12F1840 - HPWM outputs PWM on CCP pin instead of P1B pin.
Results 1 to 6 of 6
    Default Re: 12F1840 - HPWM outputs PWM on CCP pin instead of P1B pin.
    Yes it does, but when chip has multiple PWM output pins, usually HPWM 2, HPWM 3, etc, output on the corresponding pin.
    you need to set the steering mode to drive p1b
    Thanks, will try it a bit later!
    This fixed it, thanks again!
    APFCON=%00000010
    PSTR1CON=%00010010
  1. PBP Support for 12F1840 8-Pin Device?
    By springtank in forum mel PIC BASIC Pro
    Last Post: - 10th November 2012, 08:32
  2. Replies: 5
    Last Post: - 24th July 2010, 09:34
  3. 8 pin DIP w/6 outputs ?
    By Sam in forum General
    Last Post: - 14th September 2009, 20:15
  4. Pin outputs to an array
    By Firegod in forum mel PIC BASIC Pro
    Last Post: - 20th March 2007, 17:35
  5. Multiplexing PWM pin with other outputs
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 19th September 2006, 11:24
