SOLVED: How can I reduce ADC jitter
+ Reply to Thread
Results 1 to 40 of 96
    Default Re: SOLVED: How can I reduce ADC drift
    Coupling changed to AC.
    to measure ac noise on rail , noise hopefully in mV and not to many of them
    Coupling changed to DC.
    for any dc , logic measurements
    1. Honestly I expected no jitter on the voltage-divider, thinking FVR would remove 1/2 the instability, leaving only VS as a variable source for comparison.
    raw adc will never have no jitter
    2. As for the pots, I had no idea what "realistic" is, they don't mention that in google tutorials.
    the word you want here is resolution, if you had a 1k pot and 10 bit adc you could resolve it to 1 ohm steps in theory
    but adc is always has +- count , jitter free might get to 255 steps, you need to design for the outcome desired
    3. I'm sure I could get something useful out of 10-bit results. Just not sure how to go about massaging the result.
    depending on noise and needed resolution there are ways , from simple division, averaging or oversampling
    4. I also would have liked to try the ADC2 feature like AVERAGE. I assume it'a a hardware equivalent of what Melanie was doing.
    its not designed to average more than one ch and need exclusive use of the adc but have a go
    ...its not designed to average more than one ch and need exclusive use of the adc but have a go
    23.0 ANALOG-TO-DIGITAL CONVERTER WITH COMPUTATION (ADC2) MODULE
    The Analog-to-Digital Converter with Computation (ADC2) allows conversion of an analog input signal to a 10-bit binary representation of that signal. This device uses analog inputs, which are multiplexed into a single sample and hold circuit.
    We can't switch ADPCH manually between each Average?
    About that bug to ADCIN twice:
    23.1 ADC Configuration
    Note: It is recommended that when switching from an ADC channel of a higher voltage to a channel of a lower voltage, the software selects the VSS channel before switching to the channel of the lower voltage.
    I'm trying to switch ADPCH to 111100 = AVSS (Analog Ground) before each ADCIN to see if that fixes the problem.
    They seem to mean when you change power rail, but maybe there's a bug when "the higher voltage" is within the same rail (like changing from 1V up to 4V).
    I haven't studied your code yet, this is where I am at trying to get FVR and Average:
    __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_OFF & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    DEFINE OSC 32
    DEFINE ADC_BITS 10 ' 10-bit Analog to digital
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
    DEFINE LCD_DREG PORTB ' Set LCD data port
    DEFINE LCD_DBIT 0 ' Set starting data bit
    DEFINE LCD_RSREG PORTC ' Set LCD register select port
    DEFINE LCD_RSBIT 4 ' Set LCD register select bit
    DEFINE LCD_EREG PORTC ' Set LCD enable port
    DEFINE LCD_EBIT 5 ' Set LCD enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size
    DEFINE LCD_LINES 4 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 1000 ' Set command delay time in microseconds
    DEFINE LCD_DATAUS 50 ' Set data delay time in microseconds
    FVRCON = %10000011 ' FIXED VOLTAGE REFERENCE CONTROL REGISTER
    ' bit 7 FVREN: Fixed Voltage Reference Enable bit
    ' ---> 1 = Fixed Voltage Reference is enabled
    ' 0 = Fixed Voltage Reference is disabled
    ' bit 6 FVRRDY: Fixed Voltage Reference Ready Flag bit(1)
    ' 1 = Fixed Voltage Reference output is ready for use
    ' 0 = Fixed Voltage Reference output is not ready or not enabled
    ' bit 5 TSEN: Temperature Indicator Enable bit(3)
    ' 1 = Temperature Indicator is enabled
    ' 0 = Temperature Indicator is disabled
    ' bit 4 TSRNG: Temperature Indicator Range Selection bit(3)
    ' 1 = VOUT = VDD - 4VT (High Range)
    ' 0 = VOUT = VDD - 2VT (Low Range)
    ' bit 3-2 CDAFVR<1:0>: Comparator FVR Buffer Gain Selection bits
    ' 11 = Comparator FVR Buffer Gain is 4x, (4.096V)(2)
    ' 10 = Comparator FVR Buffer Gain is 2x, (2.048V)(2)
    ' 01 = Comparator FVR Buffer Gain is 1x, (1.024V)
    ' 00 = Comparator FVR Buffer is off
    ' bit 1-0 ADFVR<1:0>: ADC FVR Buffer Gain Selection bit
    ' ---> 11 = ADC FVR Buffer Gain is 4x, (4.096V)(2)
    ' 10 = ADC FVR Buffer Gain is 2x, (2.048V)(2)
    ' 01 = ADC FVR Buffer Gain is 1x, (1.024V)
    ' 00 = ADC FVR Buffer is off
    ' Note 1: FVRRDY is always ‘1’ for PIC16F18855/75 devices only.
