SOLVED: How can I reduce ADC jitter - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 96
  1. #41
    Default Re: SOLVED: How can I reduce ADC drift
    if your scope probes are ac coupled to measure rail noise [ as they should be ] then the DC offsets visible on the scope are not coming from your circuit the scope provides them , the drift you see is random, for stability each and every scope probe gnd reference lead needs to be connected to the same point
    ps warning , do not try to measure rails that don't share a common gnd reference , or exceed the scopes safe working voltage
    raw adc readings of x + or - 1 count is as good as it ever gets
    +-2 is very good +-3 is typical result for a designed system
    what are your expectations ?
    Added DEFINE and doubled the ADCIN, no change really.
    But I did notice a vulnerability in my system. Watch this when I gently touch power leads to the rails.
  4. #44
    the problem you see does not exist , its the scopes reaction to having an large antenna [YOUR HAND] capacitively coupled to all of its inputs providing an overwhelming signal on it most sensitive ac input range, the scope is unable to provide the dc bias needed to keep the traces aligned in the overwhelmed state
    Excellent, so this won't be an issue since the drop-down circuit will be linked directly the the main board by headers.
  6. #46
    making any measurements on a dc signal other than the ac noise level using a scope that is ac coupled to the dc signal is meaningless
    Ok.
    All rails come from the same source; 5VDC.
    And they all share the ground to that circuit.
  8. #48
    Coupling changed to AC.
    1. Honestly I expected no jitter on the voltage-divider, thinking FVR would remove 1/2 the instability, leaving only VS as a variable source for comparison.
    2. As for the pots, I had no idea what "realistic" is, they don't mention that in google tutorials.
    3. I'm sure I could get something useful out of 10-bit results. Just not sure how to go about massaging the result.
    4. I also would have liked to try the ADC2 feature like AVERAGE. I assume it'a a hardware equivalent of what Melanie was doing.
  9. #49
    ADCshift = NewADC0 >> 2
    I shifted the results 2 bits, expecting to lose any jitter from 0 - 3, but I still get jitter.
    I bet it's when a number jumps an upper bit, like 00100011 to 01000100.
    I'm using 10-bit ADC, so chopping 2 bits already bring me down to 256 increments.
    Bringing it down more won't solve when it's a higher jump, like 00111111 to 01000000
    EDIT: Divide by 4 doesn't help either, I still get jitter, even on the voltage-divider.
  10. #50
    to measure ac noise on rail , noise hopefully in mV and not to many of them
    Coupling changed to DC.
    for any dc , logic measurements
    raw adc will never have no jitter
    the word you want here is resolution, if you had a 1k pot and 10 bit adc you could resolve it to 1 ohm steps in theory
    but adc is always has +- count , jitter free might get to 255 steps, you need to design for the outcome desired
    depending on noise and needed resolution there are ways , from simple division, averaging or oversampling
    its not designed to average more than one ch and need exclusive use of the adc but have a go
    changing my test to rs 2 digits
    jitter negligible
    mean 159
    readings
    0000,0000,0000,0000,0000,0000,0000,0000,0000,0000  3596  0004,0000,0000,0000,0000,0000,0000,0000,0000,0000
    outliers 0000
    mean 159
    readings
    0000,0000,0000,0000,0000,0000,0000,0000,0000,0000  3600  0000,0000,0000,0000,0000,0000,0000,0000,0000,0000
    outliers 0000
    mean 159
    readings
    0000,0000,0000,0000,0000,0000,0000,0000,0000,0000  3598  0002,0000,0000,0000,0000,0000,0000,0000,0000,0000
    outliers 0000
    mean 159
    #CONFIG    __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_ON
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_ON & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
        __config _CONFIG4, _WRT_OFF & _SCANE_available & _LVP_ON
        DEFINE OSC 32
        DEFINE DEBUG_REG PORTD
        DEFINE DEBUG_BIT 2      ;  if not used for pwr
        DEFINE DEBUG_BAUD 9600
        DEFINE DEBUG_MODE 0
        DEFINE ADC_BITS 10                 ' 10-bit Analog to digital
        DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
        ANSELA = % 00000001                      ' Pin A0 = ADC
        TRISA = % 11101111                       ' Pin A4 = LED
        TRISD = % 11111011                       ' DEBUG
        LATD.2 = 1                              ' DEBUG
        clear
        LED VAR LATA.4
        i var byte
        j var word
        bucket              var WORD
        ADCinput            var WORD
        mean                var WORD
        buckets             var word[21]
        outlier             var WORD
        LED = 1                                  'Proof of Life
        PAUSE 2000
        DEBUG 13,10,"READY",13,10
        FVRCON = % 10000011
        ADCON0 = % 10010100
        ADREF  = % 00000000
        ADPRE  = 48
        ADCLK  = 32
        ADCAP  = 31
        LED=0
    Mainloop:
        mean = 0
        for i = 0 to 9
        ADCIN 0, ADCinput
        mean = mean + ADCinput
        next
        mean = mean/40 ;average divide 4
