Pic18f67k22 WDT
Results 1 to 10 of 10
Thread: Pic18f67k22 WDT
    Dec 2021
    Default Pic18f67k22 WDT
    Hello
    Is it pbp use one of the timer to monitor WATCHDOG TIMER ?
    in my program i use timer0, timer1, timer3.
    i write test loop to runout the MCU (confirmed all the i/o get "crazy"), but the WDT not restart the MCU.
    reset config setting:
    CONFIG PWRTEN = ON ;Power-up Timer
    CONFIG BOREN = SBORDIS ; Brown-out Reset Enabled in hardware, SBOREN disabled
    CONFIG BORPWR = HIGH ;BOR MV set to high power level
    CONFIG BORV = 2; 3 ; Brown-out Reset 0=3v, 1=2.7v, 2=2v, 3=1.8v
    CONFIG WDTEN = SWDTDIS ;WDT enabled in hardware; SWDTEN bit disabled
    CONFIG WDTPS = 64;512 ;WDT (i try many options from 1 to 1024)
    CONFIG STVREN = ON ;Stack Full/Underflow Reset
    i need some help please.
    Default Re: Pic18f67k22 WDT
    no.
    means very little to anyone.
    post a minimal complete and compliable version of your program that demonstrates your issue with the WDT [in code tags]
    Dec 2021
    Hi
    In this loop i load receiving scan resolute list from wifi module, and load only the ssid name and rssi to message array.
    The loop do the job perfect, but in the beginning i did mistake with "if CHECK=>AX1 THEN GOTO break33 'END OF LIST"
    So the MCU become "MAD" ,turn-on the buzzer , and few output i have on my pcb and even send "nul" at uart Tx and stay at loop forever.
    It made me wonder, why the WDT didn't reset.
    Here is the loop.
    RE var byte[998]
    Message var byte[998]
    ;AX1 is total receiving bytes.
    ;CHECK is the start point
    SearchSymbol: 'search "," Symbol
    '*** Must set T4 before send to this loop
    T1=0
    FOR A3 = CHECK TO AX1'
    IF RE[A3]=Symb THEN T1=T1+1
    IF T1=T4 THEN break9
    NEXT A3
    break9:
    CHECK=A3
    '*** load all +SCAN SSID,RSSI list to Message array ***
    GET_SSID_list:
    MessageL=0
    T4=2 'multiple of the symbol x time "space"
    GET_SSID_list1:
    Symb=" " '"Space"
    GOSUB SearchSymbol 'Search THE SYMBOLE
    CHECK=CHECK+1 'to jump on the "space"
    if RE[CHECK]="," THEN  'If hidden wifi move to next line
                T4=1 'multiple of the symbol
                goto  GET_SSID_list1
    FOR A3 = CHECK TO AX1 'Get SSID name
    if RE[A3]="," then break31
    Message[MessageL]=RE[A3]
    MessageL=MessageL+1
    next A3
    break31:
    T4=2 'multiple of symbol,  JUMP on channel
    Symb=","
    gosub SearchSymbol
    CHECK=A3+1 'jump on ","
    Message[MessageL]="," 'insert "," Between ssid to rssi  (ssid,rssi)
    MessageL=MessageL+1
    FOR A3 = CHECK TO AX1 'Get RSSI
    if RE[A3]=$D then break32 'CR
    MessageL=MessageL+1
    NEXT A3
    break32:
    CHECK=A3
    Message[MessageL]=$A 'insert LF
    MessageL=MessageL+1
    GOTO GET_SSID_list1 'Next line
    break33:
    i see a code snippet that cannot be compiled.
    a code snippet not in code tags.
    a code snippet that does not demonstrate in any way how you have configured the wdt
    a code snippet that does not demonstrate how you have employed any clrwdt instructions to
    achieve a reset when needed
    a minimal, complete and verifiable example MCVE is the best way to get help
    https://stackoverflow.com/help/minim...ucible-example
    Dec 2021
    Hello Richard
    Apologies, I have attached a file for review.
