Issues sending and receiving data
Results 1 to 20 of 20
    Jul 2024
    Default Issues sending and receiving data
    Hi guys,
    I'm trying to send/receive data between 2 PICs on the same circuit.
    The first one (16F1508) is sending data with debug command.
    INCLUDE "modedefs.bas"
    DEFINE DEBUG_REG PORTA             ' Set Debug pin port
    DEFINE DEBUG_BIT 2                ' Set Debug pin bit
    DEFINE DEBUG_BAUD 2400            ' Set Debug baud rate
    DEFINE DEBUG_MODE 0                ' Set Debug mode: 0 = true, 1 = inverted
    PreAmble     CON     $A5
    debug PreAmble,$af,$c2,$b5,$ef,13,10
    The second one (16F1503) is receiving the data with debugin command.
    DEFINE DEBUG_REG PORTC             ' Set Debug pin port
    DEFINE DEBUGIN_REG PORTA        ' Set Debugin pin port
    DEFINE DEBUGIN_BIT 1            ' Set Debugin pin bit
    DEFINE DEBUGIN_BAUD 2400        ' Set Debugin baud rate (same as Debug baud)
    DEFINE DEBUGIN_MODE 0            ' Set Debugin mode: 0 = true, 1 = inverted
    DEBUGIN 1000,timeoutlabel,[WAIT("$af"),DAT1,DAT2,DAT3]
    pause 3000
    IF DAT1=$c2 THEN
    GOTO SELECTION
    timeoutlabel:
    debug DEC 99,DAT1,DAT2,DAT3,13,10
    pause 3000
    The data validation fails and the code jumps to the timeout label.
    The timeout label is sending the received information out for troubleshooting purposes.
    For troubleshooting I'm using a Microchip Pickit serial analyzer.
    The information sent is different from the information received.
    This is the data sent from PIC #1 and captured with the analyzer:
    [00][A5][AF][C2][B5][EF][0D][0A]
    And this is the data sent from PIC #2 (when in timeoutlabel) and captured with the analyzer:
     [4E][4E][BF][79][0D][0A][00]
    Why is the data different? The only data that seems to be correct are the carriage return bytes.
    What am I doing wrong?
    Default Re: Issues sending and receiving data
    I do not see a loop in the sending device. Seems it sends the data once and then stops.
    So the receiving device, if fails to receive first time correct data, loops in the timeout sub.
    Then spits out the data that are randomly stored in the variables, since you do not have a CLEAR command on the top of your program. CLEAR will ensure all variables are set to zero.
    The PAUSE 3000 are not needed I guess, since you have a 1 sec timeout.
    Ioannis.
    Jul 2024
    Greetings Ioannis,
    thank you so much for your help.
    The sending device is actually running on a loop to troubleshoot the issue. I failed to copy that in here but it's something like this:
    pause 3000
    The receiving pic is also on a loop and that's the reason for the pause 3000 before going back to Main.
    You also have to disable the analog inputs of port A, set by default on PIC reset, by clearing the ANSELA register.
    If you drive the output as in the sender program, then the port is set as digital output. Still I would disable the analog function. But as input it will operate as Analog input, not digital.
    Also get rid of the PAUSE 3000. They offer nothing really useful.
    ...... [WAIT("$af"),DAT1,DAT2,DAT3]........ [WAIT($af),DAT1,DAT2,DAT3]
    Jul 2024
    Greetings all,
    thanks for the replies.
    Regarding the I/O setup, I have included the "INCLUDE "ALLDIGITAL.pbp"" on both receiver and sender codes.
    And even with the "[WAIT($af),DAT1,DAT2,DAT3]" modification, I still get the wrong data on the receiver PIC.
    Any additional thoughts?
    Thank you so much.
    Quote Originally Posted by PaulMaker View Post
    my thoughts-
    code snippets are a waste of time, a minimal, complete and verifiable example MCVE gets results
    https://stackoverflow.com/help/minim...ucible-example
    Jul 2024
    Greetings Richard,
    that makes total sense, sorry for that.
    Here is the code being used to test/troubleshoot the issue...
    The sending PIC triggers COM pin high/low before sending the data.
    The receiving PIC detects the COM trigger with IOC interrupt and starts listening.
    This part of the code is working since it's detecting the trigger and starts listening.
    The thing that is not working is the data reception correctly.