        DEBUG "mean ",DEC mean,13,10
        for j = 0 to 3599
        ADCIN 0, ADCinput
        ADCinput=ADCinput>>2
        bucket = mean-ADCinput
        i = bucket + 10
        if i>20 then
          outlier =  outlier + 1
          buckets[i]=buckets[i] + 1
        'DEBUG 13,10,"mean ",DEC mean," i ",dec i," read ",dec ADCinput,13,10
        PAUSE 5
        next
        DEBUG "readings " ,13,10
        DEBUG  dec4 buckets[0],",", dec4 buckets[1],","  , dec4 buckets[2],",", dec4 buckets[3],"," , dec4 buckets[4],","
        DEBUG  dec4 buckets[5],",", dec4 buckets[6],","  , dec4 buckets[7],",", dec4 buckets[8],"," , dec4 buckets[9],"  "
        DEBUG  dec4 buckets[10],"  "
        DEBUG  dec4 buckets[11],",", dec4 buckets[12],","  , dec4 buckets[13],",", dec4 buckets[14],"," , dec4 buckets[15],","
        DEBUG  dec4 buckets[16],",", dec4 buckets[17],","  , dec4 buckets[18],",", dec4 buckets[19],"," , dec4 buckets[20],13,10
        DEBUG  "outliers ",dec4 outlier
        DEBUG  13,10
        for i = 0 to 20
          buckets[i] = 0
        next
        outlier = 0
        GOTO Mainloop
    using the fvr gets slightly better result [mine is a 3.3v system]
    mean 255
    readings
    outliers 0000
    mean 255
    readings
    outliers 0000
    mean 255
    readings
    outliers 0000
    mean 255
    readings
    outliers 0000
    mean 255
    readings
    outliers 0000
    mean 255
        DEFINE OSC 32
        DEFINE DEBUG_MODE 0
        LATD.2 = 1                              ' DEBUG
        clear
        LED VAR LATA.4
        i var byte
        j var word
        bucket              var WORD
        ADCinput            var WORD
        mean                var WORD
        outlier             var WORD
        PAUSE 2000
        FVRCON = % 10000010;2.048v
        ADCON0 = % 10000100
        ADREF  = % 00000011,fvr
        ADCLK  = 16; faster clk
        LED=0
    Mainloop:
        mean = 0
        for i = 0 to 9
        ADCIN 0, ADCinput
        next
        mean = mean/40
        for j = 0 to 3599
        ADCIN 0, ADCinput
        i = bucket + 10
        if i>20 then
        PAUSE 5
        next
        DEBUG  13,10
        for i = 0 to 20
          buckets[i] = 0
        next
        outlier = 0
        GOTO Mainloop
    ...its not designed to average more than one ch and need exclusive use of the adc but have a go
    23.0 ANALOG-TO-DIGITAL CONVERTER WITH COMPUTATION (ADC2) MODULE
    The Analog-to-Digital Converter with Computation (ADC2) allows conversion of an analog input signal to a 10-bit binary representation of that signal. This device uses analog inputs, which are multiplexed into a single sample and hold circuit.
    We can't switch ADPCH manually between each Average?
    About that bug to ADCIN twice:
    23.1 ADC Configuration
    Note: It is recommended that when switching from an ADC channel of a higher voltage to a channel of a lower voltage, the software selects the VSS channel before switching to the channel of the lower voltage.
    I'm trying to switch ADPCH to 111100 = AVSS (Analog Ground) before each ADCIN to see if that fixes the problem.
    They seem to mean when you change power rail, but maybe there's a bug when "the higher voltage" is within the same rail (like changing from 1V up to 4V).
    I haven't studied your code yet, this is where I am at trying to get FVR and Average:
    __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_OFF & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    DEFINE OSC 32
    DEFINE LCD_DREG PORTB ' Set LCD data port
    DEFINE LCD_DBIT 0 ' Set starting data bit
    DEFINE LCD_RSREG PORTC ' Set LCD register select port
    DEFINE LCD_RSBIT 4 ' Set LCD register select bit
    DEFINE LCD_EREG PORTC ' Set LCD enable port
    DEFINE LCD_EBIT 5 ' Set LCD enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size
    DEFINE LCD_LINES 4 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 1000 ' Set command delay time in microseconds
    DEFINE LCD_DATAUS 50 ' Set data delay time in microseconds
    FVRCON = %10000011 ' FIXED VOLTAGE REFERENCE CONTROL REGISTER
    ' bit 7 FVREN: Fixed Voltage Reference Enable bit
    ' ---> 1 = Fixed Voltage Reference is enabled
    ' 0 = Fixed Voltage Reference is disabled
    ' bit 6 FVRRDY: Fixed Voltage Reference Ready Flag bit(1)
    ' 1 = Fixed Voltage Reference output is ready for use
    ' 0 = Fixed Voltage Reference output is not ready or not enabled
    ' bit 5 TSEN: Temperature Indicator Enable bit(3)
    ' 1 = Temperature Indicator is enabled
    ' 0 = Temperature Indicator is disabled
    ' bit 4 TSRNG: Temperature Indicator Range Selection bit(3)
    ' 1 = VOUT = VDD - 4VT (High Range)
    ' 0 = VOUT = VDD - 2VT (Low Range)
    ' bit 3-2 CDAFVR<1:0>: Comparator FVR Buffer Gain Selection bits
    ' 11 = Comparator FVR Buffer Gain is 4x, (4.096V)(2)
    ' 10 = Comparator FVR Buffer Gain is 2x, (2.048V)(2)
    ' 01 = Comparator FVR Buffer Gain is 1x, (1.024V)
    ' 00 = Comparator FVR Buffer is off
    ' bit 1-0 ADFVR<1:0>: ADC FVR Buffer Gain Selection bit
    ' ---> 11 = ADC FVR Buffer Gain is 4x, (4.096V)(2)
    ' 10 = ADC FVR Buffer Gain is 2x, (2.048V)(2)
    ' 01 = ADC FVR Buffer Gain is 1x, (1.024V)
    ' 00 = ADC FVR Buffer is off
    ' Note 1: FVRRDY is always ‘1’ for PIC16F18855/75 devices only.
