64 pin 18F series MCU, which operates from 5V and has same pinout as 16F series?
+ Reply to Thread
Results 1 to 3 of 3
    Default 64 pin 18F series MCU, which operates from 5V and has same pinout as 16F series?
    Hello.
    I really do not know in which part of forum to ask, so move this topic according to your decision.
    I have the following issue. I have PCB designed for 16F1947 chip, in 64 pin package.
    However, I need 64mhz clock speed with internal osc (this is important) and 5V operation (NOT 5V tolerant pins)
    And I got stuck there.
    For example, PIC18F66K80 meets all these requirements, except pinout, and PIC18F8722 has same pinout as 16F series, operates from 5V, but can only do 32mhz with intosc.
    So I'm searching for non-existent chip or I missed something?
    Apr 2025
    Default Re: 64 pin 18F series MCU, which operates from 5V and has same pinout as 16F series?
    Likely no direct drop-in with those exact specs. Consider lower speed, external clock, or other PIC families (needs PCB change).
    Yes, I already started re-designing the PCB, and discovered that there's an error in datasheet - PIC18F66K80 actually has 52 IO pins, not 54, as stated in the beginning of datasheet!
  1. 18F series performance not so good?
    Last Post: - 13th January 2023, 07:32
  2. Replies: 2
    Last Post: - 31st October 2017, 17:04
  3. Moving on to 18F series.
    By Tina10 in forum mel PIC BASIC Pro
    Last Post: - 4th September 2012, 05:50
  4. 18F series challenges
    By Charlie in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2011, 15:32
  5. 18f series chip locked up
    By glkosec in forum mel PIC BASIC Pro
    Last Post: - 11th August 2009, 07:27
Members who have read this thread : 15
