Symbol not prev defined FSR - Elapsed Timer
Results 1 to 19 of 19
    Default Symbol not prev defined FSR - Elapsed Timer
    16F18877
    Program:
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_OFF & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    ;--- Interrupts ----------------------------------------------------------------
    ;--- Defines -------------------------------------------------------------------
    DEFINE OSC 32
    RA4PPS = 0                          ' Disable CCP5
    RB0PPS = 0                          ' Disable CCP4
    RB5PPS = 0                          ' Disable CCP3
    RC1PPS = 0                          ' Disable CCP2
    RC2PPS = 0                          ' Disable CCP1
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    ;--- Setup Port directions -----------------------------------------------------
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00001000
    INCLUDE "Elapsed_DN_32MHz.bas"  ; Elapsed Timer Routines
    Days = 0                  ' set initial time
    Hours = 0
    Minutes = 0
    Seconds = 1
      LatB.5 = 0
        GOSUB StartTimer
      LatB.5 = 1
        IF Ticks > 100 THEN
            LatB.5 = 0
      GOTO Main
    Elapsed DN, with 32MHz mod:
    '*  Name    : ELAPSED.PBP                                       *
    '*  Author  : Darrel Taylor                                     *
    '*  Notice  : Copyright (c) 2003                                *
    '*  Date    : 12/16/2003                                        *
    Define  INTHAND _ClockCount    ' Tell PBP Where the code starts on an interrupt
    Include "ASM_INTS.bas"         ' ASM Interrupt Stubs
    Ticks    VAR BYTE   ' 1/100th of a second
    Seconds  VAR BYTE
    Minutes  VAR BYTE
    Hours    VAR BYTE
    Days     VAR WORD
    R0save   VAR WORD
    R1save   VAR WORD
    ZERO             VAR BIT
    CountDown        VAR BIT
    SecondsChanged   VAR BIT
    MinutesChanged   VAR BIT
    HoursChanged     VAR BIT
    DaysChanged      VAR BIT
    CountDown = 0
    SecondsChanged = 1
    MinutesChanged = 1
    Goto OverElapsed
    Asm
      IF OSC == 4                       ; Constants for 100hz interrupt from Timer1
    TimerConst = 0D8F7h                 ; Executed at compile time only
      EndIF
      If OSC == 8
    TimerConst = 0B1E7h
      EndIF
      If OSC == 10
    TimerConst = 09E5Fh
      EndIF
      If OSC == 20
    TimerConst = 03CB7h
      EndIF
      If OSC == 32			     ; T1CON
    TimerConst = 063C7h		     ;   TMR1CS bits 7-6, 00 = FOSC/4
      EndIF				     ;   T1CKPS bits 5-4, 01 = 1:2 Prescale value
    ; -----------------  ADD TimerConst to TMR1H:TMR1L
    ADD2_TIMER   macro
        CHK?RP  T1CON
        BCF     T1CON,TMR1ON           ; Turn off timer
        MOVLW   LOW(TimerConst)        ;  1
        ADDWF   TMR1L,F                ;  1    ; reload timer with correct value
        BTFSC   STATUS,C               ;  1/2
        INCF    TMR1H,F                ;  1
        MOVLW   HIGH(TimerConst)       ;  1
        ADDWF   TMR1H,F                ;  1
    ; -----------------  ADD TimerConst to TMR1H:TMR1L and restart TIMER1
    RELOAD_TIMER  macro
        ADD2_TIMER
        BSF     T1CON,TMR1ON           ;  1    ; Turn TIMER1 back on
        CHK?RP  PIR1
        bcf     PIR1, TMR1IF           ; Clear Timer1 Interrupt Flag
    ; -----------------  Load TimerConst into TMR1H:TMR1L
    LOAD_TIMER  macro
    EndAsm
        T1CON.0 = 0                    ; Turn OFF Timer1
        TMR1L = 0
        TMR1H = 0
    Asm
        ADD2_TIMER
    EndAsm
    ' ------[ This is the Interrupt Handler ]---------------------------------------
    ClockCount:   ' Note: this is being handled as an ASM interrupt
    @  INT_START
    @  RELOAD_TIMER                    ; Reload TIMER1
       R0save = R0                     ; Save 2 PBP system vars that are used during
       R1save = R1                     ; the interrupt
       Ticks = Ticks + 1
       if Ticks = 100 then
          Ticks = 0
          IF CountDown THEN
             IF Seconds > 0 THEN
                Seconds = Seconds - 1
                SecondsChanged = 1
                IF Seconds = 0 THEN
                   IF Days = 0 THEN
                      IF Hours = 0 THEN
                         IF Minutes = 0 THEN
                            GOSUB StopTimer    ; Zero reached
                            ZERO = 1
                IF Minutes > 0 THEN
                   Minutes = Minutes - 1
                   Seconds = 59
                   SecondsChanged = 1
                   MinutesChanged = 1
                   IF Hours > 0 THEN
                      Hours = Hours - 1
                      Minutes = 59
                      Seconds = 59
                      SecondsChanged = 1
                      MinutesChanged = 1
                      HoursChanged = 1
                      IF Days > 0 THEN
                         Days = Days - 1
                         Hours = 23
                         Minutes = 59