    ' 2: Fixed Voltage Reference output cannot exceed VDD.
    ADCON0 = %10000100 ' ADC CONTROL REGISTER 0
    ' bit 7 ADON: ADC Enable bit
    ' ---> 1 = ADC is enabled
    ' 0 = ADC is disabled
    ' bit 6 ADCONT: ADC Continuous Operation Enable bit
    ' 1 = ADGO is retriggered upon completion of each conversion trigger until ADTIF is set (if ADSOI is
    ' set) or until ADGO is cleared (regardless of the value of ADSOI)
    ' ---> 0 = ADGO is cleared upon completion of each conversion trigger
    ' bit 5 Unimplemented: Read as ‘0’
    ' bit 4 ADCS: ADC Clock Selection bit
    ' 1 = Clock supplied from FRC dedicated oscillator
    ' ---> 0 = Clock supplied by FOSC, divided according to ADCLK register
    ' bit 3 Unimplemented: Read as ‘0’
    ' bit 2 ADFRM0: ADC results Format/alignment Selection
    ' ---> 1 = ADRES and ADPREV data are right-justified
    ' 0 = ADRES and ADPREV data are left-justified, zero-filled
    ' bit 1 Unimplemented: Read as ‘0’
    ' bit 0 ADGO: ADC Conversion Status bit
    ' 1 = ADC conversion cycle in progress. Setting this bit starts an ADC conversion cycle. The bit is
    ' cleared by hardware as determined by the ADCONT bit
    ' ---> 0 = ADC conversion completed/not in progress
    ADCON2 = %00101010 ' ADC CONTROL REGISTER 2
    ' bit 7 ADPSIS: ADC Previous Sample Input Select bits
    ' 1 = ADFLTR is transferred to ADPREV at start-of-conversion
    ' 0 = ADRES is transferred to ADPREV at start-of-conversion
    ' bit 6-4 ADCRS<2:0>: ADC Accumulated Calculation Right Shift Select bits
    ' 111 = Reserved
    ' 110 = Reserved
    ' 101 through 000:
    ' If ADMD = 100:
    ' Low-pass filter time constant is 2ADCRS, filter gain is 1:1
    ' If ADMD = 001, 010 or 011:
    ' ---> The accumulated value is right-shifted by ADCRS (divided by 2ADCRS)(2)
    ' Otherwise:
    ' Bits are ignored
    ' bit 3 ADACLR: ADC Accumulator Clear Command bit
    ' 1 = Initial clear of ADACC, ADAOV, and the sample counter. Bit is cleared by hardware.
    ' 0 = Clearing action is complete (or not started)
    ' bit 2-0 ADMD<2:0>: ADC Operating Mode Selection bits(1)
    ' 111 = Reserved
    ' 101 = Reserved
    ' 100 = Low-pass Filter mode
    ' 011 = Burst Average mode
    ' ---> 010 = Average mode
    ' 001 = Accumulate mode
    ' 000 = Basic (Legacy) mode
    ' Note 1: See Table 23-3 for Full mode descriptions.
    ' 2: All results of divisions using the ADCRS bits are truncated, not rounded.
    ADCNT = %00001000 ' ADC CONVERSION COUNTER REGISTER
    ' bit 7-0 ADRPT<7:0>: ADC Conversion Counter
    ' Counts the number of times that the ADC is triggered. Determines when the threshold is checked for
    ' the Low-Pass Filter, Burst Average, and Average Computation modes. Count saturates at 0xFF and
    ' does not roll-over to 0x00.
    ADCLK = %00111111 ' ADC CLOCK SELECTION REGISTER
    ' bit 7-6 Unimplemented: Read as ‘0’
    ' bit 5-0 ADCCS<5:0>: ADC Conversion Clock Select bits
    ' ---> 111111 = FOSC/128
    ' 111110 = FOSC/126
    ' 111101 = FOSC/124
    ' 000000 = FOSC/2
    ADREF = %00000011 ' ADC REFERENCE SELECTION REGISTER
    ' bit 7-5 Unimplemented: Read as ‘0’
    ' bit 4 ADNREF: ADC Negative Voltage Reference Selection bit
    ' 1 = VREF- is connected to VREF- pin
    ' ---> 0 = VREF- is connected to AVSS
    ' bit 3-2 Unimplemented: Read as ‘0’
    ' bit 1-0 ADPREF: ADC Positive Voltage Reference Selection bits
    ' ---> 11 = VREF+ is connected to FVR_buffer 1
    ' 10 = VREF+ is connected to VREF+ pin
    ' 01 = Reserved
    ' 00 = VREF+ is connected to VDD
    ADPCH = %00000000 ' ADC POSITIVE CHANNEL SELECTION REGISTER
    ' bit 5-0 ADPCH<5:0>: ADC Positive Input Channel Selection bits
    ' 111111 = Fixed Voltage Reference (FVR)
    ' 111110 = DAC1 output
    ' 111101 = Temperature Indicator
    ' ---> 111100 = AVSS (Analog Ground)
    ' 111011 = Reserved. No channel connected.
