SOLVED: How can I reduce ADC jitter
Results 1 to 40 of 96
    Default Re: SOLVED: How can I reduce ADC drift
    i tried the burst mode averaging method. very nice if you don't need the adc for anything else, it would be ideal for monitoring a lifepo4 battery during all phases of discharge/charging/float. no great advantage for multiple inputs that i can see
    I'm going to see about using something like your MEAN average example. I had something like that a while ago (inspired by Melanie), but I had noisy power supplies. The TPS56637 works nicely, so I was hoping ADC2 could make my life easier.
    I only have a few 1000uF electrolytics, so I put 2 on each rail, same ADC flutter of mostly 1, sometimes 2.
    +- 2 counts is as good as it will ever get for raw adc reads on a breadboard, if you right shift 2 bits that's a 256 count resolution that should be very stable
    the scope is your friend here , measure the AC noise. every 5mV of noise on the rail and/or the pot wiper is +- 1 more count
    note some of the variations you are calling flutter are actually "Quantization noise" and can never be eliminated from the adc process,
    the best adc result is always +-1 count. at the expense of some resolution[level bandwidth etc] you can filter it out "mostly" people with "hifi" ears reckon they can hear it on the best of cd recoding's , yet scratched vinyl records are pure, go figure. as a true cloth eared pariah i call wtf
    On a PCB of a irrelevant project I tested the simple ADCin and display the result on the LCD.
    As Richard says the +/-1 LSB is what I get with no process. Occasionaly 2 LSBs.
    I just sample every sec. and display it.
    Of course the PCB is double sided with lot of ground, a cap on the ADC input pin and linear 5Volt regulator. So any external noise is minimized.
    Breadboards are just a noise antennas and never give clean results.
    Ultimately, the system has to be able to read ADC while managing to 2-3 LED strips and 4 LCDs with PWM.
    I'm trying a double PSU approach to see if the input PIC (right) can keep line noise to a minimum, and have all output functions on the output PIC (left).
    Input functions will consume very little current, it's the output functions that will consume a lot more, and have multiple PWMs.
    The only unknown is the rotary encoders; no idea if their rapid ON-OFF will create noise. I can always move them over to the output PIC.
    At worse, I'd end up with a "clean" PIC, and a "noisy" PIC instead of input/output.
    I've gone back to getting a "basic" ADC routine working for 1 voltage-divider and 2 pots (for a better sampling).
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_OFF & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    DEFINE OSC 32
    DEFINE  ADC_BITS 10                 ' 10-bit Analog to digital
    DEFINE  ADC_SAMPLEUS 50             ' Set sampling time in uS
    DEFINE  HSER_RXREG PORTC
    DEFINE  HSER_RXBIT 7
    DEFINE  HSER_TXREG PORTC
    DEFINE  HSER_TXBIT 6
    DEFINE  HSER_RCSTA 90h              ' Enable serial port & continuous receive
    DEFINE  HSER_TXSTA 24h              ' Enable transmit, BRGH = 1
    Define  HSER_BAUD 115200
    DEFINE  HSER_CLROERR 1              ' Clear overflow automatically
    DEFINE  HSER_SPBRGH  0
    DEFINE  HSER_SPBRG  68
    ;--- Setup registers -----------------------------------------------------------
    BAUDCON.3 = 1                       ' Enable 16 bit baudrate generator
    FVRCON = %10000011                  ' FIXED VOLTAGE REFERENCE CONTROL REGISTER
    '   bit 7   FVREN: Fixed Voltage Reference Enable bit
    '       --->    1 = Fixed Voltage Reference is enabled
    '   bit 1-0 ADFVR<1:0>: ADC FVR Buffer Gain Selection bit
    '       --->    11 = ADC FVR Buffer Gain is 4x, (4.096V)(2)
    ADCON0 = %10000100                  ' ADC CONTROL REGISTER 0
    '   bit 7   ADON: ADC Enable bit
    '        --->   1 = ADC is enabled
    '   bit 2   ADFRM0: ADC results Format/alignment Selection
    '        --->   1 = ADRES and ADPREV data are right-justified
    ADCON2 = %00000000                  ' ADC CONTROL REGISTER 2
    '   bit 2-0 ADMD<2:0>: ADC Operating Mode Selection bits(1)
    '        --->   000 = Basic (Legacy) mode
    ADCLK = %00111111                   ' ADC CLOCK SELECTION REGISTER
    '   bit 5-0 ADCCS<5:0>: ADC Conversion Clock Select bits
    '        --->   111111 = FOSC/128
    ADREF = %00000011                   ' ADC REFERENCE SELECTION REGISTER
    '   bit 4 ADNREF: ADC Negative Voltage Reference Selection bit
    '        --->   0 = VREF- is connected to AVSS
    '   bit 1-0 ADPREF: ADC Positive Voltage Reference Selection bits
    '        --->   11 = VREF+ is connected to FVR_buffer 1
    ADPCH = %00000000                   ' ADC POSITIVE CHANNEL SELECTION REGISTER
    '        --->   000000 = ANA0
    ANSELA = %00000111                      ' Pin A2 = ADC (B5K)
                                            ' Pin A1 = ADC (B5K)
