Low frequency Hardware PWM
Results 1 to 8 of 8
    Default Low frequency Hardware PWM
    Is it possible to have 50Hz PWM with any PIC?
    I think Alain mentioned that CCP module could do that but have no clue how.
    Default Re: Low frequency Hardware PWM
    what chip what osc ?
    a 16f18426 can do it @8mhz
    a 18f27q43 can do it at any fosc
    k42 family is a likely candidate too
    I will not stick to specific PIC.
    Any one that can do it is OK with me. K42 is most likely the one.
    Thanks Richard,
    Are you talking PWM or HPWM? Isn't using the CCP module automatically HPWM?
    I kept hitting my face into the chart in the PBP manual under HPWM that lists lowest possible frequency per oscillator speed. Even at 4MHz it's a minimum 245Hz (I'm not really interested in PWM).
    How are you folks getting around that? Assembler?
    its not quite that simple, contemporary chips like 18f27q43 have a pwm module that can use alternative clock sources like the mfosc @[500k] and its that allows 50hz operation, some others have much bigger timer2 type prescalers that can get there in a pinch too
    i doubt the hpwm command can select the alternative clock/prescaler so some manual intervention will be needed. its not rocket science and if you plug it into MCC it does all the heavy lifting
    My interest is in hardware PWM but PBP cannot manipulate the appropriate registers that is needed to get that low on frequency, as Richard noted.
    Have not done it yet but hope to manage it.
    Jan 2011
    Sydney, Australia
    You might consider using the Numerically Controlled Oscillator (NCO) to achieve this low frequency output.
    I have recently been looking at the 16F1503 to achieve a stable 1Hz output.
    This device has the ability to do both 50% duty cycle (my particular interest) as well as PWM output.
    Agreed, this is not something that is doable directly from PBP commands but is quite manageable with register manipulation.
    Cheers
    Barry
    Thanks Barry.
    Never thought of that NCO.
  1. Low frequency generator
    Last Post: - 29th September 2013, 21:53
  2. HPWM at very low frequency
    Last Post: - 9th May 2013, 08:41
  3. Low frequency PWM
    By Charlie in forum General
    Last Post: - 16th February 2011, 14:31
  4. Low-Frequency Counter
    By Zeke in forum General
    Last Post: - 19th January 2006, 18:06
  5. Low frequency output
    By barkerben in forum General
    Last Post: - 16th November 2004, 15:25