    ' 100010 = ANE2 * 16F18877 only
    ' 100001 = ANE1 * 16F18877 only
    ' 100000 = ANE0 * 16F18877 only
    ' 011111 = AND7 * 16F18877 only
    ' 011110 = AND6 * 16F18877 only
    ' 011101 = AND5 * 16F18877 only
    ' 011100 = AND4 * 16F18877 only
    ' 011011 = AND3 * 16F18877 only
    ' 011010 = AND2 * 16F18877 only
    ' 011001 = AND1 * 16F18877 only
    ' 011000 = AND0 * 16F18877 only
    ' 010111 = ANC7
    ' 010110 = ANC6
    ' 010101 = ANC5
    ' 010100 = ANC4
    ' 010011 = ANC3
    ' 010010 = ANC2
    ' 010001 = ANC1
    ' 010000 = ANC0
    ' 001111 = ANB7
    ' 001110 = ANB6
    ' 001101 = ANB5
    ' 001100 = ANB4
    ' 001011 = ANB3
    ' 001010 = ANB2
    ' 001001 = ANB1
    ' 001000 = ANB0
    ' 000111 = ANA7
    ' 000110 = ANA6
    ' 000101 = ANA5
    ' 000100 = ANA4
    ' 000011 = ANA3
    ' 000010 = ANA2
    ' 000001 = ANA1
    ' 000000 = ANA0
    ANSELA = %00001001 ' Pin A3 = ADC (voltage divider)
    ' Pin A0 = ADC (B5K)
    ANSELB = %00000000
    ANSELC = %00000000
    TRISA = %00001001 ' Pin A3 = ADC input 3
    ' Pin A0 = ADC input 0
    TRISB = %00000000
    TRISC = %00000000
    AVSS var byte
    AVSS = %00111100 ' AVSS (Analog Ground)
    ADCinput var WORD
    OldADC0 var WORD
    OldADC3 var WORD
    NewADC0 var WORD
    NewADC3 var WORD
    ADCshift var WORD
    Pause 100 ' Let PIC and LCD stabilize
    ADCinput = 0
    OldADC0 = 9999 : OldADC3 = 9999
    NewADC0 = 0 : NewADC3 = 0
    LCDOUT $FE, 1 : Pauseus 1
    LCDOUT $FE, $80, " ADC test" : Pauseus 1
    LCDOUT $FE, $94, "ADC0:" : Pauseus 1
    LCDOUT $FE, $D4, "ADC3:" : Pauseus 1
    Mainloop:
    rem ADC 0
    ADPCH = AVSS : adcin 0, ADCinput
    NewADC0 = 1023 - ADCinput ' inverted so pot goes from 0 to 1024
    if NewADC0 <> oldadc0 then
    oldadc0 = NewADC0
    ADCshift = NewADC0 / 4
    LCDOUT $FE, $94+6, DEC4 oldadc0, " ", dec4 ADCshift : Pauseus 1
    rem ADC 3
    ADPCH = AVSS : adcin 3, ADCinput
    NewADC3 = ADCinput
    if NewADC3 <> oldadc3 then
    oldadc3 = NewADC3
    ADCshift = NewADC3 / 4
    LCDOUT $FE, $D4+6, DEC4 oldadc3, " ", dec4 ADCshift : Pauseus 1
    GOTO Mainloop
    It still jitters. I'm sure I'm missing some parameters.
  14. #54
    Can't edit my post:
    (like changing from 4V down to 1V)
    And of course my code alignment is totally whacked...
  15. #55
    mean 255
    readings
    outliers 0000
    mean 255
    readings
    outliers 0000
    mean 255
    readings
    outliers 0000
    mean 255
    readings
    outliers 0000
    mean 255
    readings
    outliers 0000
    mean 255
    My readings never jitter at 0000 or 1023, always rock solid.
    It's when I start taking readings within the range that things go nuts.
  16. #56
    not really
    it needs to take the number of readings to average in an uninterrupted exclusive sequence
    once the average is obtained you can set a new channel and set the device to perform a new average
    or cease averaging. a sequence cannot be interrupted for an additional extra adc read
    or makes it worse if acquisition time is inadequate or marginal , the dummy read is most successful
    not sure about this chip but when does channel change occur, a delay is probably required
    i don't see any form of averaging here
    oldadc0 = NewADC0
    there are heaps of other ways too
    mean var word
    ADCinput var word
    average
        mean = 0
        for i = 0 to 9
        ADCIN 0, ADCinput
        next
        mean = mean/10
        DEBUG "mean ",DEC mean,",",DEC mean>>2,13,10
    running average
       ADCIN 0, ADCinput
       mean = mean */ 200 + ADCinput */ 55
    All your setup is on a Breadboard?
    I can suspect that even low current PWM loads on a breadboard may cause such issues. The stray capacitance of these things is too mauch to have a reliable operation.
    My test of ADC on a Picdem boards show rock-solid readings. But is of good design with a lot of grounds that you are missing on breadboards.
    ...i don't see any form of averaging here...
    There isn't. I thought it all happened in the background when you did ADCIN, the average was calculated, and results stored in output fields, like a normal ADCIN.
    I guess you're telling me this is an on-going process, and ADCIN just gives you the average "at that point in time", but it keeps on going.
    I thought setting this OFF meant we could disable continuous sampling:
    16F18855
    23.5.8 CONTINUOUS SAMPLING MODE
    Setting the ADCONT bit in the ADCON0 register automatically retriggers a new conversion cycle after updating the ADACC register.
  20. #60
    the computational adc is more complex than that, microchip have a number of YT clips on it usages
    eg
    i have never had any reason to use it to date
    Ok, thanks.
