Nope. But I'm using a IRFZ44N n-channel to PWM the LED strip with has similar specs.
Good idea. Choosing the proper resistors to drive the MOSFET is still a black art to me.
Because when I first started testing blue-on-white LCDs, I was PWMing both the Contrast (V0) and Backlight (LedA). I didn't even consider MOSFETs and went straight to transistors since we're not talking about a lot of current. Why I chose PNP transistors back then is a mystery; maybe I saw a schematic on google and copied that.
I've since switched to white-on-black LCDs, I don't need to have adjustable Contrast (V0). So controlling the Backlight with a PNP transistor is just "the old way of doing things". But since noise has become an issue, getting a P-channel MOSFET seemed like the logical way to replace the PNP.
But if I had thought about it for 2 seconds, I would have realized I have access to both the Anode and Cathode on the Backlight. Since I already have an IRFZ44N on the circuit, it would cost less at JLCPCB to use another IRFZ44N instead of a second type of component.
So that's the long-winded way of me saying that now I'm going to swap the 2N2907A PNP to a IRFZ44N n-channel.
Funny story, I finally realized the letter at the end of a MOSFET seems to indicate the channel. I don't know if it holds true for all, but it's working for the first two that I researched.