    Send pic code
    '****************************************************************'*  Name    : 16F1508_Send.PBP                                  *
    '*            PORTA.2 CONNECTED TO PORTA.1 ON RECEIVING PIC     *
    ;----[16F1508 Hardware Configuration]-------------------------------------------
    #IF __PROCESSOR__ = "16F1508"
      #DEFINE MCU_FOUND 1
    cfg1 = _FOSC_INTOSC           ; INTOSC oscillator: I/O function on CLKIN pin
    cfg1&= _WDTE_OFF              ; WDT disabled
    cfg1&= _PWRTE_OFF             ; PWRT disabled
    cfg1&= _MCLRE_OFF             ; MCLR/VPP pin function is digital input
    cfg1&= _CP_OFF                ; Program memory code protection is disabled
    cfg1&= _BOREN_OFF             ; Brown-out Reset disabled
    cfg1&= _CLKOUTEN_OFF          ; CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin
    cfg1&= _IESO_OFF              ; Internal/External Switchover Mode is disabled
    cfg1&= _FCMEN_OFF             ; Fail-Safe Clock Monitor is disabled
      __CONFIG _CONFIG1, cfg1
    cfg2 = _WRT_OFF               ; Write protection off
    cfg2&= _STVREN_OFF            ; Stack Overflow or Underflow will not cause a Reset
    cfg2&= _BORV_LO               ; Brown-out Reset Voltage (Vbor), low trip point selected.
    cfg2&= _LPBOR_OFF             ; Low-Power BOR is disabled
    cfg2&= _LVP_OFF               ; High-voltage on MCLR/VPP must be used for programming
      __CONFIG _CONFIG2, cfg2
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    DEFINE OSC 16                               ' Let PBP clock speed will be 16MHz
    OSCCON = %01111011                          ' Use internal oscillator and set to 16MHz
    OPTION_REG.7 = 0                            ' Enable individual control of weak pull-ups
    WPUA.0 = 0                                  ' Disable weak pull-up on RA0
    WPUA.1 = 0                                  ' Disable weak pull-up on RA1
    WPUA.2 = 0                                  ' Disable weak pull-up on RA2
    WPUA.3 = 0                                  ' Disable weak pull-up on RA3
    WPUA.4 = 1                                  ' Enable weak pull-up on RA4
    WPUA.5 = 1                                  ' Enable weak pull-up on RA5
    DACCON0.7 = 0                               ' Disable DAC
    CM1CON0.7 = 0                               ' Disable comparator 1
    CM2CON0.7 = 0                               ' Disable comparator 2
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    DEFINE SHOWDIGITAL 1
    'PORTS & PINS
    COMMTX	    	VAR		PORTA.2
    MESLED	    	VAR		PORTB.5		'MESSAGE LED
    PreAmble 		CON 	$A5
    INIT:
    PORTA=%00000000
    PORTB=%00000000
    PORTC=%00000000
    GOTO START
    START:
    HIGH INTLED
    HIGH COMMTX
    PAUSE 500
    LOW COMMTX
    LOW INTLED
    PAUSE 200
    HIGH MESLED
    PAUSE 500
    LOW MESLED
    PAUSE 4000
    GOTO START
    Receive pic code
    '****************************************************************'*  Name    : 16F1503_Receive.PBP                               *
    '*            PORTA.1 CONNECTED TO PORTA.2 ON SENDING PIC       *
    ;----[16F1503 Hardware Configuration]-------------------------------------------
    #IF __PROCESSOR__ = "16F1503"
      #DEFINE MCU_FOUND 1
    #ENDIF
    #IFNDEF MCU_FOUND
    #ENDIF
    WPUA.4 = 0                                  ' Disable weak pull-up on RA4
    WPUA.5 = 0                                  ' Disable weak pull-up on RA5
    TRISA = %00001010                           ' Set RA1-RA3 as inputs
    TRISC = %00000000                           ' Set RC port as output
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    DEFINE DEBUG_BIT 3				' Set Debug pin bit
    ;____[ For 12F/16F only - Interrupt Context save locations]_________________
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    ;wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    ;wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    ;wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    'https://www.picbasic.co.uk/forum/showthread.php/3251-Instant-Interrupts-Revisited/page7?highlight=DT%27s+instant+interrupts
    'https://www.picbasic.co.uk/forum/showthread.php/3251-Instant-Interrupts-Revisited/page16?highlight=DT%27s+instant+interrupts
    'Open the DT_INTS-14.bas file and comment out the wsave lines.