    I've reverted to legacy mode, still using FVR, removed all LCD components, added USART:
    DEFINE OSC 32
    DEFINE  HSER_RXREG PORTC
    DEFINE  HSER_RXBIT 7
    DEFINE  HSER_TXREG PORTC
    DEFINE  HSER_TXBIT 6
    DEFINE  HSER_RCSTA 90h              ' Enable serial port & continuous receive
    DEFINE  HSER_TXSTA 24h              ' Enable transmit, BRGH = 1
    Define  HSER_BAUD 115200
    DEFINE  HSER_CLROERR 1              ' Clear overflow automatically
    DEFINE  HSER_SPBRGH  0
    DEFINE  HSER_SPBRG  68
    ;--- Setup registers -----------------------------------------------------------
    BAUDCON.3 = 1                       ' Enable 16 bit baudrate generator
    ADCON2 = %00000000                  ' ADC CONTROL REGISTER 2
    '        --->   000 = Basic (Legacy) mode
    '        --->   000000 = ANA0
    ANSELB = %00000000
    ANSELC = %00000000
    TRISB = %00000000                       ' Pin B7 = ...not available, ICSPDAT
                                            ' Pin B6 = ...not available, ICSPCLK
    TRISC = %11000000                       ' Pin C7 = RX      *** Datasheet requirement, INPUT ***
                                            ' Pin C6 = TX      *** Datasheet requirement, INPUT ***
    ADCinput            var WORD
    ADCdiff             var WORD
    OldADC0             var WORD
    OldADC3             var WORD
        ADCinput = 0        : ADCdiff = 0
        Hserout [   "ADC TEST",                     _
                    10,                             _
                    "Initial values = 9999", 10, 10]
    Mainloop:
    rem                             ADC 0
        adcin 0, ADCinput : adcin 0, ADCinput
        if ADCinput < oldADC0 then
            ADCdiff = oldadc0 - adcinput
            ADCdiff =  adcinput - oldadc0
        if ADCinput <> oldADC0 then
            oldADC0 = ADCinput
            Hserout [   "B5K pot = ", dec4 ADCinput,"    diff = ", dec4 ADCdiff, 10]
            while TXSTA.1 = 0               ' Check TRMT bit
            wend
    rem                             ADC 3
        adcin 3, ADCinput : adcin 3, ADCinput
        if ADCinput < oldADC3 then
            ADCdiff = oldadc3 - adcinput
            ADCdiff =  adcinput - oldadc3
        if ADCinput <> oldADC3 then
            oldADC3 = ADCinput
            Hserout [   "                                         ", _
                        "Volt/divider = ", dec4 ADCinput,"    diff = ", dec4 ADCdiff, 10]
            wend
      GOTO Mainloop
    This is what I get now, variations of 1 and 2 mostly:
    ADC TEST
    B5K pot = 0680    diff = 9319
                                             Volt/divider = 0627    diff = 9372
    B5K pot = 0681    diff = 0001
                                             Volt/divider = 0628    diff = 0001
    B5K pot = 0680    diff = 0001
    B5K pot = 0679    diff = 0002
                                             Volt/divider = 0627    diff = 0001
                                             Volt/divider = 0629    diff = 0002
    B5K pot = 0679    diff = 0001
                                             Volt/divider = 0630    diff = 0001
                                             Volt/divider = 0629    diff = 0001
    B5K pot = 0678    diff = 0001
    B5K pot = 0680    diff = 0002
                                             Volt/divider = 0631    diff = 0001
                                             Volt/divider = 0632    diff = 0001
    B5K pot = 0677    diff = 0001
                                             Volt/divider = 0626    diff = 0001
                                             Volt/divider = 0625    diff = 0001
                                             Volt/divider = 0627    diff = 0002
                                             Volt/divider = 0624    diff = 0001
                                             Volt/divider = 0623    diff = 0001
    B5K pot = 0681    diff = 0002
                                             Volt/divider = 0622    diff = 0001
                                             Volt/divider = 0624    diff = 0002
  22. #62
    With those differences, I suppose I should add a mean average and call it a day.
  23. #63
    Would dual TPS56637 step-down circuits help me reduce noise by PWM, LCD and other "noisy stuff"?
    Name:  Dual TPS56637.png
    Would diodes help in further isolating the 2 circuits? (like blocking surges) I looking for the minimum voltage for the TPS56637 circuit now, to make sure the voltage drop from 2 diodes wouldn't interfere with 9V input.
    I'd use dedicated PICs per function; 1 for input on top circuit, 1 for output on bottom circuit.
  24. #64
    I found this, that says it wouldn't hurt to put Schottkys on VDD.
    You don't need the diodes for ground, only using diodes for Vcc is sufficent....
    You could use schottky diodes as the voltage drop is 0.2V, that would be easiest.
    Circuit with dual power source: Replacing diodes with MOSFETs
    https://electronics.stackexchange.co...s-with-mosfets
    I suppose adding a bunch of filter caps downstream of the diodes would help reduce "fluctuations" before it enters the TPS56637.
  25. #65
    stick a 2200uF low esr electrolytic in every power rail on each bread-board and be done with it. if it still noisy add another set.
    if that fails isolate noisy bits behind rfc's [rf chokes]. ditch the hi switching speed [noise inducing] mosfets for pwm, use bjt instead, its only a backlight
    as ioannis says, breadboards and low noise are very close to mutually exclusive concepts
    i tried the burst mode averaging method. very nice if you don't need the adc for anything else, it would be ideal for monitoring a lifepo4 battery during all phases of discharge/charging/float. no great advantage for multiple inputs that i can see
    stick a 2200uF low esr electrolytic in every power rail on each bread-board and be done with it. if it still noisy add another set....
    I only have a few 1000uF electrolytics, so I put 2 on each rail, same ADC flutter of mostly 1, sometimes 2.
    ...if that fails isolate noisy bits behind rfc's [rf chokes]....
