1Wire conversion
Results 1 to 9 of 9
    Alabama,USA
    Default 1Wire conversion
    I am working with a pair of DS1820 temperature sensors. I need to display the temperature on a Sure 0832 dot matrix display. This means I need to take the DS1820 output and break it into each decimal digit of the resulting temperature. The 1Wire output is in 16 bit sign-extended 2,s complement number. I’m not sure about the best approach to this problem.
    I could shift off bit 0-3 and have the next eight bits Binary if the S bit is 0. then I would have to convert to Decimal or use a lookup table. Once in Decimal I must breakout each digit of the number to send it to the display. This makes me wonder how PBP3 handles this conversion in “lcdout” to display in decimal. Is there a better method. Comments Please!
    Wayne
    Default Re: 1Wire conversion
    first off there are ds18s20 and ds18b20 devices each would need slightly different treatment.
    then you need to decide the resolution and "sign" you wish to display.
    if negative[below zero] temps are involved the the sign bit of the result must be properly accommodated before results are scaled.
    once you have a unsigned scaled binary result pbp can extract the digits with the DIG function.
    the digits can then be displayed along with the sign and decimal point if needed as you desired.
    Alabama,USA
    Thanks Richard, I had forgotten about the DIG function. Thanks for the reminder, I'll give it a try.
    Alabama,USA
    Continuing with the same project. I have run into this problem many times over the years and I have yet to understand it. Why does this "If Then" statement fail to compile.
        if Bvar = 0 then Cimage
            else Avar = Bvar
            gosub GetImage
    I can rewrite it in any form with the same results. It does not compile.
    I get an error code "Endif without a If...Then statment. It seems like a no brainer but I just don't' understand what I'm doing wrong.
    one of the reasons snippets are fairly useless is that assumptions have to be made, however assuming Cimage is a subroutine
    the correct syntax is
       if Bvar = 0 then
            gosub Cimage
            Avar = Bvar
            gosub GetImage
    Alabama,USA
    Your right as always! Not very forgiving is it. The format doesn't seem to fallow that of other functions.
    thanks Richard
    This one could be useful ...
    '* Universal thermostat -25/+75 C.  by R.T.G. van Steenis                  *
    '* Compiler : PicBasic Pro 2.45                                            *
    '* B0 = Mode switch in (In)            A0 = LCD Enable    (Out)            *
    '* B1 = + switch in    (In)            A1 = LCD RS        (Out)            *
    '* B2 = - switch in    (In)            A2 = "Warm" Output (Out)            *
    '* B3 = Not connected  (Out)           A3 = "Cold" Output (Out)            *
    '* B4 = LCD Bit 4      (Out)           A4 = DQ DS1820     (In)             *
    '* B5 = LCD Bit 5      (Out)                                               *
    '* B6 = LCD Bit 6      (Out)                                               *
    '* B7 = LCD Bit 7      (Out            PIC16F877A Code size = 1966 Words   *
    '* Oscillator XT (4 MHz.) - Power up timer enabled - MCR enable            *
    '*                  LCD Defines for EasyPic5 & 16F877A                                *
    '@ ERRORLEVEL -306
    '@ __config _HS_OSC & _WDT_ON & _PWRTE_ON & _BODEN_ON & _LVP_OFF & _CP_OFF
    '    DEFINE LCD_DREG PORTB               ' I/O port where LCD is connected
    '    DEFINE LCD_DBIT 0
    '    DEFINE LCD_RSREG PORTB
    '    DEFINE LCD_RSBIT 4                  ' Register select pin
    '    DEFINE LCD_EREG PORTB
    '    DEFINE LCD_EBIT 5                   ' Enable pin
    '    DEFINE LCD_BITS 4                   ' 4-bit data bus
    '    DEFINE LCD_LINES 2                  ' LCD has 2 character lines
    '    DEFINE OSC 8
    '    DEFINE BUTTON_PAUSE 100
    ''Pinout for EasyPic5
    '	Heat			Var PORTC.0
    '	Cool 			Var PORTC.2
    '	Waitbit			Var PortC.4
    '    DQ				Var	PORTE.2		' One-wire data pin
    '    Mode_B			Var PORTA.0		'Pullups ...
