Direct Port Manipulation PBP3 Pro silver edition
+ Reply to Thread
Results 1 to 9 of 9
    Jan 2022
    Default Direct Port Manipulation PBP3 Pro silver edition
    Hello everyone,
    I currently have the PBP3 silver edition, on this edition I can use a PIC18F25K22 with an internal clock of 64Mhz max.
    my question is how fast can I send a signal either a pulse or a High to Low / Low to high to any I/O port.
    I'm looking to send a signal with a duration less than 1us (around 100ns ~ 800ns) in that range
    Is it possible with PBP3 Basic instructions.
    Thanks for any comments.
    Default Re: Direct Port Manipulation PBP3 Pro silver edition
    At 64MHz each instruction cycle is 62.5ns so
    LATB.0 = 1
    @ NOP
    LATB.0 = 0
    Will produce a 125ns pulse. Remove the @NOP for 62.5ns
    I think Richard noted that it is not good idea to manipulate LAT registers.
    Maybe I am wrong though,
    indeed you are
    this is correct code
    LATB.0 = 1
    @ NOP
    LATB.0 = 0
    this is incorrect [pbp high level commands cannot be used with LATx registers]
    HIGH LATB.0
    @ NOP
    LOW LATB.0
    Jan 2022
    Thanks for great help
    I understand the NOP , but the LATB.0 = 1 ?
    Where can I find information about LAT command/function and NOP
    I assume this LAT = register
    B = Port
    .0 = Pin#
    1/0 = High or Low
    I'll test this code below and post the oscilloscope results
    If someone can verify my code it it's correct for a 64Mhz clock speed.
    used meConfig to generate the config section.
    Thanks again
    '  PIC18F25K22
    '  Name    : Pulse Test
    '  Date    : Oct 25-2024
    ;----[18F25K22 Hardware Configuration]------------------------------------------
      CONFIG  FOSC = HSHP        ; HS oscillator (high power > 16 MHz)
      CONFIG  PLLCFG = ON        ; Oscillator multiplied by 4
      CONFIG  PRICLKEN = OFF     ; Primary clock can be disabled by software
      CONFIG  FCMEN = OFF        ; Fail-Safe Clock Monitor disabled
      CONFIG  IESO = OFF         ; Oscillator Switchover mode disabled
      CONFIG  PWRTEN = OFF       ; Power up timer disabled
      CONFIG  BOREN = SBORDIS    ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
      CONFIG  BORV = 190         ; VBOR set to 1.90 V nominal
      CONFIG  WDTEN = ON         ; WDT is always enabled. SWDTEN bit has no effect
      CONFIG  WDTPS = 32768      ; 1:32768
      CONFIG  CCP2MX = PORTC1    ; CCP2 input/output is multiplexed with RC1
      CONFIG  PBADEN = OFF       ; PORTB<5:0> pins are configured as digital I/O on Reset
      CONFIG  CCP3MX = PORTB5    ; P3A/CCP3 input/output is multiplexed with RB5
      CONFIG  HFOFST = ON        ; HFINTOSC output and ready status are not delayed by the oscillator stable status
      CONFIG  T3CMX = PORTC0     ; T3CKI is on RC0
      CONFIG  P2BMX = PORTB5     ; P2B is on RB5
      CONFIG  MCLRE = INTMCLR    ; RE3 input pin enabled; MCLR disabled
      CONFIG  STVREN = ON        ; Stack full/underflow will cause Reset
      CONFIG  LVP = OFF          ; Single-Supply ICSP disabled
      CONFIG  XINST = OFF        ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
      CONFIG  DEBUG = OFF        ; Disabled
      CONFIG  CP0 = OFF          ; Block 0 (000800-001FFFh) not code-protected
      CONFIG  CP1 = OFF          ; Block 1 (002000-003FFFh) not code-protected
      CONFIG  CP2 = OFF          ; Block 2 (004000-005FFFh) not code-protected
      CONFIG  CP3 = OFF          ; Block 3 (006000-007FFFh) not code-protected
      CONFIG  CPB = OFF          ; Boot block (000000-0007FFh) not code-protected
      CONFIG  CPD = OFF          ; Data EEPROM not code-protected
      CONFIG  WRT0 = OFF         ; Block 0 (000800-001FFFh) not write-protected
      CONFIG  WRT1 = OFF         ; Block 1 (002000-003FFFh) not write-protected
      CONFIG  WRT2 = OFF         ; Block 2 (004000-005FFFh) not write-protected
