Pic18f67k22 WDT
Results 1 to 10 of 10
Thread: Pic18f67k22 WDT
    Default Re: Pic18f67k22 WDT
    i see a code snippet that cannot be compiled.
    a code snippet not in code tags.
    a code snippet that does not demonstrate in any way how you have configured the wdt
    a code snippet that does not demonstrate how you have employed any clrwdt instructions to
    achieve a reset when needed
    a minimal, complete and verifiable example MCVE is the best way to get help
    https://stackoverflow.com/help/minim...ucible-example
    Dec 2021
    Hello Richard
    Apologies, I have attached a file for review.
    '*  Notice  : Copyright (c) 2024 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 11/16/2024                                        *
    #config
     CONFIG RETEN=OFF
     CONFIG XINST = OFF ;Extended Instruction Set
     CONFIG FOSC = INTIO2 ;internal RC oscillator
     ;CONFIG FOSC = EC3  ; HS oscillator (high power > 16 MHz)
     CONFIG SOSCSEL=DIG
     ;CONFIG SOSCSEL=HIGH
     CONFIG FCMEN = OFF   ;Fail-Safe Clock Monitor ****
     CONFIG IESO = OFF  ;Two-Speed Start-up is disabled
     CONFIG PLLCFG = OFF  ;4x xtal PLL
     CONFIG PWRTEN = ON ;Power-up Timer
     CONFIG BOREN = SBORDIS ; Brown-out Reset Enabled in hardware, SBOREN disabled
     CONFIG BORPWR = HIGH ;BOR MV set to high power level
     CONFIG BORV = 2 ; Brown-out Reset  0=3v, 1=2.7v, 2=2v, 3=1.8v
     CONFIG WDTEN = SWDTDIS ;ON ;OFF ;WDT enabled in hardware; SWDTEN bit disabled
     CONFIG WDTPS = 64;512 ;WDT
     CONFIG RTCOSC = INTOSCREF  ; RTCC uses INTRC
     ;CONFIG  ECCPMX = PORTH ; Enhanced CCP1/3 [P1B/P1C/P3B/P3C] muxed with RH7/RH6/RH5/RH4 (pwm)
     ;CONFIG  CCP2MX = PORTBE ;PORTC
     CONFIG  MCLRE = ON
     CONFIG STVREN = ON ;Stack Full/Underflow Reset
    ; CONFIG BBSIZ = BB1KL ; 1K word Boot Block size
    ; CONFIG BBSIZ = BB2K  ; 2K word Boot Block size
     CONFIG DEBUG = OFF ;Background Debugger
     CONFIG CP0 = ON  ;code-protected
     CONFIG CP1 = ON
     CONFIG CP2 = ON
     CONFIG CP3 = ON
     CONFIG CP4 = ON
     CONFIG CP5 = ON
     CONFIG CP6 = ON
     CONFIG CP7 = ON
     CONFIG CPB = ON  ;Boot Block Code Protection
     CONFIG CPD = ON  ;Data EEPROM Code Protection
    ; CONFIG CP0 = OFF  ;code-protected
    ; CONFIG CP1 = OFF
    ; CONFIG CP2 = OFF
    ; CONFIG CP3 = OFF
    ; CONFIG CP4 = OFF
    ; CONFIG CP5 = OFF
    ; CONFIG CP6 = OFF
    ; CONFIG CP7 = OFF
    ; CONFIG CPB = OFF  ;Boot Block Code Protection
    ; CONFIG CPD = OFF  ;Data EEPROM Code Protection
    #endconfig
    'DEFINE RESET_ORG 4000h'4000h HID bootloader must org the program at 2000 HEX
    include "fp1832L.bas"
    'include "FLASH.bas"
    '*** At 64MHz each instruction cycle is 62.5ns
    OSCCON=%11110100 'OSCILLATOR CONTROL & Frequency  (16M RC)
    OSCTUNE.6=1 'Frequency Multiplier PLL Enable bit FOR INIT RC
    DEFINE OSC 64
    INTCON2.7=1 'PORTB Pull-up Disable
    PADCFG1.7=0 'PORTD Pull-up Disable
    PADCFG1.6=0 'PORTE Pull-up Disable
    PADCFG1.5=0 'PORTJ Pull-up Disable
    ANCON0=0 'AN0-AN7 digital port
    ANCON1=0 'AN8-AN15 digital port