                         Seconds = 59
                         SecondsChanged = 1
                         MinutesChanged = 1
                         HoursChanged = 1
                         DaysChanged = 1
                      ELSE                     ; Zero already reached, shouldn't get here
                         GOSUB StopTimer
                         ZERO = 1
          ELSE                                ; Counting Up
             Seconds = Seconds + 1
             SecondsChanged = 1
             IF Seconds = 60 THEN
                Minutes = Minutes + 1
                MinutesChanged = 1
                Seconds = 0
             IF Minutes = 60 THEN
                Hours = Hours + 1
                HoursChanged = 1
                Minutes = 0
             IF Hours = 24 THEN
                Days = Days + 1
                DaysChanged = 1
                Hours = 0
       R1 = R1save                     ; Restore the PBP system vars
       R0 = R0save
    @ INT_RETURN                      ; Restore context and return from interrupt
    '-----====[ END OF TMR1 Interrupt Handler ]====---------------------------------
    StartTimer:
      IF NOT ZERO THEN
        T1CON.1 = 0                   ; (TMR1CS) Select FOSC/4 Clock Source
        T1CON.3 = 0                   ; (T1OSCEN) Disable External Oscillator
        PIR1.0  = 0                   ; (TMR1IF) Clear Timer1 Interrupt Flag
        PIE1.0  = 1                   ; (TMR1IE) Enable TMR1 overflow interrupt
        INTCON.6 = 1                  ; (PEIE) Enable peripheral interrupts
        INTCON.7 = 1                  ; (GIE) Enable global interrupts
        T1CON.0 = 1                   ; (TMR1ON) Start TIMER1
    StopTimer:
    ResetTime:
        ZERO = 0
        R0save = T1CON.0              ; Save TMR1ON bit
        TMR1L = 0
        TMR1H = 0
    @   LOAD_TIMER                    ; Load TimerConst
        T1CON.0 = R0save              ; Restore TMR1ON bit
        Ticks = 0
        Seconds = 0
        Minutes = 0
        Hours = 0
        Days = 0
        SecondsChanged = 1
    OverElapsed:
    ASM_INTS.bas:
    '*  Name    : ASM_INTS.PBP                                      *
    '*  Date    : JAN 4, 2003                                       *
    wsave       var byte    $20     SYSTEM          ' location for W if in bank0
    ' --- IF any of these three lines cause an error ??  Simply Comment them out to fix the problem ----
    wsave1      var byte    $A0     SYSTEM          ' location for W if in bank1
    wsave2      var byte    $120    SYSTEM          ' location for W if in bank2
    wsave3      var byte    $1A0    SYSTEM          ' location for W if in bank3
    ssave       var byte    BANK0   SYSTEM          ' location for STATUS register
    psave       var byte    BANK0   SYSTEM          ' location for PCLATH register
    fsave       var byte    BANK0   SYSTEM          ' location for FSR register
    Asm
    INT_START  macro
        IF (CODE_SIZE <= 2)
            movwf   wsave            ; copy W to wsave register
            swapf   STATUS,W         ; swap status reg to be saved into W
            clrf    STATUS           ; change to bank 0 regardless of current bank
            movwf   ssave            ; save status reg to a bank 0 register
            movf    PCLATH,w         ; move PCLATH reg to be saved into W reg
            movwf   psave            ; save PCLATH reg to a bank 0 register
    	EndIF
        movf      FSR,W              ; move FSR reg to be saved into W reg
        movwf     fsave              ; save FSR reg to a bank 0 register
    EndAsm
    Asm
    INT_RETURN   macro
        MOVF    fsave,W              ; Restore the FSR reg
        MOVWF   FSR
        Movf    psave,w              ; Restore the PCLATH reg
        Movwf   PCLATH
        swapf   ssave,w              ; Restore the STATUS reg
        movwf   STATUS
        swapf   wsave,f
        swapf   wsave,w              ; Restore W reg
        Retfie                       ; Exit the interrupt routine
    EndAsm
    For starters, I'm just trying to get a 100tick interval on the Logic Probe with LatB.5.
    Default Re: Symbol not prev defined FSR - Elapsed Timer
    Modded this code for program:
    https://dt.picbasic.co.uk/CODEX/ETimer
    Elapsed_DN.bas came from here:
    https://www.picbasic.co.uk/forum/con...sed-Timer-Demo
    ASM_INTS.bas came from here:
    https://dt.picbasic.co.uk/CODEX/ETimerExamples
    Aug 2011
    There is no FSR in the 16F18877, you have FSR0 and FSR1.
    You need to look at the TMR1 setup... you need to set different registers and bits (ie T1CON and T1CLK).
    There is no FSR in the 16F18877, you have FSR0 and FSR1...
    I don't see a difference between FSR0 and FSR1. I assume I can use either one?
    EDIT: Wooops, highlighted the wrong one, but you get the idea. FSR1 is right there as well, and it points to the same blocks as FSR0.
    16F18877
    I start the timer, but I don't get a pulse on Logic Probe after 100 Ticks.
