Peltier musings:
I'm looking at ways to cool a LR1084 and tempted to try a tiny peltier sandwich on the front and back of a TO220 VR. I found this guy; 10mmx10mm peltier, TEC1-00703 rated 0.85V 3A:
https://www.aliexpress.com/item/1005007689267535.html
So far I see 2 challenges:
1. Getting a very low voltage power source. The common design I'm seeing is using diodes, but there are comments that they introduce "noise" from the constant clipping action.
...my go-to idea would be to PWM a logic-level MOSFET to get the low voltage.
2. Reducing the current, I don't plan on using the peltier at 100% (3A). According to the datasheet, lowering the voltage brings down the current consumption. I'd just need a source of very low voltage that could "possibly" supply up to 1A (off the top of my head, maybe I need more, maybe I need less).
3. Getting a reliable thermal adhesive since I can't use the screw, and that chinesium thermal tape looks like crap (unless a 3M product from a known supplier is worth it).
4. Learning to count.
Has anyone played with these yet?
