Calculating Sunrise and Sunset 2
Results 1 to 18 of 18
    SWITZERLAND (french speaking)
    Default Re: Calculating Sunrise and Sunset 2
    Just a thought: from what I understand from Amgen's and Henrik's suggestions, is that the sunrise and sunset would be roughtly linearly calculable.
    Is it so?
    Roger
    Bombay, India
    Depending on your application, the approach you take to solve your problem could differ.
    For a changeable lattitude, longitude, Height above sea level, DST the calculation is not trivial. The astronomical calculations used require double precision (15digits floating point) math to get accurate results.
    If your location is fixed, then perhaps a table driven approach with corrections applied to the table for different dates of the year may work - I am not sure of this.
    You may find C code for the calculations if you search for such calculations.
    IMO : this is most certainly not easy to undetake in PicBasic.
  1. Calculating MKT
    By pedja089 in forum General
    Last Post: - 10th November 2013, 14:46
  2. Calculating a checksum
    By simongie in forum General
    Last Post: - 21st August 2009, 13:08
  3. Calculating Sunrise and Sunset
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 21st November 2007, 16:56
  4. calculating speed of a loop
    By EDWARD in forum mel PIC BASIC Pro
    Last Post: - 5th June 2005, 20:34
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