    'The 675 doesn't have any usable RAM in banks 1,2 or 3
    INTCON.3=1
    IOCAP.1=1 	     'POSITIVE EDGE @ A1 ON
    IOCAN=%0		 'NEGATIVE EDGE OFF
    'page 106
    '---[INT - interrupt handler]---------------------------------------------------
            INT_Handler  IOC_INT,    _IOCinterrupts,    PBP,  yes
    @ INT_ENABLE IOC_INT
    'PORTS & PINS
    INTLED	    VAR		PORTC.3		'INTERRUPT LED
    MESLED	    VAR		PORTC.4		'MESSAGE LED
    DAT1        VAR     BYTE	'
    DAT2        VAR     BYTE	'
    DAT3        VAR     BYTE	'
    CT			VAR		BYTE	'
    INIT:
    PORTC=%000000
    GOTO START
    START:
    LOW INTLED
    LOW MESLED
    GOTO START
    IOCinterrupts:
    @   INT_DISABLE IOC_INT
    HIGH INTLED
    PAUSE 500
    DEBUGIN 1000,timeoutlabel,[WAIT($af),DAT1,DAT2,DAT3]
    PAUSE 200
    low INTLED
    PAUSE 500
    IF DAT1=$c2 THEN
    GOTO PROGSEL
    'RETURN TO PROGRAM
    IOCAF=%0
    @ INT_RETURN
    timeoutlabel:
    low INTLED
    HIGH MESLED
    debug DEC 99,DAT1,DAT2,DAT3,13,10 'Message confirming bad reception
    low MESLED
    'RETURN TO PROGRAM
    IOCAF=%0
    @ INT_RETURN
    PROGSEL
    debug DEC 09,DAT1,DAT2,DAT3,13,10 'Message confirming reception
    for ct=0 to 10
    toggle INTLED
    toggle MESLED
    next ct
    'RETURN TO PROGRAM
    IOCAF=%0
    @ INT_RETURN
    Thanks for the help
    .... also maybe.....
    PreAmble CON $A5
    PreAmble CON $A5
    ,$af,$c2,$b5,$ef,13,10 is equal to 175,194,181,239,13,10 .... so ... debug 165,175,194,181,239,13,10.... or debug HEX 165,175,194,181,239,13,10
    then.... Main:
    DEBUGIN 1000,timeoutlabel,[WAIT(165),DAT1,DAT2,DAT3]
    pause 3000
    or
    DEBUGIN 1000,timeoutlabel,[WAIT(HEX $AF),$DAT1,$DAT2,$DAT3]
    pause 3000....
    have to know what exactly characters are sending and receiving... I would output to a serial terminal to see if what you are sending is what you think you are sending
    Jul 2024
    Greetings amgen,
    thanks for the help,
    your sending capture looks good. Handling the receive, the debug in may or may not filter how you want... play with that some because if receiving HEX, that is 2 bytes to make into 1 byte value of DAT etc... ???? ... can also dictate (if it is not the default) 2 digits for the hex... HEX2
    maybe.... DEBUGIN 1000,timeoutlabel,[WAIT("AF"),$DAT1,$DAT2,$DAT3].... or DEBUGIN 1000,timeoutlabel,[WAIT(HEX2 AF),$DAT1,$DAT2,$DAT3].... or DEBUGIN 1000,timeoutlabel,[WAIT(HEX2 "AF"),$DAT1,$DAT2,$DAT3]
    . Thought of 1 more thing.... add a temporary serout or debug and send to your capture or ser terminal 1 received character at a time to easily see what you are receiving
    I do not have that chip, so can you check if this code works please?
      #DEFINE MCU_FOUND 1
    #ENDIF
    #IFNDEF MCU_FOUND
    #ENDIF
    INTCON.3=1
    'page 106
    'ASM
    'INT_LIST  macro    ; IntSource,        Label,  Type, ResetFlag?