    ANCON2=0 'AN16-AN23 dig
    CM1CON.7=0 'COMPERATOR1 OFF
    CM2CON.7=0 'COMPERATOR2 OFF
    CM3CON.7=0 'COMPERATOR3 OFF
    PSPCON.4=0 'General Purpose I/O mode 'PSPMODE: Parallel Slave Port Mode Select bit
    Restart:
    TRISA=$FF
    TRISB=$FF
    TRISC=$FF
    TRISD=$FF
    TRISE=$FF
    TRISF=$FF
    TRISG=%11111
    TRISC=%10111110
    LATC.0=1 'HOST RTS 1=STOP SEND 0=ALOW TO SEND
    '*C.1=MODULE RTS
    '*C.2=1 Pump Sence
    '*C.3=SCL RTC
    '*C.4=SDA RTC
    '*C.5=MFP RTC
    LATC.6=1 'Tx1  WiFi
    '*C7=RX1 WiFi
    TRISA=%11101110 '
    LATA.0=1 'PD_SCK HX711 low power mode
    '*A0=PD_SCK HX711
    '*A1=DOUT HX711
    '*A2= HX711 TEMP SENSOR '02-09-2024
    '*A3= INT  IC PCAL6524HEAZ   '02-09-2024
    '*A5= general I/O connected to Test Point X16  '02-09-2024
    latA.4=1 'wifi BW16 Reset/Disable 1=Reset/Disable
    TRISB=%11111111
    'B0-B4 not connected
    '*B5= GENERAL I/O
    '*B6=PROGRAMMING
    '*B7=PROGRAMMING
    TRISD=%00100011
    ' RD0 = scl2  AT24C16
    ' RD1 = sda2  AT24C16
    LATD.2=0  'Buzzer
    LATD.3=0  'External Unit Power on/off 1=on
    LATD.4=0 'SDO2 FLASH
    'D5=SDI2 FLASH
    LATD.6=0 'SCK2 FLASH
    LATD.7=1 'SS2 FLASH WP WRITE PROTECTION (0=PROTECT  1=ENABLE)
    TRISE=%10011100
    LATE.0=0 'HOLD FLASH  1=ACTIVE 0=HOLD
    LATE.1=1 'CE FLASH  0=ENABLE 1=DISABLE
    '*E2-E3= n.c
    '*E4= Extension i/o
    LATE.5=0 '1= Reset IC PCAL6524HEAZ
    LATE.6=0 'AO3400A PWM6
    '*E7= n.c
    TRISF=%11111111
    '*F0= n.c
    '*F1= Power Fail input
    '*F2= n.c
    '*F3=Current Sense
    TRISF.4=0 : LATF.4=1 ' Software Tx
    '*F5= Software Rx
    '*F6= Extension GENERAL I/O
    '*F7= Extension GENERAL I/O
    TRISG=%11101
    '*G0= Busy
    LATG.1=1 'TX2
    '*G2= RX2
    '*G3= Extension GENERAL I/O
    '*G4= Extension GENERAL I/O
    '**** WIFI ****
    DEFINE HSER_SPBRG 34  ' 115200 Baud @ 64MHz, -0.79%
    '**** Uart 2 ****
    DEFINE HSER2_RCSTA 90h ' Enable serial port & continuous receive for RAFID
    DEFINE HSER2_TXSTA 24h ' Enable transmit, BRGH = 1
    DEFINE HSER2_SPBRG  34  ' 115200 Baud @ 64MHz, -0.79%
    DEFINE HSER2_CLROERR 1 ' Clear overflow automatically
    '**** Debug  ****
    DEFINE DEBUG_REG PORTF
    DEFINE DEBUG_BIT 4
    DEFINE DEBUG_BAUD 115200
    DEFINE DEBUG_MODE 0  '0=TRUE 1=INVERTER
    A VAR BYTE  'general use
    RE VAR BYTE[999]' wifi Rx buffer
    'SSID_N VAR BYTE[32] 'SSID NAME buffer
    'SSID_nC VAR BYTE  'SSID NAME BYTE COUNTER
    'SSID_P VAR BYTE[128]  'SSID PASWORD buffer
    'SSID_pC VAR BYTE  'SSID PASSWORD BYTE COUNTER
    A1 VAR WORD
    A2 VAR WORD
    A3 VAR WORD
    CHECK VAR WORD
    COUNT_A VAR BYTE[50]
    T VAR BYTE[50]
    T1 VAR BYTE
    T2 VAR WORD
    T3 VAR BYTE
    T4 VAR BYTE
    Tlong VAR long '
    AX1 VAR WORD  'WIFI
    AX2 VAR WORD  'WIFI
    Message var byte[500] '  for APP
    MessageL VAR WORD 'Message Length
    RSSI var LONG 'SSID signal
    RxEvent var LONG 'wifi
    ReplyEvent VAR LONG 'WIFI
    Symb VAR BYTE
    CLEAR
    'Note: at GET_SSID_list1 loop, remove " if CHECK=>AX1 THEN GOTO break33 '   ***** to runout MCU *****
