ID[1],CRC]
      IF FAM = $05 THEN
       	LCDOUT $FE,$80, "DS 2405     "
      	PAUSE 1000
      	LCDOUT $FE,$80, 				" CRC: ",HEX2 CRC," FAM: ", HEX2 FAM
    ' DS 1820 / DS 18S20
      IF FAM = $10 THEN
      	LCDOUT $FE,$80, "DS 18S20/1820"
      	PAUSE 2000
    ' DS 18B20 Config
      IF FAM = $28 THEN
       	LCDOUT $FE,$80, 				"DS 18B20     "
     	OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_bit]    'Skip ROM search and write N_bits
      	'                                                 resolution to scratch pad
    'DS 18B20 PAR Test
    	HIGH DQ
    	PAUSE 10							'Keep DQ High for 10 ms
    	INPUT DQ
      	PAUSE 2000
    ' Show CRC and FAM
    ' Show ID
      LCDOUT $FE,$C0," ID:",HEX2 ID[1],HEX2 ID[2],HEX2 ID[3],HEX2 ID[4],HEX2 ID[5],HEX2 ID[6]
      PAUSE 2000
    ' Clear Screen
      LCDOUT $FE,1
    MainLoop:
    ' Select and Save Function
     If Mode_B=0 then                      ' Mode switch pressed
      Pause 50                              ' Debounce
      LcdOut $FE, $8F, "*"                  ' Show that command is accepted
      If Mode_B=0 then MainLoop            ' Wait until button is released
      Mode=Mode+1                           ' Increment mode
      If Mode=2 then                        ' Save Target Temperature (Mode1 -> Mode2)
    	   WRITE 0,TargetTemp / 256  		' TargetTemp MSB
    	   WRITE 1,TargetTemp MOD 256       ' TargetTemp LSB
      EndIf
      If Mode > 2 Then                      ' Save Hysteresis (Mode 2 -> Mode 0)
    	   Mode=0               		' Only 0, 1, 2 are valid
    	   WRITE 2, Hyst / 10                ' Divide Hyst value to fit in Byte
      EndIf
     EndIf
    ' set Temperature
     If Mode =1 then                        ' Set Target Temperature
      LcdOut $FE, $80, "SET TEMPERATURE "   ' Show function
      V=TargetTemp                          ' TargetTemp in V
      Gosub SelectSign                      ' Select +/blank/-
      Gosub DisplayTemp                     ' Display Target Temperature
      If (UP_B=0) Or (DOWN_B=0) then    ' Up or Down button pushed
    ' Decrease set Temp
       If DOWN_B=0 then                    ' Down button
        If TargetTemp > 7500 then           ' Not lower than -25 C. (10000-MinTemp * 100)
         TargetTemp=TargetTemp-25           ' Decrease temperuture with 0.25 C.
        EndIf
       EndIf
    ' Increase set Temp
       If UP_B=0 then                    ' Up button
        If TargetTemp < 17500 then          ' Not higher than 75 C. (10000+MaxTemp * 100)
         TargetTemp=TargetTemp+25           ' Increase temperature with 0.25 C.
        EndIf
       EndIf
    ' Display set Temp
       GoSub SetTargetTemp                  ' Display TargetTemp and delay 0.25 Sec.
      EndIf
     EndIf
    ' Set Hysteresis
     If Mode=2 then                         ' Set Hysteresis
      LcdOut $FE, $80, "HYSTERESIS      "   ' Show function
      Sign=" "                              ' No sign
      V= 10000+Hyst                         ' Set value for V
      Gosub DisplayTemp                     ' Display Hysteresis
      If (UP_B=0) Or (DOWN_B=0) then    ' Up or down button pushed
       Sign=" "                             ' No sign for Hysteresis
    ' Decrease Hysteresis
        If Hyst > 10 then Hyst=Hyst-10      ' Not less than 0.1 C.
       EndIf
    ' Increase Hysteresis
        If Hyst < 1000 then Hyst=Hyst+10    ' Not more than 10.0 C.
       EndIf
    ' Scale and show Hysteresis
       Pause 250                            ' Delay 0.25 Sec.
      EndIf
     EndIf
    ' Wait for End setting
     If Mode > 0 then Mainloop              ' Setting TargetTemperature or Hysteresis
     LcdOut $FE, $80, "  TEMPERATURE   "    ' Show function
    ' Sensor Presence Test
     LOW DQ										' OneWire line Low
     PauseUs 480                           		' Keep down for 480 µS
     Input DQ                               	' Make Pin Input
     PauseUs 70                             	' Wait 70 µS
     If DQ then                           		' No presence pulse from DS1820
      	LcdOut $FE, $1,  "** No sensor! **"  	' Show message
     	Disable_out = 1
      	Pause 500                             	' Wait 0.5 Sec.
