What is this IC?
Results 1 to 27 of 27
    Default Re: What is this IC?
    I'm thinking germanium too, but even then, google seems to believe there isn't a standard bar code.
    They look an awful lot like theses guys:
    https://www.ebay.com/itm/125030406073
    I still have to test the voltage.
    (I'm cutting plexi right now)
    I had to have a quickie look. Used 2 meters on diode mode and got these readings:
    Name:  Diode Aneng DT9205A.jpg
    Is the top one measuring resistance (339)?
    Name:  Diode TES-2712.jpg
    And is the bottom one measuring voltage (0.282)?
    Then germanium it is!
    Bombay, India
    These used to be the AM detector diode commonly used in transistor radios in the 80's and early 90's
    Then, Jerson, I bet you are around 60's ?
    Bombay, India
    Almost there
    Obviously...!
    Youngers I am sure do not know about AM demodulation through germanium diodes!
    Once, at the age of 10-11, I made the first AM radio with such a diode, and an old telephone earpiece that was connected to a vertical metal waterpipe. It was amazing experience to here the local radio station with this!!!
