SOLVED: How can I reduce ADC jitter - Page 3
+ Reply to Thread
Page 3 of 3 FirstFirst 123
Results 81 to 96 of 96
  1. #81
    Default Re: SOLVED: How can I reduce ADC drift
    Either my PIC is damaged, or something is whacked inside the breadboard.
    105c and wasn't stopping.
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_OFF & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    ANSELA = %00000010                      ' Pin A1 = ADC (B5K)
    ANSELB = %00000000
    ANSELC = %00000000
    TRISA = %00000010                       ' Pin A1 = ADC input 1
    TRISB = %00000000                       ' Pin B7 = ...not available, ICSPDAT
                                            ' Pin B6 = ...not available, ICSPCLK
    TRISC = %11000000                       ' Pin C7 = RX      *** Datasheet requirement, INPUT ***
                                            ' Pin C6 = TX      *** Datasheet requirement, INPUT ***
    ADCinput            var WORD
        Pause 500                           ' Let PIC and LCD stabilize
        ADCinput = 0
    Mainloop:
        adcinput = 1023
  2. #82
    i simply hate this , all these pins made into outputs , shorted to gnd , no attempt to set them low
    at power up are they low? before you short it all out
    worst idea ever for breadboarding , i leave all pins as inputs unless they need to be an output
    all this care re floating inputs is complete bull shit. for a battery operated device it will save a few microwatts that's it.
    for the finished manufactured product sure do it , for bread boarding its dangerous nonsense where every mistake will be a bad one
    TRISC = %11000000
    I took everything non-essential off the breadboard (just kept my 2 power LEDs):
    and all the dangerous grounds
    I realized something was seriously wrong when that nothing circuit was taking 670mA. I added:
    PORTA = %00000000
    PORTB = %00000000
    PORTC = %00000000
    Before the ANSELx and TRISx and it's taking 20mA now, 33c with no ADC, just ADCinput set at 1023 and the HSEROUT loop.
  4. #84
    ... i leave all pins as inputs unless they need to be an output
    all this care re floating inputs is complete bull shit....
    I try to keep my development code as close to final as possible, cause I know I'll forget to change stuff back. At least this way I can fire and forget the pin initialization.
    But yeah, major bonehead move on my part. I put the old PIC back in and it runs at 20mA too. Gonna leave that 1st PIC in, just in case I do some other numbnut thing.
    Thanks mucho Richard.
    EDIT: Now this warning will follow my code for the rest of the development.
    PORTA = %00000000                       '-------------------------------------------'
    PORTB = %00000000                       '       ALWAYS SET PINS LOW FIRST           '
    PORTC = %00000000                       '-------------------------------------------'
  5. #85
    grounding unused pins and setting them as outputs is pointless , useless and potentially catastrophic
    just leaving them as analog is ten times easier and can never do any harm, setting them as input with wpu on is also ok and can never do any harm
    if the device is not battery powered its not worth any sort of effort
    - digital input,
    - weak pull-up ON,
    - pin not connected.
    I try to stay away from analog settings; no idea why. Maybe cause I started using only digital way back when.
    https://skills.microchip.com/introdu...tecture/691929
    Unit will always be powered by wall adapter, or possibly USB; but never battery..
  7. #87
    According to this:
    The pull-up is disabled automatically when either TRIS is set to an output or the pin is set as an analog input. These changes to TRIS and ANSEL will override WPU settings.
    I can just set all pull-ups ON, leave the unused pins unconnected and forget about them. Then use the others as I wish in ANSEL and TRIS.
    The only times I need to be concerned with WPU is on pins that must not be disturbed for whatever special reason.
    WPUA = %11111111    '----------------------------------------------------------------'
    WPUB = %11111111    '           ALWAYS SET WEAK PULL-UPS ON ALL PINS FIRST           '
    WPUC = %11111111    '----------------------------------------------------------------'
                        '       CHANGES TO ANSEL AND TRIS WILL OVERRIDE AS REQUIRED      '
    ANSELA = %00000010                      ' Pin A3 = SW input                 not implemented yet
                                            ' Pin A2 = ADC (B5K)                not implemented yet
                                            ' Pin A0 = ADC (voltage divider)    not implemented yet
    ANSELB = %00000000
    ANSELC = %00000000
    TRISA = %00000010                       ' Pin A3 = SW input                 not implemented yet
                                            ' Pin A2 = ADC input 2              not implemented yet
                                            ' Pin A0 = ADC input 0              not implemented yet
    EDIT: I can even leave PORT at the top in case a pin is left as analog output.
