SOLVED: How can I reduce ADC jitter
+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 40 of 96
    Post SOLVED: How can I reduce ADC jitter
    SOLVED: Noisy VDD/VSS using DC-DC converter. ADC stopped bouncing after using a 7805.
    https://picbasic.co.uk/forum/showthr...527#post156527
    16F18877
    - Using fixed input on ADC pin (1K to VDD, 1K to VSS - simulating pot at 50%)
    - The ADC will drift from 498 to 509.
    HSEROUTs on Serial Communicator:
    Low=00498 High=00509
    Is there anything in the registers that I can "tune" for the ADC?
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_OFF & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    DEFINE OSC 32
    DEFINE  ADC_BITS 10                 ' 10-bit Analog to digital
    define  CCP1_REG     0              ' Must clear unused CCP pins or else unpredictable results
    DEFINE  CCP1_BIT     0
    define  CCP2_REG     0
    DEFINE  CCP2_BIT     0
    DEFINE  CCP3_REG     0
    DEFINE  CCP3_BIT     0
    define  CCP4_REG     0
    DEFINE  CCP4_BIT     0
    define  CCP5_REG     0              ' Must clear unused CCP pins or else unpredictable results
    DEFINE  CCP5_BIT     0
    DEFINE  HSER_RXREG PORTC
    DEFINE  HSER_RXBIT 7
    DEFINE  HSER_TXREG PORTC
    DEFINE  HSER_TXBIT 6
    DEFINE  HSER_RCSTA 90h              ' Enable serial port & continuous receive
    DEFINE  HSER_TXSTA 24h              ' Enable transmit, BRGH = 1
    Define  HSER_BAUD 115200
    DEFINE  HSER_CLROERR 1              ' Clear overflow automatically
    DEFINE  HSER_SPBRGH  0
    DEFINE  HSER_SPBRG  68
    BAUDCON.3 = 1                       ' Enable 16 bit baudrate generator
    RA4PPS = 0                          ' Disable CCP5
    RB0PPS = 0                          ' Disable CCP4
    RB5PPS = 0                          ' Disable CCP3
    RC1PPS = 0                          ' Disable CCP2
    RC2PPS = 0                          ' Disable CCP1
    IOCAP = %00000000                               'IOC Positive Edge, low-to-high
    IOCAN = %00000000                               'IOC Negative Edge, from high-to-low
    IOCBP = %00000000                               'IOC Positive Edge, low-to-high
    IOCBN = %00000000                               'IOC Negative Edge, from high-to-low
    IOCCP = %00000000                               'IOC Positive Edge, low-to-high
    IOCCN = %00000000                               'IOC Negative Edge, from high-to-low
    'IOCDP = %00000000                              '...not available
    'IOCDN = %00000000                              '...not available
    'IOCEP = %00000000                              '...not available
    'IOCEN = %00000000                              '...not available
    WPUA = %00000000                        ' Pull-up resistors
    WPUB = %00000000
    WPUC = %00000000
    WPUD = %00000000
    WPUE = %00000000
    INLVLA = %00000000                      ' TTL input level
    INLVLB = %00000000
    INLVLC = %00000000
    INLVLD = %00000000
    'INLVLE = %00000000                      ' ...only available on E3 / MCLR pin
    ADCON0 = %10000100                      ' ADC CONTROL REGISTER 0
    ADCLK  = %00111111                      ' ADC CLOCK SELECTION REGISTER
    'ADPCH  = %00011010                      ' Channel 26 - D2
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000110                      ' Pin D2 = ADC input, NavCom
                                            ' Pin D1 = ADC input, Glareshield
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000110
    TRISE = %00000000
    include "I:\Project_v2\PBP\PBP_Includes\USART.bas"
    ADCInput                var word
    LowADC                  var word
    HighADC                 var word
        Pause 1                                     ' Let PIC stabilize
        LowADC = 1023
        HighADC = 0
        AdcInput = 0
    Mainloop:
        adcin 26, AdcInput
        if AdcInput < LowADC then LowADc = AdcInput
        if AdcInput > HighADC then HighADC = AdcInput
        hserout [   "Low=", dec5 LowADC, "  High=", DEC5 HighADC, 10  ]
        goto mainloop
    I was getting desperate with the drift on the pots, so I thought I'd do a control run using resistors.
