18f25k22 hserin
+ Reply to Thread
Results 1 to 18 of 18
Thread: 18f25k22 hserin
    Jan 2022
    Default 18f25k22 hserin
    Hello,
    I've tried to use the Hserin with no success, let me explain,
    I used the example from the PBP3 compiler reference manual p:150
    and scanning with hand barcode scanner nothing show or random character show up on the serial terminal.
    the scanner is set at 9600,8,1,n and it's working on other application
    I'm looking for the code to wait until I scan a code then it send to a serial port and come back waiting for the next scan.
    is there someone who can help.
    thanks to everyone
    ' Name  : Hserin Test  (18F25K22)
    ' Serout Baud rate: 188:4800,84:9600,49:14400,32:19200,15:28800,6:38400  'ok
    ' Serout : p296,297
    ' 9600 Open Inverted None 49236
    ' HSERIN [WAIT("!"), STR MyArray\200, STR MyArray(200)\200, _
    ' STR MyArray(400)\200, STR MyArray(600)\100]
     Include "modedefs.bas" ' Include serial modes
    ;----[18F25K22 Hardware Configuration]------------------------------------------
      CONFIG  FOSC = INTIO67
      CONFIG  PLLCFG = On
      CONFIG  WDTEN = Off
      CONFIG  MCLRE = INTMCLR
      CONFIG  LVP = Off
        ANSELA = 0  ; All Digital
        ANSELB = 0
        ANSELC = 0
    DEFINE OSC 64
    TRISA = 111111    '1:IN, 0:OUT
    TRISB = 111110
    TRISC = 111111
    OSCCON = $70
    OSCTUNE = $40
    ' Set receive register to receiver enabled
    DEFINE HSER_RCSTA 90h
    DEFINE HSER2_RCSTA 90h
    ' Set transmit register to transmitter enabled
    DEFINE HSER_TXSTA 20h
    DEFINE HSER2_TXSTA 20h
    ' Set baud rate
    DEFINE HSER_BAUD 9600
    DEFINE HSER2_BAUD 9600
    DEFINE HSER_CLROERR 1
    AArray VAR BYTE[12]
    BArray VAR BYTE[12]
    ' code to scan sample : 0 59749 96859 1
    MAIN:
    HSERIN [wait ("0"), str AArray\12]
    serOut2 PORTB.0,84, [str BArray\12,13,10]
    GoTo MAIN
    Miami, Florida USA
    Default Re: 18f25k22 hserin
    I don't have the manual in front of me now, but I think that you are missing some parameters in the HSERIN command.
    Anonymous
    Jan 2022
    the manual is in PDF format.
    Let me know what is missing when you can.
    from the data sheet only 3 setup as to be done for receiving.
    thank you
    Miami, Florida USA
    Anonymous
    Miami, Florida USA
    Also, HSERIN starts saving the variables after the WAIT requirement has been met. In your case, it will only save 11 numbers instead of 12.
    MAIN:
    HSERIN [wait ("0"), str AArray\11]
    Anonymous
    Jan 2022
    Thanks for your time, I'll look at it, also I did used a timeout label (hserin 5,MAIN,[STR AARRAY\12])
    still no result.
    Thanks again.
    Jan 2022
    I rectified it (hserin 5,MAIN,[STR AARRAY\12])
    Jan 2022
    here's the code from today post:
    Works ok for me if BArray has something printable placed in it
    perhaps u wired it up incorrectly
    Jan 2022
    even this
    MAIN:
    serOut2 PORTB.0,84, [str aarray\12,13,10]
    GoTo MAIN
    ....."0" is decimal 48
    Jan 2022
    thanks to everyone involved to help me on this project.
    I tried about every way to setup the HSerin1,2
    still not working.
    I'm realy suprise since these HSerin command are part of PBP3 for at least 15 years
    and today in 2025 cannot find any reliable sample codes.
    even the PBP3 examples does not work at all for my setup.
    I had 1 rs232/ttl scanner bad (intermitent power on the rs232 rail)
    connected another one and the only easy way to make work it's
    with the code below.