    I only have these 2 on hand:
    RL-1284 100uH, https://www.electronicsurplus.com/re...uh-irms-0-4amp
    79F101K-TR-RC 100uH, https://www.mouser.com/datasheet/2/5...te-1371239.pdf
    ...ditch the hi switching speed [noise inducing] mosfets for pwm, use bjt instead, its only a backlight...
    I was having difficulties turning the backlight all the way off using 2N2907A PNP. The BS250P P-chan worked like a charm from full OFF to full ON.
    ...as ioannis says, breadboards and low noise are very close to mutually exclusive concepts
    Yeah, that's why I moved away from my larger main prototype board to only 2 PCB boards to get ADC working perfectly.
  28. #68
    I'm going to see about using something like your MEAN average example. I had something like that a while ago (inspired by Melanie), but I had noisy power supplies. The TPS56637 works nicely, so I was hoping ADC2 could make my life easier.
  29. #69
    +- 2 counts is as good as it will ever get for raw adc reads on a breadboard, if you right shift 2 bits that's a 256 count resolution that should be very stable
    the scope is your friend here , measure the AC noise. every 5mV of noise on the rail and/or the pot wiper is +- 1 more count
    note some of the variations you are calling flutter are actually "Quantization noise" and can never be eliminated from the adc process,
    the best adc result is always +-1 count. at the expense of some resolution[level bandwidth etc] you can filter it out "mostly" people with "hifi" ears reckon they can hear it on the best of cd recoding's , yet scratched vinyl records are pure, go figure. as a true cloth eared pariah i call wtf
    On a PCB of a irrelevant project I tested the simple ADCin and display the result on the LCD.
    As Richard says the +/-1 LSB is what I get with no process. Occasionaly 2 LSBs.
    I just sample every sec. and display it.
    Of course the PCB is double sided with lot of ground, a cap on the ADC input pin and linear 5Volt regulator. So any external noise is minimized.
    Breadboards are just a noise antennas and never give clean results.
    Ultimately, the system has to be able to read ADC while managing to 2-3 LED strips and 4 LCDs with PWM.
    I'm trying a double PSU approach to see if the input PIC (right) can keep line noise to a minimum, and have all output functions on the output PIC (left).
    Input functions will consume very little current, it's the output functions that will consume a lot more, and have multiple PWMs.
    The only unknown is the rotary encoders; no idea if their rapid ON-OFF will create noise. I can always move them over to the output PIC.
    At worse, I'd end up with a "clean" PIC, and a "noisy" PIC instead of input/output.
  33. #73
    I've gone back to getting a "basic" ADC routine working for 1 voltage-divider and 2 pots (for a better sampling).
    DEFINE OSC 32
    DEFINE  HSER_RXBIT 7
    DEFINE  HSER_TXBIT 6
    ANSELA = %00000111                      ' Pin A2 = ADC (B5K)
                                            ' Pin A1 = ADC (B5K)
                                            ' Pin A0 = ADC (voltage divider)
    ANSELB = %00000000
    ANSELC = %00000000
    TRISA = %00000111                       ' Pin A2 = ADC input 2
                                            ' Pin A1 = ADC input 1
    ADCinput            var WORD
    ADCtot              var WORD
    ADCcalc             var WORD
    ADCdiff             var WORD
    ADCLoop             VAR BYTE
    OldADC0             var WORD
    OldADC1             var WORD
    OldADC2             var WORD
        Pause 500                           ' Let PIC and LCD stabilize
        OldADC0 = 9999  : OldADC1 = 9999  : OldADC2 = 9999
    Mainloop:
    rem                 ADC0, 4K7-4K7 voltage divider
        adcin 0, ADCinput : Pauseus 1               ' preliminary ADCIN to establish channel used
        ADCtot = 0
        FOR ADCLoop = 0 TO 15                       ' Load 16 ADC values
            ADCtot = ADCtot + ADCinput
        NEXT ADCLoop
        ADCcalc = ADCtot / 16                       ' Average out
        if ADCcalc < oldADC0 then                   ' Calculate change in ADC
            ADCdiff = oldadc0 - ADCcalc
            ADCdiff =  ADCcalc - oldadc0
        IF  (ADCdiff > 2) or _                      ' Check for Diff over 2 ... OR
           ((adccalc <> oldadc0) and _              '   ADC value changed ...   AND
             (adccalc = 0 or adccalc = 1023)) then  '   Reached end of rotation
            hserout [   "OldADC0:",     DEC4 oldadc0, "  ", _
                        "                            ", _
                        "ADCin:",       DEC4 ADCcalc, "  ", _
                        "Diff:",        dec4 ADCdiff, "  ", _
                        "Sum:",         Dec5 ADCtot, 10]
            wend
            oldADC0 = ADCcalc
    rem                 ADC1, B5K pot
        ADCtot = 0
            adcin 1, ADCinput : Pauseus 1
        NEXT ADCLoop
        if ADCcalc < oldADC1 then                   ' Calculate change in ADC
            ADCdiff = oldadc1 - ADCcalc
            ADCdiff =  ADCcalc - oldadc1
           ((adccalc <> oldadc1) and _              '   ADC value changed ...   AND
            hserout [   "              ", _
                        "OldADC1:",     DEC4 oldadc1, "  ", _
                        "              ", _
            wend
            oldADC1 = ADCcalc
    rem                 ADC2, B5K pot
        adcin 2, ADCinput : Pauseus 1               ' preliminary ADCIN to establish channel used
        ADCtot = 0
        NEXT ADCLoop
        if ADCcalc < oldADC2 then                   ' Calculate change in ADC
            ADCdiff = oldadc2 - ADCcalc
            ADCdiff =  ADCcalc - oldadc2
           ((adccalc <> oldadc2) and _              '   ADC value changed ...   AND
            hserout [   "                            ", _
                        "OldADC2:",     DEC4 oldadc2, "  ", _
            wend
            oldADC2 = ADCcalc
      GOTO Mainloop
    Checklist:
    - PIC 16F18855,
    - used legacy ADC (no ADC2),
    - did not touch VREFs,
    - used FVR 4x with 5 VDC in,
    - used FOSC / 128,
    - used average of 16 ADC readings,
    - removed all LCD logic (used for debugging),
    - used USART to show results
    - added PAUSEUS 1 after all ADC operations - THIS NEEDS TO BE VERIFIED IF IT'S NECESSARY, it was just to make sure things worked.