    I expected it to remain the same or very close, but I'm still getting drift.
    Default Re: How can I reduce ADC drift
    50mV of noise on the power supply would do that.
    using FVR as adc ref might help a little and or a better regulator for the pots
    I use a DC-DC converter to lower 12V down to 5V for the entire circuit.
    Would a dedicated 7805 for the pots be a "meaningful" improvement?
    I'll have up to 10 pots in the final circuit. Right now I'm trying to get 1 ADC working well.
    the first step is to measure the noise on the power rail and then to determine if that's an issue, there is no point adding a regulator for the pots if the adc pos reference is noisy
    Based on the fact that you are using Power Supply as a reference voltage for the ADC:
    1. the Power Supply noise is random and in the length of time it would have very minimal effect on the adc average value.
    2. you are feeding the ADC input from a resistor divider that is connected to the Vdd, where also the reference voltage is connected to. It is called ratiometric and should zero the effect of regulator voltage drift. If the voltage of the Resistor divider changes by x % then the reference voltage will change by x % too. So eventually no drift should happen.
    What you experience is strange and should not happen.
    Needs more investigation.
    If you heat or cool the PIC chip, is there any change?
    P.S. If you finally use external Voltage reference, that is reasonably stable, I feel that the results will be even worse, because then the Vdd change will have maximum effect on the voltage sample.
    The Vdd that resistors are connected to, is the exact same point that PIC Vdd pin is connected also?
    Yes, it is.
    Temperature (heating or cooling PIC) has any effect on the drift?
    I'm curious how can this help me?
    It is room temperature, just like target customer environment (gaming).
    It's not like I'm overclocking the PIC like a PC CPU...?
    If the ADC result has no or minimal effect because of temp then we have to look elsewhere for the drift.
    Jan 2011
    Sydney, Australia
    I would try the following:
    1/. Use the Fixed Voltage Reference (FVR) instead of Vdd as your ADC reference voltage.
    2/. Add some capacitance - say 100nF - between the pot wiper and ground.
    Cheers
    Barry
    VK2XBP
    Quote Originally Posted by Aussie Barry View Post
    Cheers
    Barry
    VK2XBP
    1. Yeah, FVR is on my TO-DO list (Richard mentioned it up there).
    2. Does it matter if the cap is at the switch or up against PIC (like decoupler caps).
    3. Temp is also on my TO-DO list.
    also try using the fastest conversion clock that does not go Outside the recommended TAD time.
    you are using the slowest possible clock
    if you use the fvr don't let the wiper volts exceed the fvr output volts
    Jan 2011
    Sydney, Australia
    It shouldn't really matter if the cap is at the PIC end or the Pot end, as long as the distance between both is not too great.
    Note the silicon errata document (Item 1.3) regarding the use of FVR as ADC reference voltage:
    https://ww1.microchip.com/downloads/...-80000702J.pdf
    Cheers
    Barry
    Jan 2011
    Sydney, Australia
    What happens if the wiper voltage exceeds the FVR voltage?
    Jan 2011
    Sydney, Australia
    16F18877
    The PIC16F18877 has an Analog-to-Digital converter with Computation
    These post-processing functions are applied to the ADC conversion result and include averaging and low-pass filtering.
    Cheers
    Barry
    Ain specs from datasheet
    Name:  Screenshot 2024-11-02 121344.jpg
    at best the top range of the pot would be useless
    Using FVR will make things worse...
    I thought I'd step back and check VDD and VSS using my SDS1104 scope.
