Display 2 WORDs as a 32bit integer
Results 1 to 14 of 14
    Default Display 2 WORDs as a 32bit integer
    I have two WORD variables representing a 32bit number, lets call them CountH and CountL.
    I am displaying these as the two individual variables they are, using HSEROUT with the DEC modifier. (ex: 12, 45234 where 12 is CountH and 45234 is CountL)
    Ideally I'd like to display them as the signed 32bit integer that they represent (ex: 831666). I'm at 14.8k on a 16k device, switching to LONGs is not an option, switching device is not an option either since the 18F2431 is the only bloody 8-bitter with the QEI peripheral.
    Anyone have a nifty routine to do it?
    Default Re: Display 2 WORDs as a 32bit integer
    maybe something like this old gem
    Hours     VAR WORD[2]    ; 32-bit (Dword) Holds up to 99999.9 hoursHoursH    VAR Hours(1)
    HoursL    Var Hours(0)
    Result    Var Word
    Remainder Var Word
    ;----[Load a 32-bit (Dword) variable into PBP registers, Prior to DIV32]--------
    Asm
    PutMulResult?D macro Din
        MOVE?BB   Din, R2
        MOVE?BB   Din + 1 , R2 + 1
        MOVE?BB   Din + 2, R0
        MOVE?BB   Din + 3, R0 + 1
        RST?RP
    EndAsm
    ;====[Simple loop to test the HourMeter]========================================
    MainLoop:
        gosub AddHourTenth
        Gosub ShowHourMeter
    goto MainLoop    ;============================================================
    ;----[Add 1 tenth of an hour to the hourmeter]----------------------------------
    AddHourTenth:
        HoursL = HoursL + 1
        IF HoursL = 0 then HoursH = HoursH + 1
        if (HoursH = $F) and (HoursL = $4240) then   ; Roll over at 1,000,000
            HoursH = 0                               ;            99999.9 + .1
            HoursL = 0
    ;----[Display hourmeter using LCDOUT]-------------------------------------------
    ShowHourMeter:
    @   PutMulResult?D  _Hours
        Result = DIV32 1000
        Remainder = R2
        LCDOUT $FE, 2            ; Home Cursor
        IF Result > 0 then
            LCDOUT Dec Result, DEC2 Remainder/10,".",DEC1 Remainder//10
            LCDOUT DEC Remainder/10,".",DEC1 Remainder//10
    the other way is n-bit math
    like post #23 here
    signed 32 bit divide here
    or do it the easy way in C where its not an issue
    Thanks Richard,
    I don't need to "do" anything with the value, "all" I need is to display it
    ValueH = 12
    ValueL = 45234
    GOSUB Print32BitValue
    Result: 831666
    I tried your HourMeter aproach and it works fine with example above. Cool!
    Unfortunately it falls appart when the high word is >1000, ie when the Result of DIV32 is >65535.
    Without really thinking I changed DIV32 to 10000 and massaged the display code but obviously it only pushes the problem to when the high word is >10000.
    I feel daft...
    Bombay, India
    Many years back, I solved the problem like this.
    I have a variable Total defined as 4 bytes
    In the routine that increments the total, I did it like this
    Total       var byte[4]    ' packed BCD totalizer upto 99999999
    asm
    ; assembler code embedded into PBP increments Total till 99999999 and then rolls over
              incf  _Total+3
    	  movlw 100
    	  subwf _Total+3,w
    	  btfss status,c
    	  goto  DoneTotal
    	  clrf  _Total+3
    	  incf  _Total+2
    	  movlw 100
    	  subwf _Total+2,w
    	  btfss status,c
    	  goto  DoneTotal
    	  clrf  _Total+2
    	  incf  _Total+1
    	  movlw 100
    	  subwf _Total+1,w
    	  btfss status,c
    	  goto  DoneTotal
    	  clrf  _Total+1
    	  incf  _Total+0
    	  movlw 100
    	  subwf _Total+0,w
    	  btfss status,c
    	  goto  DoneTotal
    	  clrf  _Total+0
    DoneTotal:
    endasm
    This allows for a maximum total content of 99,99,99,99 with Total[3] being the lowest byte
    Now, in the display routine, I did something like this to show the lower 6 digits. Mind you, this is only for unsigned values.
      		Dat = Total[2] dig 0
      			gosub Code2Segment       ' convert to 7 segment code
      			gosub Dsp_Data                ' display the 7 segment code
                            Dat = Total[2] dig 1
      			gosub Code2Segment
      			gosub Dsp_Data
      			Dat = Total[1] dig 0
      			gosub Code2Segment
      			gosub Dsp_Data
                            Dat = Total[1] dig 1
      			gosub Code2Segment
      			gosub Dsp_Data
      			Dat = Total[0] dig 0
      			gosub Code2Segment
      			gosub Dsp_Data
                            Dat = Total[0] dig 1
      			gosub Code2Segment
      			gosub Dsp_Data
    I hope this will help you find some solution to your stated problem.