    DEFINE OSC 32
    define  CCP1_REG     0              ' Must clear unused CCP pins or else unpredictable results
    DEFINE  CCP1_BIT     0
    define  CCP2_REG     0
    DEFINE  CCP2_BIT     0
    DEFINE  CCP3_REG     0
    DEFINE  CCP3_BIT     0
    define  CCP4_REG     0
    DEFINE  CCP4_BIT     0
    define  CCP5_REG     0              ' Must clear unused CCP pins or else unpredictable results
    DEFINE  CCP5_BIT     0
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00001000
    INCLUDE "Elapsed_DN_Timer3_32MHz.bas"   ' Elapsed Timer Routines
    'Include "ASM_INTS_FSR0.bas"             ' Required in folder to compile
    Hours = 0
    Minutes = 1
    Seconds = 0
      LatB.0 = 0            ' Set interrupt trace low
      LatB.1 = 0            ' Set heartbeat trace low
        GOSUB StartTimer
      LatB.0 = 1            ' Beginning of interrupt
      LatB.1 = 1            ' Pulse heartbeat
        IF Ticks > 100 THEN
            LatB.0 = 0      ' End of interrupt
      LatB.1 = 0            ' Reset heartbeat trace
      GOTO Main
    Elapsed_DN_Timer3_32MHz.bas, modified for Timer3 and 32MHz:
    '*  Name    : Elapsed_DN_Timer3_32MHz.bas                       *
    '*  Author  : Robert H                                          *
    '*  Date    : 2024-10-05                                        *
    '*  Notes   : Added support for 16F18877:                       *
    '             a) Added 32MHz                                    *
    '             b) Used Timer3 instead of Timer1:                 *
    '                  - changed Timer1 to Timer3                   *
    '                  - changed T1 to T3                           *
    '                  - changed TMR1 to TMR3                       *
    '                  - changed PIR1 to PIR4                       *
    '                  - changed PIE1 to PIE4                       *
    '             c) Changed T3CON,TMR3ON to T3CON,ON               *
    '             d) Used FSR0 in ASM_INTS_FSR0.bas                 *
    Include "ASM_INTS_FSR0.bas"    ' ASM Interrupt Stubs
    Seconds  VAR BYTE
    Minutes  VAR BYTE
    Hours    VAR BYTE
    Days     VAR WORD
    R0save   VAR WORD
    R1save   VAR WORD
    ZERO             VAR BIT
    CountDown        VAR BIT
    DaysChanged      VAR BIT
    CountDown = 0
    SecondsChanged = 1
    MinutesChanged = 1
    Goto OverElapsed
    Asm
      IF OSC == 4                       ; Constants for 100hz interrupt from Timer3
      EndIF
      If OSC == 8
    TimerConst = 0B1E7h
      EndIF
      If OSC == 10
    TimerConst = 09E5Fh
      EndIF
      If OSC == 20
    TimerConst = 03CB7h
      EndIF
      If OSC == 32			     ; T3CON
    TimerConst = 063C7h		     ;   TMR3CS bit 1,   0  = FOSC/4
      EndIF				     ;   T3CKPS bit 5-4, 01 = 1:2 Prescale value
    ; -----------------  ADD TimerConst to TMR3H:TMR3L
    ADD2_TIMER   macro
        CHK?RP  T3CON
        BCF     T3CON,TMR3ON           ; Turn off timer
        ADDWF   TMR3L,F                ;  1    ; reload timer with correct value
        INCF    TMR3H,F                ;  1
        ADDWF   TMR3H,F                ;  1
    ; -----------------  ADD TimerConst to TMR3H:TMR3L and restart Timer3
    RELOAD_TIMER  macro
        ADD2_TIMER
        BSF     T3CON,TMR3ON           ;  1    ; Turn Timer3 back on
        CHK?RP  PIR4
        bcf     PIR4, TMR3IF           ; Clear Timer3 Interrupt Flag
    ; -----------------  Load TimerConst into TMR3H:TMR3L
    LOAD_TIMER  macro
    EndAsm
        T3CON.0 = 0                    ; Turn OFF Timer3
        TMR3L = 0
        TMR3H = 0
    Asm
        ADD2_TIMER
    EndAsm
    @  INT_START
    @  RELOAD_TIMER                    ; Reload Timer3
       Ticks = Ticks + 1
       if Ticks = 100 then
          Ticks = 0
          IF CountDown THEN
             IF Seconds > 0 THEN
                SecondsChanged = 1
                IF Seconds = 0 THEN
                   IF Days = 0 THEN
                      IF Hours = 0 THEN
                         IF Minutes = 0 THEN
                            ZERO = 1
                IF Minutes > 0 THEN
                   Seconds = 59
                   SecondsChanged = 1
                   MinutesChanged = 1
                   IF Hours > 0 THEN
                      Hours = Hours - 1
                      Minutes = 59
                      Seconds = 59
                      SecondsChanged = 1
                      MinutesChanged = 1
                      HoursChanged = 1
                      IF Days > 0 THEN
                         Days = Days - 1
                         Hours = 23
                         Minutes = 59
                         Seconds = 59
                         SecondsChanged = 1
                         MinutesChanged = 1
                         HoursChanged = 1
                         DaysChanged = 1
                         GOSUB StopTimer
                         ZERO = 1
          ELSE                                ; Counting Up
             SecondsChanged = 1
                MinutesChanged = 1
                Seconds = 0
                Hours = Hours + 1
                HoursChanged = 1
                Minutes = 0
             IF Hours = 24 THEN
                Days = Days + 1
                DaysChanged = 1
                Hours = 0
       R0 = R0save
    '-----====[ END OF TMR3 Interrupt Handler ]====---------------------------------
    StartTimer:
      IF NOT ZERO THEN
        T3CON.1 = 0                   ; (TMR3CS) Select FOSC/4 Clock Source
        T3CON.3 = 0                   ; (T3OSCEN) Disable External Oscillator
        PIR4.0  = 0                   ; (TMR3IF) Clear Timer3 Interrupt Flag
        PIE4.0  = 1                   ; (TMR3IE) Enable TMR3 overflow interrupt
        T3CON.0 = 1                   ; (TMR3ON) Start Timer3
    StopTimer:
    ResetTime:
        ZERO = 0
        R0save = T3CON.0              ; Save TMR3ON bit
        TMR3L = 0
        TMR3H = 0
        T3CON.0 = R0save              ; Restore TMR3ON bit
        Ticks = 0
        Seconds = 0
        Minutes = 0
        Hours = 0
        Days = 0
        SecondsChanged = 1
    OverElapsed:
    ASM_INTS_FSR0.bas, modified for FSR0:
    '*  Name    : ASM_INTS_FSR0.bas                                 *
    '             a) Changed FSR to FSR0                            *
    fsave       var byte    BANK0   SYSTEM          ' location for FSR0 register
    Asm
    INT_START  macro
        IF (CODE_SIZE <= 2)
    	EndIF
        movf      FSR0,W              ; move FSR0 reg to be saved into W reg
        movwf     fsave              ; save FSR0 reg to a bank 0 register
    EndAsm
    Asm
    INT_RETURN   macro
        MOVF    fsave,W              ; Restore the FSR0 reg
        MOVWF   FSR0
        Movwf   PCLATH
        movwf   STATUS
        swapf   wsave,f
    EndAsm
    I used 18F4450 as an example of "default" settings.