    This is at 50mV:
    Name:  SDS1104 scope VDD.jpg
Size:  140.7 KBName:  SDS1104 scope VSS .jpg
    Is it realistic to expect no drift on ADC with this much noise on my lines?
    CONFIRMED: Noisy power definitely messes up everything when the PIC tries to compare the "wiper" reading with VDD/VSS, even using two 1K resistors to simulate 50% pot.
    I switched to a 7805 supply and put back my "supposedly dirty" potentiometer. ADC low/high was back to a steady reading no matter where I turned the pot.
    I had code prepared using the techniques discussed in Melanie's ADC thread (or was it SORT, I don't remember). I got lost looking at the computational feature of the ADC in the 16F18877; that could have replaced my averaging routine and most likely reduced time.
    At worse if I get a dirty pot, I can drop the 1-2 lower bits from the 10-bit reading and still get 512-256 resolution out of a maximum 1024.
    I did an extra test to confirm it wasn't another component on my main test board that was "messing up" the power.
    I powered my isolated PIC with that DC-DC converter and sure enough ADC was jumping between 546 and 569 using my pot.
    So now i have to find a 7805 variant that can supply 700mA without breaking a sweat.
    Drift is tottaly different than jumping numbers...
    When you said drift I assumed that you started with say 512 as a 50% of FSD and then it went up or down after some time, like 511, 510, 509 etc.
    Having random numbers sure can be due to crappy and noisy Voltage on Vdd.
    Cheers
    Barry
    VK2XBP
    Ok, finally got back to working on my ADC jitters:
    - FOSC/128, 111111, 4.0 uS at 32 MHz
    - using FVR x 4
    - added 0.1uF at ADC pin
    No change, still jitters. I took at the manual averaging routine; it doesn't go to the extreme ends (rarely get completely to 0 or 1024 because of jittter).
    I'd like to try one of those COMPUTATION FEATURES, but I'm not sure which is better for me, nor what I need to properly set in the registers:
    - Basic: essentially what I'm doing now.
    - Accumulate,
    - Average,
    - Burst Average,
    - Low-Pass Filter.
    I'm testing 2 pots on this board; 1 regular, 1 with switch.
    DEFINE OSC 32
    DEFINE  LCD_DREG      PORTB         ' Set LCD data port
    DEFINE  LCD_DBIT      0             ' Set starting data bit
    DEFINE  LCD_RSREG     PORTC         ' Set LCD register select port
    DEFINE  LCD_RSBIT     4             ' Set LCD register select bit
    DEFINE  LCD_EREG      PORTC         ' Set LCD enable port
    DEFINE  LCD_EBIT      5             ' Set LCD enable bit
    DEFINE  LCD_BITS      4             ' Set LCD bus size
    DEFINE  LCD_LINES     4             ' Set number of lines on LCD
    DEFINE  LCD_COMMANDUS 1000          ' Set command delay time in microseconds
    DEFINE  LCD_DATAUS    50            ' Set data delay time in microseconds
    DEFINE  CCP1_BIT     0
    define  CCP2_REG     0
    DEFINE  CCP2_BIT     0
    define  CCP3_REG     PORTB          ' PWM Pulse out to LCD backlight
    DEFINE  CCP3_BIT     5
    define  CCP4_REG     0              ' Must clear unused CCP pins or else unpredictable results
    DEFINE  CCP4_BIT     0
    define  CCP5_REG     0
    DEFINE  CCP5_BIT     0
    FVRCON = %10000011                  ' FIXED VOLTAGE REFERENCE CONTROL REGISTER
    '   bit 7   FVREN: Fixed Voltage Reference Enable bit
    '       --->    1 = Fixed Voltage Reference is enabled
    '               0 = Fixed Voltage Reference is disabled
    '   bit 6   FVRRDY: Fixed Voltage Reference Ready Flag bit(1)
    '               1 = Fixed Voltage Reference output is ready for use
    '               0 = Fixed Voltage Reference output is not ready or not enabled
    '   bit 5   TSEN: Temperature Indicator Enable bit(3)
    '               1 = Temperature Indicator is enabled
    '               0 = Temperature Indicator is disabled
    '   bit 4   TSRNG: Temperature Indicator Range Selection bit(3)