    '*  Notice  : Copyright (c) 2024 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 11/16/2024                                        *
    #config
     CONFIG RETEN=OFF
     CONFIG XINST = OFF ;Extended Instruction Set
     CONFIG FOSC = INTIO2 ;internal RC oscillator
     ;CONFIG FOSC = EC3  ; HS oscillator (high power > 16 MHz)
     CONFIG SOSCSEL=DIG
     ;CONFIG SOSCSEL=HIGH
     CONFIG FCMEN = OFF   ;Fail-Safe Clock Monitor ****
     CONFIG IESO = OFF  ;Two-Speed Start-up is disabled
     CONFIG PLLCFG = OFF  ;4x xtal PLL
     CONFIG BORV = 2 ; Brown-out Reset  0=3v, 1=2.7v, 2=2v, 3=1.8v
     CONFIG WDTEN = SWDTDIS ;ON ;OFF ;WDT enabled in hardware; SWDTEN bit disabled
     CONFIG RTCOSC = INTOSCREF  ; RTCC uses INTRC
     ;CONFIG  ECCPMX = PORTH ; Enhanced CCP1/3 [P1B/P1C/P3B/P3C] muxed with RH7/RH6/RH5/RH4 (pwm)
     ;CONFIG  CCP2MX = PORTBE ;PORTC
     CONFIG  MCLRE = ON
    ; CONFIG BBSIZ = BB1KL ; 1K word Boot Block size
    ; CONFIG BBSIZ = BB2K  ; 2K word Boot Block size
     CONFIG DEBUG = OFF ;Background Debugger
     CONFIG CP0 = ON  ;code-protected
     CONFIG CP1 = ON
     CONFIG CP2 = ON
     CONFIG CP3 = ON
     CONFIG CP4 = ON
     CONFIG CP5 = ON
     CONFIG CP6 = ON
     CONFIG CP7 = ON
     CONFIG CPB = ON  ;Boot Block Code Protection
     CONFIG CPD = ON  ;Data EEPROM Code Protection
    ; CONFIG CP0 = OFF  ;code-protected
    ; CONFIG CP1 = OFF
    ; CONFIG CP2 = OFF
    ; CONFIG CP3 = OFF
    ; CONFIG CP4 = OFF
    ; CONFIG CP5 = OFF
    ; CONFIG CP6 = OFF
    ; CONFIG CP7 = OFF
    ; CONFIG CPB = OFF  ;Boot Block Code Protection
    ; CONFIG CPD = OFF  ;Data EEPROM Code Protection
    #endconfig
    'DEFINE RESET_ORG 4000h'4000h HID bootloader must org the program at 2000 HEX
    include "fp1832L.bas"
    'include "FLASH.bas"
    '*** At 64MHz each instruction cycle is 62.5ns
    OSCCON=%11110100 'OSCILLATOR CONTROL & Frequency  (16M RC)
    OSCTUNE.6=1 'Frequency Multiplier PLL Enable bit FOR INIT RC
    DEFINE OSC 64
    INTCON2.7=1 'PORTB Pull-up Disable
    PADCFG1.7=0 'PORTD Pull-up Disable
    PADCFG1.6=0 'PORTE Pull-up Disable
    PADCFG1.5=0 'PORTJ Pull-up Disable
    ANCON0=0 'AN0-AN7 digital port
    ANCON1=0 'AN8-AN15 digital port
    ANCON2=0 'AN16-AN23 dig
    CM1CON.7=0 'COMPERATOR1 OFF
    CM2CON.7=0 'COMPERATOR2 OFF
    CM3CON.7=0 'COMPERATOR3 OFF
    PSPCON.4=0 'General Purpose I/O mode 'PSPMODE: Parallel Slave Port Mode Select bit
    Restart:
    TRISA=$FF
    TRISB=$FF
    TRISC=$FF
    TRISD=$FF
    TRISE=$FF
    TRISF=$FF
    TRISG=%11111
    TRISC=%10111110
    LATC.0=1 'HOST RTS 1=STOP SEND 0=ALOW TO SEND
    '*C.1=MODULE RTS
    '*C.2=1 Pump Sence
    '*C.3=SCL RTC
    '*C.4=SDA RTC
    '*C.5=MFP RTC
    LATC.6=1 'Tx1  WiFi
    '*C7=RX1 WiFi
    TRISA=%11101110 '
    LATA.0=1 'PD_SCK HX711 low power mode
    '*A0=PD_SCK HX711
    '*A1=DOUT HX711