    Cheers
    Oct 2012
    Many years ago DT helped me with something similar
    https://www.picbasic.co.uk/forum/showthread.php/24-Retrieving-32bit-Multiply-Result
    Not sure if it might apply to your application.
    Nick
    yes biggest num is 655359999
    this does a divide by 100000 first in asm and will do rest in pbp to encompass the entire 32 bit signed range
    #config CONFIG RETEN=OFF
     CONFIG XINST = OFF ;Extended Instruction Set
     CONFIG FOSC = INTIO2 ;internal RC oscillator
     CONFIG SOSCSEL=DIG
     CONFIG FCMEN = OFF   ;Fail-Safe Clock Monitor ****
     CONFIG IESO = OFF  ;Two-Speed Start-up is disabled
     CONFIG PLLCFG = OFF  ;4x xtal PLL
     CONFIG PWRTEN = ON ;Power-up Timer
     CONFIG BOREN = SBORDIS ; Brown-out Reset Enabled in hardware, SBOREN disabled
     CONFIG BORPWR = HIGH ;BOR MV set to high power level
     CONFIG BORV = 2 ; Brown-out Reset  0=3v, 1=2.7v, 2=2v, 3=1.8v
     CONFIG WDTEN = SWDTDIS ;ON ;OFF ;WDT enabled in hardware; SWDTEN bit disabled
     CONFIG WDTPS = 512 ;WDT     512*4Ms = 2 SECONDS
     CONFIG RTCOSC = INTOSCREF  ; RTCC uses INTRC
     CONFIG  MCLRE = ON
     CONFIG STVREN = ON ;Stack Full/Underflow Reset
     CONFIG DEBUG = OFF ;Background Debugger
     CONFIG CP0 = OFF  ;code-protected
     CONFIG CP1 = OFF
     CONFIG CP2 = OFF
     CONFIG CP3 = OFF
     CONFIG CP4 = OFF
     CONFIG CP5 = OFF
     CONFIG CP6 = OFF
     CONFIG CP7 = OFF
     CONFIG CPB = OFF ;Boot Block Code Protection
     CONFIG CPD = OFF ;Data EEPROM Code Protection
    #endconfig
    DEFINE OSC 64
    DEFINE DEBUG_REG PORTD
    DEFINE DEBUG_BIT 4
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 0  '0=TRUE 1=INVERTER
        OSCCON=110100
        OSCTUNE.6=1 'Frequency Multiplier PLL Enable bit FOR INIT RC
        TRISD=$ed
        ANCON0=0 'AN0-AN7 digital port
        ANCON1=0 'AN8-AN15 digital port
        ANCON2=0 'AN16-AN23 dig
        PSPCON.4=0 'General Purpose I/O mode 'PSPMODE: Parallel Slave Port Mode Select bit
        Test     var byte[3] SYSTEM
        Dividend   var byte[6] SYSTEM
        Remainder  var byte[4] SYSTEM      ; remainder from 1000000 division
        Shift  var byte[6] SYSTEM
        Counter  VAR BYTE  SYSTEM
        HoursH    VAR Hours(1)
        HoursL    Var Hours(0)
        QUOTL     VAR WORD EXT       ; top 5 digits
        Result    Var Word           ;  middle 10,000;s  single digit
        Remains Var Word             ; bottom 4 digits
        i var byte
    goto overasm
     Asm
    QUOTL=Dividend
        MOVE?BB   Din, R2
        MOVE?BB   Din + 2, R0
        RST?RP
    PutDIV?D macro Din
        MOVE?BB   Din, Dividend
        MOVE?BB   Din + 1 , Dividend  + 1
        MOVE?BB   Din + 2, Dividend   + 2
        MOVE?BB   Din + 3, Dividend  + 3
        MOVE?CB   0 ,   Dividend  + 4
        MOVE?CB   0 ,   Dividend  + 5
        RST?RP
    EndAsm
    Remainder[3]=0
    overasm:
        HoursL=$fff0
        HoursH=$7fff
        latd=18
        debug "ready",13,10
    MainLoop:
        gosub AddHourTenth
        Gosub ShowHourMeter
    AddHourTenth:
        HoursL = HoursL + 1
    ShowHourMeter:
        Test    [0]=$a0       ;divisor 100000
        Test    [1]=$86
        Test    [2]=1
    @   PutDIV?D  _Hours
        CALL  Div4824U      ;divide by 100000
         debug  ,13,10
    @   PutMulResult?D  Remainder
        Result = DIV32 10000
        Remains = R2
        debug DEC QUOTL, Dec1 Result, ".",DEC4 Remains ,13,10
    ;Div4824U
    ;Inputs:
    ;    Dividend - Dividend:6    (0 - least significant!)