    18F4450, bit 0 is called TMR1ON in the datasheet.
    16F18877, bit 0 is called ON.
    If I rename the bit to ON, I get Symbol not previously defined (ON).
    I must have missed something.
    I would start off with interrupt and in routine just add to a counter then in Basic do the math to get seconds, minutes etc. Otherwise that is a lot of code to fumble through.
    there are more problems here than i can count
    1, timer3 has no clock source
    2, how can ticks ever get beyond 100
    main:  LatB.1 = 1            ' Pulse heartbeat
        IF Ticks > 100 THEN
      GOTO Main
    when
    @  INT_START
       Ticks = Ticks + 1
       if Ticks = 100 then
          Ticks = 0
          IF CountDown THEN
    3, a 16f18877 like all enhanced core pic16's has Auto context save
    the entire int_start / int_return macros are inappropriate
    4, you need to rethink that, that is for timer1 not 3
    StartTimer:
      IF NOT ZERO THEN
    I'm already using Timer1, hence why I hoped to use Timer3.
    I'll swap what I'm doing, so I can use DT's routine without changing Timer1.
    (At the restaurant, so can't post elaborate reply)
    ... how can ticks ever get beyond 100 ...
    I only wanted 1 interval, so I'd know the mods were working with the 16F18877.
    how big would Ticks have to be to make this true ?
    IF Ticks > 100 THEN
    IF Ticks > 100 THEN
    I have a feeling I'll be waiting a while for that to happen. I've brought that down to Ticks > 1.
    I've started again with the original includes, and:
    - added 32MHz
    - changed FSR to FSR0
    ...I'm adding T1CON and T1CLK now...
    I'm still puzzled by T1CON,TMR1ON. The datasheet doesn't have TMR1ON, it's just ON.
    EDIT: Confirmed, it works once I added T1CON and T1CLK. I was blindly following the instructions on the Book of Interrupts and forgetting that this PIC is different.
    a) I'm still puzzled why TMR1ON works though; seems contradictory to me.
    b) so 1 Tick is 66.4ms on a 16F18877.
    Blissful ignorance is a wonderful thing...
    all bit definitions are in the mpasmx folder *.inc files. the datasheet refers to any timer1 type timer for that chip, ie tmr1 tmr3 tmr5
    eg
    I want to post my code in Code Examples.
    What would be a good label for new PICs like the 16F18877 that need modified includes?
    Should we edit those includes to match the names In the datasheet?
    Or is that opening another can of worms?
    absolutely not, there is no problem to solve
    if you want to use mpasm bit names in your code then use the bit names that microchip have created for them
    there is zero point in inventing names that mpasmx will not recognize.
    the proper and correct names are in the mpasmx picxxxxx.inc files
    I have no clue why the elapsed timer worked once before I went to bed. I get up today, and I can't get it to repeat the same results.
    ... a 16f18877 like all enhanced core pic16's has Auto context save the entire int_start / int_return macros are inappropriate...
    I didn't comprehend the depth of this statement, until now. I thought I was just forced to accept using Timer1 in the routines, and adapt my main code to use other timers.
    I would start off with interrupt and in routine just add to a counter. ..
    As they say, this is the way. I already have Timer1 running in 50ms intervals, I can easily repeat the same process with Timer3 and maintain a counter (I'm only after 100-200ms intervals anyways, this is just to avoid checking ADC every MainLoop).
    I really thought Elapsed Timer could work with the 16F18877. I didn't understand that the assembler code just doesn't work with the newer PICs.
    (Hopefully I haven't misunderstood anything this time )
    PIC 16F18877
    Timer1 at 50ms intervals
    Timer3 at 150ms intervals
    '                         Generate trace on Interrupt on Logic Probe                               *
    '                                       PIC 16F18877                                               *
    include "I:\Project_v2\PBP\PBP_Includes\DT_INTS-14_16F18877.bas"
    include "I:\Project_v2\PBP\PBP_Includes\ReEnterPBP.bas"
            INT_Handler    TMR1_INT,  _Timer1Interrupt,   PBP,  yes
            INT_Handler    TMR3_INT,  _Timer3Interrupt,   PBP,  yes
        INT_ENABLE    TMR1_INT   ;enables TMR1 interrupts
        INT_ENABLE    TMR3_INT   ;enables TMR3 interrupts
    DEFINE OSC 32
    define  CCP1_REG     0
    DEFINE  CCP1_BIT     0
    define  CCP2_REG     0
    DEFINE  CCP2_BIT     0
    DEFINE  CCP3_REG     0
    DEFINE  CCP3_BIT     0
    define  CCP4_REG     0
    DEFINE  CCP4_BIT     0
    DEFINE  CCP5_BIT     0
    T1CON = %00110001                                   ' 1:8 Prescale, Enables Timer1
    T3CON = %00110001                                   ' 1:8 Prescale, Enables Timer3
    '   bit 7-6 Unimplemented: Read as ‘0’
    '   bit 5-4 CKPS<1:0>: Timer1 Input Clock Prescale Select bits
    '        ---->  11 = 1:8 Prescale value
    '               10 = 1:4 Prescale value
    '               01 = 1:2 Prescale value
    '               00 = 1:1 Prescale value
    '   bit 3   Unimplemented: Read as ‘0’
    '   bit 2   SYNC: Timer1 Synchronization Control bit
    '                   When TMR1CLK = FOSC or FOSC/4
    '                       This bit is ignored. The timer uses the internal clock and no
    '                       additional synchronization is performed.