    ' 2: Fixed Voltage Reference output cannot exceed VDD.
    ADCON0 = %10000100 ' ADC CONTROL REGISTER 0
    ' bit 7 ADON: ADC Enable bit
    ' ---> 1 = ADC is enabled
    ' 0 = ADC is disabled
    ' bit 6 ADCONT: ADC Continuous Operation Enable bit
    ' 1 = ADGO is retriggered upon completion of each conversion trigger until ADTIF is set (if ADSOI is
    ' set) or until ADGO is cleared (regardless of the value of ADSOI)
    ' ---> 0 = ADGO is cleared upon completion of each conversion trigger
    ' bit 5 Unimplemented: Read as ‘0’
    ' bit 4 ADCS: ADC Clock Selection bit
    ' 1 = Clock supplied from FRC dedicated oscillator
    ' ---> 0 = Clock supplied by FOSC, divided according to ADCLK register
    ' bit 3 Unimplemented: Read as ‘0’
    ' bit 2 ADFRM0: ADC results Format/alignment Selection
    ' ---> 1 = ADRES and ADPREV data are right-justified
    ' 0 = ADRES and ADPREV data are left-justified, zero-filled
    ' bit 1 Unimplemented: Read as ‘0’
    ' bit 0 ADGO: ADC Conversion Status bit
    ' 1 = ADC conversion cycle in progress. Setting this bit starts an ADC conversion cycle. The bit is
    ' cleared by hardware as determined by the ADCONT bit
    ' ---> 0 = ADC conversion completed/not in progress
    ADCON2 = %00101010 ' ADC CONTROL REGISTER 2
    ' bit 7 ADPSIS: ADC Previous Sample Input Select bits
    ' 1 = ADFLTR is transferred to ADPREV at start-of-conversion
    ' 0 = ADRES is transferred to ADPREV at start-of-conversion
    ' bit 6-4 ADCRS<2:0>: ADC Accumulated Calculation Right Shift Select bits
    ' 111 = Reserved
    ' 110 = Reserved
    ' 101 through 000:
    ' If ADMD = 100:
    ' Low-pass filter time constant is 2ADCRS, filter gain is 1:1
    ' If ADMD = 001, 010 or 011:
    ' ---> The accumulated value is right-shifted by ADCRS (divided by 2ADCRS)(2)
    ' Otherwise:
    ' Bits are ignored
    ' bit 3 ADACLR: ADC Accumulator Clear Command bit
    ' 1 = Initial clear of ADACC, ADAOV, and the sample counter. Bit is cleared by hardware.
    ' 0 = Clearing action is complete (or not started)
    ' bit 2-0 ADMD<2:0>: ADC Operating Mode Selection bits(1)
    ' 111 = Reserved
    ' 101 = Reserved
    ' 100 = Low-pass Filter mode
    ' 011 = Burst Average mode
    ' ---> 010 = Average mode
    ' 001 = Accumulate mode
    ' 000 = Basic (Legacy) mode
    ' Note 1: See Table 23-3 for Full mode descriptions.
    ' 2: All results of divisions using the ADCRS bits are truncated, not rounded.
    ADCNT = %00001000 ' ADC CONVERSION COUNTER REGISTER
    ' bit 7-0 ADRPT<7:0>: ADC Conversion Counter
    ' Counts the number of times that the ADC is triggered. Determines when the threshold is checked for
    ' the Low-Pass Filter, Burst Average, and Average Computation modes. Count saturates at 0xFF and
    ' does not roll-over to 0x00.
    ADCLK = %00111111 ' ADC CLOCK SELECTION REGISTER
    ' bit 7-6 Unimplemented: Read as ‘0’
    ' bit 5-0 ADCCS<5:0>: ADC Conversion Clock Select bits
    ' ---> 111111 = FOSC/128
    ' 111110 = FOSC/126
    ' 111101 = FOSC/124
    ' 000000 = FOSC/2
    ADREF = %00000011 ' ADC REFERENCE SELECTION REGISTER
    ' bit 7-5 Unimplemented: Read as ‘0’
    ' bit 4 ADNREF: ADC Negative Voltage Reference Selection bit
    ' 1 = VREF- is connected to VREF- pin
    ' ---> 0 = VREF- is connected to AVSS
    ' bit 3-2 Unimplemented: Read as ‘0’
    ' bit 1-0 ADPREF: ADC Positive Voltage Reference Selection bits
    ' ---> 11 = VREF+ is connected to FVR_buffer 1
    ' 10 = VREF+ is connected to VREF+ pin
    ' 01 = Reserved
    ' 00 = VREF+ is connected to VDD
    ADPCH = %00000000 ' ADC POSITIVE CHANNEL SELECTION REGISTER
    ' bit 5-0 ADPCH<5:0>: ADC Positive Input Channel Selection bits
    ' 111111 = Fixed Voltage Reference (FVR)
    ' 111110 = DAC1 output
    ' 111101 = Temperature Indicator
    ' ---> 111100 = AVSS (Analog Ground)
    ' 111011 = Reserved. No channel connected.
