I/O Pin status during startup
+ Reply to Thread
Results 1 to 19 of 19
    Jul 2024
    Default I/O Pin status during startup
    Hi guys,
    quick question...
    Is there a way (somewhere on the datasheet for example) to know what are the I/O pins state during power up?
    I've noticed that some I/O pins (on my 18F2580 MCU) start high even placing "clear" and "PORTA=000000, PORTB=000000, PORTC=000000) at the start of the code (when i say start, i mean after all the configuration lines).
    I currently have the "INCLUDE "ALLDIGITAL.pbp"" before the actual code start.
    How can I force all the I/Os to be low until the code tells them to go high?
    Default Re: I/O Pin status during startup
    no defined I/Os state before you set it ...
    the one and only way is an external pull up or down resistor, as I/Os are placed in an INPUT state ( High impedance ) @ power up ...
    moreover, you have to manually set input state before some PBP Commands ( pulsin, RC Time, Toggle ... ) to be sure of what you get.
    Jul 2024
    Hi Acetronics2,
    thanks for your reply.
    To be accurate, during power on, these I/Os turn on and off (and then stay off) very quickly (like a flash). The idea is to stop that high-low behavior.
    Bombay, India
    Quote Originally Posted by PaulMaker View Post
    Hi
    Simple answer- you cannot do that.
    You should design your project with active low outputs to account for the High-Z input state at power on. Almost every microcontroller, I know, behaves similarly unless there is special hardware built in to retain a certain state at power on. Till such time as your program code runs, the microcontroller IO pins are kept in a High-Z state to prevent unintentional damage to itself.
    Jul 2024
    Greetings,
    thank you Jerson for your reply.
    Regarding "design your project with active low outputs to account for the High-Z input state at power on", what do you mean exactly?
    If, for example, I only have LEDs on these I/Os, what can I do?
    if you have leds that illuminate on power up before the pins have been set as outputs then you are doing something very odd
    or you have broken something
    schematic and code ?
    Yeah, this sounds very strange.
    As others have said, after power on and reset (POR) all the pins come up as inputs so they should not go either high or low for any duration. Leakage current into the pin is MUCH less than a uA (200nA max) so basically "any" sort of resistance (ie several mega Ohms) to either Vdd or Vss will pull the pin to that.
    And it doesn't really matter what you do with the PORT or LAT registers until you also clears the TRIS bits in questions. Ie, at power up the pins are inputs (high impedence), then you "preset" their default state(s) by writing to PORT or LAT and finally you clear the corresponding TRIS bits to enable the output drivers.
    The 18F2580 have pull-ups on PORTB (and PORTB only it seems). They are disabled on POR so they should not be able to pull the pin high. The current sourced thru the pull-up resistor is between 50 and 400uA so even WITH them enabled I don't think you'd see a LED light up.
    More details please...
    Bombay, India
    Greetings,
    Many a times, I have used an I/O pin to drive a relay through a transistor. So, assuming I need an active high output to turn on the relay, I have observed (across microcontroller families) that the relay flicks on for the fraction of a second till the program code takes control and the pin get set to the off - state of the relay (0). So, the ideal way to resolve such a situation is to ensure that the relay turns on only when the I/O pin is made to output a LOW.
    In case of driving an LED from an IO pin, my thinking is biased with the TTL logic output specificiation where the sinking current limit is larger than the sourcing current limit. So, I usually tend to use LEDS with an active low output configuration. The IO port has to be low for the LED to turn on. This spec thing is no longer true with the current generation of microcontrollers except the 8051 family dies from old.
    So, as a best practice, I tend to use active low outputs for any device that needs to be turned on.
    I Never saw something like that ....
    but, if we consider LEDs as current generators when illuminated ( Yes, the built in input clamp diodes ... )
    the question comes ... is the pic in a true OFF state @ "powerup" ???
    THE ONE and ONLY thing to have here is ...