    '    UP_B			Var PORTA.1
    '    DOWN_B			Var PORTA.2
    ''Configs EasyPic5
    'ADCON1 = 7			          	' Set PORTD and PORTE to digital
    'CMCON  = 7						' Comparators OFF
    'PORTA = %00000111
    'PORTB = 0
    'PORTC = 0
    'PORTD = 0
    'PORTE = 0
    'TRISA = %00000111
    'TRISB = 0
    'TRISC = 0
    'TRISD = 0
    'TRISE = %00000100
    ' Elektor LCD Defines
    @ __CONFIG _XT_OSC & _WDT_ON & _PWRTE_ON & _MCLRE_ON & _BODEN_OFF & _LVP_OFF & _CP_OFF
    DEFINE LCD_DREG PORTB                   ' LCD on port B
    DEFINE LCD_DBIT 4                       ' Data bits B4..B7
    DEFINE LCD_RSREG PORTA                  ' RS on PORTA
    DEFINE LCD_RSBIT 1                      ' RS on A1
    DEFINE LCD_EREG PORTA                   ' E on PORTA
    DEFINE LCD_EBIT 0                       ' E on A0
    DEFINE LCD_BITS 4                       ' LCD 4 bit mode
    DEFINE LCD_LINES 2                      ' 2 line LCD display
    'Pinout for Elektor
    Heat			Var PORTA.2
    Cool 			Var	PORTA.3
    DQ				Var	PORTA.4		' One-wire data pin
    Mode_B			Var PORTB.0
    UP_B			Var PORTB.1
    DOWN_B			Var PORTB.2
    ' I/o Settings
    PORTA = 0
    PORTB = 0
    TRISA= %11110000                        ' RA0..3=Outputs RA4=Input
    TRISB= %00000111 			' RB0..RB2=Inputs, RB3..RB7=Outputs
    CMCON=7                                 ' Disable comparators
    ' Variables
    Temperature 	Var	Word		' Temperature storage
    TempC			Var Word
    Float			Var Word
    TargetTemp		Var	Word		' Desired Temperature
    Hyst			Var	Word		' Hystereris
    V				Var	Word		' Var. for display
    Cadence 		Var Word
    B1              Var Byte            ' Byte for TargetTemp calculation
    B2              Var Byte            ' Byte for TargetTemp calculation
    Sign			Var	Byte		' +/- sign
    Mode 			Var	Byte		' 0=Temp. display, 1=Set Temp, 2=Set Hysteresis
    DS18B20_Bit		Var Byte
    FAM				Var Byte
    CRC				Var Byte
    ID				Var Byte[7]
    Twist			Var Bit
    Busy			Var Bit
    Disable_out		Var Bit
    ' Resolution
    'DS18B20_9bit  	CON %00011111   	' 93.75ms, 0.5°C
    'DS18B20_10bit 	CON %00111111   	' 187.5ms, 0.25°C  <-- My favorite
    'DS18B20_11bit 	CON %01011111   	' 375ms,   0.125°C
    'DS18B20_12bit 	CON %01111111   	' 750ms,   0.0625°C  (default)
    Resolution  CON 12
    Offset		CON 300
    'Initialization
     SELECT CASE Resolution
     	Case 9
     		 DS18B20_bit = %00011111   	' 93.75ms, 0.5°C
     		 Cadence = 900
     	Case 10
    		 DS18B20_bit = %00111111   	' 187.5ms, 0.25°C  <-- My favourite
    		 Cadence = 810
    	Case 11
    		 DS18B20_bit = %01011111   	' 375ms,   0.125°C
    		 Cadence = 625
    	Case 12
    		 DS18B20_bit = %01111111   	' 750ms,   0.0625°C  (default)
    		 Cadence = 250
    END SELECT
    DATA 46, 224, 20                        ' Temp MSB, TEMP LSB, Hysteresis DIV 10
    Heat=0                               ' Warm Output Low
    Cool=0                               ' Cold Output Low
    Disable_out = 1
    Mode=0                                  ' Temperature display mode
    Twist = 0
    ' Program start
    PAUSE 500
    READ 0, B1                              'READ TargetTemp MSB
    READ 1, B2                              'READ TargetTemp LSB
    TargetTemp=B1*256+B2                    ' Calculate TargetTemp value (Default=20.0 C.)
    READ 2, B1                              'READ Hysteresis
    Hyst=10*B1                              ' Calculate Hysteresis value (Default= 2.0 C.)
