SOLVED: How can I reduce ADC jitter
+ Reply to Thread
Results 1 to 40 of 96
    Default Re: SOLVED: How can I reduce ADC drift
    raw adc readings of x + or - 1 count is as good as it ever gets
    +-2 is very good +-3 is typical result for a designed system
    what are your expectations ?
    Coupling changed to AC.
    1. Honestly I expected no jitter on the voltage-divider, thinking FVR would remove 1/2 the instability, leaving only VS as a variable source for comparison.
    2. As for the pots, I had no idea what "realistic" is, they don't mention that in google tutorials.
    3. I'm sure I could get something useful out of 10-bit results. Just not sure how to go about massaging the result.
    4. I also would have liked to try the ADC2 feature like AVERAGE. I assume it'a a hardware equivalent of what Melanie was doing.
    ADCshift = NewADC0 >> 2
    I shifted the results 2 bits, expecting to lose any jitter from 0 - 3, but I still get jitter.
    I bet it's when a number jumps an upper bit, like 00100011 to 01000100.
    I'm using 10-bit ADC, so chopping 2 bits already bring me down to 256 increments.
    Bringing it down more won't solve when it's a higher jump, like 00111111 to 01000000
    EDIT: Divide by 4 doesn't help either, I still get jitter, even on the voltage-divider.
    changing my test to rs 2 digits
    jitter negligible
    mean 159
    readings
    0000,0000,0000,0000,0000,0000,0000,0000,0000,0000  3596  0004,0000,0000,0000,0000,0000,0000,0000,0000,0000
    outliers 0000
    mean 159
    readings
    0000,0000,0000,0000,0000,0000,0000,0000,0000,0000  3600  0000,0000,0000,0000,0000,0000,0000,0000,0000,0000
    outliers 0000
    mean 159
    readings
    0000,0000,0000,0000,0000,0000,0000,0000,0000,0000  3598  0002,0000,0000,0000,0000,0000,0000,0000,0000,0000
    outliers 0000
    mean 159
    #CONFIG    __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_ON
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_ON & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
        __config _CONFIG4, _WRT_OFF & _SCANE_available & _LVP_ON
        DEFINE OSC 32
        DEFINE DEBUG_REG PORTD
        DEFINE DEBUG_BIT 2      ;  if not used for pwr
        DEFINE DEBUG_BAUD 9600
        DEFINE DEBUG_MODE 0
        DEFINE ADC_BITS 10                 ' 10-bit Analog to digital
        DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
        ANSELA = % 00000001                      ' Pin A0 = ADC
        TRISA = % 11101111                       ' Pin A4 = LED
        TRISD = % 11111011                       ' DEBUG
        LATD.2 = 1                              ' DEBUG
        clear
        LED VAR LATA.4
        i var byte
        j var word
        bucket              var WORD
        ADCinput            var WORD
        mean                var WORD
        buckets             var word[21]
        outlier             var WORD
        LED = 1                                  'Proof of Life
        PAUSE 2000
        DEBUG 13,10,"READY",13,10
        FVRCON = % 10000011
        ADCON0 = % 10010100
        ADREF  = % 00000000
        ADPRE  = 48
        ADCLK  = 32
        ADCAP  = 31
        LED=0
    Mainloop:
        mean = 0
        for i = 0 to 9
        ADCIN 0, ADCinput
        mean = mean + ADCinput
        next
        mean = mean/40 ;average divide 4
        DEBUG "mean ",DEC mean,13,10
        for j = 0 to 3599
        ADCIN 0, ADCinput
        ADCinput=ADCinput>>2
        bucket = mean-ADCinput
        i = bucket + 10
        if i>20 then
          outlier =  outlier + 1
          buckets[i]=buckets[i] + 1
        'DEBUG 13,10,"mean ",DEC mean," i ",dec i," read ",dec ADCinput,13,10
        PAUSE 5
        next
        DEBUG "readings " ,13,10
        DEBUG  dec4 buckets[0],",", dec4 buckets[1],","  , dec4 buckets[2],",", dec4 buckets[3],"," , dec4 buckets[4],","
        DEBUG  dec4 buckets[5],",", dec4 buckets[6],","  , dec4 buckets[7],",", dec4 buckets[8],"," , dec4 buckets[9],"  "