    ADC readings on the voltage-divider and 2 rotary pots did not "drift/vary/whatever" more than 2.
    I still have to:
    - try with slide pots, just to see if that fixed their "irregularities" that I experienced in the past.
    - reconnect the 2nd breadboard that displays to LCD with backlight PWM, and PWMs 2 LED strips.
    EDIT: This was working perfectly with the voltage divider (ADC0) and pot 2 (ADC2), now that I've put back in pot 1 (ADC1), the 2 pots don't reach 0 and stop at 2.
    ARGH...
  34. #74
    What do you mean by this , you have changes pos vref to fvr buffer1- used FVR 4x with 5 VDC in,
    which will turn out to be a mistake since pots use vdd as top input , by doing this you have lost 20% of their travel range
    Anything over VREF+ will be interpreted as the max ADC output. Anything lower than VREF- will be interpreted as the min ADC output value.
    There will be no damage if you exceed VREF+/VREF- as long as you don't exceed Vdd/Vss
    - used FOSC / 128,way too slow , while not out of acceptable range fosc/32 is more reasonable
    not sure about that , its not necessary either if every thing else is ok
    it does nothing useful
    my schema , added another supply rail straddling 10k pot , without series wiper resistor to an2
    not no none nil caps across an inputs
    typical raw readings
    R 827    669
    R 826    669
    R 826    669
    R 826    668
    R 825    669
    R 827    669
    R 826    669
    R 826    669
    R 826    668
    R 825    668
    R 827    670
    R 826    669
    R 825    668
    R 827    669
    R 827    669
    DEFINE OSC 32
    DEFINE DEBUG_REG PORTC
    DEFINE DEBUG_BIT 0 ; if not used for pwr
    DEFINE DEBUG_MODE 0
    DEFINE ADC_SAMPLEUS 5 ' Set sampling time in uS
    ANSELA = % 00000101 ' Pins A0 A2 = ADC
    LATC.0 = 1 ' DEBUG
    clear
    LED VAR LATA.4
    i var byte
    j var word
    bucket var WORD
    ADCinput var WORD
    mean var WORD
    outlier var WORD
    PAUSE 2000
    FVRCON = % 10000011
    ;ADCON0 = % 10000100 ;NOT USED
    ADREF = % 00000000
    ADCLK = 15
    LED=0
    Mainloop:
    ;NOTE an inputs sampled twice to overcome pbp poor adc ch changes
    ADCIN 0, ADCinput
    ADCIN 0, ADCinput
    DEBUG 13,10,"R ",DEC ADCinput,9
    ADCIN 2, ADCinput
    ADCIN 2, ADCinput
    DEBUG DEC ADCinput
    PAUSE 500
    GOTO Mainloop
    i just tried it without the double adc reads on input change and it works ok , so that's not an issue anymore it seems
    [i very rarely if ever use the adcin command , prefer to use asm sequences instead]
    Lets clarify something Robert please.
    Do you expect to have an ADC reading that will be absolutely stable on every pot position? Say that a user can set 1023 positions on the pot. Do you expect to have solid 1023 readings?
    This cannot be done no matter what. On an absolutely perfect circuit you will get +/- 1 digit because of the way ADC works along with every kind of noise present (wire induced, ground loops, resistors noise, shot noise, Johnson noise and so many other kinds).
    The ADC steps are 5/1023= 4.8876mV. This means that if ADC input is over that step, you get a count of 1. But if one of the above noise or more than one is present, you may get 0 or even 2 as a result, if the noise adds another 4.88mv.
    Hope this is clear and helps you not chasing the impossible.
    Any kind of averaging helps but because of the above, it does not eliminate the small jitter that you should accept.
    Averaging with Moving average routine limits the maximum number of counts. The one Richard posted on #57 goes up to 1004 after about 30 samples. Darrels Taylor Oversampling routine does also suffer of this kind of problem. Well gives from 8bit ADC a 16bit result but you have to pay in time...
    Best keep a simple average of 10 samples and get done with it.
    Last edited by Ioannis; - 4th March 2025 at 00:03. Reason: Corrected the #XX post to #57
  36. #76
    Do you expect to have an ADC reading that will be absolutely stable on every pot position? Say that a user can set 1023 positions on the pot. Do you expect to have solid 1023 readings? ...
    No, I was expecting a reading ranging between 0 and 1023, with 256 near 1/4 rotation (from available travel or course), 512 midway and 768 about 3/4 through.
  37. #77
    Yes, you can expect that, depending on the pot of course.
    But the readings will have a play around the specific point, because of what I explained.
    agreed , at the 1/4 turn posn the raw reading expected WHEN vref == vdd and vdd is a well filtered stable supply would be 256 + or - 1 count. if you want better than that use either a 12 bit adc or averaging or oversampling. none of which come without a cost.