    '*A2= HX711 TEMP SENSOR '02-09-2024
    '*A3= INT  IC PCAL6524HEAZ   '02-09-2024
    '*A5= general I/O connected to Test Point X16  '02-09-2024
    latA.4=1 'wifi BW16 Reset/Disable 1=Reset/Disable
    TRISB=%11111111
    'B0-B4 not connected
    '*B5= GENERAL I/O
    '*B6=PROGRAMMING
    '*B7=PROGRAMMING
    TRISD=%00100011
    ' RD0 = scl2  AT24C16
    ' RD1 = sda2  AT24C16
    LATD.2=0  'Buzzer
    LATD.3=0  'External Unit Power on/off 1=on
    LATD.4=0 'SDO2 FLASH
    'D5=SDI2 FLASH
    LATD.6=0 'SCK2 FLASH
    LATD.7=1 'SS2 FLASH WP WRITE PROTECTION (0=PROTECT  1=ENABLE)
    TRISE=%10011100
    LATE.0=0 'HOLD FLASH  1=ACTIVE 0=HOLD
    LATE.1=1 'CE FLASH  0=ENABLE 1=DISABLE
    '*E2-E3= n.c
    '*E4= Extension i/o
    LATE.5=0 '1= Reset IC PCAL6524HEAZ
    LATE.6=0 'AO3400A PWM6
    '*E7= n.c
    TRISF=%11111111
    '*F0= n.c
    '*F1= Power Fail input
    '*F2= n.c
    '*F3=Current Sense
    TRISF.4=0 : LATF.4=1 ' Software Tx
    '*F5= Software Rx
    '*F6= Extension GENERAL I/O
    '*F7= Extension GENERAL I/O
    TRISG=%11101
    '*G0= Busy
    LATG.1=1 'TX2
    '*G2= RX2
    '*G3= Extension GENERAL I/O
    '*G4= Extension GENERAL I/O
    '**** WIFI ****
    DEFINE HSER_SPBRG 34  ' 115200 Baud @ 64MHz, -0.79%
    '**** Uart 2 ****
    DEFINE HSER2_RCSTA 90h ' Enable serial port & continuous receive for RAFID
    DEFINE HSER2_TXSTA 24h ' Enable transmit, BRGH = 1
    DEFINE HSER2_SPBRG  34  ' 115200 Baud @ 64MHz, -0.79%
    DEFINE HSER2_CLROERR 1 ' Clear overflow automatically
    '**** Debug  ****
    DEFINE DEBUG_REG PORTF
    DEFINE DEBUG_BIT 4
    DEFINE DEBUG_BAUD 115200
    DEFINE DEBUG_MODE 0  '0=TRUE 1=INVERTER
    A VAR BYTE  'general use
    RE VAR BYTE[999]' wifi Rx buffer
    'SSID_N VAR BYTE[32] 'SSID NAME buffer
    'SSID_nC VAR BYTE  'SSID NAME BYTE COUNTER
    'SSID_P VAR BYTE[128]  'SSID PASWORD buffer
    'SSID_pC VAR BYTE  'SSID PASSWORD BYTE COUNTER
    A1 VAR WORD
    A2 VAR WORD
    A3 VAR WORD
    CHECK VAR WORD
    COUNT_A VAR BYTE[50]
    T VAR BYTE[50]
    T1 VAR BYTE
    T2 VAR WORD
    T3 VAR BYTE
    T4 VAR BYTE
    Tlong VAR long '
    AX1 VAR WORD  'WIFI
    AX2 VAR WORD  'WIFI
    Message var byte[500] '  for APP
    MessageL VAR WORD 'Message Length
    RSSI var LONG 'SSID signal
    RxEvent var LONG 'wifi
    ReplyEvent VAR LONG 'WIFI
    Symb VAR BYTE
    CLEAR
    'Note: at GET_SSID_list1 loop, remove " if CHECK=>AX1 THEN GOTO break33 '   ***** to runout MCU *****
    Gosub DEMO_RECEIVE 'Simulation of receiving DATA from wifi module
    gosub Decoding 'Decoding the received data
    debug "SSID LIST:<ssid>,<rssi>",$D,$A,STR Message\MessageL
    Decoding: 'Decoding the received data
    ''*** 128 Indicates end of array ****
    arraywrite T,["+WSCAN:",128] 'COUNT_A[15]  'search '+WSCAN:
    T3=18 'COUNT_A[] number
    GOSUB ConfirmMessage
    if COUNT_A[18]=$FF THEN 'found?