    MAIN:
    serin2 PORTB.0,84,50,MAIN,[STR AARRAY\12]
    serOut2 PORTB.1,84, [str aarray\12,13,10]
    serOut2 PORTB.1,84, ["Done!",13,10]
    GoTo MAIN
    works as expected
    only slight change was to move serout to portb.7 to suit my pickit2 debug uart tool and put something printable
    into BArray
    '-------------------------------------------------------------------------' Name  : Hserin Test  (18F25K22)
    ' Serout : p296,297
      CONFIG  PLLCFG = On
      CONFIG  WDTEN = Off
      CONFIG  LVP = Off
        ANSELB = 0
        ANSELC = 0
    DEFINE OSC 64
    TRISA = % 11111111    '1:IN, 0:OUT
    TRISB = % 11111111
    TRISC = % 11111111
    OSCCON = $70
    OSCTUNE = $40
    ' Set baud rate
    AArray VAR BYTE[12]
    BArray VAR BYTE[12]
     ARRAYWRITE BARRAY,["GOT IT",0]
    MAIN:
    serOut2 PORTB.7,84, [str BArray,13,10]
    GoTo MAIN
    what doesn't work are code snippets and failure to provide connection details [ schematic]
    and even a description of what happens versus what you expect to happen
    more useful would be
    ' Serout : p296,297
      CONFIG  PLLCFG = On
      CONFIG  WDTEN = Off
      CONFIG  LVP = Off
        ANSELB = 0
        ANSELC = 0
    DEFINE OSC 64
    TRISB = % 11111111
    TRISC = % 11111111
    OSCCON = $70
    OSCTUNE = $40
    ' Set baud rate
    AArray VAR BYTE[12]
    BArray VAR BYTE[12]
    MAIN:
    hserout ["got", str AArray\12 ,13,10]
    GoTo MAIN
    Jan 2022
    Hello everyone, and thank to all for helping me
    this case is solved!
    1st
    the GM65 scanner Tx/Rx line are at 3.3v not at standard 5V TTL logic, so I add a BSS138 between the Tx and the Rx (HSerin) of the PIC
    2nd
    I like to thank also BrianS (HSERIN issue with a 18F452 and IF THEN statements or Case statements)
    while reading about his case I took part of the HSerin setup and added to my program, first try work just fine on HSerin/HSerin2.
      CONFIG  PLLCFG = ON
      CONFIG  WDTEN = Off
      CONFIG  LVP = Off
    RCSTA = $90
    TXSTA = $20
    DEFINE HSER2_CLROERR 1
    RCSTA2 = $90
    TXSTA2 = $20
       ANSELB = 0
       ANSELC = 0
    DEFINE OSC 64
    TRISA = 111101    '1:IN, 0:OUT
    TRISB = 000001
    TRISC = 111101
    OSCCON = $70
    OSCTUNE = $40
    AArray VAR BYTE[12]
    MAIN:
    HSERIN 50,MAIN,[STR AARRAY\12]
    'HSERIN2 50,MAIN,[STR AARRAY\12]
    GoTo MAIN
    Name:  BSS138 CIRCUIT FROM SPARKFUN.png
    Jan 2022
    Many thanks richard.
    Take care.
    No code error , no compiler deficiency. as suggested in post #9 its wired incorrectly
    who would have known
    Jan 2022
    Specialy when the GM65 user manual mention TTL logic level, yes the DC supply is 5V, for the USB / UART ports.
    but it's not specify 3.3V Tx/Rx output line.
    Learning everyday like everyone here.
  1. Hserin
    By Dinoden in forum mel PIC BASIC Pro
    Last Post: - 13th December 2016, 04:16
  2. 18F25K22 Help
    By ERMEGM in forum mel PIC BASIC Pro
    Last Post: - 25th November 2014, 10:36
  3. migration from 16F876a to 18F25k22
    By MOUNTAIN747 in forum General
    Last Post: - 19th March 2012, 21:33
  4. Config 18F25K22
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 26th April 2011, 19:08
  5. hserin
    By jcleaver in forum mel PIC BASIC Pro
    Last Post: - 21st February 2007, 18:15
Members who have read this thread : 13