    '        INT_Handler  IOC_INT,    _IOCinterrupts,    PBP,  yes
    'endm
    'INT_CREATE               ; Creates the interrupt processor
    'ENDASM
    '@ INT_ENABLE IOC_INT
    'PORTS & PINS
    DAT1        VAR     BYTE	'
    DAT2        VAR     BYTE	'
    DAT3        VAR     BYTE	'
    CT			VAR		BYTE	'
    INIT:
    PORTC=%000000
    GOTO START
    START:
    LOW INTLED
    LOW MESLED
    GOTO START
    timeoutlabel:
        low INTLED
        HIGH MESLED
        debug "Bad data",13,10 'Message confirming bad reception
        low MESLED
    goto START
    'IOCinterrupts:
    '@   INT_DISABLE IOC_INT
    'HIGH INTLED
    'PAUSE 500
    'DEBUGIN 1000,timeoutlabel,[WAIT($af),DAT1,DAT2,DAT3]
    'PAUSE 200
    'pause 500
    'low INTLED
    'PAUSE 500
    'IF DAT1=$c2 THEN
    'GOTO PROGSEL
    'ENDIF
    ''RETURN TO PROGRAM
    'IOCAF=%0
    '@ INT_RETURN
    'timeoutlabel:
    'low INTLED
    'HIGH MESLED
    'debug DEC 99,DAT1,DAT2,DAT3,13,10 'Message confirming bad reception
    'pause 1000
    'low MESLED
    ''RETURN TO PROGRAM
    'IOCAF=%0
    '@ INT_RETURN
    PROGSEL
    for ct=0 to 10
    toggle INTLED
    toggle MESLED
    next ct
    'RETURN TO PROGRAM
    'IOCAF=%0
    '@ INT_RETURN
    i don't see this working , porta.3 is input only
    Receive pic code
    the concept of reading a serial transmission in an interrupt routine triggered by the start bit is badly flawed.
    by the time the isr's bit-banged reception routine is activated the start bit has been lost and you will just read in a bunch of framing errors
    hard to see the red bits doing anything of value except to cause framing errors
    you could add the blue bits to prevent framing errors @ startup
    COMMTX            VAR        PORTA.2    MESLED            VAR        PORTB.5        'MESSAGE LED
    PreAmble         CON     $A5
    INIT:
    PORTA=000000
    PORTB=000000
    PORTC=000000
    HIGH COMMTX
    pause 10
    GOTO START
    START:
    HIGH INTLED
    HIGH COMMTX
    PAUSE 500
    LOW COMMTX
    LOW INTLED
    PAUSE 200
    HIGH MESLED
    PAUSE 500
    LOW MESLED
    PAUSE 4000
    GOTO START
    if you use a viable pin on the rx unit it for debug will work , its not a way i would recommend
    Jul 2024
    Greetings everyone,
    first of all, thank you so much for your help.
    Will try your suggestions tonight and give feedback.
    @Richard, just to explain...the red bits are there only to trigger the IOC on the receiver side so that it knows when it needs to start listening.
    The reason is because the receiver PIC will do a lot of tasks and will only stop to pay attention to the RX pin when the IOC is triggered.
    The IOC and RX pins are defined as the same pin to save an I/O pin on both sender and received PICs.
    Best regards
    Rui
    If you instist on using ISR for the USART receiver, why not use the USART Interrupt directly? It will not work otherwise as Richard noted.
    Test your circuit and logic of the communication first with no interrupts and then decide what to do next.
    Jul 2024
    Greetings Ioannis,
    Yes, I know...
    the problem is that, although the TX PIC 16F1508 is equipped with a EUSART module, the receiver PIC 16F1503 is not
    The IOC was a workaround that i came up with to trigger the debugin command on the RX PIC.
    Best regards
    wow, no hardware usart is serious..... your 1503 has mssp interrupt..... if you can make all that work, you are very skilled indeed !
    Then you have to run a fast loop and make sure you won't miss any byte.
    Are you sure you cannot change that 1503?
    Jul 2024
    Hi guys,
    sorry for the late reply...
    After some testing, I decided to change my 16F1503 receiver PIC to a 16F1508 which is equipped with an USART module. It's much easier to implement this way.
    Thank you all for the support!
  1. SERIN2 Receiving Wrong Data
    By rsocor01 in forum mel PIC BASIC Pro
    Last Post: - 4th May 2024, 21:31
  2. how to display data receiving from xbee to LCD
    By NURULHAIZA in forum mel PIC BASIC
    Last Post: - 19th November 2010, 22:24
  3. Sending/receiving data using Linx modules
    By Goat 403 in forum Serial
    Last Post: - 21st May 2009, 14:57
  4. Receiving and Transmitting Serial data at the same time
    Last Post: - 12th April 2007, 23:00
  5. Receiving data from more than one serial Port
    By PICtron in forum mel PIC BASIC Pro
    Last Post: - 15th March 2005, 11:20