    Or did I miss something important...?
  8. #88
    it looks to me that you are creating problems and complications trying to solve a problem that does not exist.
    generic pin control solutions will never work for all chips, there are too many chip variations.
    pic pins to date always default to inputs, analog if possible. leave them that way unless you need one to be different.
    each and every pin you employ needs to configured to suit its usage
    mcc makes it easy
    it looks to me that you are creating problems and complications...
    My memory is getting worse by the year. That's why I try ways to set my code so it's easy to copy and modify for future modules. Of course it rarely works.
    Having WPUA.1 = 1 caused leakage to VSS; it wasn't completely 0; varying in the 1.1mV range. My ADC reading never reached 0.
    I took out the Port = 0 settings, set WPU properly instead of leaving ANSEL/TRIS override it, and now my ADC reading varies from 0 to 1.
    WPUA = %11111101    '----------------------------------------------------------------'
    ANSELB = %00000000
    ANSELC = %00000000
  10. #90
    Yeah, FVR gave me a dead spot at the high end. These pots already have a slight deadzone at both ends, so FVR made it much more apparent.
        adcin 1, ADCreading
        ADCinput = ADCreading >> 1
    Has light jitter with this pot.
        adcin 1, ADCreading
        ADCinput = ADCreading >> 2
    Works, but if I get a pot that's slightly "less good", I'll get jitters.
    I can work with >> 3, that still gives me 128 positions. That<S plenty of increments for a manual control, and I can always multiply by 4 when the flight sim absolutely wants 1024.
  11. #91
    makes little sense , the wpu is approx 47k its impact on a 5k pot should not be noticeable , this may be indicative of a different problem
    ansel does not override wpu , what you claim makes zero sense
    your power supply must be very noisy or the pots are complete crap [possibly microphonic] to get such poor results
    it happens to us all , especially if you don't use the knowledge regularly. that why i participate in the forum to keep my "practice" hours up.
    the problem here is copying errors forward and propagating ancient pic myths. setting each pin as you employ it to make it work as you want it to is not difficult. imo it is actually easier and less prone to error.
    using mcc documents it all for you and consolidates all pin setting into one file, it could not be easier
    ...ansel does not override wpu , what you claim makes zero sense ...s
    Got that info here, at the bottom:
    https://developerhelp.microchip.com/...ly/digital-io/
    The pull-up will be disabled automatically when either TRIS is set to an output or the pin is set as an analog input. These changes to TRIS and ANSEL will override WPU settings
    Anyways, I'm setting the WPU only for the unused pins now (even analog), playing it safe despite that quote above.
    ...your power supply must be very noisy or the pots are complete crap [possibly microphonic] to get such poor results
    The TPS56637 seems very stable, especially since I have nothing on that one. The LCD and LED strip are on a separate TPS56637.
    What do you mean by microphonic? Are you talking about the taper? Mine are linear, like Bourns B:
  14. #94
    like a microphone in that the slightest vibration causes the resistance to vary
    it might be stable but it can till be noisy , use your scope AC coupled X1 probe on say 5mV range 5mS/div, measure peak to peak noise
    and to be sure, use a resistor divider with cap of 1uF to ground from the tap point to ADC, instead of POT. If your results are stable then you can replace with a pot and see if the problem is the pot itself.
    p.s. corrected the drift to jitter on the Thread title
  16. #96
    Default Re: SOLVED: How can I reduce ADC jitter
    Oh I still get jitter at 1023 or ">> 1". I'm running at ">> 2" and had to use Vref- (3R/1K) cause I was having some instability at the 0 end of scale. The pots already have a slight deadzone under 5% and above 95% (look at the chart above - that was from manuf spec sheet).
    I only have a resolution of 256, with a maximum of 88 detents because I TX with changes in ADC larger than 2. But I'm still happy because this is good enough for my application (so far).
