Voltage regulation circuit 12V to 5V in 5A range
+ Reply to Thread
Results 1 to 40 of 83
    Default Re: Voltage regulation circuit 12V to 5V in 5A range
    Right now I'm just basking in the glory of having found the root cause of most of that noise on the lines, and started looking for a source of affordable "good" 9V 5A power adapters.
    not trying to 'rain on your parade'..... it is possible that isn't where your noise is coming from...... if you haven't already, put a 10 or 100 microfarad electrolytical and a couple of .1 or .01 microfarad caps at the output of the power supply..... and I didn't look to see but you would want to put the same capacitor duo on each separate circuit board..... that SHOULD squash the noise. Plus..... a bunch of interconnected grounds running here and there are often culprits for noise. And keep in mind that often serious engineers and engineering is involved with noise and interference
    Also breadboards are the worse for low noise circuits!
    VDD with all ADC pots OFF; VDD is super stable.
    Name:  2N2907 jitter before.jpg
    I control the contrast on all 4 LCDs with PWM on a 2N2907:
    Name:  2N2907 jitter.jpg
    Guess what happens to VDD when I turn up the contrast:
    Name:  2N2907 jitter after.jpg
    that seems a strange way to control the contrast.
    how does it go if you set the contrast the normal way ?
    anecdotally contrast by pwm needs a substantial LPF otherwise all sorts of nasty artefacts are introduced
    perhaps a schematic would enlighten things
    that seems a strange way to control the contrast. ...
    Sorry, contrast is hardwired to prevent the user from burning out the LCD. It's the backlight that's PWMed.
    Name:  V0 and BL.png
    Backlight is controlled by PWM from a 2N2907A because it controls the 4 physical LCDs simultaneously as well as the radio in-game via USB:
    Name:  Cockpit 50pct radio.png
    I'm waiting on some IRF5305P hexfets to replace the 2N2907A. Hopefully they're less noisy.
    does that drive all four backlights ?
    where does led cathode go ?
    if the cathode goes to vss then no wonder its noisy
    the fet should make it worse
  1. upg D1730 automatic lead acid battery charger circuit board 12v 500ma
    By koenton in forum FAQ - Frequently Asked Questions
    Last Post: - 9th June 2012, 17:28
  2. One Circuit, Three Different Voltage Levels
    By rsocor01 in forum General
    Last Post: - 22nd April 2010, 13:27
  3. Adding voltage to a circuit
    By Tobias in forum General
    Last Post: - 28th May 2008, 20:11
  4. Replies: 3
    Last Post: - 29th October 2006, 09:16
  5. 3.6v regulation
    By barkerben in forum General
    Last Post: - 13th December 2005, 02:32
Members who have read this thread : 13
