Interfacing MH-Z16 CO2 sensor with PBP?
+ Reply to Thread
Results 1 to 8 of 8
    Default Interfacing MH-Z16 CO2 sensor with PBP?
    Hello.
    I have this sensor and I want to read CO2 reading from it using PBP.
    According to manual, it can be done either via PWM or serial interface.
    PWM works, I checked it with scope and pulse width changes according to CO2 value.
    I tried to capture it with PULSIN statement, and sometimes it works a bit, sometimes - not.
    first, reading loop looks like this:
    32768
    actual value
    32768
    actual value
    32768
    actual value
    and so on
    I would "filter" out 32768 quite easily, but sometimes, strange values being measured - like say, average reading is around 6000 at the moment, but there might be some measurements that are below 500 or above 40000 - for 1-2 loop iterations.
    These are not sensor issues, since I checked with scope and everything works properly, there are no out of spec pulses.
    I'm using PIC18F45K80 @64 mhz and here's the code:
    #config
    CONFIG RETEN = OFF
    CONFIG INTOSCSEL = HIGH
    CONFIG SOSCSEL = DIG
    CONFIG XINST = OFF	    ;Enabled
    CONFIG FOSC = INTIO1
    CONFIG PLLCFG = OFF
    CONFIG FCMEN = OFF	    ;Disabled
    CONFIG PWRTEN = OFF	    ;Disabled
    CONFIG BOREN = OFF	    ;Disabled in hardware, SBOREN disabled
    CONFIG WDTEN = OFF	    ;WDT disabled in hardware; SWDTEN bit disabled
    CONFIG CANMX = PORTB
    CONFIG MCLRE = OFF
    #endconfig
    OSCTUNE.6 = 1 ; Enable 4x PLL
    OSCCON = %01110000
    ANCON1=0 'DISABLE ADC D3-D2-D1-D0-
    ANCON0=0
    ADCON0=0
    TRISC=%10100001 'set PORTC
    TRISD=%00000000 'set PORTD
    TRISB=%00000000 'set PORTB
    TRISA=%01000100 'set PORTA
    TRISE=%0000000  'set PORTE
    define OSC 64
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EREG PORTA
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 850
    DEFINE LCD_DATAUS 30
    'PORTS
    PWIN VAR PORTC.0 'PWM INPUT
    'VARIABLES
    X VAR word  'TEMP VARIABLE 1
    co2check:
    PULSIN PWIN,1, X
    LCDOUT $FE,$2,"CO2=", DEC X
    PAUSE 100
    GOTO CO2CHECK
    This device also supports serial TX/RX, I tried to read serial data from it, but it does not responds to the serial statement - there are no pulses coming back from the sensor. I'm using this to query the sensor, according to the sensor manual:
    https://www.winsen-sensor.com/d/files/MH-Z16.pdf
    serout2 PORTA.7, 84,[$FF,$01,$86,0,0,0,0,0,$79]
    Of course, I'd prefer serial output to be used, but I'm ok with PULSIN, if there's no other solutions available, but why it behaves so weirdly? connecting wires are short, and sensor outputs clean signal, but PBP detects it wrongly. Maybe this is because PWM is being read irregularly? but how can I change that?, ok, in that code I'll reduce PAUSE to say 1. But in actual code, I have other things to do...
    Miami, Florida USA
    Default Re: Interfacing MH-Z16 CO2 sensor with PBP?
    The PULSIN command is not too reliable. I have tried something similar to the PWM measurements that you are trying to do with 2 resistors in series and a 100 nF capacitor using ADC in the PIC. Connect 2 resistors in series to ground from the PWM output from the sensor. You can try 100 kOhms both. Connect the ADC input of the PIC to the junction between the two resistors. Conn0ect a 100pF cap to ground from the ADC input port. Get a reading. Try different values for the resistors. It works. Wait like small pause fefore the ADC reading. Something like 20 uSeconds.
    Anonymous
    The PWM period of the sensor output signal is a whopping 1004ms!
    At 64MHz the longest time you can measure with PULSIN is ~41ms. You'll only be able to measure at the very low end of the sensor range with that method.
    There seems to be an analog output as well, perhaps you can use that if you're not able to get the serial working. Or lowpass filter the PWM signal as mentioned.
    Your settings and command string does seem correct. The datasheet says "Users must use TTL level. If RS232 level, it must be converted." which to me means you should send data non-inverted (which you are). You could try sending it inverted as well, mode 16468 I believe. I'd be surprised if that's it but it's easy to try.
    Sometimes the terms RXD/TXD gets mixed up. In this case the datasheet is pretty clear that RXD is the input of the device (as apposed to mean "connect to RXD on the uC). Do you have it wired correctly? Have you tried switching RXD/TXD?
    Thanks!
    So since pulse duration is so long, instead of pulsin I can use something like
    WHILE PIN=1 A=A+1 and then count number of A's ?
    For the analog output, my particular sensor does not have it, I talked to manufacturer (I bought sensor directly from them), they said this is optional feature and had to be noted when ordering the sensor.
    Arduino library for the sensor is available, I'll try to connect to it later and check that way.
    I just tried this, but it always returns 0...
    puka:
    IF PWIN=1 THEN
    X=X+1
    LCDOUT $FE, $C0, DEC x, " "
    PAUSE 100
    x=0
    GOTO PUKA
    More than one issue with that piece of code. For one, you're running at 64MHz so it's probably going to wrap around X variable quite quickly giving you weird results. I'd try something like this:
    Th VAR WORD
    Tl VAR WORD
    PWIN VAR PORTB.0
        GOSUB Measure
        LCDOUT $FE, $01, "High: ",  DEC Th
        LCDOUT $FE, $C0, "Low: ",   DEC Tl
    GOTO Main
    Measure:
      Th = 0
      Tl = 0
      WHILE !PWIN : WEND	' Wait for rising edge
      WHILE PWIN			' Measure high pulse width
        Th = Th + 1
        PAUSEUS 999
      WEND
      WHILE !PWIN			' Measure low pulse width
        Tl = Tl + 1
        PAUSEUS 999
      WEND
    Once you have that working, displaying pulsewidth values matching what you see on the scope you can A) increase resolution (if needed) and/or B) calculate PPMs or percentage or whatever you want to display. Small steps...
    Thanks a lot!
    Will check it tomorrow.
    Just tried this code, it works fine, "High" displays readings consistent with actual CO2 concentrations, LOW displays some fixed numbers which only slightly change.
  1. LM 35 Sensor interfacing with PIC16F877A
    By girish09 in forum Code Examples
    Last Post: - 7th November 2012, 14:23
  2. KINECT Sensor interfacing with PICs
    By MrRoboto in forum USB
    Last Post: - 29th August 2012, 17:43
  3. Temp & Humidity sensor interfacing question
    By tacbanon in forum mel PIC BASIC Pro
    Last Post: - 20th February 2012, 23:12
  4. current sensor interfacing
    By hell_pk in forum mel PIC BASIC Pro
    Last Post: - 29th January 2009, 04:55
  5. CO2 MG811 sensor connection
    By elektoro2009 in forum mel PIC BASIC Pro
    Last Post: - 8th May 2008, 00:49
Members who have read this thread : 11