        DEBUG  dec4 buckets[10],"  "
        DEBUG  dec4 buckets[11],",", dec4 buckets[12],","  , dec4 buckets[13],",", dec4 buckets[14],"," , dec4 buckets[15],","
        DEBUG  dec4 buckets[16],",", dec4 buckets[17],","  , dec4 buckets[18],",", dec4 buckets[19],"," , dec4 buckets[20],13,10
        DEBUG  "outliers ",dec4 outlier
        DEBUG  13,10
        for i = 0 to 20
          buckets[i] = 0
        next
        outlier = 0
        GOTO Mainloop
    using the fvr gets slightly better result [mine is a 3.3v system]
    mean 255
    readings
    outliers 0000
    mean 255
    readings
    outliers 0000
    mean 255
    readings
    outliers 0000
    mean 255
    readings
    outliers 0000
    mean 255
    readings
    outliers 0000
    mean 255
        DEFINE OSC 32
        DEFINE DEBUG_MODE 0
        LATD.2 = 1                              ' DEBUG
        clear
        LED VAR LATA.4
        i var byte
        j var word
        bucket              var WORD
        ADCinput            var WORD
        mean                var WORD
        outlier             var WORD
        PAUSE 2000
        FVRCON = % 10000010;2.048v
        ADCON0 = % 10000100
        ADREF  = % 00000011,fvr
        ADCLK  = 16; faster clk
        LED=0
    Mainloop:
        mean = 0
        for i = 0 to 9
        ADCIN 0, ADCinput
        next
        mean = mean/40
        for j = 0 to 3599
        ADCIN 0, ADCinput
        i = bucket + 10
        if i>20 then
        PAUSE 5
        next
        DEBUG  13,10
        for i = 0 to 20
          buckets[i] = 0
        next
        outlier = 0
        GOTO Mainloop
    mean 255
    readings
    outliers 0000
    mean 255
    readings
    outliers 0000
    mean 255
    readings
    outliers 0000
    mean 255
    readings
    outliers 0000
    mean 255
    readings
    outliers 0000
    mean 255
    My readings never jitter at 0000 or 1023, always rock solid.
    It's when I start taking readings within the range that things go nuts.
    We can't switch ADPCH manually between each Average?
    not really
    it needs to take the number of readings to average in an uninterrupted exclusive sequence
    once the average is obtained you can set a new channel and set the device to perform a new average
    or cease averaging. a sequence cannot be interrupted for an additional extra adc read
    I'm trying to switch ADPCH to 111100 = AVSS (Analog Ground) before each ADCIN to see if that fixes the problem.
    or makes it worse if acquisition time is inadequate or marginal , the dummy read is most successful
    not sure about this chip but when does channel change occur, a delay is probably required
    i don't see any form of averaging here
    ADPCH = AVSS : adcin 0, ADCinput
    NewADC0 = 1023 - ADCinput ' inverted so pot goes from 0 to 1024
    if NewADC0 <> oldadc0 then
    oldadc0 = NewADC0
    ADCshift = NewADC0 / 4
    LCDOUT $FE, $94+6, DEC4 oldadc0, " ", dec4 ADCshift : Pauseus 1
    to measure ac noise on rail , noise hopefully in mV and not to many of them
    Coupling changed to DC.
    for any dc , logic measurements
    raw adc will never have no jitter
    the word you want here is resolution, if you had a 1k pot and 10 bit adc you could resolve it to 1 ohm steps in theory
    but adc is always has +- count , jitter free might get to 255 steps, you need to design for the outcome desired
    depending on noise and needed resolution there are ways , from simple division, averaging or oversampling
    its not designed to average more than one ch and need exclusive use of the adc but have a go
    ...its not designed to average more than one ch and need exclusive use of the adc but have a go
    23.0 ANALOG-TO-DIGITAL CONVERTER WITH COMPUTATION (ADC2) MODULE
    The Analog-to-Digital Converter with Computation (ADC2) allows conversion of an analog input signal to a 10-bit binary representation of that signal. This device uses analog inputs, which are multiplexed into a single sample and hold circuit.