    '               1 = VOUT = VDD - 4VT (High Range)
    '               0 = VOUT = VDD - 2VT (Low Range)
    '   bit 3-2 CDAFVR<1:0>: Comparator FVR Buffer Gain Selection bits
    '               11 = Comparator FVR Buffer Gain is 4x, (4.096V)(2)
    '               10 = Comparator FVR Buffer Gain is 2x, (2.048V)(2)
    '               01 = Comparator FVR Buffer Gain is 1x, (1.024V)
    '               00 = Comparator FVR Buffer is off
    '   bit 1-0 ADFVR<1:0>: ADC FVR Buffer Gain Selection bit
    '       --->    11 = ADC FVR Buffer Gain is 4x, (4.096V)(2)
    '               10 = ADC FVR Buffer Gain is 2x, (2.048V)(2)
    '               01 = ADC FVR Buffer Gain is 1x, (1.024V)
    '               00 = ADC FVR Buffer is off
    ' Note  1: FVRRDY is always ‘1’ for PIC16F18855/75 devices only.
    '       2: Fixed Voltage Reference output cannot exceed VDD.
    CCP3CON = %10001111                 ' CCP3 CONTROL REGISTER
    '   bit 7   EN: CCPx Module Enable bit
    '               1 = CCPx is enabled
    '               0 = CCPx is disabled
    '   bit 6   Unimplemented: Read as ‘0’
    '   bit 5   OUT: CCP3 Output Data bit (read-only)
    '   bit 4   FMT: CCPW (Pulse Width) Alignment bit
    '       MODE = Capture mode
    '           Unused
    '       MODE = Compare mode
    '           Unused
    '       MODE = PWM mode
    '           1 = Left-aligned format
    '           0 = Right-aligned format
    '   bit 3-0 MODE<3:0>: CCPx Mode Select bits(1)
    '     --->  1111 = PWM mode
    '           1110 = Reserved
    '           1101 = Reserved
    '           1100 = Reserved
    '           1011 = Compare mode: output will pulse 0-1-0; Clears TMR1
    '           1010 = Compare mode: output will pulse 0-1-0
    '           1001 = Compare mode: clear output on compare match
    '           1000 = Compare mode: set output on compare match
    '           0111 = Capture mode: every 16th rising edge of CCPx input
    '           0110 = Capture mode: every 4th rising edge of CCPx input
    '           0101 = Capture mode: every rising edge of CCPx input
    '           0100 = Capture mode: every falling edge of CCPx input
    '           0011 = Capture mode: every edge of CCPx input
    '           0010 = Compare mode: toggle output on match
    '           0001 = Compare mode: toggle output on match; clear TMR1
    '           0000 = Capture/Compare/PWM off (resets CCPx module)
    '   bit 7   ADON: ADC Enable bit
    '        --->   1 = ADC is enabled
    '               0 = ADC is disabled
    '   bit 6   ADCONT: ADC Continuous Operation Enable bit
    '               1 = ADGO is retriggered upon completion of each conversion trigger until ADTIF is set (if ADSOI is
    '                   set) or until ADGO is cleared (regardless of the value of ADSOI)
    '        --->   0 = ADGO is cleared upon completion of each conversion trigger
    '   bit 5   Unimplemented: Read as ‘0’
    '   bit 4   ADCS: ADC Clock Selection bit
    '               1 = Clock supplied from FRC dedicated oscillator
    '        --->   0 = Clock supplied by FOSC, divided according to ADCLK register
    '   bit 3   Unimplemented: Read as ‘0’
    '   bit 2   ADFRM0: ADC results Format/alignment Selection
    '        --->   1 = ADRES and ADPREV data are right-justified
    '               0 = ADRES and ADPREV data are left-justified, zero-filled
    '   bit 1   Unimplemented: Read as ‘0’
    '   bit 0   ADGO: ADC Conversion Status bit
    '               1 = ADC conversion cycle in progress. Setting this bit starts an ADC conversion cycle. The bit is
    '                   cleared by hardware as determined by the ADCONT bit
    '        --->   0 = ADC conversion completed/not in progress
    '   bit 7-6 Unimplemented: Read as ‘0’
    '   bit 5-0 ADCCS<5:0>: ADC Conversion Clock Select bits
    '        --->   111111 = FOSC/128
    '               111110 = FOSC/126
    '               111101 = FOSC/124
