PIC hangs after interrupt when FT232RL is connected
Results 1 to 4 of 4
    Question PIC hangs after interrupt when FT232RL is connected
    I bought one of these boards on amazon to help with debugging:
    https://www.amazon.ca/gp/product/B075N82CDL/
    The PIC hangs after the first timer interrupt is triggered. The FT232 is connected to VSS and TX/RX which is wired to and RX/TX on a 2nd PIC (4K7 pull-ups).
    If I unplug the USB cable and reset the circuit, the PIC starts up and loops as expected.
    Is there something we should be aware of when using these?
    Default Re: PIC hangs after interrupt when FT232RL is connected
    What steps did you take to make the output of the adapter open collector so that it won't clash with the pics outputs on your bus.?
    Are you sure it's correctly connected, arduino things are often labelled to show the arduino pin they connect to, making rx the output tx the input
    What steps did you take to make the output of the adapter open collector so that it won't clash with the pics outputs on your bus.? ...
    None that I know of. I'm using the Serial Communicator from MCSP+ 5.0.0.5. on the PC side.
    ... Are you sure it's correctly connected, arduino things are often labelled to show the arduino pin they connect to, making rx the output tx the input
    The adapter has RX/TX labels. I connected them in relation to the PC - not the PIC.
    I reconnected the whole circuit now, and it works...? I don't know why, I didn't change anything except recompiled with the HSEROUTs enabled again.
    1. The only difference is that I rebooted the PC today. The only thing I can imagine is that the adapter was somehow disturbing the PIC USART even if it was only sending, there is no HSERIN code.
    2. I have noticed recently that I have to shut MCSP+ down because it no longer sees INCLUDES and stuff like that (I can't remember what exactly). I would just restart MCSP= and the compile would work without errors.
    I hate intermittent problems...
    Sep 2009
    There is probablu RX interupt when connected, and it is not handled correctly for what ever reason.
  1. Replies: 5
    Last Post: - 28th January 2011, 14:21
  2. Replies: 0
    Last Post: - 1st September 2008, 08:03
  3. PIC HANGS with SERIN and Timeout?
    Last Post: - 18th January 2008, 18:33
  4. Any sample FTDI FT232RL or FT232BM code?
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2007, 19:04
  5. PIC Hangs when using Serin TimeOut
    By Squibcakes in forum Serial
    Last Post: - 20th July 2006, 02:59
