Voltage regulation circuit 12V to 5V in 5A range
+ Reply to Thread
Results 1 to 40 of 83
    Default Re: Voltage regulation circuit 12V to 5V in 5A range
    Wow! You did a lot of work!
    I am pretty sure that the extra layers TI suggest are for less noise ad better heat dissipation. Have you checked how much extra cost is added by JLCPCB?
    In general if you want/need to make the board smaller, you can move all componets to the left, connector closer to the inductor and the right board edge also moved to the left. I don't see why this pcb needs to be that large. Saves cost also I guess.
    I'd add an extra output capacitor for less noise and better operation without much cost. Parallel capacitors make for lower ESR also.
    Nice design. You become an KiCad expert!
    EDIT:
    At first I was tempted to make 2 prototypes; 2 layers and 4 layers; just to see if the extra cost is worth it. But the more I think about it, the more I'm leaning for the 4-layer design.
    Two of the main objectives with this circuit is to reduce heat and stabilize the voltage (ripples). If the pros design their Eval board to that size with 4 layers, I can't really see why I should consider cutting corners.
    But boy am I tempted.
    ...Have you checked how much extra cost is added by JLCPCB? ...
    Not yet, I wanted to get as close to a "finalized design" before using JLCPCB's quote generator.
    ... I'd add an extra output capacitor for less noise and better operation without much cost. Parallel capacitors make for lower ESR also. ...
    I didn't know that about the lower ESR.
    EDIT the CAPS section
    I just noticed the datasheet has a range of output capacitance at 5V from 25 to 100uF (table 4). So I just added 10uF and 1uF ceramics alongside the 47uF.
    These guys have a nice bla-bla about "why there can be too much output capacitance on SMPS circuits":
    https://www.cui.com/blog/understandi...citance-limits
    ... Nice design. You become an KiCad expert!
    Thanks, but I can't really take credit for the design. I feel like Mr. Bean copying the test answers from the guy next to him. I really did put a lot of effort to do as close to what TI recommends.
    As for "Kicad expert", that remains to be seen.
    Well, if I'm going to have all that unused real-estate at the top, might as well do something with it:
    - DC jack,
    - power switch,
    - multiple output headers,
    - amp and volt test points.
    It's all parts I have on hand, so it's not really costing me more. I don't see how it would disturb the cooling, since TI placed all the ventilation holes on the bottom section. It anything, it's extra cooling fins.
    Name:  TPS56637 3D final.png
    Now I just have to remember to slap a jumper on the amp test point for the circuit to work.
    ... Have you checked how much extra cost is added by JLCPCB? ...
    4 layers with 2-1-1-2 ounces with assembly, the area of my circuit jumps from 63mm x 50mm up to 73mm x 70mm.
    2oz $32.20
    1oz $16.07
    Another issue, I can't use Economy with 0201 SMD, i have to use Standard. I had to swap 0201 resistor and capacitor for 0402.
    Final bill for 5 PCBs:
    - PCB $55.45
    - Assembly $83.89
    - Total $165.21 (with UPS shipping), $33.04 each PCB.
    Plan B:
    1oz all layers
    PCB $23.15
    PCBA $67.92
    Ship $ 25.87
    Total $116.94, $23.39 each PCB.
    Tempted to go with plan B. It's not like I'm going to push 5 amps, most likely 2.5A at best.
    Ten dollars is quite enough. I'd select that 1oz too.
    Maybe and more caps too.
    I ordered 2 models:
    - 4 layers, all 1 oz, 5 for $147 including shipping and duties, $29.40 each
    - 2 layers, all 1 oz, 5 for $108 including shipping and duties, $21.60 each
    I was able to stay on Economic price by avoiding 2oz layers, and remained at recommended area size by TI.
    Output caps, 47uF (recommended), 10uF and 1uF.
    I was tempted to add 0.1uF and 0.001uF but I thought I might be exaggerating. I can still add them in the final version if you guys think I should; I have room and it's not like they cost anything.
    At least I'll have something to see how it ripples using PWM from transistors and mosfets.
    I can also push it for heat test by PWMing a whole roll of LED strip.
    I can get the price down a bit more by using another inductor:
    Current: XAL1010-332MED by Coilcraft, $4.4191 x 5 = $22.10
    Alternative: SRP1265A-3R3M by Bourns, $1.5387 x 5 = $7.70
    That's a difference of $14.40 ($2.88/unit)
    I didn't use the Bourns cause I'd have to order a minimum of 10 from Mouser, and that takes 8-15 lead days, and I wanted my PCB for testing yesterday.
    There was 73 inductors in stock from Coilcraft, but that's already down to 38 (I only used 10 in my 2 orders).
    Ioannis, have you had any experience ordering from Element or Onlinecomponents?
    Once I get my order and done some testing, I'll be in a better position to know what configuration of layers I'm going to need.
    I'm always getting emails from PCB assembly suppliers from alibaba, so I'll to make a RFQ for that "winning" configuration.
    Just to see if I can get anything better than JLCPCB.
    That'll also give me a chance to find a good competitor for my PCBs in the future. But I gotta admit, JLCPCB's online system is pretty slick once you get used to it.
    No. My country adds a lot of import taxes so I select suppliers within European Union or Mouser that ships tax free.
    May main suppliers are Mouser, TME, SOSelectronics and local resellers for larger quantities.
    Regarding the inductors, I think either Coilcraft or Burns (or other reputable brands) will make no difference, as long as you select one that has the specs.
    At testing time you will see if adding more caps on output of the power supply makes any significant difference. Can't tell right now.
    For mass production of assembled pcb JLCPCB may be more expensive. I usually do this for no more than 20-30 pcs, depending on the component count too. Greater production is cheaper for me if I do it locally and just order only the pcb's from JLCPCB.
    Assembled, checked each header and basic test on v1; 2 layer, 1-1oz.
    Name:  First test 1-1oz layers.jpg
    Now I need to finish my load tester using this puppy.
    Name:  Power resistor 200W 1R.jpg
    The plan is to PWM the power resistor while monitoring current, and using E02 thermal camera to watch heat spots on PCB.
    Still undecided if using N or P channel logic-level MOSFET. I have yet to find a good tutorial to determine the base resistor.
  1. upg D1730 automatic lead acid battery charger circuit board 12v 500ma
    By koenton in forum FAQ - Frequently Asked Questions
    Last Post: - 9th June 2012, 17:28
  2. One Circuit, Three Different Voltage Levels
    By rsocor01 in forum General
    Last Post: - 22nd April 2010, 13:27
  3. Adding voltage to a circuit
    By Tobias in forum General
    Last Post: - 28th May 2008, 20:11
  4. Replies: 3
    Last Post: - 29th October 2006, 09:16
  5. 3.6v regulation
    By barkerben in forum General
    Last Post: - 13th December 2005, 02:32
Members who have read this thread : 13