    '               000000 = FOSC/2
    ADPCH = %00000000                   ' ADC POSITIVE CHANNEL SELECTION REGISTER
    '   bit 5-0 ADPCH<5:0>: ADC Positive Input Channel Selection bits
    '               111111 = Fixed Voltage Reference (FVR)
    '               111110 = DAC1 output
    '               111101 = Temperature Indicator
    '               111100 = AVSS (Analog Ground)
    '               111011 = Reserved. No channel connected.
    '               100010 = ANE2       * 16F18877 only
    '               100001 = ANE1       * 16F18877 only
    '               100000 = ANE0       * 16F18877 only
    '               011111 = AND7       * 16F18877 only
    '               011110 = AND6       * 16F18877 only
    '               011101 = AND5       * 16F18877 only
    '               011100 = AND4       * 16F18877 only
    '               011011 = AND3       * 16F18877 only
    '               011010 = AND2       * 16F18877 only
    '               011001 = AND1       * 16F18877 only
    '               011000 = AND0       * 16F18877 only
    '               010111 = ANC7
    '               010110 = ANC6
    '               010101 = ANC5
    '               010100 = ANC4
    '               010011 = ANC3
    '               010010 = ANC2
    '               010001 = ANC1
    '               010000 = ANC0
    '               001111 = ANB7
    '               001110 = ANB6
    '               001101 = ANB5
    '               001100 = ANB4
    '               001011 = ANB3
    '               001010 = ANB2
    '               001001 = ANB1
    '               001000 = ANB0
    '               000111 = ANA7
    '               000110 = ANA6
    '               000101 = ANA5
    '               000100 = ANA4
    '               000011 = ANA3
    '               000010 = ANA2
    '        --->   000001 = ANA1
    '        --->   000000 = ANA0
    ANSELA = %00000011                      ' Pin A1 = ADC
                                            ' Pin A0 = ADC
    ANSELB = %00000000
    ANSELC = %00000000
    TRISA = %00000111                       ' Pin A2 = SW input 1
                                            ' Pin A1 = ADC input 1
                                            ' Pin A0 = ADC input 0
    TRISB = %00000000
    TRISC = %00000000
    SW1                 var PORTA.2
    ADCinput            var WORD
    OldADC0             var WORD
    OldADC1             var WORD
    OldSW1              var BYTE
    NewADC0             var WORD
    NewADC1             var WORD
    HPWMbacklight       var BYTE
    '    Pause 200                           ' Let PIC and LCD stabilize
        ADCinput = 0
        OldADC0 = 9999
        OldADC1 = 9999
        OldSW1 = 9
        NewADC0 = 0
        NewADC1 = 0
        HPWMbacklight = 150
        HPWM 3,HPWMbacklight,1953
        LCDOUT $FE, 1 : Pauseus 1
        LCDOUT $FE, $80, "      ADC test" : Pauseus 1
        LCDOUT $FE, $94, "ADC 0:" : Pauseus 1
        LCDOUT $FE, $D4, "ADC 1:       SW:" : Pauseus 1
    Mainloop:
    rem                             ADC 0
        ADPCH = %00000000
        adcin 0, ADCinput
        NewADC0 = 1023 - ADCinput
        if NewADC0 <> oldadc0 then
            oldadc0 = NewADC0
            LCDOUT $FE, $94+7, DEC4 oldadc0 : Pauseus 1
    rem                             ADC 1
        ADPCH = %00000001
        adcin 1, ADCinput
        NewADC1 = 1023 - ADCinput
        if NewADC1 <> oldadc1 then
            oldadc1 = NewADC1
            LCDOUT $FE, $D4+7, DEC4 oldadc1 : Pauseus 1
    rem                             SW 1
        if SW1 <> oldSW1 then
            oldSW1 = SW1
            IF OldSW1 = 0 THEN
                LCDOUT $FE, $D4+17, "Off" : Pauseus 1
                LCDOUT $FE, $D4+17, "On " : Pauseus 1
        HPWMbacklight = 255 - (NewADC0 / 4)
      GOTO Mainloop
    Cheers
    Barry
    Right now I'm testing on 16F18855, but I'll face the same problem on final version with 16F18877.