    SHOW US the full Pic program ( with config ! ) and the Circuit real scheme.
    already asked for @ #6 !!!
    Jul 2024
    Greetings all,
    thank you all for your inputs.
    Here is the code:
    '****************************************************************'*  Name    : Led Controller.PBP                                *
    '*  Author  : Paul Maker                                        *
    '*  Notice  : Copyright (c) 2024 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 19/12/2024                                        *
    '*  Notes   : 18F2580                                           *
    ;----[18F2580 Hardware Configuration]-------------------------------------------
    #IF __PROCESSOR__ = "18F2580"
      #DEFINE MCU_FOUND 1
      CONFIG  OSC = IRCIO67      ; Internal oscillator block, port function on RA6 and RA7
      CONFIG  FCMEN = OFF        ; Fail-Safe Clock Monitor disabled
      CONFIG  IESO = OFF         ; Oscillator Switchover mode disabled
      CONFIG  PWRT = OFF         ; PWRT disabled
      CONFIG  BOREN = OFF        ; Brown-out Reset disabled in hardware and software
      CONFIG  BORV = 3           ; VBOR set to 2.1V
      CONFIG  WDT = OFF          ; WDT disabled (control is placed on the SWDTEN bit)
      CONFIG  WDTPS = 512        ; 1:512
      CONFIG  PBADEN = OFF       ; PORTB<4:0> pins are configured as digital I/O on Reset
      CONFIG  LPT1OSC = OFF      ; Timer1 configured for higher power operation
      CONFIG  MCLRE = OFF        ; RE3 input pin enabled; MCLR disabled
      CONFIG  STVREN = ON        ; Stack full/underflow will cause Reset
      CONFIG  LVP = OFF          ; Single-Supply ICSP disabled
      CONFIG  BBSIZ = 1024       ; 1K words (2K bytes) boot block
      CONFIG  XINST = OFF        ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
      CONFIG  DEBUG = OFF        ; Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
      CONFIG  CP0 = OFF          ; Block 0 (000800-001FFFh) not code-protected
      CONFIG  CP1 = OFF          ; Block 1 (002000-003FFFh) not code-protected
      CONFIG  CP2 = OFF          ; Block 2 (004000-005FFFh) not code-protected
      CONFIG  CP3 = OFF          ; Block 3 (006000-007FFFh) not code-protected
      CONFIG  CPB = OFF          ; Boot block (000000-0007FFh) not code-protected
      CONFIG  CPD = OFF          ; Data EEPROM not code-protected
      CONFIG  WRT0 = OFF         ; Block 0 (000800-001FFFh) not write-protected
      CONFIG  WRT1 = OFF         ; Block 1 (002000-003FFFh) not write-protected
      CONFIG  WRT2 = OFF         ; Block 2 (004000-005FFFh) not write-protected
      CONFIG  WRT3 = OFF         ; Block 3 (006000-007FFFh) not write-protected
      CONFIG  WRTC = OFF         ; Configuration registers (300000-3000FFh) not write-protected
      CONFIG  WRTB = OFF         ; Boot block (000000-0007FFh) not write-protected
      CONFIG  WRTD = OFF         ; Data EEPROM not write-protected
      CONFIG  EBTR0 = OFF        ; Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTR1 = OFF        ; Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTR2 = OFF        ; Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTR3 = OFF        ; Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTRB = OFF        ; Boot block (000000-0007FFh) not protected from table reads executed in other blocks
