SOLVED: How can I reduce ADC jitter
Results 1 to 40 of 96
Threaded View
  1. #11
    Default Re: SOLVED: How can I reduce ADC drift
    - did not touch VREFs,
    What do you mean by this , you have changes pos vref to fvr buffer1- used FVR 4x with 5 VDC in,
    which will turn out to be a mistake since pots use vdd as top input , by doing this you have lost 20% of their travel range
    Anything over VREF+ will be interpreted as the max ADC output. Anything lower than VREF- will be interpreted as the min ADC output value.
    There will be no damage if you exceed VREF+/VREF- as long as you don't exceed Vdd/Vss
    - used FOSC / 128,way too slow , while not out of acceptable range fosc/32 is more reasonable
    - used average of 16 ADC readings,
    not sure about that , its not necessary either if every thing else is ok
    - used USART to show results
    - added PAUSEUS 1 after all ADC operations - THIS NEEDS TO BE VERIFIED IF IT'S NECESSARY, it was just to make sure things worked.
    it does nothing useful
    my schema , added another supply rail straddling 10k pot , without series wiper resistor to an2
    not no none nil caps across an inputs
    typical raw readings
    R 827    669
    R 826    669
    R 826    669
    R 826    668
    R 825    669
    R 827    669
    R 826    669
    R 826    669
    R 826    668
    R 825    668
    R 827    670
    R 826    669
    R 825    668
    R 827    669
    R 827    669
    __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_ON
    __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_ON & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    __config _CONFIG4, _WRT_OFF & _SCANE_available & _LVP_ON
    DEFINE OSC 32
    DEFINE DEBUG_REG PORTC
    DEFINE DEBUG_BIT 0 ; if not used for pwr
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 0
    DEFINE ADC_BITS 10 ' 10-bit Analog to digital
    DEFINE ADC_SAMPLEUS 5 ' Set sampling time in uS
    ANSELA = % 00000101 ' Pins A0 A2 = ADC
    TRISA = % 11101111 ' Pin A4 = LED
    TRISD = % 11111011 ' DEBUG
    LATC.0 = 1 ' DEBUG
    clear
    LED VAR LATA.4
    i var byte
    j var word
    bucket var WORD
    ADCinput var WORD
    mean var WORD
    buckets var word[21]
    outlier var WORD
    LED = 1 'Proof of Life
    PAUSE 2000
    DEBUG 13,10,"READY",13,10
    FVRCON = % 10000011
    ;ADCON0 = % 10000100 ;NOT USED
    ADREF = % 00000000
    ADCLK = 15
    LED=0
    Mainloop:
    ;NOTE an inputs sampled twice to overcome pbp poor adc ch changes
    ADCIN 0, ADCinput
    ADCIN 0, ADCinput
    DEBUG 13,10,"R ",DEC ADCinput,9
    ADCIN 2, ADCinput
    ADCIN 2, ADCinput
    DEBUG DEC ADCinput
    PAUSE 500
    GOTO Mainloop
    i just tried it without the double adc reads on input change and it works ok , so that's not an issue anymore it seems
    [i very rarely if ever use the adcin command , prefer to use asm sequences instead]
  1. SOLVED - IOC works on B0 but not B5
    By Demon in forum General
    Last Post: - 26th September 2024, 22:11
  2. Replies: 6
    Last Post: - 5th November 2023, 17:26
  3. trying to reduce current consumption on a 12HV615
    By Max Power in forum mel PIC BASIC Pro
    Last Post: - 30th November 2011, 15:57
  4. Unwanted output signal jitter
    By LinkMTech in forum mel PIC BASIC Pro
    Last Post: - 18th January 2008, 03:31
  5. Dmx Solved !!!!!!!
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 22:57
Members who have read this thread : 9