    About that bug to ADCIN twice:
    23.1 ADC Configuration
    Note: It is recommended that when switching from an ADC channel of a higher voltage to a channel of a lower voltage, the software selects the VSS channel before switching to the channel of the lower voltage.
    They seem to mean when you change power rail, but maybe there's a bug when "the higher voltage" is within the same rail (like changing from 1V up to 4V).
    I haven't studied your code yet, this is where I am at trying to get FVR and Average:
    __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_OFF & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    DEFINE OSC 32
    DEFINE LCD_DREG PORTB ' Set LCD data port
    DEFINE LCD_DBIT 0 ' Set starting data bit
    DEFINE LCD_RSREG PORTC ' Set LCD register select port
    DEFINE LCD_RSBIT 4 ' Set LCD register select bit
    DEFINE LCD_EREG PORTC ' Set LCD enable port
    DEFINE LCD_EBIT 5 ' Set LCD enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size
    DEFINE LCD_LINES 4 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 1000 ' Set command delay time in microseconds
    DEFINE LCD_DATAUS 50 ' Set data delay time in microseconds
    FVRCON = %10000011 ' FIXED VOLTAGE REFERENCE CONTROL REGISTER
    ' bit 7 FVREN: Fixed Voltage Reference Enable bit
    ' ---> 1 = Fixed Voltage Reference is enabled
    ' 0 = Fixed Voltage Reference is disabled
    ' bit 6 FVRRDY: Fixed Voltage Reference Ready Flag bit(1)
    ' 1 = Fixed Voltage Reference output is ready for use
    ' 0 = Fixed Voltage Reference output is not ready or not enabled
    ' bit 5 TSEN: Temperature Indicator Enable bit(3)
    ' 1 = Temperature Indicator is enabled
    ' 0 = Temperature Indicator is disabled
    ' bit 4 TSRNG: Temperature Indicator Range Selection bit(3)
    ' 1 = VOUT = VDD - 4VT (High Range)
    ' 0 = VOUT = VDD - 2VT (Low Range)
    ' bit 3-2 CDAFVR<1:0>: Comparator FVR Buffer Gain Selection bits
    ' 11 = Comparator FVR Buffer Gain is 4x, (4.096V)(2)
    ' 10 = Comparator FVR Buffer Gain is 2x, (2.048V)(2)
    ' 01 = Comparator FVR Buffer Gain is 1x, (1.024V)
    ' 00 = Comparator FVR Buffer is off
    ' bit 1-0 ADFVR<1:0>: ADC FVR Buffer Gain Selection bit
    ' ---> 11 = ADC FVR Buffer Gain is 4x, (4.096V)(2)
    ' 10 = ADC FVR Buffer Gain is 2x, (2.048V)(2)
    ' 01 = ADC FVR Buffer Gain is 1x, (1.024V)
    ' 00 = ADC FVR Buffer is off
    ' Note 1: FVRRDY is always ‘1’ for PIC16F18855/75 devices only.
    ' 2: Fixed Voltage Reference output cannot exceed VDD.