    Gosub DEMO_RECEIVE 'Simulation of receiving DATA from wifi module
    gosub Decoding 'Decoding the received data
    debug "SSID LIST:<ssid>,<rssi>",$D,$A,STR Message\MessageL
    Decoding: 'Decoding the received data
    ''*** 128 Indicates end of array ****
    arraywrite T,["+WSCAN:",128] 'COUNT_A[15]  'search '+WSCAN:
    T3=18 'COUNT_A[] number
    GOSUB ConfirmMessage
    if COUNT_A[18]=$FF THEN 'found?
                         RxEvent.18=1
                         COUNT_A[18]=0
                         GOSUB GET_SSID_list 'load the SSID list to the Message array
    '**** SEARCH MESSAGE AT RECEIVED ARRAY ****
    ConfirmMessage:
    for T4 = 0 to 49  'GET T array Length
    if T[T4]=128 THEN GOTO break5
    NEXT T4
    break5:
    FOR CHECK = 0 TO AX1
    IF RE[CHECK]=T[0] THEN 'confirm the first charter at T array
                        COUNT_A[T3]=COUNT_A[T3]+1
                        FOR T1= 1 TO T4-1  'the number of charter need to confirm
                        IF RE[CHECK+T1]=T[T1] THEN
                                                COUNT_A[T3]=COUNT_A[T3]+1 'if charter true then count
                                                COUNT_A[T3]=0  'if one of charter not the same, clear counter
                                                goto break24
                        next T1
                        break24:
                        if COUNT_A[T3]=T4 THEN
                                            COUNT_A[T3]=$FF 'True
    '                                        if T3=7 then  ReplyEvent.14=1  '+WSCANACTIVE Confirm found the ssid   'RxEvent.14
    '                                        if T3=19 THEN ReplyEvent.19=1 '+WSCAN Confirm found the ssid  'RxEvent.19
                                            GOTO break7
    'IF pir1.0 THEN gosub CLEAR_TIMER1'TIMER1 OVER FLOW 20ms
    next CHECK
    break7:
    T[T4]=0 'clear T
    DEMO_RECEIVE:
    arraywrite RE,[$d,$a,_
    "+WSCAN:index SSID,CH,RSSI",$d,$a,_
    "1 TP-Link_Guest_ABD6_5G,48,-42",$d,$a,_
    "2 TP-Link_ABD6,48,-42",$d,$a,_
    "3 ,48,-42",$d,$a,_
    "4 TP-Link_ABD6,1,-45",$d,$a,_
    "5 TP-Link_Guest_ABD6,1,-45",$d,$a,_
    "6 ,1,-45",$d,$a,_
    "7 Mamad_EXT2,4,-46",$d,$a,_
    "8 Mamad_EXT5g 2,48,-48",$d,$a,_
    "9 ,10,-57",$d,$a,_
    "10 HOME,11,-68",$d,$a,_
    "11 HOME_EXT,11,-74",$d,$a,_
    "12 ,52,-80",$d,$a,_
    "13 HOME_5G,52,-80",$d,$a,_
    "14 HOTWiFi-D7D,6,-85",$d,$a,_
    "15 HOME_5G_EXT,52,-85",$d,$a,_
    "16 Mali,6,-89",$d,$a,_
    "17 lior,11,-92",$d,$a,_
    $d,$a,"OK",$d,$a]
    'Rx Byte:360
    AX1=360 'received byte
    SearchSymbol: 'search "," Symbol
    '*** Must set T4 before send to this loop
    T1=0
    FOR A3 = CHECK TO AX1'
    IF RE[A3]=Symb THEN T1=T1+1
    IF T1=T4 THEN break9
    NEXT A3
    break9:
    CHECK=A3
    '*** load all +SCAN SSID,RSSI list to Message array ***
    GET_SSID_list:
    MessageL=0
    T4=2 'multiple of the symbol x time "space"
    GET_SSID_list1:
    Symb=" " '"Space"
    GOSUB SearchSymbol 'Search THE SYMBOLE
    if CHECK=>AX1 THEN GOTO break33 'END OF LIST    ***** REMOVED to runout MCU *****
