SOLVED: How can I reduce ADC jitter
Results 1 to 40 of 96
Threaded View
  1. #19
    Default Re: SOLVED: How can I reduce ADC drift
    the first thing i notice is you have not set a sample time , not sure if or what the defa may be
    try this
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
    secondly the adcin command has often been accused of wonky readings when the channel is changed
    try this known work around of dual reads after a ch change
     Mainloop:
    rem                             ADC 0
        adcin 0, ADCinput
        adcin 0, ADCinput
        NewADC0 = 1023 - ADCinput           ' inverted so pot goes from 0 to 1024
        if NewADC0 <> oldadc0 then
            oldadc0 = NewADC0
            LCDOUT $FE, $94+6, DEC4 oldadc0 : Pauseus 1
    rem                             ADC 3
        adcin 3, ADCinput
        adcin 3, ADCinput
        NewADC3 = ADCinput
        if NewADC3 <> oldadc3 then
            oldadc3 = NewADC3
            LCDOUT $FE, $D4+6, DEC4 oldadc3 : Pauseus 1
      GOTO Mainloop
  1. SOLVED - IOC works on B0 but not B5
    By Demon in forum General
    Last Post: - 26th September 2024, 22:11
  2. Replies: 6
    Last Post: - 5th November 2023, 17:26
  3. trying to reduce current consumption on a 12HV615
    By Max Power in forum mel PIC BASIC Pro
    Last Post: - 30th November 2011, 15:57
  4. Unwanted output signal jitter
    By LinkMTech in forum mel PIC BASIC Pro
    Last Post: - 18th January 2008, 03:31
  5. Dmx Solved !!!!!!!
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 22:57
Members who have read this thread : 9