    ' 100010 = ANE2 * 16F18877 only
    ' 100001 = ANE1 * 16F18877 only
    ' 100000 = ANE0 * 16F18877 only
    ' 011111 = AND7 * 16F18877 only
    ' 011110 = AND6 * 16F18877 only
    ' 011101 = AND5 * 16F18877 only
    ' 011100 = AND4 * 16F18877 only
    ' 011011 = AND3 * 16F18877 only
    ' 011010 = AND2 * 16F18877 only
    ' 011001 = AND1 * 16F18877 only
    ' 011000 = AND0 * 16F18877 only
    ' 010111 = ANC7
    ' 010110 = ANC6
    ' 010101 = ANC5
    ' 010100 = ANC4
    ' 010011 = ANC3
    ' 010010 = ANC2
    ' 010001 = ANC1
    ' 010000 = ANC0
    ' 001111 = ANB7
    ' 001110 = ANB6
    ' 001101 = ANB5
    ' 001100 = ANB4
    ' 001011 = ANB3
    ' 001010 = ANB2
    ' 001001 = ANB1
    ' 001000 = ANB0
    ' 000111 = ANA7
    ' 000110 = ANA6
    ' 000101 = ANA5
    ' 000100 = ANA4
    ' 000011 = ANA3
    ' 000010 = ANA2
    ' 000001 = ANA1
    ' 000000 = ANA0
    ANSELA = %00001001 ' Pin A3 = ADC (voltage divider)
    ' Pin A0 = ADC (B5K)
    ANSELB = %00000000
    ANSELC = %00000000
    TRISA = %00001001 ' Pin A3 = ADC input 3
    ' Pin A0 = ADC input 0
    TRISB = %00000000
    TRISC = %00000000
    AVSS var byte
    AVSS = %00111100 ' AVSS (Analog Ground)
    ADCinput var WORD
    OldADC0 var WORD
    OldADC3 var WORD
    NewADC0 var WORD
    NewADC3 var WORD
    ADCshift var WORD
    Pause 100 ' Let PIC and LCD stabilize
    ADCinput = 0
    OldADC0 = 9999 : OldADC3 = 9999
    NewADC0 = 0 : NewADC3 = 0
    LCDOUT $FE, 1 : Pauseus 1
    LCDOUT $FE, $80, " ADC test" : Pauseus 1
    LCDOUT $FE, $94, "ADC0:" : Pauseus 1
    LCDOUT $FE, $D4, "ADC3:" : Pauseus 1
    Mainloop:
    rem ADC 0
    ADPCH = AVSS : adcin 0, ADCinput
    NewADC0 = 1023 - ADCinput ' inverted so pot goes from 0 to 1024
    if NewADC0 <> oldadc0 then
    oldadc0 = NewADC0
    ADCshift = NewADC0 / 4
    LCDOUT $FE, $94+6, DEC4 oldadc0, " ", dec4 ADCshift : Pauseus 1
    rem ADC 3
    ADPCH = AVSS : adcin 3, ADCinput
    NewADC3 = ADCinput
    if NewADC3 <> oldadc3 then
    oldadc3 = NewADC3
    ADCshift = NewADC3 / 4
    LCDOUT $FE, $D4+6, DEC4 oldadc3, " ", dec4 ADCshift : Pauseus 1
    GOTO Mainloop
    It still jitters. I'm sure I'm missing some parameters.
    Can't edit my post:
    (like changing from 4V down to 1V)
    And of course my code alignment is totally whacked...
  1. SOLVED - IOC works on B0 but not B5
    By Demon in forum General
    Last Post: - 26th September 2024, 22:11
  2. Replies: 6
    Last Post: - 5th November 2023, 17:26
  3. trying to reduce current consumption on a 12HV615
    By Max Power in forum mel PIC BASIC Pro
    Last Post: - 30th November 2011, 15:57
  4. Unwanted output signal jitter
    By LinkMTech in forum mel PIC BASIC Pro
    Last Post: - 18th January 2008, 03:31
  5. Dmx Solved !!!!!!!
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 22:57
Members who have read this thread : 15
