SOLVED: How can I reduce ADC drift
+ Reply to Thread
Results 1 to 22 of 22
    Post SOLVED: How can I reduce ADC drift
    SOLVED: Noisy VDD/VSS using DC-DC converter. ADC stopped bouncing after using a 7805.
    https://picbasic.co.uk/forum/showthr...527#post156527
    16F18877
    - Using fixed input on ADC pin (1K to VDD, 1K to VSS - simulating pot at 50%)
    - The ADC will drift from 498 to 509.
    HSEROUTs on Serial Communicator:
    Low=00498 High=00509
    Is there anything in the registers that I can "tune" for the ADC?
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_OFF & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    DEFINE OSC 32
    DEFINE  ADC_BITS 10                 ' 10-bit Analog to digital
    define  CCP1_REG     0              ' Must clear unused CCP pins or else unpredictable results
    DEFINE  CCP1_BIT     0
    define  CCP2_REG     0
    DEFINE  CCP2_BIT     0
    DEFINE  CCP3_REG     0
    DEFINE  CCP3_BIT     0
    define  CCP4_REG     0
    DEFINE  CCP4_BIT     0
    define  CCP5_REG     0              ' Must clear unused CCP pins or else unpredictable results
    DEFINE  CCP5_BIT     0
    DEFINE  HSER_RXREG PORTC
    DEFINE  HSER_RXBIT 7
    DEFINE  HSER_TXREG PORTC
    DEFINE  HSER_TXBIT 6
    DEFINE  HSER_RCSTA 90h              ' Enable serial port & continuous receive
    DEFINE  HSER_TXSTA 24h              ' Enable transmit, BRGH = 1
    Define  HSER_BAUD 115200
    DEFINE  HSER_CLROERR 1              ' Clear overflow automatically
    DEFINE  HSER_SPBRGH  0
    DEFINE  HSER_SPBRG  68
    BAUDCON.3 = 1                       ' Enable 16 bit baudrate generator
    RA4PPS = 0                          ' Disable CCP5
    RB0PPS = 0                          ' Disable CCP4
    RB5PPS = 0                          ' Disable CCP3
    RC1PPS = 0                          ' Disable CCP2
    RC2PPS = 0                          ' Disable CCP1
    IOCAP = %00000000                               'IOC Positive Edge, low-to-high
    IOCAN = %00000000                               'IOC Negative Edge, from high-to-low
    IOCBP = %00000000                               'IOC Positive Edge, low-to-high
    IOCBN = %00000000                               'IOC Negative Edge, from high-to-low
    IOCCP = %00000000                               'IOC Positive Edge, low-to-high
    IOCCN = %00000000                               'IOC Negative Edge, from high-to-low
    'IOCDP = %00000000                              '...not available
    'IOCDN = %00000000                              '...not available
    'IOCEP = %00000000                              '...not available
    'IOCEN = %00000000                              '...not available
    WPUA = %00000000                        ' Pull-up resistors
    WPUB = %00000000
    WPUC = %00000000
    WPUD = %00000000
    WPUE = %00000000
    INLVLA = %00000000                      ' TTL input level
    INLVLB = %00000000
    INLVLC = %00000000
    INLVLD = %00000000
    'INLVLE = %00000000                      ' ...only available on E3 / MCLR pin
    ADCON0 = %10000100                      ' ADC CONTROL REGISTER 0
    ADCLK  = %00111111                      ' ADC CLOCK SELECTION REGISTER
    'ADPCH  = %00011010                      ' Channel 26 - D2
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000110                      ' Pin D2 = ADC input, NavCom
                                            ' Pin D1 = ADC input, Glareshield
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000110
    TRISE = %00000000
    include "I:\Project_v2\PBP\PBP_Includes\USART.bas"
    ADCInput                var word
    LowADC                  var word
    HighADC                 var word
        Pause 1                                     ' Let PIC stabilize
        LowADC = 1023
        HighADC = 0
        AdcInput = 0
    Mainloop:
        adcin 26, AdcInput
        if AdcInput < LowADC then LowADc = AdcInput
        if AdcInput > HighADC then HighADC = AdcInput
        hserout [   "Low=", dec5 LowADC, "  High=", DEC5 HighADC, 10  ]
        goto mainloop
    I was getting desperate with the drift on the pots, so I thought I'd do a control run using resistors.
    I expected it to remain the same or very close, but I'm still getting drift.
    Default Re: How can I reduce ADC drift
    50mV of noise on the power supply would do that.
    using FVR as adc ref might help a little and or a better regulator for the pots
    I use a DC-DC converter to lower 12V down to 5V for the entire circuit.
    Would a dedicated 7805 for the pots be a "meaningful" improvement?
    I'll have up to 10 pots in the final circuit. Right now I'm trying to get 1 ADC working well.
    the first step is to measure the noise on the power rail and then to determine if that's an issue, there is no point adding a regulator for the pots if the adc pos reference is noisy
    Based on the fact that you are using Power Supply as a reference voltage for the ADC:
    1. the Power Supply noise is random and in the length of time it would have very minimal effect on the adc average value.