    I'm still trying to figure out how to see the Revision using MeLabs USB programmer. This is the most I can see.
    Name:  PIC revision.png
    Default Re: SOLVED: How can I reduce ADC drift
    I do not think you can see the Revision of your chip with Melabs USB programer. Only with Microchips IDE and a Pickit or ICD programers.
    1. Can you test with increased conversion time as the Errata says?
    2. Can you test with Vdd reference instead of FVR to be sure of the cause of this jitter? In this case use a linear 5V regulator to have the cleanest Vdd power supply.
    That's what I'm afraid of. I never got my PK4 to work right.
    I could try that.
    I was using VDD before, jittery. I'm using FVR x 4 right now, still jittery.
    And 7805 can't handle 3A anyways. That's why I switched to TPS56637 design.
    Can't edit post 23:
    I took OUT the manual averaging routine; it doesn't go to the extreme ends (rarely get completely to 0 or 1024 because of jittter).
    I'd like to try the ADC² average a try. Hardware should be faster than anything I can write in PBP.
    Is it possible to just feed a clean 5V to this chip, just to test the ADC?
    Have to go to restaurant for wife's birthday. Gonna try 2 bench power supplies later.
    Absolutely, wife is coming first!
    So you will have a peacefull rest of the day!
    When you will test it, please try also instead of a pot, just a voltage divider, say two 1K resistor in series to feed half of the supply to the adc. Maybe it is a pot problem.
    i have a 16f18875 , on a microchip HPC curiosity board, the adc is quite stable.
    reading the onboard pot has a statistical result from over 3600 readings like this below. for 99.8% of reads its within 3 counts.
    there is no adc problem to find.