    TX:
    ;--- Interrupts ----------------------------------------------------------------
    include "I:\Project_v2\PBP\PBP_Includes\DT_INTS-14_16F1885x-7x.bas"
    include "I:\Project_v2\PBP\PBP_Includes\ReEnterPBP.bas"
            INT_Handler    RX_INT,      _RXInterrupt,   PBP,  no
    DEFINE OSC 32
    DEFINE  ADC_BITS 10                 ' 10-bit Analog to digital
    DEFINE  ADC_SAMPLEUS 5              ' Set sampling time in uS
    DEFINE  HSER_RXREG PORTC
    DEFINE  HSER_RXBIT 7
    DEFINE  HSER_TXREG PORTC
    DEFINE  HSER_TXBIT 6
    DEFINE  HSER_RCSTA 90h              ' Enable serial port & continuous receive
    DEFINE  HSER_TXSTA 24h              ' Enable transmit, BRGH = 1
    Define  HSER_BAUD 115200
    DEFINE  HSER_CLROERR 1              ' Clear overflow automatically
    DEFINE  HSER_SPBRGH  0
    DEFINE  HSER_SPBRG  68
    define  CCP1_REG     0              ' Must clear unused CCP pins or else unpredictable results
    DEFINE  CCP1_BIT     0
    define  CCP2_REG     0
    DEFINE  CCP2_BIT     0
    define  CCP3_REG     0
    DEFINE  CCP3_BIT     0
    define  CCP4_REG     0
    DEFINE  CCP4_BIT     0
    define  CCP5_REG     0
    DEFINE  CCP5_BIT     0
    ;--- Setup registers -----------------------------------------------------------
    BAUDCON.3 = 1                       ' Enable 16 bit baudrate generator
    INTCON = %11000000                  ' INTERRUPT CONTROL REGISTER
    '   bit 7   GIE: Global Interrupt Enable bit
    '               1 = Enables all active interrupts
    '               0 = Disables all interrupts
    '   bit 6   PEIE: Peripheral Interrupt Enable bit
    '               1 = Enables all active peripheral interrupts
    '               0 = Disables all peripheral interrupts
    PIE3 = %00100000                    ' PERIPHERAL INTERRUPT ENABLE REGISTER 3
    '   bit 5   RCIE: USART Receive Interrupt Enable bit
    '               1 = Enables the USART receive interrupt
    '               0 = Enables the USART receive interrupt
    PIR3 = %00000000                    ' PERIPHERAL INTERRUPT REQUEST REGISTER 3
    '   bit 5   RCIF: EUSART Receive Interrupt Flag (read-only) bit (1)
    '               1 = The EUSART receive buffer is not empty (contains at least one byte)
    '               0 = The EUSART receive buffer is empty
    FVRCON = %0000000                  ' FIXED VOLTAGE REFERENCE CONTROL REGISTER
    '   bit 7   FVREN: Fixed Voltage Reference Enable bit
    '               1 = Fixed Voltage Reference is enabled
    '   bit 1-0 ADFVR<1:0>: ADC FVR Buffer Gain Selection bit
    '               11 = ADC FVR Buffer Gain is 4x, (4.096V)(2)
    ADCON0 = %10000100                  ' ADC CONTROL REGISTER 0
    '   bit 7   ADON: ADC Enable bit
    '               1 = ADC is enabled
    '   bit 2   ADFRM0: ADC results Format/alignment Selection
    '               1 = ADRES and ADPREV data are right-justified
    ADCON2 = %00000000                  ' ADC CONTROL REGISTER 2
    '   bit 2-0 ADMD<2:0>: ADC Operating Mode Selection bits(1)
    '               000 = Basic (Legacy) mode
    ADCLK = %00001111                   ' ADC CLOCK SELECTION REGISTER
    '   bit 5-0 ADCCS<5:0>: ADC Conversion Clock Select bits
    '               1111 = FOSC/32
    ADREF = %00010000                   ' ADC REFERENCE SELECTION REGISTER
    '   bit 4 ADNREF: ADC Negative Voltage Reference Selection bit
    '               1 = VREF- is connected to VREF- pin
    '               0 = VREF- is connected to AVSS
    '   bit 1-0 ADPREF: ADC Positive Voltage Reference Selection bits
    '               11 = VREF+ is connected to FVR_buffer 1
    '               10 = VREF+ is connected to VREF+ pin
    '               00 = VREF+ is connected to VDD
    ADPCH = %00000000                   ' ADC POSITIVE CHANNEL SELECTION REGISTER
