PC Interface
Results 1 to 15 of 15
Thread: PC Interface
    Default Re: PC Interface
    I'll check my PC. I'm sure I found a tutorial.
    Edit: this is where I'll start reviewing vb community.
    I remember this guy being my #1 reference.
    https://www.picbasic.co.uk/forum/sho...229#post154229
    Thanks for that. I review it in the past but is a bit complicated for me. I guess I am too old to do that...!
    Maybe there is a simpler environment to build an executable with few drop down selections.
    Something like this https://www.electronic-software-shop...expert-40.html
    Look at tutorials for Winform using BASIC specifically. It's in VB community, and probably as simplified graphical interface you can get, for FREE.
    You wouldn't have to get back into C, C++ or C#.
    There's most likely commercial tools to do the same, but MS has a proven track record.
    EDIT: I had to use C++ because the interface tool for MS Flight Sim had C++ interfaces available.
    If you want something else, I'd start googling for "simplified gui generator software".
    Like: https://retool.com/pricing
    Interesting comments here:
    https://www.reddit.com/r/AskProgramm...imple_gui_app/
    More discussion here pushing for Winform:
    https://www.reddit.com/r/csharp/comm...ay_to_build_a/
    and here:
    https://forums.freebsd.org/threads/l...builder.72104/
    and here:
    https://stackoverflow.com/questions/...ui-application
    So far, I don't see one software standing up above the crowd, except for Winform.
    I used Visual Basic back in the good old VB6 days. When .net came along it got complicated. They removed the built in serial port control which made it a lot harder to use. In later versions they put it back. But what was always an issue for me was the portabillity of the application developed. I was never able to have it produce a single executable or an installer (with all needed dependencies) that was easy to deploy on someone elses computer. For ones own use, where you run what you develop on the machine where it's being developed it doesn't matter.
    PureBasic looks interesting (I have not tried it).
    Claims to generate single, 32 or 64bit executable without depending on multi gigabyte frameworks, runtime interpreters and what not on the "customer" machine. A bit old school perhaps but if you liked VB6 as much as I did perhaps PureBasic will do the thing.
    Thanks Henrik.
    Will have a look at that.
    OK, thanks Robert. Seems also a possibility.
    how about a brief description of what you want to do..... maybe we could do some parts and share some experiences... I made this visual basic thing a while back and somehow it still works..... communicates with my pic over wifi network and doing serial comms was pretty easy.Name:  test socket.JPG
    Yes, seems OK. But I guess on your own machine (as Henrik stated).
    But were you able to make an installer for third party to have it installed on new PC? or even a stand alone executable file to distribute without any worry for DLLs and other crap files?
  1. SPI interface
    Last Post: - 9th January 2011, 01:06
  2. Interface for 16f818
    By davekav in forum Serial
    Last Post: - 17th April 2008, 11:33
  3. 'SCI' interface
    By ecua64 in forum Off Topic
    Last Post: - 29th September 2005, 16:02
  4. DMX Interface
    By electronicsuk in forum mel PIC BASIC Pro
    Last Post: - 15th July 2005, 13:13
  5. PC interface
    By tigrot in forum Schematics
    Last Post: - 9th October 2004, 19:32
