Trouble with 16F628's PORTA
Results 1 to 5 of 5
    SebastianO's Avatar
    SebastianO Guest
    Default Trouble with 16F628's PORTA
    Hello,
    I am facing a really annoying problem. The PORTA of my 16F628 doest not want to cooperate with me as input. The biggest ptoblem is that only the RA0 pin can be used as input, the rest of the pins: RA1, RA2 and RA3 does not react to any inputs. I have set the cmcon register to 0x07, but nothing, nothing.....
    If anybody has any idea about what is hapenning, please don't hasitate to complete this topic.
    Thank you in advabce your responses.
    As development tool I use MPlab IDE. A short fragment of my code:
    if((PORTA & 0x01) == TRUE)
    PORTB = 0x01;
    if((PORTA & 0x02) == TRUE)
    PORTB = 0x02;
    if((PORTA & 0x04) == TRUE)
    PORTB = 0x04;
    if((PORTA & 0x08) == TRUE)
    {PORTB = 0x08;
    where TRUE is defined as 0x01
    as usual... datasheet>> analog comparator section >> CMCON register to disable them
    SebastianO's Avatar
    SebastianO Guest
    I already mentioned in my topic that I have disabled the comparators from the PORTA pins. CMCON = oxo7 isalready set by me.
    Any other sugestions?
    Oct 2003
    Australia
    Question
    I don't quite follow your code, but anyways, have you set the TRISA register to all 1's?
    ie TRISA = 255
    J
    Default PORTA prob as well... surprising solution
    I developed a pulse reader application on a 16F84A.. worked well.
    Needed the Timer1 function and compiled the code to a 16F628.
    Setup the ports as follows:-
    'Setup the hardware, define i/p and o/p
    define osc 4
    CMCON = 7 'turn comparators off
    VRCON = 0
    TRISB = 0 'set all PortB pins to outputs
    TRISA = %00000111 'set RA0, RA1 & RA2 to input, all other outputs
    I was using PortA1 for i/p and PortB4 for o/p on the 'F84A and after adding the CMCON and VRCON plugged in a 'F628 in lieu of the 'F84A.
    Didn't work !!
    Eventually, I found that if I reversed the i/p and o/p ports i.e PortA1 for o/p and PortB4 for i/p it worked.
    TRISB = 1
    TRISA = 0
    My theory is that it is the Schmitt trigger on A0-A5 is causing the issue. Don't see how, as yet, as the i/p is a clean squarewave from a signal generator (am testing on the bench at the moment).
    May give you a clue... and maybe someone has more info on this ?
  1. error worring pbp247
    Last Post: - 17th January 2010, 05:51
  2. PortA digita input?
    By MOUNTAIN747 in forum mel PIC BASIC Pro
    Last Post: - 27th January 2009, 22:55
  3. PIC's ports individual bits manipulation - how to?
    Last Post: - 27th February 2007, 23:34
  4. 16f876 PortA set-up trouble?
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 20:31
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
