Voltage regulation circuit 12V to 5V in 5A range
+ Reply to Thread
Results 1 to 40 of 83
    Default Re: Voltage regulation circuit 12V to 5V in 5A range
    Ten dollars is quite enough. I'd select that 1oz too.
    Maybe and more caps too.
    I ordered 2 models:
    - 4 layers, all 1 oz, 5 for $147 including shipping and duties, $29.40 each
    - 2 layers, all 1 oz, 5 for $108 including shipping and duties, $21.60 each
    I was able to stay on Economic price by avoiding 2oz layers, and remained at recommended area size by TI.
    Output caps, 47uF (recommended), 10uF and 1uF.
    I was tempted to add 0.1uF and 0.001uF but I thought I might be exaggerating. I can still add them in the final version if you guys think I should; I have room and it's not like they cost anything.
    At least I'll have something to see how it ripples using PWM from transistors and mosfets.
    I can also push it for heat test by PWMing a whole roll of LED strip.
    I can get the price down a bit more by using another inductor:
    Current: XAL1010-332MED by Coilcraft, $4.4191 x 5 = $22.10
    Alternative: SRP1265A-3R3M by Bourns, $1.5387 x 5 = $7.70
    That's a difference of $14.40 ($2.88/unit)
    I didn't use the Bourns cause I'd have to order a minimum of 10 from Mouser, and that takes 8-15 lead days, and I wanted my PCB for testing yesterday.
    There was 73 inductors in stock from Coilcraft, but that's already down to 38 (I only used 10 in my 2 orders).
    Ioannis, have you had any experience ordering from Element or Onlinecomponents?
    Once I get my order and done some testing, I'll be in a better position to know what configuration of layers I'm going to need.
    I'm always getting emails from PCB assembly suppliers from alibaba, so I'll to make a RFQ for that "winning" configuration.
    Just to see if I can get anything better than JLCPCB.
    That'll also give me a chance to find a good competitor for my PCBs in the future. But I gotta admit, JLCPCB's online system is pretty slick once you get used to it.
    No. My country adds a lot of import taxes so I select suppliers within European Union or Mouser that ships tax free.
    May main suppliers are Mouser, TME, SOSelectronics and local resellers for larger quantities.
    Regarding the inductors, I think either Coilcraft or Burns (or other reputable brands) will make no difference, as long as you select one that has the specs.
    At testing time you will see if adding more caps on output of the power supply makes any significant difference. Can't tell right now.
    For mass production of assembled pcb JLCPCB may be more expensive. I usually do this for no more than 20-30 pcs, depending on the component count too. Greater production is cheaper for me if I do it locally and just order only the pcb's from JLCPCB.
    Assembled, checked each header and basic test on v1; 2 layer, 1-1oz.
    Name:  First test 1-1oz layers.jpg
    Now I need to finish my load tester using this puppy.
    Name:  Power resistor 200W 1R.jpg
    The plan is to PWM the power resistor while monitoring current, and using E02 thermal camera to watch heat spots on PCB.
    Still undecided if using N or P channel logic-level MOSFET. I have yet to find a good tutorial to determine the base resistor.
    Tested on prototype board; 430mA.
    Name:  First test v1 430mA.jpg
    Top side, TPS56637 step-down IC is the hottest at 25C, followed by inductor and switch bracket. I just touched power jack at far left, so that's not actual temp.
    Name:  First test v1 430mA top.jpeg
    Bottom side, center is at 23C, the max spots are my finger (can see through top left mounting hole too) and LED strip in background.
    Name:  First test v1 430mA bottom.jpeg
    That's insane compared to 7805 or LM1084. Humungous difference in efficiency and heat (never expected it to be so much difference).
    I can touch this with my fingers.
    The LM1084 was maxxing out near 124C, and that was only at 300mA with heatsinks on front and back.
    Name:  LM1084 4 300ma front.jpeg
    I'm both flabber and gasted.
  1. upg D1730 automatic lead acid battery charger circuit board 12v 500ma
    By koenton in forum FAQ - Frequently Asked Questions
    Last Post: - 9th June 2012, 17:28
  2. One Circuit, Three Different Voltage Levels
    By rsocor01 in forum General
    Last Post: - 22nd April 2010, 13:27
  3. Adding voltage to a circuit
    By Tobias in forum General
    Last Post: - 28th May 2008, 20:11
  4. Replies: 3
    Last Post: - 29th October 2006, 09:16
  5. 3.6v regulation
    By barkerben in forum General
    Last Post: - 13th December 2005, 02:32
Members who have read this thread : 15