                                            ' Pin A0 = ADC (voltage divider)
    ANSELB = %00000000
    ANSELC = %00000000
    TRISA = %00000111                       ' Pin A2 = ADC input 2
                                            ' Pin A1 = ADC input 1
                                            ' Pin A0 = ADC input 0
    TRISB = %00000000                       ' Pin B7 = ...not available, ICSPDAT
                                            ' Pin B6 = ...not available, ICSPCLK
    TRISC = %11000000                       ' Pin C7 = RX      *** Datasheet requirement, INPUT ***
                                            ' Pin C6 = TX      *** Datasheet requirement, INPUT ***
    ADCinput            var WORD
    ADCtot              var WORD
    ADCcalc             var WORD
    ADCdiff             var WORD
    ADCLoop             VAR BYTE
    OldADC0             var WORD
    OldADC1             var WORD
    OldADC2             var WORD
        Pause 500                           ' Let PIC and LCD stabilize
        ADCinput = 0    : ADCdiff = 0
        OldADC0 = 9999  : OldADC1 = 9999  : OldADC2 = 9999
    Mainloop:
    rem                 ADC0, 4K7-4K7 voltage divider
        adcin 0, ADCinput : Pauseus 1               ' preliminary ADCIN to establish channel used
        ADCtot = 0
        FOR ADCLoop = 0 TO 15                       ' Load 16 ADC values
            ADCtot = ADCtot + ADCinput
        NEXT ADCLoop
        ADCcalc = ADCtot / 16                       ' Average out
        if ADCcalc < oldADC0 then                   ' Calculate change in ADC
            ADCdiff = oldadc0 - ADCcalc
            ADCdiff =  ADCcalc - oldadc0
        IF  (ADCdiff > 2) or _                      ' Check for Diff over 2 ... OR
           ((adccalc <> oldadc0) and _              '   ADC value changed ...   AND
             (adccalc = 0 or adccalc = 1023)) then  '   Reached end of rotation
            hserout [   "OldADC0:",     DEC4 oldadc0, "  ", _
                        "                            ", _
                        "ADCin:",       DEC4 ADCcalc, "  ", _
                        "Diff:",        dec4 ADCdiff, "  ", _
                        "Sum:",         Dec5 ADCtot, 10]
            while TXSTA.1 = 0               ' Check TRMT bit
            wend
            oldADC0 = ADCcalc
    rem                 ADC1, B5K pot
        ADCtot = 0
            adcin 1, ADCinput : Pauseus 1
        NEXT ADCLoop
        if ADCcalc < oldADC1 then                   ' Calculate change in ADC
            ADCdiff = oldadc1 - ADCcalc
            ADCdiff =  ADCcalc - oldadc1
           ((adccalc <> oldadc1) and _              '   ADC value changed ...   AND
            hserout [   "              ", _
                        "OldADC1:",     DEC4 oldadc1, "  ", _
                        "              ", _
            wend
            oldADC1 = ADCcalc
    rem                 ADC2, B5K pot
        adcin 2, ADCinput : Pauseus 1               ' preliminary ADCIN to establish channel used
        ADCtot = 0
        NEXT ADCLoop
        if ADCcalc < oldADC2 then                   ' Calculate change in ADC
            ADCdiff = oldadc2 - ADCcalc
            ADCdiff =  ADCcalc - oldadc2
           ((adccalc <> oldadc2) and _              '   ADC value changed ...   AND
            hserout [   "                            ", _
                        "OldADC2:",     DEC4 oldadc2, "  ", _
            wend
            oldADC2 = ADCcalc
      GOTO Mainloop
    Checklist:
    - PIC 16F18855,
    - used legacy ADC (no ADC2),
    - did not touch VREFs,
    - used FVR 4x with 5 VDC in,
    - used FOSC / 128,
    - used average of 16 ADC readings,
    - removed all LCD logic (used for debugging),
    - used USART to show results
    - added PAUSEUS 1 after all ADC operations - THIS NEEDS TO BE VERIFIED IF IT'S NECESSARY, it was just to make sure things worked.
    ADC readings on the voltage-divider and 2 rotary pots did not "drift/vary/whatever" more than 2.
    I still have to:
    - try with slide pots, just to see if that fixed their "irregularities" that I experienced in the past.
    - reconnect the 2nd breadboard that displays to LCD with backlight PWM, and PWMs 2 LED strips.
    EDIT: This was working perfectly with the voltage divider (ADC0) and pot 2 (ADC2), now that I've put back in pot 1 (ADC1), the 2 pots don't reach 0 and stop at 2.
    ARGH...
  1. SOLVED - IOC works on B0 but not B5
    By Demon in forum General
    Last Post: - 26th September 2024, 21:11
  2. Replies: 6
    Last Post: - 5th November 2023, 16:26
  3. trying to reduce current consumption on a 12HV615
    By Max Power in forum mel PIC BASIC Pro
    Last Post: - 30th November 2011, 14:57
  4. Unwanted output signal jitter
    By LinkMTech in forum mel PIC BASIC Pro
    Last Post: - 18th January 2008, 02:31
  5. Dmx Solved !!!!!!!
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 21:57
Members who have read this thread : 4