    CHECK=CHECK+1 'to jump on the "space"
    if RE[CHECK]="," THEN  'If hidden wifi move to next line
                T4=1 'multiple of the symbol
                goto  GET_SSID_list1
    FOR A3 = CHECK TO AX1 'Get SSID name
    if RE[A3]="," then break31
    Message[MessageL]=RE[A3]
    MessageL=MessageL+1
    next A3
    break31:
    T4=2 'multiple of symbol,  JUMP on channel
    Symb=","
    gosub SearchSymbol
    CHECK=A3+1 'jump on ","
    Message[MessageL]="," 'insert "," Between ssid to rssi  (ssid,rssi)
    MessageL=MessageL+1
    FOR A3 = CHECK TO AX1 'Get RSSI
    if RE[A3]=$D then break32 'CR
    MessageL=MessageL+1
    NEXT A3
    break32:
    CHECK=A3
    Message[MessageL]=$A 'insert LF
    MessageL=MessageL+1
    GOTO GET_SSID_list1 'Next line
    break33:
    Use this tags to embed the code:
    [ code ]
    [/ code ]
    without spaces.
    a simple example to demonstrate WDT
    '****************************************************************'*  Name    : UNTITLED.BAS                                      *
    '*  Author  : richard                                           *
    '*  Notice  : Copyright (c) 2024 caveat emptor                  *
    '*  Date    : 17/11/2024                                        *
    #config
     CONFIG RETEN=OFF
     CONFIG SOSCSEL=DIG
     CONFIG WDTPS = 512 ;WDT     512*4Ms = 2 SECONDS
     CONFIG  MCLRE = ON
     CONFIG CP1 = ON
     CONFIG CP2 = ON
     CONFIG CP3 = ON
     CONFIG CP4 = ON
     CONFIG CP5 = ON
     CONFIG CP6 = ON
     CONFIG CP7 = ON
    #endconfig
    DEFINE NO_CLRWDT 1 'Don’t insert CLRWDTs
    DEFINE DEBUG_REG PORTD
    DEFINE DEBUG_BIT 4
    DEFINE DEBUG_BAUD 9600
    DEFINE OSC 64
        TRISD=$ed
        latd=18
        @ CLRWDT        ;WDT needs to be cleared every   512*4Ms = 2 SECONDS  at most else chip will reset
        @ CLRWDT
        debug "ready",13,10
        @ CLRWDT
        MAIN:              ; if porta.0 is not detected going high the wdt will overflow and reset chip
            LATD.1=0
            IF PORTA.0 THEN
                @ CLRWDT       ; in main loop the wdt is cleared when porta.0 goes high
                WHILE PORTA.0 : WEND
        GOTO MAIN
    stop
    ************************************************** **************'* Name : UNTITLED.BAS *
    '* : All Rights Reserved *
    '* Version : 1.0 *
    '* Notes : *
    #config
    CONFIG RETEN=OFF
    Are you a wizard of some kind.......... you wrote/posted this a day ahead of today...... writing now in the future ??????
    warning: I am an idiot!
    the world is not flat , time is relative
    Dec 2021
    Hello Richard
    Thanks a lot for the help.
  1. Replies: 8
    Last Post: - 18th September 2017, 23:29
  2. What commands reset the WDT?
    By pointjohn in forum mel PIC BASIC Pro
    Last Post: - 4th November 2010, 16:47
  3. Detect reset by WDT
    By Art in forum mel PIC BASIC Pro
    Last Post: - 13th April 2010, 08:34
  4. SLEEP, WDT and INT
    Last Post: - 30th March 2008, 14:45
  5. WDT-Reset - How to know
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 12th November 2005, 17:33