    This all becomes a ridiculous overkill if the "pot" for instance represents say the 'CHOKE' position when it is displayed as 0-100 in 5% steps.
    i have asked several times now what are your expectations ?
    which will turn out to be a mistake since pots use vdd as top input , by doing this you have lost 20% of their travel range...
    I meant, did not touch VREF-, sorry.
    If I use VREF+ = VDD, my ADC readings stop at 1000 or so.
    If I use VREF+ = FVRx4, my readings reach 1023.
    Weird.
    ...- used FOSC / 128,way too slow , while not out of acceptable range fosc/32 is more reasonable...
    I've switched to 32 as well.
    ...used average of 16 ADC readings,
    not sure about that , its not necessary either if every thing else is ok ...
    If I don't use averages, I jump all over like this:
    OldADC1:00847  ADCin:00844  Diff:00003
    OldADC1:00844  ADCin:00847  Diff:00003
    OldADC1:00844  ADCin:00848  Diff:00004
    OldADC1:00848  ADCin:00845  Diff:00003
    OldADC1:00845  ADCin:00848  Diff:00003
    OldADC1:00848  ADCin:00844  Diff:00004
    ...- used USART to show results
    it does nothing useful ...
    I removed them.
    ...my schema , added another supply rail straddling 10k pot , without series wiper resistor to an2
    R 827    669
    R 826    669
    R 826    669
    R 826    668
    R 825    669
    R 827    669
    R 826    669
    R 826    669
    R 826    668
    R 825    668
    R 827    670
    R 826    669
    R 825    668
    R 827    669
    R 827    669
    Envious emote...
    DEFINE ADC_SAMPLEUS 5 ' Set sampling time in uS...
    Reduced mine from 50 down to 5 as well
    I just noticed that my temps on the 16F18855 goes over 100c when ADC runs; that's insane. I have no other routines running. If I stop ADC, it comes back down to 30ies.
    Name:  ADC high temps on 16F18855.jpeg
    I took everything non-essential off the breadboard (just kept my 2 power LEDs):
    Name:  ADC circuit.jpg
    DEFINE OSC 32
    DEFINE  HSER_RXBIT 7
    DEFINE  HSER_TXBIT 6
    '               1 = Fixed Voltage Reference is enabled
    '               11 = ADC FVR Buffer Gain is 4x, (4.096V)(2)
    'ADCON0 = %10000100                  ' ADC CONTROL REGISTER 0
    '               1 = ADC is enabled
    '               1 = ADRES and ADPREV data are right-justified
    ADCLK = %00001111                   ' ADC CLOCK SELECTION REGISTER
    '               001111 = FOSC/32
    '               0 = VREF- is connected to AVSS
    '               11 = VREF+ is connected to FVR_buffer 1
    ANSELA = %00000010                      ' Pin A1 = ADC (B5K)
    ANSELB = %00000000
    ANSELC = %00000000
    TRISA = %00000010                       ' Pin A1 = ADC input 1
    ADCinput            var WORD
    ADCdiff             var WORD
    OldADC1             var WORD
        ADCinput = 0
        ADCdiff = 0
        OldADC1 = 9999
    Mainloop:
    rem                 ADC1, B5K pot
        adcin 1, ADCinput
        ADCinput = ADCinput >> 6                                ' tried left justified for fun
        if ADCinput < oldADC1 then                              ' Calculate change in ADC
            ADCdiff = oldadc1 - ADCinput
            ADCdiff =  ADCinput - oldadc1
        IF  ADCdiff > 2 then                                    ' Check for Diff over 2
            hserout [   "OldADC1:",     DEC5 oldadc1, "  ", _
                        "ADCin:",       DEC5 ADCinput, "  ", _
                        "Diff:",        DEC5 ADCdiff, 10]
            wend
            oldADC1 = ADCinput
            if ADCinput <> oldadc1 then                         '   ADC value diff than previous
                if ADCinput = 0 then                            '     Reached end of rotation
                                "Diff:",        DEC5 ADCdiff, "  ", 10]
                    wend
                    oldADC1 = ADCinput
                    if ADCinput = 1023 then                     '     Reached start of rotation
                        wend
                        oldADC1 = ADCinput
      GOTO Mainloop
    I know I can join those Ifs to check for end of rotation, I just wanted to keep code simple to make sure everything was getting picked up.
    Averages was why sometimes it would not reach 0 or 1023.
    It works, but it has jumps of 3 now. Gonna see if more caps can reduce that.
    No clue why ADC is running so hot, specs say 85c is normal operating temp.
    The mounting holes are "slightly" warm, never noticed that before.
    Name:  Pot infrared.jpeg
Size:  143.5 KB Name:  Pot normal.jpeg
  40. #80
    ...The mounting holes are "slightly" warm, never noticed that before.
    Attachment 9922 Attachment 9923
    I just checked the mounting holes on my test LCD, the holes do the same thing and the LCD hasn't been connected in days.
    Copper/bare metal is at a different temp than the rest so the scanner detects it.
  1. SOLVED - IOC works on B0 but not B5
    By Demon in forum General
    Last Post: - 26th September 2024, 21:11
  2. Replies: 6
    Last Post: - 5th November 2023, 16:26
  3. trying to reduce current consumption on a 12HV615
    By Max Power in forum mel PIC BASIC Pro
    Last Post: - 30th November 2011, 14:57
  4. Unwanted output signal jitter
    By LinkMTech in forum mel PIC BASIC Pro
    Last Post: - 18th January 2008, 02:31
  5. Dmx Solved !!!!!!!
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 21:57
Members who have read this thread : 4