    '                   When TMR1CS<1:0> = (any setting other than FOSC or FOSC/4)
    '               1 = Do not synchronize external clock input
    '               0 = Synchronized external clock input with system clock
    '   bit 1   RD16: Timer1 On bit
    '               1 = All 16 bits of Timer1 can be read simultaneously (TMR1H is buffered)
    '               0 = 16-bit reads of Timer1 are disabled (TMR1H is not buffered)
    '   bit 0   ON: Timer1 On bit
    '        ---->  1 = Enables Timer1
    '               0 = Stops Timer1 and clears Timer1 gate flip-flop
    T1CLK = %00000001                                   ' FOSC/4 Timer1 Clock
    T3CLK = %00000001                                   ' FOSC/4 Timer1 Clock
    '   bit 7-4 Unimplemented: Read as ‘0’
    '   bit 3-0 TxCS<3:0>: Timer1/3/5 Clock Select bits
    '               1111 = LC4_out
    '               1110 = LC3_out
    '               1101 = LC2_out
    '               1100 = LC1_out
    '               1011 = TMR5 overflow output
    '               1010 = TMR3 overflow output
    '               1001 = TMR1 overflow output
    '               1000 = TMR0 overflow output
    '               0111 = CLKR output clock
    '               0110 = SOSC
    '               0101 = MFINTOSC                     ' 1.05msec @ 32MHz with no preload
    '               0100 = LFINTOSC                     ' n/a
    '               0011 = HFINTOSC                     ' 16.56msec @ 32MHz with no preload
    '               0010 = FOSC                         ' 16.54msec @ 32MHz with no preload
    '        ---->  0001 = FOSC/4                       ' 66.18msec @ 32MHz with no preload
    '               0000 = TxCKIPPS
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00001000
    Timer1Ended             var byte
    Timer3Ended             var byte
    Timer3Counter           var byte
      LatB.2 = 0            ' Set Timer1 trace low
      LatB.0 = 0            ' Set Timer3 trace low
        pause 1
        goto Start
    Timer1Interrupt:
        T1CON.0 = 0                                 ' Stops Timer1
        Timer1Ended = 1                             ' Set flag
    @ INT_RETURN
    Timer3Interrupt:
        T3CON.0 = 0                                 ' Stops Timer3
        Timer3Ended = 1                             ' Set flag
    @ INT_RETURN
    ;--- Subroutines ---------------------------------------------------------------
    StartTimer1:
    @ INT_CLEAR TMR1_INT -- clear flags
        TMR1H = 62 : TMR1L = 95                    ' 50msec interval (32MHz, 16bit, 1:8)
        T1CON.0 = 1                                 ' Starts Timer1
        Timer1Ended = 0                             ' Set flag
    StartTimer3:
        TMR3H = 62 : TMR3L = 95                    ' 50msec interval (32MHz, 16bit, 1:8)
        T3CON.0 = 1                                 ' Starts Timer3
        Timer3Ended = 0                             ' Set flag
    Start:
        GOSUB StartTimer1
      LatB.2 = 1            ' Start Timer1 trace
        Timer3Counter = 0
        GOSUB StartTimer3
      LatB.0 = 1            ' Start Timer3 trace
        IF Timer1Ended = 1 THEN
      LatB.2 = 0            ' Stop Timer1 trace
            GOSUB StartTimer1
        IF Timer3Ended = 1 THEN
            Timer3Counter = Timer3Counter + 1
            if Timer3Counter = 3 then
                Timer3Counter = 0
      LatB.0 = 0            ' Stop Timer3 trace
            GOSUB StartTimer3
      GOTO Main
    Name:  Elapsed timer solution.png
    In case someone needs it.