    0000,0000,0000,0000,0000,0000,0002,0001,0108,1754 1731 0003,0001,0000,0000,0000,0000,0000,0000,0000,0000
    1731 reads are at the mean , 1754 are 1 count down 108 are 2 down 3 are 1 up ...etc
    max variance is -4 to + 2 counts , the two extremes coincide with my air conditioner compressor cycling
    until you figure what you are doing wrong to cause so much noise on your power rails you are just painting over the real problem
        __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_ON
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_ON & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
        __config _CONFIG4, _WRT_OFF & _SCANE_available & _LVP_ON
        DEFINE OSC 32
        DEFINE DEBUG_REG PORTD
        DEFINE DEBUG_BIT 2      ;  if not used for pwr
        DEFINE DEBUG_BAUD 9600
        DEFINE DEBUG_MODE 0
        DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
        ANSELA = % 00000001                      ' Pin A0 = ADC
        TRISA = % 11101111                       ' Pin A4 = LED
        TRISD = % 11111011                       ' DEBUG
        LATD.2 = 1                              ' DEBUG
        clear
        LED VAR LATA.4
        i var byte
        j var word
        bucket                var WORD
        ADCinput             var WORD
        mean                  var WORD
        buckets               var word[21]
        outlier                 var WORD
        LED = 1                                  'Proof of Life
        PAUSE 2000
        DEBUG 13,10,"READY",13,10
        FVRCON = % 10000011
        ADCON0 = % 10010100
        ADREF  = % 00000000
        ADCLK  = 32
        LED=0
    Mainloop:
        mean = 0
        for i = 0 to 9
        ADCIN 0, ADCinput
        mean = mean + ADCinput
        next
        mean = mean/10
        DEBUG "mean ",DEC mean,13,10
        for j = 0 to 3599
        ADCIN 0, ADCinput
        bucket = mean-ADCinput
        i = bucket + 10
        if i>20 then
          outlier =  outlier + 1
          buckets[i]=buckets[i] + 1
        'DEBUG 13,10,"mean ",DEC mean," i ",dec i," read ",dec ADCinput,13,10
        PAUSE 5
        next
        DEBUG "readings " ,13,10
        DEBUG  dec4 buckets[0],",", dec4 buckets[1],","  , dec4 buckets[2],",", dec4 buckets[3],"," , dec4 buckets[4],","
        DEBUG  dec4 buckets[5],",", dec4 buckets[6],","  , dec4 buckets[7],",", dec4 buckets[8],"," , dec4 buckets[9],"  "
        DEBUG  dec4 buckets[10],"  "
        DEBUG  dec4 buckets[11],",", dec4 buckets[12],","  , dec4 buckets[13],",", dec4 buckets[14],"," , dec4 buckets[15],","
        DEBUG  dec4 buckets[16],",", dec4 buckets[17],","  , dec4 buckets[18],",", dec4 buckets[19],"," , dec4 buckets[20],13,10
        DEBUG  "outliers ",dec4 outlier
        DEBUG  13,10
        for i = 0 to 20
          buckets[i] = 0
        next
        outlier = 0
        GOTO Mainloop
    Yeah, i'll check if desktop power supplies are more stable, but I doubt it.
    Then I'll gut my circuit; remove pwm and lcd logic and send adc to pc via usart.
    If it doesn't work smooth with just a pot running, I've got other problems.
    And that voltage divider test too.
    1st test: Voltage divider 4K7-4K7 using TPS56637 5V 5A drop-down circuit.
    ADC readings for voltage-divider:
    9VDC wall adapter, 63-66
    XP-581 set at 9VDC, 61-64
    XP-605 set at 9VDC, 62-64
    (Elenco desktop power supplies)
    Naturally the pots jitter a bit more than the fixed divider.
    Game plan:
    1. remove the PWM and use a fix resistor for backlight.
    2. feed the TPS56637 using a 9-12V battery.
    3. try using 2 separate TPS56637 circuits:
    - 1 for ADC (all inputs).
    - 1 for PWM and LCD (all outputs).
    The one for inputs "might' be replaced with an ordinary 7805 later. I don't need a lot of current to read pots, switches and encoders.
    Used 270R resistor for backlight, disabled all PWM/HPWM functionality on code:
    - ADC reading jumped to 430, no longer in the 60ies.
    - ADC reading for pots also jumped up near 400, which is what I expected for pots near 50%.
    (pot reading still went from 0 to 1024 before, so don't know what happened).
    ADC reading on V/D still jumps from 428-430, turned power OFF and back ON, now it's 444-447, slowly creeping up as I type, now seeing 450 blink.
    what any of that actually means needs way more explanation
    more importantly what does the power rail look like noise wise ?
    i assume that's now one resistor per each backlight
    what is the volts across the backlight resistor ?
    did you ever measure backlight current @ 5v ?
    what any of that actually means needs way more explanation...
    It's just the ADC readings I display on the LCD to check for jitter.
    more importantly what does the power rail look like noise wise ?...