    '               000000 = ANA0
    WPUA = %01100000                        ' Pin A7 = ADC-A0 debug
                                            ' Pin A4 = ADC-A4 (B10K)
                                            ' Pin A3 = SW             external pull-down
                                            ' Pin A2 = Vref-
                                            ' Pin A1 = ADC-A1 (B5K w/SW)
                                            ' Pin A0 = ADC-A0 (B5K)
    WPUB = %11111111
    WPUC = %00100111                        ' Pin C7 = RX
                                            ' Pin C6 = TX
                                            ' Pin C4 = ADC-C4 (B10K)
                                            ' Pin C3 = ADC-C3 (B10K)
    ANSELA = %00010011                      ' Pin A4 = ADC-A4 (B10K)
    ANSELB = %00000000
    ANSELC = %00011000                      ' Pin C7 = RX
                                            ' Pin C6 = TX
    TRISA = %00011011                       ' Pin A7 = ADC-A0 debug
                                            ' Pin A3 = SW
    TRISC = %11011000                       ' Pin C7 = RX      *** Datasheet requirement, INPUT ***
    A0debug             var LATA.7
    SW                  var PORTA.3
    MsgData             var byte[3]
    MsgCode             VAR BYTE
    ADCinput            var WORD
    ADCcalc             var WORD
    ADCdiff             var WORD
    ADCchange           var byte
    ShiftRight          var byte
    OldADC              var WORD
    OldADC_A0           var WORD
    OldADC_A1           var WORD
    OldADC_A4           var WORD
    OldADC_C3           var WORD
    OldADC_C4           var WORD
    OldSW               var BYTE
    RXoccurred          var BYTE
        A0debug = 0
        RXoccurred = 0                              ' Clear RX flag
    @   INT_ENABLE   RX_INT             ; Enable USART Receive interrupts
        Pause 1500                           ' Let PIC and LCD stabilize
        goto Start
    RXInterrupt:
        hserin [ STR MsgData\3  ]
        while BAUDCON1.6 = 0                        ' Check RCIDL bit
        wend
        RXoccurred = 1                              ' Set flag
    @ INT_RETURN
    ;--- Subroutines ---------------------------------------------------------------
    SendData:
        hserout [   MsgData[0], MsgData[1], MsgData[2]   ]
        while TX1STA.1 = 0                           ' Check TRMT bit
        wend
        while RXoccurred = 0                       ' Check for interrupt
        wend
        RXoccurred = 0                              ' Set flag
        ADCchange = 1
    ProcessADC:
        ADCchange = 0
        if ADCcalc < oldADC then
            ADCdiff = oldADC - ADCcalc
            ADCdiff =  ADCcalc - oldADC
        IF  ADCdiff > 2 then                                        ' Check for Diff over 2
            MsgData[0] = MsgCode
            if ADCcalc <> oldADC then                               ' ADC value changed
                MsgData[1] = ADCcalc.byte1 : MsgData[2] = ADCcalc.byte0
                GOSUB SendData
            IF  ADCdiff > 0 then                                    ' Check for Diff over 0
                if ADCcalc = 0 then                                 ' Reached end of rotation
                    GOSUB SendData
                    if ADCcalc = 255 then                           ' Reached end of rotation
                        GOSUB SendData
    Start:
        ADCinput = 0   : ADCdiff = 0 : ADCcalc = 0
        OldADC_A0 = 9999 : OldADC_A1 = 9999 : OldADC_A4 = 9999 : OldADC_C3 = 9999 : OldADC_C4 = 9999
        OldSW = 9
        ShiftRight = 2
    Mainloop:
    rem                             ADC A0 test
        MsgCode = 0
        adcin 0, ADCinput