    ADCON0 = %10000100 ' ADC CONTROL REGISTER 0
    ' bit 7 ADON: ADC Enable bit
    ' ---> 1 = ADC is enabled
    ' 0 = ADC is disabled
    ' bit 6 ADCONT: ADC Continuous Operation Enable bit
    ' 1 = ADGO is retriggered upon completion of each conversion trigger until ADTIF is set (if ADSOI is
    ' set) or until ADGO is cleared (regardless of the value of ADSOI)
    ' ---> 0 = ADGO is cleared upon completion of each conversion trigger
    ' bit 5 Unimplemented: Read as ‘0’
    ' bit 4 ADCS: ADC Clock Selection bit
    ' 1 = Clock supplied from FRC dedicated oscillator
    ' ---> 0 = Clock supplied by FOSC, divided according to ADCLK register
    ' bit 3 Unimplemented: Read as ‘0’
    ' bit 2 ADFRM0: ADC results Format/alignment Selection
    ' ---> 1 = ADRES and ADPREV data are right-justified
    ' 0 = ADRES and ADPREV data are left-justified, zero-filled
    ' bit 1 Unimplemented: Read as ‘0’
    ' bit 0 ADGO: ADC Conversion Status bit
    ' 1 = ADC conversion cycle in progress. Setting this bit starts an ADC conversion cycle. The bit is
    ' cleared by hardware as determined by the ADCONT bit
    ' ---> 0 = ADC conversion completed/not in progress
    ADCON2 = %00101010 ' ADC CONTROL REGISTER 2
    ' bit 7 ADPSIS: ADC Previous Sample Input Select bits
    ' 1 = ADFLTR is transferred to ADPREV at start-of-conversion
    ' 0 = ADRES is transferred to ADPREV at start-of-conversion
    ' bit 6-4 ADCRS<2:0>: ADC Accumulated Calculation Right Shift Select bits
    ' 111 = Reserved
    ' 110 = Reserved
    ' 101 through 000:
    ' If ADMD = 100:
    ' Low-pass filter time constant is 2ADCRS, filter gain is 1:1
    ' If ADMD = 001, 010 or 011:
    ' ---> The accumulated value is right-shifted by ADCRS (divided by 2ADCRS)(2)
    ' Otherwise:
    ' Bits are ignored
    ' bit 3 ADACLR: ADC Accumulator Clear Command bit
    ' 1 = Initial clear of ADACC, ADAOV, and the sample counter. Bit is cleared by hardware.
    ' 0 = Clearing action is complete (or not started)
    ' bit 2-0 ADMD<2:0>: ADC Operating Mode Selection bits(1)
    ' 111 = Reserved
    ' 101 = Reserved
    ' 100 = Low-pass Filter mode
    ' 011 = Burst Average mode
    ' ---> 010 = Average mode
    ' 001 = Accumulate mode
    ' 000 = Basic (Legacy) mode
    ' Note 1: See Table 23-3 for Full mode descriptions.
    ' 2: All results of divisions using the ADCRS bits are truncated, not rounded.
    ADCNT = %00001000 ' ADC CONVERSION COUNTER REGISTER
    ' bit 7-0 ADRPT<7:0>: ADC Conversion Counter
    ' Counts the number of times that the ADC is triggered. Determines when the threshold is checked for
    ' the Low-Pass Filter, Burst Average, and Average Computation modes. Count saturates at 0xFF and
    ' does not roll-over to 0x00.
    ADCLK = %00111111 ' ADC CLOCK SELECTION REGISTER
    ' bit 7-6 Unimplemented: Read as ‘0’
    ' bit 5-0 ADCCS<5:0>: ADC Conversion Clock Select bits
    ' ---> 111111 = FOSC/128
    ' 111110 = FOSC/126
    ' 111101 = FOSC/124
    ' 000000 = FOSC/2
    ADREF = %00000011 ' ADC REFERENCE SELECTION REGISTER
    ' bit 7-5 Unimplemented: Read as ‘0’
    ' bit 4 ADNREF: ADC Negative Voltage Reference Selection bit
    ' 1 = VREF- is connected to VREF- pin
    ' ---> 0 = VREF- is connected to AVSS
    ' bit 3-2 Unimplemented: Read as ‘0’
    ' bit 1-0 ADPREF: ADC Positive Voltage Reference Selection bits
    ' ---> 11 = VREF+ is connected to FVR_buffer 1
    ' 10 = VREF+ is connected to VREF+ pin
    ' 01 = Reserved
    ' 00 = VREF+ is connected to VDD
    ADPCH = %00000000 ' ADC POSITIVE CHANNEL SELECTION REGISTER
    ' bit 5-0 ADPCH<5:0>: ADC Positive Input Channel Selection bits
    ' 111111 = Fixed Voltage Reference (FVR)
    ' 111110 = DAC1 output
    ' 111101 = Temperature Indicator
    ' ---> 111100 = AVSS (Analog Ground)
    ' 111011 = Reserved. No channel connected.