    LCDOUT $FE, 1, $FE, $0C                 ' Clear display, cursor off
    PAUSE 250
    SensID:' Sensor Identification
      OWOUT DQ, 1, [ $33 ]								'READ Chip Family code
      OWIN  DQ, 2, [ FAM,ID[6],ID[5],ID[4],ID[3],ID[2],ID[1],CRC]
      IF FAM = $05 THEN
       	LCDOUT $FE,$80, "DS 2405     "
      	PAUSE 1000
      	LCDOUT $FE,$80, 				" CRC: ",HEX2 CRC," FAM: ", HEX2 FAM
    ' DS 1820 / DS 18S20
      IF FAM = $10 THEN
      	LCDOUT $FE,$80, "DS 18S20/1820"
      	PAUSE 2000
    ' DS 18B20 Config
      IF FAM = $28 THEN
       	LCDOUT $FE,$80, 				"DS 18B20     "
     	OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_bit]    'Skip ROM search and write N_bits
      	'                                                 resolution to scratch pad
    'DS 18B20 PAR Test
    	HIGH DQ
    	PAUSE 10							'Keep DQ High for 10 ms
    	INPUT DQ
      	PAUSE 2000
    ' Show CRC and FAM
    ' Show ID
      LCDOUT $FE,$C0," ID:",HEX2 ID[1],HEX2 ID[2],HEX2 ID[3],HEX2 ID[4],HEX2 ID[5],HEX2 ID[6]
      PAUSE 2000
    ' Clear Screen
      LCDOUT $FE,1
    MainLoop:
    ' Select and Save Function
     If Mode_B=0 then                      ' Mode switch pressed
      Pause 50                              ' Debounce
      LcdOut $FE, $8F, "*"                  ' Show that command is accepted
      If Mode_B=0 then MainLoop            ' Wait until button is released
      Mode=Mode+1                           ' Increment mode
      If Mode=2 then                        ' Save Target Temperature (Mode1 -> Mode2)
    	   WRITE 0,TargetTemp / 256  		' TargetTemp MSB
    	   WRITE 1,TargetTemp MOD 256       ' TargetTemp LSB
      EndIf
      If Mode > 2 Then                      ' Save Hysteresis (Mode 2 -> Mode 0)
    	   Mode=0               		' Only 0, 1, 2 are valid
    	   WRITE 2, Hyst / 10                ' Divide Hyst value to fit in Byte
      EndIf
     EndIf
    ' set Temperature
     If Mode =1 then                        ' Set Target Temperature
      LcdOut $FE, $80, "SET TEMPERATURE "   ' Show function
      V=TargetTemp                          ' TargetTemp in V
      Gosub SelectSign                      ' Select +/blank/-
      Gosub DisplayTemp                     ' Display Target Temperature
      If (UP_B=0) Or (DOWN_B=0) then    ' Up or Down button pushed
    ' Decrease set Temp
       If DOWN_B=0 then                    ' Down button
        If TargetTemp > 7500 then           ' Not lower than -25 C. (10000-MinTemp * 100)
         TargetTemp=TargetTemp-25           ' Decrease temperuture with 0.25 C.
        EndIf
       EndIf
    ' Increase set Temp
       If UP_B=0 then                    ' Up button
        If TargetTemp < 17500 then          ' Not higher than 75 C. (10000+MaxTemp * 100)
         TargetTemp=TargetTemp+25           ' Increase temperature with 0.25 C.
        EndIf
       EndIf
    ' Display set Temp
       GoSub SetTargetTemp                  ' Display TargetTemp and delay 0.25 Sec.
      EndIf
     EndIf
    ' Set Hysteresis
     If Mode=2 then                         ' Set Hysteresis
      LcdOut $FE, $80, "HYSTERESIS      "   ' Show function
      Sign=" "                              ' No sign
      V= 10000+Hyst                         ' Set value for V
      Gosub DisplayTemp                     ' Display Hysteresis
      If (UP_B=0) Or (DOWN_B=0) then    ' Up or down button pushed
       Sign=" "                             ' No sign for Hysteresis
    ' Decrease Hysteresis
        If Hyst > 10 then Hyst=Hyst-10      ' Not less than 0.1 C.
       EndIf
    ' Increase Hysteresis
        If Hyst < 1000 then Hyst=Hyst+10    ' Not more than 10.0 C.
       EndIf
    ' Scale and show Hysteresis
       Pause 250                            ' Delay 0.25 Sec.
      EndIf
     EndIf
    ' Wait for End setting
     If Mode > 0 then Mainloop              ' Setting TargetTemperature or Hysteresis
     LcdOut $FE, $80, "  TEMPERATURE   "    ' Show function
    ' Sensor Presence Test
     LOW DQ										' OneWire line Low
     PauseUs 480                           		' Keep down for 480 µS
     Input DQ                               	' Make Pin Input
     PauseUs 70                             	' Wait 70 µS
     If DQ then                           		' No presence pulse from DS1820
      	LcdOut $FE, $1,  "** No sensor! **"  	' Show message
     	Disable_out = 1
      	Pause 500                             	' Wait 0.5 Sec.