    2. you are feeding the ADC input from a resistor divider that is connected to the Vdd, where also the reference voltage is connected to. It is called ratiometric and should zero the effect of regulator voltage drift. If the voltage of the Resistor divider changes by x % then the reference voltage will change by x % too. So eventually no drift should happen.
    What you experience is strange and should not happen.
    Needs more investigation.
    If you heat or cool the PIC chip, is there any change?
    P.S. If you finally use external Voltage reference, that is reasonably stable, I feel that the results will be even worse, because then the Vdd change will have maximum effect on the voltage sample.
    The Vdd that resistors are connected to, is the exact same point that PIC Vdd pin is connected also?
    Yes, it is.
    Temperature (heating or cooling PIC) has any effect on the drift?
    I'm curious how can this help me?
    It is room temperature, just like target customer environment (gaming).
    It's not like I'm overclocking the PIC like a PC CPU...?
    If the ADC result has no or minimal effect because of temp then we have to look elsewhere for the drift.
    Jan 2011
    Sydney, Australia
    I would try the following:
    1/. Use the Fixed Voltage Reference (FVR) instead of Vdd as your ADC reference voltage.
    2/. Add some capacitance - say 100nF - between the pot wiper and ground.
    Cheers
    Barry
    VK2XBP
    Quote Originally Posted by Aussie Barry View Post
    Cheers
    Barry
    VK2XBP
    1. Yeah, FVR is on my TO-DO list (Richard mentioned it up there).
    2. Does it matter if the cap is at the switch or up against PIC (like decoupler caps).
    3. Temp is also on my TO-DO list.
    also try using the fastest conversion clock that does not go Outside the recommended TAD time.
    you are using the slowest possible clock
    if you use the fvr don't let the wiper volts exceed the fvr output volts
    Jan 2011
    Sydney, Australia
    It shouldn't really matter if the cap is at the PIC end or the Pot end, as long as the distance between both is not too great.
    Note the silicon errata document (Item 1.3) regarding the use of FVR as ADC reference voltage:
    https://ww1.microchip.com/downloads/...-80000702J.pdf
    Cheers
    Barry
    Jan 2011
    Sydney, Australia
    What happens if the wiper voltage exceeds the FVR voltage?
    Jan 2011
    Sydney, Australia
    16F18877
    The PIC16F18877 has an Analog-to-Digital converter with Computation
    These post-processing functions are applied to the ADC conversion result and include averaging and low-pass filtering.
    Cheers
    Barry
    Ain specs from datasheet
    Name:  Screenshot 2024-11-02 121344.jpg
    at best the top range of the pot would be useless
    Using FVR will make things worse...
    I thought I'd step back and check VDD and VSS using my SDS1104 scope.
    This is at 50mV:
    Name:  SDS1104 scope VDD.jpg
Size:  140.7 KBName:  SDS1104 scope VSS .jpg
    Is it realistic to expect no drift on ADC with this much noise on my lines?
    CONFIRMED: Noisy power definitely messes up everything when the PIC tries to compare the "wiper" reading with VDD/VSS, even using two 1K resistors to simulate 50% pot.
    I switched to a 7805 supply and put back my "supposedly dirty" potentiometer. ADC low/high was back to a steady reading no matter where I turned the pot.
    I had code prepared using the techniques discussed in Melanie's ADC thread (or was it SORT, I don't remember). I got lost looking at the computational feature of the ADC in the 16F18877; that could have replaced my averaging routine and most likely reduced time.
    At worse if I get a dirty pot, I can drop the 1-2 lower bits from the 10-bit reading and still get 512-256 resolution out of a maximum 1024.
    I did an extra test to confirm it wasn't another component on my main test board that was "messing up" the power.
    I powered my isolated PIC with that DC-DC converter and sure enough ADC was jumping between 546 and 569 using my pot.
    So now i have to find a 7805 variant that can supply 700mA without breaking a sweat.
    Drift is tottaly different than jumping numbers...
    When you said drift I assumed that you started with say 512 as a 50% of FSD and then it went up or down after some time, like 511, 510, 509 etc.
    Having random numbers sure can be due to crappy and noisy Voltage on Vdd.
  1. SOLVED - IOC works on B0 but not B5
    By Demon in forum General
    Last Post: - 26th September 2024, 22:11
  2. SOLVED - How to calculate Timer preload
    Last Post: - 23rd August 2024, 18:33
  3. trying to reduce current consumption on a 12HV615
    By Max Power in forum mel PIC BASIC Pro
    Last Post: - 30th November 2011, 15:57
  4. Hanging on SERIN2 - SOLVED!
    By blainecf in forum Serial
    Last Post: - 13th July 2006, 18:55
  5. Dmx Solved !!!!!!!
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2005, 22:57
Members who have read this thread : 8