      CONFIG  WRT3 = OFF         ; Block 3 (006000-007FFFh) not write-protected
      CONFIG  WRTC = OFF         ; Configuration registers (300000-3000FFh) not write-protected
      CONFIG  WRTB = OFF         ; Boot Block (000000-0007FFh) not write-protected
      CONFIG  WRTD = OFF         ; Data EEPROM not write-protected
      CONFIG  EBTR0 = OFF        ; Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTR1 = OFF        ; Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTR2 = OFF        ; Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTR3 = OFF        ; Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTRB = OFF        ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    DEFINE OSC 64
    ANSELA = 0
    TRISA = %000000
    OSCTUNE = $40
    OSCCON = $70
    do
    LATA.0 = 1
    @ NOP
    @ NOP
    LATA.1 = 0
    @ NOP
    LATA.1 = 1
    @ NOP
    @ NOP
    LATA.0 = 0
    PAUSE 1000
    LOOP
    Jan 2022
    Hello
    I'm not sure if my code are alright I programmed a PIC18F25K22
    and put 2 oscilloscope probe on Pin RA0, and RA1 as form the code listed and no signal found on those 2 pins.
    I use this chip to control other logic chips, and 2 of theses pin need to send 1 pulse each as shown in the scope pic.
    I'm missing some info's
    If possible let me know what I'm doing wrong with my code.
    thank you
    Name:  RIGOL MM74HC221 WE-OE TRACE.jpg
    '  PIC18F25K22   28x2
    '  Name    : Pulse Test
    DEFINE OSC 64
    ANSELA = 0
    TRISA = 0000
    OSCTUNE = $40
    OSCCON = $70
    do
    LATA.0 = 1
    @ NOP
    @ NOP
    LATA.1 = 0
    @ NOP
    LATA.1 = 1
    @ NOP
    @ NOP
    LATA.0 = 0
    LOOP
    Jan 2022
    Hello everyone,
    I have good news !
    it's finally work fine let me explain my mistakes.
    Changed :
    CONFIG FOSC = HSHP ; HS oscillator (high power > 16 MHz) (need External Xtal)
    for :
    CONFIG FOSC = INTIO67 ; Internal oscillator block (Internal OSC)
    and all the pin signals shows up on the scope.
    I like to thanks everyone here for your excellent support, and also Charles Leo from MELabs.
    Just one more question about the LAT and @ NOP instruction I'm not familiar with theses instructions where can I find
    documentations, and does it work with all PIC or just for a family of PIC like this one PIC18F25K22.
    Here's the scope results with 2 set of code.
    Name:  PIC18F25K22 TRACE-1.png
    LATB is a register within the PIC, not a PBP command. Exactly the same as TRISA, CMCON, WPUA, ANSELA, ADCON and a few hundred more that you will not find in the PBP manual but rather in the datasheet for the specific PIC you're using - again because they are not PBP commands but registers in the PIC that you can read/write.
    LATB.0 = 1 is the syntax used to set bit 0 of the LATB register to '1'.
    Not all PICs have a LAT registers. On those who don't you need use the PORT register instead.
    NOP is the assembly instruction "No Operation" which "wastes" one instruction cycle. @ is the inline assembly directive used to tell PBP that the rest of the line is in fact assembly and not PBP commands.
    Jan 2022
    Thanks so much HenrikOlsson for all this,
    just read about (LAT register (output latch)) in datasheet, and found the NOP but was puzzle about the @. you did clarify all this.
  1. 16F1827 ADC Direct manipulation not working
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 5th June 2013, 22:16
  2. Replies: 3
    Last Post: - 25th February 2011, 02:11
  3. Port bit manipulation useing variables
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 21st November 2010, 04:41
  4. Port Manipulation
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 5th March 2008, 04:30
  5. Serial Port Complete 2nd Edition
    By Bruce in forum Serial
    Last Post: - 8th November 2007, 15:28
Members who have read this thread : 12