        ADCcalc = ADCinput >> ShiftRight
        oldADC = OldADC_A0
        gosub ProcessADC
        if ADCchange = 1 then
            A0debug = 1
            OldADC_A0 = ADCcalc
            A0debug = 0
    rem                             ADC A1 test
        MsgCode = 1
        adcin 1, ADCinput
        oldADC = OldADC_A1
        gosub ProcessADC
            OldADC_A1 = ADCcalc
    rem                             SW A3
        MsgCode = 3
        if SW <> oldSW then
            oldSW = SW
            MsgData[0] = MsgCode : MsgData[1] = oldSW :MsgData[2] = " "
            GOSUB SendData
    rem                             ADC A4 test
        MsgCode = 4
        adcin 4, ADCinput
        oldADC = OldADC_A4
        gosub ProcessADC
            OldADC_A4 = ADCcalc
    rem                             ADC C3 test
        MsgCode = 5
        adcin 19, ADCinput
        oldADC = OldADC_C3
        gosub ProcessADC
            OldADC_C3 = ADCcalc
    rem                             ADC C4 test
        MsgCode = 6
        adcin 20, ADCinput
        oldADC = OldADC_C4
        gosub ProcessADC
            OldADC_C4 = ADCcalc
      GOTO Mainloop
    RX:
    DEFINE OSC 32
    DEFINE  LCD_DREG      PORTB         ' Set LCD data port
    DEFINE  LCD_DBIT      0             ' Set starting data bit
    DEFINE  LCD_RSREG     PORTC         ' Set LCD register select port
    DEFINE  LCD_RSBIT     4             ' Set LCD register select bit
    DEFINE  LCD_EREG      PORTC         ' Set LCD enable port
    DEFINE  LCD_EBIT      5             ' Set LCD enable bit
    DEFINE  LCD_BITS      4             ' Set LCD bus size
    DEFINE  LCD_LINES     4             ' Set number of lines on LCD
    DEFINE  LCD_COMMANDUS 1000          ' Set command delay time in microseconds
    DEFINE  LCD_DATAUS    50            ' Set data delay time in microseconds
    DEFINE  CCP1_BIT     0
    define  CCP2_REG     0
    DEFINE  CCP2_BIT     0
    define  CCP3_REG     PORTB          ' PWM Pulse out to LCD backlight
    DEFINE  CCP3_BIT     5
    define  CCP4_REG     0              ' Must clear unused CCP pins or else unpredictable results
    DEFINE  CCP4_BIT     0
    define  CCP5_REG     PORTA          ' PWM Pulse out to LED strips
    DEFINE  CCP5_BIT     4
    DEFINE  HSER_RXBIT 7
    DEFINE  HSER_TXBIT 6
    CCP3CON = %10001111                 ' CCP3 CONTROL REGISTER
    '   bit 7   EN: CCPx Module Enable bit
    '               1 = CCPx is enabled
    '   bit 4   FMT: CCPW (Pulse Width) Alignment bit
    '       MODE = PWM mode
    '               0 = Right-aligned format
    '   bit 3-0 MODE<3:0>: CCPx Mode Select bits(1)
    '               1111 = PWM mode
    CCP5CON = %10001111                 ' CCP5 CONTROL REGISTER
    '       MODE = PWM mode
    '               1111 = PWM mode
    ADCON0 = %00000000                  ' ADC CONTROL REGISTER 0
    WPUA = %11101111                    ' Pin A7 = ADC-A0 debug
    WPUB = %11011111
    WPUC = %00111111
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    TRISA = %00000000                       ' Pin A7 = ADC-A0 debug
                                            ' Pin A4 = PWM to LED strips
                                            ' Pin B5 = PWM to LCD backlight
    A0debug             var LATA.7
    MsgData             var byte[3]
    MsgCode             VAR BYTE
    MsgADC_A0             VAR WORD
    MsgADC_A1             VAR WORD
    MsgADC_A4             VAR WORD
    MsgADC_C3             VAR WORD
    MsgADC_C4             VAR WORD
    MsgSW               VAR BYTE
    SWtext              VAR BYTE[2]
    HPWMlcdBL           var BYTE
    HPWMledstripe       var BYTE
    DefaultLcdBL        var BYTE
    DefaultLedstripe    var BYTE
    RXoccurred          var BYTE
        A0debug = 0
        HPWMlcdBL = 255                             ' OFF