    ;    Divisor     - Test:3    (0 - least significant!)
    ;Temporary:
    ;    Counter     - Count
    ;    Shift     - Shift:6
    ;Output:
    ;    Quotient - Dividend:6    (0 - least significant!)
    ;    Remainder- Rem:3    (0 - least significant!)
    ;Adaptation of 24x24 division by Tony Nixon with corrections
    ;by Frank Finster 3/15/2005.
    ;Code adapted by Andy Lee
    ;01-Sep-2006    Original version
    Div4824U:
    asm
    ; SUBROUTINE - 48 by 24 BIT DIVISION
        movlw 48
        movwf Counter
        movff Dividend+0, Shift+0
        movff Dividend+1, Shift+1
        movff Dividend+2, Shift+2
        movff Dividend+3, Shift+3
        movff Dividend+4, Shift+4
        movff Dividend+5, Shift+5
        clrf Dividend+0
        clrf Dividend+1
        clrf Dividend+2
        clrf Dividend+3
        clrf Dividend+4
        clrf Dividend+5
        clrf Remainder+2
        clrf Remainder+1
        clrf Remainder+0
    dloop
        bcf STATUS, C
        rlcf Shift+0
        rlcf Shift+1
        rlcf Shift+2
        rlcf Shift+3
        rlcf Shift+4
        rlcf Shift+5
        rlcf Remainder+0
        rlcf Remainder+1
        rlcf Remainder+2
        movf Test+2, w
        subwf Remainder+2, w
        btfss STATUS, Z
        bra nochk
        movf Test+1,w
        subwf Remainder+1,w
        btfss STATUS, Z
        bra nochk
        movf Test+0,w
        subwf Remainder+0,w
    nochk
        btfss STATUS, C
        bra nogo
        movf Test+0,w
        subwf Remainder+0
        btfsc STATUS, C
        bra    nodec_remainM
        decf Remainder+1, f
        movf Remainder+1, w
        xorlw 0xff
        btfsc STATUS, Z
        decf Remainder+2, f
    nodec_remainM
        movf Test+1, w
        subwf Remainder+1, f
        btfss STATUS, C
            decf Remainder+2, f
        movf Test+2, w
        subwf Remainder+2, f
        bsf STATUS, C
    nogo
        rlcf Dividend+0
        rlcf Dividend+1
        rlcf Dividend+2
        rlcf Dividend+3
        rlcf Dividend+4
        rlcf Dividend+5
        decfsz Counter, f
        goto dloop
     endasm
    Thanks Nick,
    As far as I can see the examples provided by Darrel in that thread has the same limitation as in "only" going to 655359999 which is "only" ~15% of the 32bit range.
    In my case I really do need the full 32bits since the value can and do wrap around. Displaying it signed would be cool but I'll take unsigned over what I have right now any day.
    Richard,
    Wow, thank you very much indeed!
    I have it running on a little dev.board, next is to incorporate it in the actual code, we'll see how that goes.
    Thanks again!
    A few tweaks to scrounge some resources back
        Remainder  var byte[3] SYSTEM      ; 24 bit remainder from 1000000 division
        HoursH    VAR Hours(1)
        HoursL    Var Hours(0)
        i var byte
    goto overasm
     Asm
    QUOTL=Dividend
        MOVE?BB   Din, R2
        MOVE?BB   Din + 2, R0
        RST?RP
    PutDIV?D macro Din
        RST?RP
    PutSH?D macro Din
        MOVE?BB   Din, Shift
        MOVE?BB   Din + 1 , Shift  + 1
        MOVE?BB   Din + 2, Shift   + 2
        MOVE?BB   Din + 3, Shift  + 3
        MOVE?CB   0 ,   Shift  + 4
        MOVE?CB   0 ,   Shift  + 5
        RST?RP
    Put24?D macro Din
        MOVE?BB   Din, R2
        MOVE?BB   Din + 2, R0
        MOVE?CB   0, R0 + 1
        RST?RP
    EndAsm
    '    Remainder[3]=0
    overasm:
        HoursL=$fff0
        HoursH=$7fff
        latd=18
        debug "ready",13,10
    MainLoop:
        gosub AddHourTenth
        Gosub ShowHourMeter
    AddHourTenth:
        HoursL = HoursL + 1
    ShowHourMeter:
        Test[0]=$a0       ;divisor 100000
        Test[1]=$86
        Test[2]=1
    ;@   PutDIV?D  _Hours
    @   PutSH?D  _Hours    ; take a shortcut and load shift regs directly
        debug  ,13,10
    ;@   PutMulResult?D  Remainder
    @   Put24?D  Remainder     ; only do a 24 bit load since answer is never bigger than that
        Remains = R2
    ;Div4824U
    ;Inputs:
    ;Temporary:
    ;    Counter     - Count
    ;    Shift     - Shift:6
    ;Output:
    Div4824U:
    asm
        movlw 48
        movwf Counter
        ;movff Dividend+0, Shift+0
