More than one issue with that piece of code. For one, you're running at 64MHz so it's probably going to wrap around X variable quite quickly giving you weird results. I'd try something like this:Once you have that working, displaying pulsewidth values matching what you see on the scope you can A) increase resolution (if needed) and/or B) calculate PPMs or percentage or whatever you want to display. Small steps...Code:Th VAR WORD Tl VAR WORD PWIN VAR PORTB.0 Main: GOSUB Measure LCDOUT $FE, $01, "High: ", DEC Th LCDOUT $FE, $C0, "Low: ", DEC Tl GOTO Main Measure: Th = 0 Tl = 0 WHILE !PWIN : WEND ' Wait for rising edge WHILE PWIN ' Measure high pulse width Th = Th + 1 PAUSEUS 999 WEND WHILE !PWIN ' Measure low pulse width Tl = Tl + 1 PAUSEUS 999 WEND RETURN
