How are you folks getting around that? Assembler?
its not quite that simple, contemporary chips like 18f27q43 have a pwm module that can use alternative clock sources like the mfosc @[500k] and its that allows 50hz operation, some others have much bigger timer2 type prescalers that can get there in a pinch too
i doubt the hpwm command can select the alternative clock/prescaler so some manual intervention will be needed. its not rocket science and if you plug it into MCC it does all the heavy lifting