        ;movff Dividend+1, Shift+1
        ;movff Dividend+2, Shift+2
        ;movff Dividend+3, Shift+3
        ;movff Dividend+4, Shift+4
        ;movff Dividend+5, Shift+5
        clrf Dividend+0
        clrf Dividend+1
        clrf Dividend+2
        clrf Dividend+3
        clrf Dividend+4
        clrf Dividend+5
        clrf Remainder+2
        clrf Remainder+1
        clrf Remainder+0
    dloop
        bcf STATUS, C
        rlcf Shift+0
        rlcf Shift+1
        rlcf Shift+2
        rlcf Shift+3
        rlcf Shift+4
        rlcf Shift+5
        rlcf Remainder+0
        rlcf Remainder+1
        rlcf Remainder+2
        movf Test+2, w
        btfss STATUS, Z
        bra nochk
        movf Test+1,w
        subwf Remainder+1,w
        btfss STATUS, Z
        bra nochk
        movf Test+0,w
        subwf Remainder+0,w
    nochk
        btfss STATUS, C
        bra nogo
        movf Test+0,w
        subwf Remainder+0
        btfsc STATUS, C
        bra    nodec_remainM
        decf Remainder+1, f
        movf Remainder+1, w
        xorlw 0xff
        btfsc STATUS, Z
        decf Remainder+2, f
    nodec_remainM
        movf Test+1, w
        btfss STATUS, C
            decf Remainder+2, f
        movf Test+2, w
        bsf STATUS, C
    nogo
        rlcf Dividend+0
        rlcf Dividend+1
        rlcf Dividend+2
        rlcf Dividend+3
        rlcf Dividend+4
        rlcf Dividend+5
        decfsz Counter, f
        goto dloop
     endasm
    Thanks Richard,
    I won't pretend to comprehend the assembly voodoo but I think we can shave another BYTE worth of RAM off that thing by declaring Result as a BYTE instead of a WORD. At least it seems to work :-)
    Richard,
    Just wanted to thank you once again, the code is now incorporated in my project and I can display my two 32bit variables nicely.
    I hardcoded the divisor to 100k and got rid of the Divisor variable. It grew the codebase by 230bytes and 34bytes of RAM out of which 11 is an array to which I write the result
    DWORDtoString:
        CALL DivBy100k
        ' QUOTL top word, Remainder low word.
        ' Get Remainder into PBP system variables in preparation for DIV32
            MOVE?BB   Remainder, R2
            MOVE?BB   Remainder + 1 , R2 + 1
            MOVE?BB   Remainder + 2, R0
            MOVE?CB   0, R0 + 1
            RST?RP
        Remains = R2
        IF QUOTL THEN
            ARRAYWRITE DWordString, [DEC QUOTL, DEC Result, DEC4 Remains, 0]
        ELSEIF Result THEN
            ARRAYWRITE DWordString, [DEC Result, DEC4 Remains, 0]
            ARRAYWRITE DWordString, [DEC Remains, 0]
    Is it possible to describe the method or algorithm to get the decimal from the possible 8 hexadecimal of 32 bit number.... the conversion itself is pretty straight forward but the 8 bit manipulations are confusing...
    .Name:  hex.JPG
    No problem
    Henrik glad you could make it work for you. its good to exercise the grey matter occasionally
    @amgen
    to which 8bit manipulations do you refer ?
    Bombay, India
    .Attachment 9870
    Consider this code.
    dim array[8] as byte                        ' your hex bytes ($00-$0F) are input here from MSN to LSNibble
    decimal  as long                             ' 32 bit value
         decimal = 0
         for i = 0 to 7
               decimal = decimal * 16             ' nibble max value is 16, so multiply the existing value by 16 to move decimal value one nibble to the left
               decimal = decimal + array[i]     ' add in the new nibble
         next
         ' at this point, decimal contains the converted value of the hex digits
    Is this what you're looking for?
  1. Microchip 32bit floating point to integer conversion
    By timmers in forum mel PIC BASIC Pro
    Last Post: - 1st February 2011, 16:49
  2. IEEE 754 32bit floating point value.
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 18th December 2010, 12:32
  3. Signed 32bit to ASCII?
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 7th May 2010, 22:13
  4. Retrieving 32bit Multiply Result
    Last Post: - 28th January 2008, 15:15
  5. Newbee How to get LCD to display 4-6 var words
    By emmett brown in forum mel PIC BASIC Pro
    Last Post: - 15th August 2006, 01:11