    I'm reconnecting the scope to see if it changed now that there's no PWM.
    ...i assume that's now one resistor per each backlight...
    I use only 1 LCD for this
    ...what is the volts across the backlight resistor ?...
    1.83V, but I think you wanted voltage divider voltages, no?
    ...did you ever measure backlight current @ 5v ?
    with 270R = 6.7mA
    direct 5V = 32mA
    i was just curious about the backlight's current for potential noise generation, it seemed the most likely candidate to generate that much noise via pwm control. but even at max I of 32mA it should not cause that much noise, so that's my idea's blown out of the water.
    This is my gutted code, only 1 pot and 1 voltage divider, with LCD (no PWM):
    I'm trying to use FVR, no idea if I got all settings for that feature.
    Voltage at rail directly over V-D = 4.62V
    Voltage on 4K7 ADC to VDD = 2.30V
    Voltage on 4K7 ADC to VSS = 2.30V
    But I noticed the voltages fluctuate by 0.02V easily while taking readings.
    DEFINE OSC 32
    '               111110 = FOSC/126
    '               111101 = FOSC/124
    '               000000 = FOSC/2
    ANSELA = %00001001                      ' Pin A3 = ADC (voltage divider)
                                            ' Pin A0 = ADC (B5K)
    ANSELB = %00000000
    ANSELC = %00000000
    TRISA = %00001001                       ' Pin A3 = ADC input 3
    TRISB = %00000000
    TRISC = %00000000
    ADCinput            var WORD
    OldADC0             var WORD
    OldADC3             var WORD
    NewADC0             var WORD
    NewADC3             var WORD
        Pause 100                           ' Let PIC and LCD stabilize
        ADCinput = 0
        OldADC0 = 9999      : OldADC3 = 9999
        NewADC0 = 0         : NewADC3 = 0
        LCDOUT $FE, $94, "ADC0:       B5K" : Pauseus 1
        LCDOUT $FE, $D4, "ADC3:       Volt-Div" : Pauseus 1
    Mainloop:
    rem                             ADC 0
        adcin 0, ADCinput
        NewADC0 = 1023 - ADCinput           ' inverted so pot goes from 0 to 1024
            oldadc0 = NewADC0
            LCDOUT $FE, $94+6, DEC4 oldadc0 : Pauseus 1
    rem                             ADC 3
        adcin 3, ADCinput
        NewADC3 = ADCinput
        if NewADC3 <> oldadc3 then
            oldadc3 = NewADC3
            LCDOUT $FE, $D4+6, DEC4 oldadc3 : Pauseus 1
      GOTO Mainloop
    I'm setting up my scope to read both rails used by the pot and voltage divider.
    This is what it looks like.
    (I don't talk loud cause wife is sleeping)
    the first thing i notice is you have not set a sample time , not sure if or what the defa may be
    try this
    secondly the adcin command has often been accused of wonky readings when the channel is changed
    try this known work around of dual reads after a ch change
     Mainloop:
    rem                             ADC 0
        adcin 0, ADCinput
        adcin 0, ADCinput
            oldadc0 = NewADC0
    rem                             ADC 3
        adcin 3, ADCinput
        adcin 3, ADCinput
        NewADC3 = ADCinput
            oldadc3 = NewADC3
      GOTO Mainloop
  1. SOLVED - IOC works on B0 but not B5
    By Demon in forum General
    Last Post: - 26th September 2024, 22:11
  2. Replies: 6
    Last Post: - 5th November 2023, 17:26
  3. trying to reduce current consumption on a 12HV615
    By Max Power in forum mel PIC BASIC Pro
    Last Post: - 30th November 2011, 15:57
  4. Unwanted output signal jitter
    By LinkMTech in forum mel PIC BASIC Pro
    Last Post: - 18th January 2008, 03:31
  5. Dmx Solved !!!!!!!
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 22:57
Members who have read this thread : 15