    DT_INTS-14_16F18877.bas, supports on 16F18877:
    - IOC
    - Timer1
    - Timer3
    - RX
    - CCP1
    - CCP2
    - CCP3
    - CCP4
    - CCP5
    '*  Name    : DT_INTS-14_16F18877.bas                                      *
    '*  Author  : Darrel Taylor (modified by Demon)                            *
    '*  Version : 1.15 (8/29/2024)                                             *
    '*  Date    : OCT 13, 2009                                                 *
    '* REV 1.15  Customized for 16F1885xx-7x (IOC, USART-RX, CCPx)             *
    '* REV 1.10  Fixes Duplicate label error when Handlers cross page boundary *
    '*           Fixes error with 16F1's and MPLAB 8.53 (high)                 *
    '* REV 1.00  Completely re-written, with optimization and F1 chips in mind *
    '* REV 0.93  Fixed CMIF and EEIF problem with older PIC's                  *
    '*           that have the Flags in PIR1 instead of PIR2                   *
    '* Rev 0.92  solves a "Missed Interrupt" and                               *
    '*           banking switching problem                                     *
    DEFINE  DT_INTS_VERSION  110
    DEFINE  INTHAND  INT_ENTRY
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    ;wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    ;wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    ;wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    ssave       VAR BYTE    BANK0   SYSTEM      ' location for STATUS register
    psave       VAR BYTE    BANK0   SYSTEM      ' location for PCLATH register
    fsave       VAR BYTE    BANK0   SYSTEM      ' location for FSR register
    RetAddr     VAR WORD    BANK0
    INT_Bits    VAR BYTE    BANK0
      Serviced  VAR INT_Bits.0
      Vars_Saved VAR INT_Bits.1
    GIE         VAR INTCON.7
    PEIE        VAR INTCON.6
      ifdef PM_USED                             ; verify MPASM is the assembler
        "ERROR: DT_INTS does not support the PM assembler, USE MPASM"
      ifdef ReEnterUsed
        ifdef ReEnterVersion
          if (ReEnterVersion < 34)
            error "Wrong version of ReEnterPBP.bas - Ver 3.4 or higher required
        if (BANK0_END == 0x7F)
          ifdef BANK1_END
            if (BANK1_END == 0xEF)   ; doesn't find 12F683
              variable ACCESSRAM = 1
              variable ACCESSRAM = 0
    #define OrChange Or change to   wsave BYTE $70 SYSTEM
    AddWsave macro B
      if (B == 0)
        if (ACCESSRAM == 1)
          error   "                     Add:"       wsave VAR BYTE $70 SYSTEM
          error   "                     Add:"       wsave VAR BYTE $20 SYSTEM
      if (B == 1)
        if (ACCESSRAM == 1)
          error   "   Add:"       wsave1 VAR BYTE $A0 SYSTEM, OrChange
      if (B == 2)
        if (ACCESSRAM == 1)
          error   "   Add:"       wsave2 VAR BYTE $120 SYSTEM, OrChange
      if (B == 3)
        if (ACCESSRAM == 1)
          error   "   Add:"       wsave3 VAR BYTE $1A0 SYSTEM, OrChange
    #define WsaveE1(B) Chip has RAM in BANK#v(B), but wsave#v(B) was not found.
    ;#define WsaveE2(B) Uncomment wsave#v(B) in the DT_INTS-14.bas file.
    #define WsaveCouldBe This chip has access RAM at $70
    #define WsaveError(B) error  WsaveE1(B)
      ifndef FSR0L     ; not a 16F1
        ifndef wsave
    ;      if (ACCESSRAM == 1)
            error wsave variable not found,
            AddWsave(0)
            variable wsave = 0 ; stop further wsave errors
    ;      else
    ;      endif
          if (wsave == 0x70)
            if (ACCESSRAM == 0)
              error This chip does not have AccessRAM at $70, change to   wsave VAR BYTE $20 SYSTEM
              if (wsave != 0x20)
                error wsave must be either $20 or $70
        ifdef BANK1_START
          ifndef wsave1
            ifdef wsave
              if (wsave != 0x70)
                WsaveError(1)
                AddWsave(1)
              if (ACCESSRAM == 1)
                if (wsave != 0x70)
                  WsaveCouldBe
        ifdef BANK2_START
          ifndef wsave2
            ifdef wsave
              if (wsave != 0x70)
                WsaveError(2)
                AddWsave(2)
        ifdef BANK3_START
          ifndef wsave3
            ifdef wsave
              if (wsave != 0x70)
                WsaveError(3)
                AddWsave(3)
    asm = 0
    Asm = 0
    ASM = 0
    pbp = 1
    Pbp = 1
    PBP = 1
    yes = 1
    Yes = 1
    YES = 1
    no  = 0
    No  = 0
    NO  = 0
    ;---[Original DEFINES]------------------------------------------------------
      #define ALL_INT      INTCON,GIE, INTCON,GIE      ;-- Global Interrupts   *
    ;  #define IOC_INT      INTCON,IOCIF, INTCON,IOCIE  ;-- Int On Change
    ;  #define RX_INT       PIR1,RCIF, PIE1,RCIE        ;-- USART Receive
    ;  #define CCP1_INT     PIR1,CCP1IF, PIE1,CCP1IE    ;-- CCP1
    ;  #define CCP2_INT     PIR2,CCP2IF, PIE2,CCP2IE    ;-- CCP2
    ;  #define CCP3_INT     PIR3,CCP3IF, PIE3,CCP3IE    ;-- CCP3
    ;  #define CCP4_INT     PIR3,CCP4IF, PIE3,CCP4IE    ;-- CCP4
    ;  #define CCP5_INT     PIR3,CCP5IF, PIE3,CCP5IE    ;-- CCP5
      #define IOC_INT      PIR0,IOCIF, PIE0,IOCIE      ;-- Int On Change
      #define TMR1_INT     PIR4,TMR1IF, PIE4,TMR1IE    ;-- Timer1
      #define TMR3_INT     PIR4,TMR3IF, PIE4,TMR3IE    ;-- Timer3
      #define RX_INT       PIR3,RCIF, PIE3,RCIE        ;-- USART Receive