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    OSCCON =%01110000
    OSCTUNE=%11000000
    DEFINE OSC 8
    DEFINE SHOWDIGITAL 1
    INCLUDE "modedefs.bas"
    'DEFINE DEBUGIN_REG PORTB
    'DEFINE DEBUGIN_BIT 5
    'DEFINE DEBUGIN_BAUD 1200
    'DEFINE DEBUGIN_MODE 0
    TRISA = %00000000
    TRISB = %00100000
    TRISC = %00000000
    'PORTS & PINS
    LED1			var		PORTC.1 'IC5
    LED2 			var		PORTC.2 'IC5
    LED3			var		PORTC.0 'IC5
    LED4			var		PORTA.6 'IC5
    LED5			var		PORTB.4 'IC5
    LED6			var		PORTA.7 'IC5
    LED7 			var 	PORTB.0 'IC5
    LED8 			var		PORTB.1 'IC5
    LED9 			var		PORTB.2 'IC5
    LED10 			var		PORTB.3 'IC5
    LED11			var		PORTC.3 'IC5
    LED12			var		PORTC.4 'IC5
    LED13			var		PORTC.5 'IC5
    LED14			var		PORTC.6 'IC5
    LED15			var		PORTC.7 'IC5
    LED16			var		PORTA.5 'IC5
    LED17			var		PORTA.4 'IC5
    LED18			var		PORTA.3 'IC5
    LED19			var		PORTA.2 'IC5
    LED20			var		PORTA.1 'IC5
    LED21			var		PORTA.0 'IC5
    LED22			var		PORTB.7 'IC5
    LED23			var		PORTB.6 'IC5
    IC_RX			var		PORTB.5	'IC5 INPUT
    CT					VAR		BYTE
    CT					VAR		BYTE
    PA1   				VAR 	WORD
    PA2   				VAR 	WORD
    PA3   				VAR 	WORD
    PA4   				VAR 	WORD
    INIT:
    clear
    PORTA=%00000000
    PORTB=%00000000
    PORTC=%00000000
    TRISB.5=1
    PA1=300
    PA2=600
    PA3=900
    PA4=1500
    CT=0
    CT2=0
    START:
    pause 400
    high LED3
    high LED4
    pause 1600
    high LED10
    high LED15
    pause PA4
    high LED1
    high LED2
    high LED6
    HIGH LED16
    PAUSE 600
    PAUSE PA4
    GOTO ANIM
    ANIM:
    high LED9
    high LED14
    PAUSE PA3
    high LED8
    high LED13
    PAUSE PA3
    LOW LED13
    PAUSE PA3
    HIGH LED7
    PAUSE PA3
    LOW LED7
    HIGH LED13
    PAUSE PA3
    PAUSE PA3
    PAUSE PA3
    LOW LED8
    PAUSE PA3
    LOW LED13
    PAUSE PA3
    PAUSE PA3
    PAUSE PA3
    HIGH LED8
    HIGH LED13
    Goto ANIM
    Regarding the schematic, I don't have one at the moment but basically it's just the MCU connected to 5V (with 1uF capacitor between VDD and GND pins) and several LEDs connected to each pin (one LED on each pin) in series with a resistor.
    are the leds connected to gnd or vdd ?
    are the leds powered by the same supply?
    what size is the led series resistor ?
    and what does actually happen compared what you expect to happen
    note a schematic can be a picture of a simple hand drawn pencil/paper sketch , or a doodle from paint brush
    it does not need to be fancy just readable and complete
    So, looking at your code....effectively it boils down to
    TRISA = %00000000	    ' This enables 23 of 24 output drivers, pins goes to whatever state PORT/LAT says
    TRISB = %00100000
    TRISC = %00000000
    clear
    pause 100                 ' Twiddle thumbs for 100ms
    PORTA=%00000000     ' And THEN the pins are set to 0
    PORTB=%00000000
    PORTC=%00000000
    [/code]
    You need to do it the other way around.
    Jul 2024
    Hi Richard, thanks for the help.
    Regarding the drawing...will try to get it and post here.
    In the meantime here are the answers:
    The LEDs are connected to ground
    Yes, same power supply as the MCU
    It's 500ohms for a SMD LED
    The same moment that i turn the power on, the LEDs turn on and then off very fast.
    After some seconds (when the code kicks in) the LED animation starts.
