PIC18F14K50 USB Not Working
Results 1 to 11 of 11
    Miami, Florida USA
    Default PIC18F14K50 USB Not Working
    Okay, it looks like I'm stuck with the 18F4550 for my USB projects. Nothing else seems to work for me. I'm trying to just compile this program with the Include "descript.bas", but it doesn't work. This descript file works just fine with the 18F4550. I checked the USB_DEV.ASM and USB_HID.ASM files, but I don't know what the problem is. It might be an easy fix, but this assembler language is not my best friend. Any help is appreciated. Thanks, Robert
    Include	"descript.bas"	' Include the USB & HID descriptors
    Define  OSC  16
    OSCCON = %11110111
        CONFIG  CPUDIV = NOCLKDIV     ; No CPU System Clock divide
        CONFIG  USBDIV = OFF          ; USB clock comes directly from the OSC1/OSC2 oscillator block; no divide
        CONFIG  FOSC = IRC            ; Internal RC oscillator             ??????
        CONFIG  PLLEN = ON            ; Oscillator multiplied by 4
        CONFIG  PCLKEN = ON           ; Primary clock enabled
        CONFIG  PWRTEN = OFF          ; PWRT disabled
        CONFIG  BOREN = OFF           ; Brown-out Reset disabled in hardware and software
        CONFIG  BORV = 19             ; VBOR set to 1.9 V nominal
        CONFIG  WDTEN = OFF           ; WDT is controlled by SWDTEN bit of the WDTCON register
        CONFIG  WDTPS = 512           ; 1:512
        CONFIG  HFOFST = OFF          ; The system clock is held off until the HFINTOSC is stable.
        CONFIG  MCLRE = OFF           ; RA3 input pin enabled; MCLR disabled
        CONFIG  STVREN = OFF          ; Stack full/underflow will not cause Reset
        CONFIG  BBSIZ = OFF           ; 512W boot block size
        CONFIG  DEBUG = OFF           ; Background debugger disabled, RA0 and RA1 configured as general purpose I/O pins
        CONFIG  CP0 = ON              ; Block 0 code-protected
        CONFIG  CP1 = ON              ; Block 1 code-protected
        CONFIG  CPB = OFF             ; Boot block not code-protected
        CONFIG  WRT0 = OFF            ; Block 0 not write-protected
        CONFIG  WRT1 = OFF            ; Block 1 not write-protected
        CONFIG  WRTC = OFF            ; Configuration registers not write-protected
        CONFIG  WRTB = OFF            ; Boot block not write-protected
        CONFIG  EBTR0 = OFF           ; Block 0 not protected from table reads executed in other blocks
        CONFIG  EBTR1 = OFF           ; Block 1 not protected from table reads executed in other blocks
        CONFIG  EBTRB = OFF           ; Boot block not protected from table reads executed in other blocks
    Anonymous
    Default Re: PIC18F14K50 USB Not Working
    Does that short piece of code (with different CONFIG of course) really compile for the 18F4550 but not for 18F14K50?
    There really isn't much actual code there is it?
    I see no USBINIT or anything so it might be that the USB libraries aren't included by PBP during compile time and therefor the variables that the assembler is looking for isn't being declared.
    Aug 2011
    +1
    What is "Include "descript.bas"?
    maybe he meant
    Include "hid_desc.bas" ?
    Miami, Florida USA
    Yes, it compiles for the 18F4550 even without the config lines.
    Anonymous
    Miami, Florida USA
    maybe he meant
    Hmm, it works with the "hid_desc.bas" include. The descript.bas file is part of a HidMaker package that I bought before. Apparently, this descript file was made only for the 18F4550. Unfortunately, HidMaker went out of business. His owner Dr. Bob is not even responding to the emails. It is a shame to see a great program like HidMaker to close.
    Anonymous
    Maybe the syntax of the descript file is different than the one expected?
    Anyway it is a pity to see that company shutdown.
    People are getting old, retired or even die...
    Miami, Florida USA
    Also, PBP is getting less popular everyday. I'm going to have to dust off my C language skills again because I think that's what people are using the most today to program the PICs.
    Anonymous
    I hate to admit it but yeah, that is very true. We all should do that.
    But I also hate C...
    Miami, Florida USA
    I'm not a big fan of C either.
    Anonymous
  1. PIC18F14K50 USB Keyboard firmware
    By ScumariTec in forum USB
    Last Post: - 27th January 2021, 11:29
  2. Pic18f14k50
    By JoeyWallice in forum mel PIC BASIC
    Last Post: - 23rd October 2012, 12:13
  3. Pic18f14k50
    Last Post: - 17th October 2012, 03:16
  4. USB with 20 pins anyone? PIC18F14K50 issues
    By ScaleRobotics in forum USB
    Last Post: - 17th July 2009, 16:39
  5. Replies: 6
    Last Post: - 5th November 2008, 12:30