      #define CCP1_INT     PIR6,CCP1IF, PIE6,CCP1IE    ;-- CCP1
      #define CCP2_INT     PIR6,CCP2IF, PIE6,CCP2IE    ;-- CCP2
      #define CCP3_INT     PIR6,CCP3IF, PIE6,CCP3IE    ;-- CCP3
      #define CCP4_INT     PIR6,CCP4IF, PIE6,CCP4IE    ;-- CCP4
      #define CCP5_INT     PIR6,CCP5IF, PIE6,CCP5IE    ;-- CCP5
    ;---[Returns the Address of a Label as a Word]------------------------------
    GetAddress macro Label, Wout
        CHK?RP Wout
        movlw low Label          ; get low byte
        movwf Wout
    ;    movlw High Label         ; get high byte  MPLAB 8.53 killed high
        movlw Label >> 8         ; get high byte
        movwf Wout + 1
    ;---[find correct bank for a BIT variable]----------------------------------
    CHKRP?T  macro reg, bit
        CHK?RP  reg
    ;---[This creates the main Interrupt Service Routine (ISR)]-----------------
    INT_CREATE  macro
      local OverCREATE
        L?GOTO OverCREATE
    INT_ENTRY
        ifndef FSR0L
          if (CODE_SIZE <= 2)
              movwf   wsave       ; 1 copy W to wsave register
              swapf   STATUS,W    ; 2 swap status reg to be saved into W
              clrf    STATUS      ; 3 change to bank 0
              movwf   ssave       ; 4 save status reg to a bank 0 register
              movf    PCLATH,W    ; 5 move PCLATH reg to be saved into W reg
              movwf   psave       ; 6 save PCLATH reg to a bank 0 register
          endIF
          movf      FSR,W         ; 7 move FSR reg to be saved into W reg
          movwf     fsave         ; 8 save FSR reg to a bank 0 register
          banksel 0               ; BANK 0 for F1 chips
        variable  PREV_BANK = 0
        MOVE?CT  0, _Vars_Saved
    List_Start
        ifdef LoopWhenServiced
          MOVE?CT  0, _Serviced   ; indicate nothing has been serviced
        INT_LIST                  ; Expand the users list of interrupt handlers
                                ; INT_LIST macro must be defined in main program
          BIT?GOTO  1, _Serviced, List_Start
        ifdef ReEnterUsed         ; if ReEnterPBP.bas was included
            CHKRP?T  _Vars_Saved
            btfss    _Vars_Saved  ; if PBP system vars have been saved
            goto     INT_EXIT
            L?GOTO   _RestorePBP  ; Restore PBP system Vars
    INT_EXIT
        ifndef FSR0L              ; if chip is not an F1 - restore context
          clrf    STATUS          ; BANK 0
          movf    fsave,W         ; Restore the FSR reg
          movwf   FSR
          movf    psave,w         ; Restore the PCLATH reg
          movwf   PCLATH
          movwf   STATUS
          swapf   wsave,f
        retfie                    ; Exit the interrupt routine
      LABEL?L OverCREATE
        bsf      INTCON, 6      ; Enable Peripheral interrupts
        bsf      INTCON, 7      ; Enable Global interrupts
    ;---[Add an Interrupt Source to the user's list of INT Handlers]------------
    #INT_HANDLER  macro  FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
      list
        local AfterSave, AfterUserRoutine, NoInt
          ifdef FlagBit
            CHK?RP   EnableReg
            btfss    EnableReg, EnableBit        ; if the INT is enabled
            goto     NoInt
            CHK?RP   FlagReg
            btfss    FlagReg, FlagBit            ; and the Flag set?
            goto     NoInt
              MOVE?CT  1, _Serviced
            if (Type == PBP)                     ; If INT handler is PBP
              ifdef ReEnterUsed
                btfsc  _Vars_Saved
                goto   AfterSave
                GetAddress  AfterSave, _RetAddr
                L?GOTO  _SavePBP                 ; Save PBP system Vars
                LABEL?L  AfterSave
                error ReEnterPBP must be INCLUDEd to use PBP type interrupts
            GetAddress  AfterUserRoutine, _RetAddr   ; save return address
            L?GOTO   Label                       ; goto the users INT handler
            LABEL?L AfterUserRoutine
            if (Reset == YES)
              CHK?RP   FlagReg
              bcf      FlagReg, FlagBit        ; reset flag (if specified)
            INT_ERROR  "INT_Handler"
    NoInt
          banksel  0
    PREV_BANK = 0
    #define INT_HANDLER(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
      ifndef INT_Handler
    #define INT_Handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define int_handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define Int_Handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define Int_handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define int_Handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    ;---[Returns from a "goto" subroutine]--------(RetAddr must be set first)---
    #INT_RETURN  macro
          CHK?RP  _RetAddr
          movf    _RetAddr + 1, W  ; Set PCLATH with top byte of return address
          movwf   PCLATH
          movf    _RetAddr, W      ; Go back to where we were
          movwf   PCL
    ;_____________________________
    #define INT_RETURN  #INT_RETURN
      ifndef INT_Return
    #define INT_Return  #INT_RETURN
    #define int_return  #INT_RETURN
    #define Int_Return  #INT_RETURN
    #define Int_return  #INT_RETURN
    #define int_Return  #INT_RETURN
    ;----[Display not found error]----------------------------------------------
    INT_ERROR macro From
        error From -  Interrupt Flag ( FlagReg,FlagBit ) not found.