                         RxEvent.18=1
                         COUNT_A[18]=0
                         GOSUB GET_SSID_list 'load the SSID list to the Message array
    '**** SEARCH MESSAGE AT RECEIVED ARRAY ****
    ConfirmMessage:
    for T4 = 0 to 49  'GET T array Length
    if T[T4]=128 THEN GOTO break5
    NEXT T4
    break5:
    FOR CHECK = 0 TO AX1
    IF RE[CHECK]=T[0] THEN 'confirm the first charter at T array
                        COUNT_A[T3]=COUNT_A[T3]+1
                        FOR T1= 1 TO T4-1  'the number of charter need to confirm
                        IF RE[CHECK+T1]=T[T1] THEN
                                                COUNT_A[T3]=COUNT_A[T3]+1 'if charter true then count
                                                COUNT_A[T3]=0  'if one of charter not the same, clear counter
                                                goto break24
                        next T1
                        break24:
                        if COUNT_A[T3]=T4 THEN
                                            COUNT_A[T3]=$FF 'True
    '                                        if T3=7 then  ReplyEvent.14=1  '+WSCANACTIVE Confirm found the ssid   'RxEvent.14
    '                                        if T3=19 THEN ReplyEvent.19=1 '+WSCAN Confirm found the ssid  'RxEvent.19
                                            GOTO break7
    'IF pir1.0 THEN gosub CLEAR_TIMER1'TIMER1 OVER FLOW 20ms
    next CHECK
    break7:
    T[T4]=0 'clear T
    DEMO_RECEIVE:
    arraywrite RE,[$d,$a,_
    "+WSCAN:index SSID,CH,RSSI",$d,$a,_
    "1 TP-Link_Guest_ABD6_5G,48,-42",$d,$a,_
    "2 TP-Link_ABD6,48,-42",$d,$a,_
    "3 ,48,-42",$d,$a,_
    "4 TP-Link_ABD6,1,-45",$d,$a,_
    "5 TP-Link_Guest_ABD6,1,-45",$d,$a,_
    "6 ,1,-45",$d,$a,_
    "7 Mamad_EXT2,4,-46",$d,$a,_
    "8 Mamad_EXT5g 2,48,-48",$d,$a,_
    "9 ,10,-57",$d,$a,_
    "10 HOME,11,-68",$d,$a,_
    "11 HOME_EXT,11,-74",$d,$a,_
    "12 ,52,-80",$d,$a,_
    "13 HOME_5G,52,-80",$d,$a,_
    "14 HOTWiFi-D7D,6,-85",$d,$a,_
    "15 HOME_5G_EXT,52,-85",$d,$a,_
    "16 Mali,6,-89",$d,$a,_
    "17 lior,11,-92",$d,$a,_
    $d,$a,"OK",$d,$a]
    'Rx Byte:360
    AX1=360 'received byte
    T1=0
    NEXT A3
    break9:
    CHECK=A3
    GET_SSID_list:
    MessageL=0
    GET_SSID_list1:
    Symb=" " '"Space"
    if CHECK=>AX1 THEN GOTO break33 'END OF LIST    ***** REMOVED to runout MCU *****
                goto  GET_SSID_list1
    MessageL=MessageL+1
    next A3
    break31:
    Symb=","
    gosub SearchSymbol
    MessageL=MessageL+1
    MessageL=MessageL+1
    NEXT A3
    break32:
    CHECK=A3
    MessageL=MessageL+1
    break33:
    Use this tags to embed the code:
    [ code ]
    [/ code ]
    without spaces.
    a simple example to demonstrate WDT
    '****************************************************************'*  Name    : UNTITLED.BAS                                      *
    '*  Author  : richard                                           *
    '*  Notice  : Copyright (c) 2024 caveat emptor                  *
    '*  Date    : 17/11/2024                                        *
    #config
     CONFIG RETEN=OFF
     CONFIG SOSCSEL=DIG
     CONFIG WDTPS = 512 ;WDT     512*4Ms = 2 SECONDS
     CONFIG  MCLRE = ON
     CONFIG CP1 = ON
     CONFIG CP2 = ON
     CONFIG CP3 = ON
     CONFIG CP4 = ON
     CONFIG CP5 = ON
     CONFIG CP6 = ON
     CONFIG CP7 = ON
    #endconfig
    DEFINE NO_CLRWDT 1 'Don’t insert CLRWDTs
    DEFINE DEBUG_REG PORTD
    DEFINE DEBUG_BIT 4
    DEFINE DEBUG_BAUD 9600
    DEFINE OSC 64
        TRISD=$ed
        latd=18
        @ CLRWDT        ;WDT needs to be cleared every   512*4Ms = 2 SECONDS  at most else chip will reset
        @ CLRWDT
        debug "ready",13,10
        @ CLRWDT
        MAIN:              ; if porta.0 is not detected going high the wdt will overflow and reset chip
            LATD.1=0
            IF PORTA.0 THEN
                @ CLRWDT       ; in main loop the wdt is cleared when porta.0 goes high
                WHILE PORTA.0 : WEND
        GOTO MAIN
    stop
    ************************************************** **************'* Name : UNTITLED.BAS *
    '* : All Rights Reserved *
    '* Version : 1.0 *
    '* Notes : *
    #config
    CONFIG RETEN=OFF
    Are you a wizard of some kind.......... you wrote/posted this a day ahead of today...... writing now in the future ??????
    warning: I am an idiot!
    the world is not flat , time is relative
    Dec 2021
    Hello Richard
    Thanks a lot for the help.
  1. Replies: 8
    Last Post: - 18th September 2017, 23:29
  2. What commands reset the WDT?
    By pointjohn in forum mel PIC BASIC Pro
    Last Post: - 4th November 2010, 16:47
  3. Detect reset by WDT
    By Art in forum mel PIC BASIC Pro
    Last Post: - 13th April 2010, 08:34
  4. SLEEP, WDT and INT
    Last Post: - 30th March 2008, 14:45
  5. WDT-Reset - How to know
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 12th November 2005, 17:33