    I expect the LEDs not flash when turning the power on and only turn on when the code kicks in.
    before you go to too much trouble try what henrik suggests
    clear all output ports before setting the tris registers and lose that delay in between
    did you simply try to add :
    INIT:
    PORTA=%00000000
    PORTB=%00000000
    PORTC=%00000000
    clear
    TRISB.5=1
    PA1=300
    PA2=600
    PA3=900
    PA4=1500
    in the config section ...
    Aug 2011
    did you simply try to add ...
    The important part is to set the PORT (or LAT) registers BEFORE setting the TRIS registers to outputs.
    Otherwise the pins will be in output mode for a period of time but the outputs aren't specified.
    Hi, Tumbleweed
    the funny thing is I had added the port setting lines right before the TRIS statements for a run With MPLAB 8.92 sim ...
      #DEFINE MCU_FOUND 1
      CONFIG  WDT = ON           ; WDT disabled (control is placed on the SWDTEN bit)
    #ENDIF
    #IFNDEF MCU_FOUND
    #ENDIF
    OSCCON =110000
    OSCTUNE=000000
    DEFINE OSC 8
    PORTA = 0
    PORTB = 0
    PORTC = 0
    TRISA = 000000
    TRISB = 100000
    TRISC = 000000
    'PORTS & PINS
    CT                    VAR        BYTE
    CT2                    VAR        BYTE
    PA1                   VAR     WORD
    PA2                   VAR     WORD
    PA3                   VAR     WORD
    PA4                   VAR     WORD
    clear
    INIT: ' setting the Variables ... )
    PA1=300
    PA2=600
    PA3=900
    PA4=1500
    START:
    high LED3
    high LED4
    pause 1600
    high LED10
    high LED15
    pause PA4
    high LED1
    high LED2
    high LED6
    HIGH LED16
    PAUSE 600
    PAUSE PA4
    WHILE 1
    high LED9
    high LED14
    PAUSE PA3
    high LED8
    high LED13
    PAUSE PA3
    LOW LED13
    PAUSE PA3
    HIGH LED7
    PAUSE PA3
    LOW LED7
    HIGH LED13
    PAUSE PA3
    PAUSE PA3
    PAUSE PA3
    LOW LED8
    PAUSE PA3
    LOW LED13
    PAUSE PA3
    PAUSE PA3
    PAUSE PA3
    HIGH LED8
    HIGH LED13
    WEND
    With some "cleaning" ( wiped double definitions and "enlighted" the never-ending loop )
    MPLAB 8.92 ( the last one ! ) is rather useful for those simple programs debugging using checking breakpoints as it is still working fine with W11 ...
    Jul 2024
    Greetings all,
    first of all, thank you so much for all your help.
    I tried moving the port settings before the Tris statement like you recommended and it worked!
    PORTA=%00000000PORTB=%00000000
    PORTC=%00000000
    TRISA = %00000000
    TRISB = %00100000
    TRISC = %00000000
    With this change, the LEDs don't flash anymore during startup.
    You guys nailed it!
    Great !
    just remember the processor does what you tell it ... and ONLY what you tell it ! ( thanks to God, PBP doesn't show too many bugs )
    so, it's always you to set ALL the parameters, registers, variables ... etc, etc ... and overall take the greatest care of the default settings !
    READ THAT F... MANUAL ( Name:  rtfm_2.gif
Size:  3.3 KB )as we were used to write here. ) as a punishment, read carefully manual $ 8.1 ...
  1. How can I store the status of a pin?
    By Stargazer3141 in forum General
    Last Post: - 3rd December 2010, 22:59
  2. Issue with 16F88 startup
    By Plcguy in forum mel PIC BASIC Pro
    Last Post: - 21st October 2010, 15:11
  3. Startup on power up pic16f886
    By CESSKO in forum Test Area
    Last Post: - 14th April 2010, 12:26
  4. 7 second delay on startup
    Last Post: - 23rd March 2006, 01:46
  5. 12F683 Startup
    By GregK in forum mel PIC BASIC Pro
    Last Post: - 19th March 2005, 00:25
Members who have read this thread : 20