    ;---[Enable an interrupt source]--------------------------------------------
      ifndef INT_ENABLECLEARFIRST
        #define INT_ENABLECLEARFIRST 1             ; default to Clear First
      endif          ; use DEFINE INT_ENABLECLEARFIRST 0 to NOT clear First
    #INT_ENABLE  macro  FlagReg, FlagBit, EnableReg, EnableBit
          ifdef FlagBit
            ifdef INT_ENABLECLEARFIRST
              if (INT_ENABLECLEARFIRST == 1)       ; if specified
                MOVE?CT 0, FlagReg, FlagBit        ;   clear the flag first
            MOVE?CT  1, EnableReg, EnableBit       ; enable the INT source
            INT_ERROR  "INT_ENABLE"
    #define INT_ENABLE(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
      ifndef INT_Enable
    #define INT_Enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_Enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_Enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    ;---[Disable an interrupt source]-------------------------------------------
    #INT_DISABLE  macro  FlagReg, FlagBit, EnableReg, EnableBit
          ifdef FlagBit
            MOVE?CT  0, EnableReg, EnableBit       ; disable the INT source
            INT_ERROR  "INT_DISABLE"
    #define INT_DISABLE(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
      ifndef INT_Disable
    #define INT_Disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_Disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_Disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    ;---[Clear an interrupt Flag]-----------------------------------------------
    #INT_CLEAR  macro  FlagReg, FlagBit, EnableReg, EnableBit
          ifdef FlagBit
            INT_ERROR "INT_CLEAR"
    #define INT_CLEAR(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
      ifndef INT_Clear
    #define INT_Clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define int_clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_Clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define int_Clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    i doubt i will understand how you came to that conclusion. you will need a different strategy if you plan additional interrupt usage as there can only be one interrupt handler, dt's elapsed timer takes it over entirely
    by the way the newer chips are easier to use
    i called this dlapsed.pbp,
    '*  Notes   : its based on this                                 *
    '*  Name    : DLAPSED.PBP                                       *
    '*  Author  : Richard                                           *
    '*  Notes   :  for 16F18877 or similar                          *
    '             a) @32MHz                                         *
    '             b) Used Timer3                                    *
    Seconds  VAR BYTE
    Minutes  VAR BYTE
    Hours    VAR BYTE
    Days     VAR WORD
    R0save   VAR WORD
    R1save   VAR WORD
    ZERO             VAR BIT
    CountDown        VAR BIT
    DaysChanged      VAR BIT
    CountDown = 0
    SecondsChanged = 1
    MinutesChanged = 1
    Goto OverElapsed
    Asm
    TimerConst = 45537		     ; 100Hz
    ADD2_TIMER   macro
        CHK?RP  T3CON
        INCF    TMR3H,F                ;  1
        ADDWF   TMR3H,F                ;  1
    RELOAD_TIMER  macro
        ADD2_TIMER
        CHK?RP  PIR4
    LOAD_TIMER  macro
    EndAsm
        TMR3L = 0
        TMR3H = 0
    Asm
        ADD2_TIMER
    EndAsm
       Ticks = Ticks + 1
       if Ticks = 100 then
          Ticks = 0
          IF CountDown THEN
             IF Seconds > 0 THEN
                SecondsChanged = 1
                IF Seconds = 0 THEN
                   IF Days = 0 THEN
                      IF Hours = 0 THEN
                         IF Minutes = 0 THEN
                            ZERO = 1
                IF Minutes > 0 THEN
                   Seconds = 59
                   SecondsChanged = 1
                   MinutesChanged = 1
                   IF Hours > 0 THEN
                      Hours = Hours - 1
                      Minutes = 59
                      Seconds = 59
                      SecondsChanged = 1
                      MinutesChanged = 1
                      HoursChanged = 1
                      IF Days > 0 THEN
                         Days = Days - 1
                         Hours = 23
                         Minutes = 59
                         Seconds = 59
                         SecondsChanged = 1
                         MinutesChanged = 1
                         HoursChanged = 1
                         DaysChanged = 1
                         GOSUB StopTimer
                         ZERO = 1
          ELSE                                ; Counting Up
             SecondsChanged = 1
                MinutesChanged = 1
                Seconds = 0
                Hours = Hours + 1
                HoursChanged = 1
                Minutes = 0
             IF Hours = 24 THEN
                Days = Days + 1
                DaysChanged = 1
                Hours = 0
       R0 = R0save
    @  RETFIE                      ; Restore context and return from interrupt
    StartTimer:
      IF NOT ZERO THEN
        T3CLK   = 1                   ;  clock source
        t3con = $20                   ;  prescaler
        PIR4.2  = 0                   ; (TMR3IF) Clear Timer3 Interrupt Flag
        PIE4.2  = 1                   ; (TMR3IE) Enable TMR3 overflow interrupt
    StopTimer:
    ResetTime:
        ZERO = 0
        TMR3L = 0
        TMR3H = 0
        Ticks = 0
        Seconds = 0
        Minutes = 0
        Hours = 0
        Days = 0
        SecondsChanged = 1
    OverElapsed:
    usage demo
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_ON & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
        __config _CONFIG4, _WRT_OFF & _SCANE_available & _LVP_ON
    DEFINE OSC 32
    ANSELA = 0
    TRISA = %11101111
    INCLUDE "DLAPSED.PBP "   ' Elapsed Timer Routines
    Hours = 0
    Minutes = 1
    Seconds = 0
    ZERO = 0
    GOSUB StartTimer
        IF SecondsChanged THEN
            Lata.4 = !Lata.4   ' flash led on porta.4
            SecondsChanged = 0
    GOTO Main
  1. Replies: 11
    Last Post: - 23rd August 2024, 03:13
  2. Replies: 7
    Last Post: - 2nd January 2018, 05:17
  3. Symbol not previously defined - lib file
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2015, 01:33
  4. symbol not prev. def. _INTRC_OSC 16F88
    By MarkR in forum mel PIC BASIC Pro
    Last Post: - 29th July 2011, 23:33
  5. Symbol not previously defined
    By Archangel in forum Code Examples
    Last Post: - 27th December 2008, 10:52
Members who have read this thread : 4
