What is this IC?
Results 1 to 27 of 27
    Question Re: What is this IC?
    How about this one?
    Looks like a diode. Tried to take pics all around by bending lead, not sure if I got them all.
    I used 3x zoom, then cropped as much as possible.
    I don't see anything...
    Bombay, India
    Default Re: What is this IC?
    Possibly older version of the 1N4148 or 1N914 signal diode. If the body is bulkier, could be ancient germanium diode
    Miami, Florida USA
    Is that glass or clear plastic? It looks like a fuse or a diode.
    Anonymous
    I bet it is a germanium diode.
    You can confirm it by applying say 10 volts with a 10K resistor and measure the voltage drop on the part pins. If it is around 0.2-0.3 volts the you can be sure for that.
    I'm thinking germanium too, but even then, google seems to believe there isn't a standard bar code.
    They look an awful lot like theses guys:
    https://www.ebay.com/itm/125030406073
    I still have to test the voltage.
    (I'm cutting plexi right now)
    I had to have a quickie look. Used 2 meters on diode mode and got these readings:
    Name:  Diode Aneng DT9205A.jpg
    Is the top one measuring resistance (339)?
    Name:  Diode TES-2712.jpg
    And is the bottom one measuring voltage (0.282)?
    Then germanium it is!
