Lets have a look at this
Code:ToggleLED1: PIE4.0 = 0 ' Stops Timer1 no it dosent TOGGLE PortB.4 T1CON.0 = 0 ' Resets Timer1 gate no it dosent T1CON.0 = 1 TMR1H = 2 : TMR1L = 24 ' TMR1H = 4 : TMR1L = 161 PIE4.0 = 1 ' Restarts Timer1 no it dosent @ INT_RETURN
should be more like
Code:ToggleLED1: T1CON.0 = 0 ' Stops Timer1 TMR1H = 2 : TMR1L = 18 T1CON.0 = 1 ' Restarts Timer1 TOGGLE PortB.4 @ INT_RETURN
to get 65ms from my chip
TMR1H = 0 : TMR1L = 18
is required, so the int osc is not all that accurate
with multicalc figure i get about 64.8mS
Now I'm confused.I thought you said I had to handle it?
This runs 50msec non-stop:
Code:#CONFIG __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_OFF & _FCMEN_ON __config _CONFIG2, _MCLRE_ON & _PWRTE_OFF & _LPBOREN_OFF & _BOREN_ON & _BORV_LO & _ZCD_OFF & _PPS1WAY_OFF & _STVREN_ON & _DEBUG_OFF __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_OFF & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC __config _CONFIG4, _WRT_OFF & _SCANE_available & _LVP_OFF __config _CONFIG5, _CP_OFF & _CPD_OFF #ENDCONFIG include "I:\Project_v2\PBP\PBP_Includes\DT_INTS-14_16F18877.bas" include "I:\Project_v2\PBP\PBP_Includes\ReEnterPBP.bas" ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler TMR1_INT, _ToggleLED1, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM DEFINE OSC 32 ANSELA = %00000000 ANSELB = %00000000 ANSELC = %00000000 ANSELD = %00000000 ANSELE = %00000000 TRISA = %00000000 TRISB = %00000000 TRISC = %00000000 TRISD = %00000000 TRISE = %00000000 T1CON = %00110001 ' 1:8 Prescale, Enables Timer1 ' bit 7-6 Unimplemented: Read as ‘0’ ' bit 5-4 CKPS<1:0>: Timer1 Input Clock Prescale Select bits ' ----> 11 = 1:8 Prescale value ' 10 = 1:4 Prescale value ' 01 = 1:2 Prescale value ' 00 = 1:1 Prescale value ' bit 3 Unimplemented: Read as ‘0’ ' bit 2 SYNC: Timer1 Synchronization Control bit ' When TMR1CLK = FOSC or FOSC/4 ' This bit is ignored. The timer uses the internal clock and no ' additional synchronization is performed. ' When TMR1CS<1:0> = (any setting other than FOSC or FOSC/4) ' 1 = Do not synchronize external clock input ' 0 = Synchronized external clock input with system clock ' bit 1 RD16: Timer1 On bit ' 1 = All 16 bits of Timer1 can be read simultaneously (TMR1H is buffered) ' 0 = 16-bit reads of Timer1 are disabled (TMR1H is not buffered) ' bit 0 ON: Timer1 On bit ' ----> 1 = Enables Timer1 ' 0 = Stops Timer1 and clears Timer1 gate flip-flop T1CLK = %00000001 ' FOSC/4 Timer1 Clock ' bit 7-4 Unimplemented: Read as ‘0’ ' bit 3-0 TxCS<3:0>: Timer1/3/5 Clock Select bits ' 1111 = LC4_out ' 1110 = LC3_out ' 1101 = LC2_out ' 1100 = LC1_out ' 1011 = TMR5 overflow output(3) ' 1010 = TMR3 overflow output(2) ' 1001 = TMR1 overflow output(1) ' 1000 = TMR0 overflow output ' 0111 = CLKR output clock ' 0110 = SOSC ' 0101 = MFINTOSC ' 1.05msec @ 32MHz with no preload ' 0100 = LFINTOSC ' n/a ' 0011 = HFINTOSC ' 16.56msec @ 32MHz with no preload ' 0010 = FOSC ' 16.54msec @ 32MHz with no preload ' ----> 0001 = FOSC/4 ' 66.18msec @ 32MHz with no preload ' 0000 = TxCKIPPS LatB.0 = 0 TMR1H = 60 : TMR1L = 176 ' 50msec interval (32MHz, 16bit, 1:8) PIE4.0 = 1 ' Starts Timer1 LatB.0 = 1 Main: LatB.5 = 1 ' Heartbeat LatB.5 = 0 GOTO Main ToggleLED1: LatB.0 = 0 ' PIE4.0 = 0 ' Stops Timer1 TMR1H = 60 : TMR1L = 176 ' 50msec interval (32MHz, 16bit, 1:8) ' PIE4.0 = 1 ' Restarts Timer1 LatB.0 = 1 @ INT_RETURN![]()
This starts it once (same defines and registers):
Code:ToggleLED1: LatB.0 = 0 PIE4.0 = 0 ' Stops Timer1 TMR1H = 60 : TMR1L = 176 ' 50msec interval (32MHz, 16bit, 1:8) ' PIE4.0 = 1 ' Restarts Timer1 LatB.0 = 1 @ INT_RETURN
This stops it, then starts it back up again (this is what I need for my project):
Code:ToggleLED1: LatB.0 = 0 PIE4.0 = 0 ' Stops Timer1 TMR1H = 60 : TMR1L = 176 ' 50msec interval (32MHz, 16bit, 1:8) PIE4.0 = 1 ' Restarts Timer1 LatB.0 = 1 @ INT_RETURN![]()
yes with the newer chips some interrupt enable bits and flags have been relocated from INTCON reg into PIEx/PIRx regsdt ints will not enable intcon PEIE you need to
I'm not convinced dt-ints14 will always set the PEIE bit in INTCON when needed in all cases so i do it manually.
to set PEIE WITH GIE use
INTCON=$C0
for this chip and timer1 interrupts its not necessary dt-ints will set PEIE for you but this has no relationship with PIE4.0, i have no idea how you made that inference
just how does PIE4.0 = 0 stop the timer ?
writing to the timer like this when its still running is a very bad idea
I think I got that originally from the datasheet:
(16F18877 p.138)
Note: Bit PEIE of the INTCON register must be set to enable any peripheral interrupt controlled by registers PIE1-PIE8.
It looks to me like INTCOM is a master breaker; shutting that down shuts all interrupts.
And individual interrupts can be managed via their PIE registers (ie: PIE4 alone manages 6 timers)
pic16 's have one level of interrupt , therefore an interrupt can never be interrupted
disabling the timer1 interrupt inside an interrupt is a pointless exercises that accomplishes exactly nothing
except to waste machine cycles
disabling the timer1 interrupt does not in any way shape or form stop the timer from running.
the only way to stop the timer is to either turn it off or stop its clock signal.
No, but any interrupt triggered while an ISR is running will be handled once the ISR finishes.
(p.129 16F18877)
So you can have multiple Timers running at the same time (including USART interrupts and others).Note
1: Individual interrupt flag bits are set, regardless of the state of any other enable bits.
2: All interrupts will be ignored while the GIE bit is cleared. Any interrupt occurring while the GIE bit is clear will be serviced when the GIE bit is set again.
No...?