    ' 100010 = ANE2 * 16F18877 only
    ' 100001 = ANE1 * 16F18877 only
    ' 100000 = ANE0 * 16F18877 only
    ' 011111 = AND7 * 16F18877 only
    ' 011110 = AND6 * 16F18877 only
    ' 011101 = AND5 * 16F18877 only
    ' 011100 = AND4 * 16F18877 only
    ' 011011 = AND3 * 16F18877 only
    ' 011010 = AND2 * 16F18877 only
    ' 011001 = AND1 * 16F18877 only
    ' 011000 = AND0 * 16F18877 only
    ' 010111 = ANC7
    ' 010110 = ANC6
    ' 010101 = ANC5
    ' 010100 = ANC4
    ' 010011 = ANC3
    ' 010010 = ANC2
    ' 010001 = ANC1
    ' 010000 = ANC0
    ' 001111 = ANB7
    ' 001110 = ANB6
    ' 001101 = ANB5
    ' 001100 = ANB4
    ' 001011 = ANB3
    ' 001010 = ANB2
    ' 001001 = ANB1
    ' 001000 = ANB0
    ' 000111 = ANA7
    ' 000110 = ANA6
    ' 000101 = ANA5
    ' 000100 = ANA4
    ' 000011 = ANA3
    ' 000010 = ANA2
    ' 000001 = ANA1
    ' 000000 = ANA0
    ANSELA = %00001001 ' Pin A3 = ADC (voltage divider)
    ' Pin A0 = ADC (B5K)
    ANSELB = %00000000
    ANSELC = %00000000
    TRISA = %00001001 ' Pin A3 = ADC input 3
    ' Pin A0 = ADC input 0
    TRISB = %00000000
    TRISC = %00000000
    AVSS var byte
    AVSS = %00111100 ' AVSS (Analog Ground)
    ADCinput var WORD
    OldADC0 var WORD
    OldADC3 var WORD
    NewADC0 var WORD
    NewADC3 var WORD
    ADCshift var WORD
    Pause 100 ' Let PIC and LCD stabilize
    ADCinput = 0
    OldADC0 = 9999 : OldADC3 = 9999
    NewADC0 = 0 : NewADC3 = 0
    LCDOUT $FE, 1 : Pauseus 1
    LCDOUT $FE, $80, " ADC test" : Pauseus 1
    LCDOUT $FE, $94, "ADC0:" : Pauseus 1
    LCDOUT $FE, $D4, "ADC3:" : Pauseus 1
    Mainloop:
    rem ADC 0
    oldadc0 = NewADC0
    rem ADC 3
    ADPCH = AVSS : adcin 3, ADCinput
    NewADC3 = ADCinput
    if NewADC3 <> oldadc3 then
    oldadc3 = NewADC3
    ADCshift = NewADC3 / 4
    LCDOUT $FE, $D4+6, DEC4 oldadc3, " ", dec4 ADCshift : Pauseus 1
    GOTO Mainloop
    It still jitters. I'm sure I'm missing some parameters.
    Can't edit my post:
    (like changing from 4V down to 1V)
    And of course my code alignment is totally whacked...
  1. SOLVED - IOC works on B0 but not B5
    By Demon in forum General
    Last Post: - 26th September 2024, 21:11
  2. Replies: 6
    Last Post: - 5th November 2023, 16:26
  3. trying to reduce current consumption on a 12HV615
    By Max Power in forum mel PIC BASIC Pro
    Last Post: - 30th November 2011, 14:57
  4. Unwanted output signal jitter
    By LinkMTech in forum mel PIC BASIC Pro
    Last Post: - 18th January 2008, 02:31
  5. Dmx Solved !!!!!!!
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 21:57
Members who have read this thread : 17