      	Goto MainLoop                         	' Check again
     Endif
     Pauseus 400								' Wait 400µs more and see
     IF DQ = 0 THEN
      	LcdOut $FE, $1, " sensor shorted!"    	' Show message
      	Disable_out = 1
     Endif
     Disable_out = 0							' Sensor Ok : Output allowed
    ' Temp reading
     OWOut DQ, 1, [$CC, $44 ]       		' Start temperature conversion
     WaitBit = 1							' Show conversion ON
    ' REPEAT
    ' OWIn DQ, 4, [Busy] ' Check for still busy converting
    ' UNTIL BUSY
    ' DS18B20 PAR Test
    HIGH DQ
    PAUSE ( 1000 - Cadence )
    INPUT DQ
     WaitBit = 0
    ' Conversion completed
     OWOUT   DQ, 1, [$CC, $BE ]                       ' Skip ROM search & read scratchpad 														memory
     OWIN    DQ, 2, [Temperature.Lowbyte, Temperature.Highbyte]'READ two bytes / end comms
     PAUSE Cadence 									' 1 Measure/s !!!
    ' Temperature Calculation
    Convert_Temp:
    IF FAM = $10 THEN Temperature = Temperature * 8
    	IF Temperature.15 THEN
    	 	Temperature = ~Temperature + 1
    		Twist = 1
        TempC =  ( Temperature & $7FF ) >> 4   				' Partie Entière '4
        Float = ((Temperature.Lowbyte & $0F ) * 25 )>> 2    ' Partie décimale 100èmes
        Temperature = TempC*100 + Float						'Préparation 1/100 degrés
     IF Twist THEN
      V= 10000 - Temperature                ' 25 C=12500  0 C=10000  -10 C=9000
      Twist = 0
      V= 10000 + Temperature
     EndIf
    ' Offset Correction for DS 1820
     IF FAM = $10 THEN V = V + Offset
    ' Show status
    IF NOT Disable_out THEN
     If V < TargetTemp - Hyst then          ' Below Target temperature - Hysteresis
      Heat=1                           ' Activate   Warm Output
      Cool=0                             ' Deactivate Cold Output
     EndIf
     If V > TargetTemp + Hyst then          ' Above Target temperature + Hysteresis
      Heat=0                             ' Deactivate Warm output
      Cool=1                             ' Activate   Cold Output
     EndIf
     GoSub SelectSign                       ' +/blank/- Sign
     GoSub DisplayTemp                      ' Temperature to LCD
    Else
     Heat = 0 : Cool = 0
    Endif
    Goto MainLoop				' Do it forever
    ' SUBROUTINES
    SelectSign:
     If v = 10000 then                      ' Temperature = 0 C.
      Sign=" " 								' No sign
     Else
      If v < 10000 then              		' <> 0
       Sign="-"								' Temperature below 0 C.
      Else
       Sign="+"				' Temperature above 0 C.
      EndIf
     EndIf
    DisplayTemp:
     If V >= 10000 then                     ' Above 0 C.
      Temperature = V-10000
     Else
      Temperature = 10000-V                   ' Below 0 C.
     EndIf
     LcdOut $FE, $C0,"    ", Sign, DEC (Temperature / 100), ".", DEC2 Temperature,178,"C "
    SetTargetTemp:
     V=TargetTemp
     Gosub SelectSign
     Gosub DisplayTemp
     Pause 250
    I ran it aboard an EasyPic 5 Board ... but connections are described in the beginning of the listing ...
    Alabama,USA
    Got it working
    Thanks Ace
  1. 1Wire serial EEPROM, DS28EC20 and similar, any experience?
    Last Post: - 9th January 2022, 22:27
  2. Problems with CRC8 Calc in 1Wire
    By JohnB in forum mel PIC BASIC Pro
    Last Post: - 16th March 2007, 23:01
  3. conversion
    By pramodsinha in forum Forum Requests
    Last Post: - 19th January 2006, 16:58
  4. ºC -> ºF Conversion
    By CocaColaKid in forum General
    Last Post: - 15th March 2005, 10:42
  5. enumerate 1wire bus
    By justDIY in forum mel PIC BASIC Pro
    Last Post: - 30th June 2004, 20:19