        HPWMledstripe = 0                           ' OFF
        HPWM 3, HPWMlcdBL, 1953
        HPWM 5, HPWMledstripe, 1953
        Pause 200                           ' Let PIC and LCD stabilize
        goto Start                          ' Jump over sub-routines
    RXInterrupt:
    '    while BAUDCON1.6 = 0                        ' Check RCIDL bit
    '    wend
    @ INT_RETURN
    SendConfirmation:
    '    while TX1STA.1 = 0                           ' Check TRMT bit
    '    wend
    ProcessADC_A0:
        A0debug = 1
        MsgADC_A0.byte1 = MsgData[1] : MsgADC_A0.byte0 = MsgData[2]
        LCDOUT $FE, $C0+3, DEC4 MsgADC_A0
        HPWMlcdBL = MsgADC_A0
        MsgData[0] = MsgCode : MsgData[1] = "O" : MsgData[2] = "K"
        gosub SendConfirmation
        LCDOUT $FE, $C0+8, "x" : LCDOUT $FE, $C0+19, " "
        LCDOUT $FE, $94+8, " " : LCDOUT $FE, $94+19, " "
        LCDOUT $FE, $D4+8, " " : LCDOUT $FE, $D4+19, " "
        A0debug = 0
    ProcessADC_A1:
        MsgADC_A1.byte1 = MsgData[1] : MsgADC_A1.byte0 = MsgData[2]
        LCDOUT $FE, $94+3, DEC4 MsgADC_A1
        HPWMledstripe = 255 -  MsgADC_A1              ' Invert value
        LCDOUT $FE, $C0+8, " " : LCDOUT $FE, $C0+19, " "
        LCDOUT $FE, $94+8, "x" : LCDOUT $FE, $94+19, " "
    ProcessSW3:
        if MsgData[1] = 0 then
            SWtext[0] = "O" : SWtext[1] = "f" : SWtext[2] = "f"
            SWtext[0] = "O" : SWtext[1] = "n" : SWtext[2] = " "
        LCDOUT $FE, $D4+3, SWtext[0], SWtext[1], SWtext[2], " "
        LCDOUT $FE, $D4+8, "x" : LCDOUT $FE, $D4+19, " "
    ProcessADC_A4:
        MsgADC_A4.byte1 = MsgData[1] : MsgADC_A4.byte0 = MsgData[2]
        LCDOUT $FE, $C0+14, DEC4 MsgADC_A4
        LCDOUT $FE, $C0+8, " " : LCDOUT $FE, $C0+19, "x"
    ProcessADC_C3:
        MsgADC_C3.byte1 = MsgData[1] : MsgADC_C3.byte0 = MsgData[2]
        LCDOUT $FE, $94+14, DEC4 MsgADC_C3
        LCDOUT $FE, $94+8, " " : LCDOUT $FE, $94+19, "x"
    ProcessADC_C4:
        MsgADC_C4.byte1 = MsgData[1] : MsgADC_C4.byte0 = MsgData[2]
        LCDOUT $FE, $D4+14, DEC4 MsgADC_C4
        LCDOUT $FE, $C0+9, " " : LCDOUT $FE, $C0+19, " "
        LCDOUT $FE, $94+9, " " : LCDOUT $FE, $94+19, " "
        LCDOUT $FE, $D4+9, " " : LCDOUT $FE, $D4+19, "x"
    Start:
        HPWMlcdBL = 150
        HPWMledstripe = 150
        MsgADC_A0 = 0
        MsgADC_A1 = 0
        MsgADC_A4 = 0
        MsgADC_C3 = 0
        MsgADC_C4 = 0
        MsgSW = 0
        LCDOUT $FE, 1
        LCDOUT $FE, $80, "  ADC TEST with SW  "
        LCDOUT $FE, $C0, "A0:____ _  A4:____ _"
        LCDOUT $FE, $94, "A1:____ _  C3:____ _"
        LCDOUT $FE, $D4, "SW:____ _  C4:____ _"
    Mainloop:
        wend
        MsgCode = MsgData[0]
        if  MsgCode = 0 then
            gosub ProcessADC_A0
            if  MsgCode = 1 then
                gosub ProcessADC_A1
                if  MsgCode = 3 then
                    gosub ProcessSW3
                    if  MsgCode = 4 then
                        gosub ProcessADC_A4
                        if  MsgCode = 5 then
                            gosub ProcessADC_C3
                            if  MsgCode = 6 then
                                gosub ProcessADC_C4
      GOTO Mainloop
  1. SOLVED - IOC works on B0 but not B5
    By Demon in forum General
    Last Post: - 26th September 2024, 21:11
  2. Replies: 6
    Last Post: - 5th November 2023, 16:26
  3. trying to reduce current consumption on a 12HV615
    By Max Power in forum mel PIC BASIC Pro
    Last Post: - 30th November 2011, 14:57
  4. Unwanted output signal jitter
    By LinkMTech in forum mel PIC BASIC Pro
    Last Post: - 18th January 2008, 02:31
  5. Dmx Solved !!!!!!!
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 21:57
Members who have read this thread : 16