      	Goto MainLoop                         	' Check again
     Endif
     Pauseus 400								' Wait 400µs more and see
     IF DQ = 0 THEN
      	LcdOut $FE, $1, " sensor shorted!"    	' Show message
      	Disable_out = 1
     Endif
     Disable_out = 0							' Sensor Ok : Output allowed
    ' Temp reading
     OWOut DQ, 1, [$CC, $44 ]       		' Start temperature conversion
     WaitBit = 1							' Show conversion ON
    ' REPEAT
    ' OWIn DQ, 4, [Busy] ' Check for still busy converting
    ' UNTIL BUSY
    ' DS18B20 PAR Test
    HIGH DQ
    PAUSE ( 1000 - Cadence )
    INPUT DQ
     WaitBit = 0
    ' Conversion completed
     OWOUT   DQ, 1, [$CC, $BE ]                       ' Skip ROM search & read scratchpad 														memory
     OWIN    DQ, 2, [Temperature.Lowbyte, Temperature.Highbyte]'READ two bytes / end comms
     PAUSE Cadence 									' 1 Measure/s !!!
    ' Temperature Calculation
    Convert_Temp:
    IF FAM = $10 THEN Temperature = Temperature * 8
    	IF Temperature.15 THEN
    	 	Temperature = ~Temperature + 1
    		Twist = 1
        TempC =  ( Temperature & $7FF ) >> 4   				' Partie Entière '4
        Float = ((Temperature.Lowbyte & $0F ) * 25 )>> 2    ' Partie décimale 100èmes
        Temperature = TempC*100 + Float						'Préparation 1/100 degrés
     IF Twist THEN
      V= 10000 - Temperature                ' 25 C=12500  0 C=10000  -10 C=9000
      Twist = 0
      V= 10000 + Temperature
     EndIf
    ' Offset Correction for DS 1820
     IF FAM = $10 THEN V = V + Offset
    ' Show status
    IF NOT Disable_out THEN
     If V < TargetTemp - Hyst then          ' Below Target temperature - Hysteresis
      Heat=1                           ' Activate   Warm Output
      Cool=0                             ' Deactivate Cold Output
     EndIf
     If V > TargetTemp + Hyst then          ' Above Target temperature + Hysteresis
      Heat=0                             ' Deactivate Warm output
      Cool=1                             ' Activate   Cold Output
     EndIf
     GoSub SelectSign                       ' +/blank/- Sign
     GoSub DisplayTemp                      ' Temperature to LCD
    Else
     Heat = 0 : Cool = 0
    Endif
    Goto MainLoop				' Do it forever
    ' SUBROUTINES
    SelectSign:
     If v = 10000 then                      ' Temperature = 0 C.
      Sign=" " 								' No sign
     Else
      If v < 10000 then              		' <> 0
       Sign="-"								' Temperature below 0 C.
      Else
       Sign="+"				' Temperature above 0 C.
      EndIf
     EndIf
    DisplayTemp:
     If V >= 10000 then                     ' Above 0 C.
      Temperature = V-10000
     Else
      Temperature = 10000-V                   ' Below 0 C.
     EndIf
     LcdOut $FE, $C0,"    ", Sign, DEC (Temperature / 100), ".", DEC2 Temperature,178,"C "
    SetTargetTemp:
     V=TargetTemp
     Gosub SelectSign
     Gosub DisplayTemp
     Pause 250
    I ran it aboard an EasyPic 5 Board ... but connections are described in the beginning of the listing ...
    Alabama,USA
    Got it working
    Thanks Ace
  1. 1Wire serial EEPROM, DS28EC20 and similar, any experience?
    Last Post: - 9th January 2022, 21:27
  2. Problems with CRC8 Calc in 1Wire
    By JohnB in forum mel PIC BASIC Pro
    Last Post: - 16th March 2007, 22:01
  3. conversion
    By pramodsinha in forum Forum Requests
    Last Post: - 19th January 2006, 15:58
  4. ºC -> ºF Conversion
    By CocaColaKid in forum General
    Last Post: - 15th March 2005, 09:42
  5. enumerate 1wire bus
    By justDIY in forum mel PIC BASIC Pro
    Last Post: - 30th June 2004, 19:19
