My TMR1_INT Blinky is not blinking
Results 1 to 16 of 16
    Default Re: My TMR1_INT Blinky is not blinking
    there are a number of problems
    1, toggle LatB.4 is a no no. toggle or any other pbp high level command will not function correctly with LATx regs and can only be safely used with PORTx regs
    2. you have not selected a clock source for timer1 see T1CLK in data sheet
    3. dt ints will not enable intcon PEIE you need to
    this is PBP 2.6 and 20MHZ clock, and 10 times a second tmr1 interrupt....... on interrupt routine, need to, 1) stop timer... 2) reload tmr1 counters for timing period... 3) do something ( I set a flag so next loop in basic can see if something happened) .... turn tmr1 back on and leave int... of course you have to adjust for your stuff and PBP3
    include "D:\All_PIC\Project_18f2525 RTOS\A_18F2525_Setup.pbp"     'f2525 setup stuff
    include "D:\All_PIC\Project_18f2525 RTOS\A_TX_RX.pbp"
    output portc.2     ' LED on pin 13 of F2525
    T1CON = $31        ' Prescaler = 8, TMR1ON
    BH=11 : BL=190 '...MAIN INT TIMING PRELOAD FOR TIMER1 INT = 10X/SEC
    L0=0:B3=10
    '''' interrupts for T1 timeout (main timing loop), etc''''''''''''''''
            INT_Handler   TMR1_INT,      _T1int,   PBP,  yes
            INT_Handler   RX_INT,        _RCint,  PBP,  yes
            INT_Handler   TX_INT,        _TRint,  PBP,  no
    @ INT_DISABLE  RX_INT        ; enable RX interrupts
    @ INT_DISABLE  TX_INT       ;disable tx int
    ''''_________________________________________________
    ______'''
    ''''''''''''''''''''''-----END OF MAIN LOOP-------'''''''''''''''
    ''''''''''''''-----INTERRUPTS HERE----------''''''''''''''''''
    '''''''T1 main''Interrupt Routine''''''''''''''''''
    T1int:
    T1CON.0=0
    TMR1h=bh :TMR1l=bl  'load tmr1
    FLG1 =0
    T1CON.0=1
    @ INT_RETURN    ;RESET FLAG FOR BASIC LOOP
    '''-------------RCV INT ROUTINE----------------''''
    RCint:
    RCX=RCREG
    '@ bcf RCSTA,4
    '@ bsf RCSTA,4
    '''@ CLRF CREN     ;RESET RCV overrun
    '''@ SETF CREN
    Thanks both!
    I get 66.18msec intervals. I'd like to bring that down to 65msec.
    MultiCalc says 536 decimal pre-load gives 65mSec (32MHz, 16bits, 1:8)
    How do you store 536 in TMR1H and TMR1L?
    I manually get this in binary for 536:
    00000010 00011000
    In decimal, that gives 2 24.
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_OFF & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    include "I:\Project_v2\PBP\PBP_Includes\DT_INTS-14_16F18877.bas"
    include "I:\Project_v2\PBP\PBP_Includes\ReEnterPBP.bas"
            INT_Handler    TMR1_INT,  _ToggleLED1,   PBP,  yes
    DEFINE OSC 32
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00000000
    T1CON = %00110001                                   ' 1:8 Prescale, Enables Timer1
    '   bit 7-6 Unimplemented: Read as ‘0’
    '   bit 5-4 CKPS<1:0>: Timer1 Input Clock Prescale Select bits
    '        ---->  11 = 1:8 Prescale value
    '               10 = 1:4 Prescale value
    '               01 = 1:2 Prescale value
    '               00 = 1:1 Prescale value
    '   bit 3   Unimplemented: Read as ‘0’
    '   bit 2   SYNC: Timer1 Synchronization Control bit
    '                   When TMR1CLK = FOSC or FOSC/4
    '                       This bit is ignored. The timer uses the internal clock and no
    '                       additional synchronization is performed.
    '                   When TMR1CS<1:0> = (any setting other than FOSC or FOSC/4)
    '               1 = Do not synchronize external clock input
    '               0 = Synchronized external clock input with system clock
    '   bit 1   RD16: Timer1 On bit
    '               1 = All 16 bits of Timer1 can be read simultaneously (TMR1H is buffered)
    '               0 = 16-bit reads of Timer1 are disabled (TMR1H is not buffered)
    '   bit 0   ON: Timer1 On bit
    '        ---->  1 = Enables Timer1
    '               0 = Stops Timer1 and clears Timer1 gate flip-flop
    T1CLK = %00000001                                   ' FOSC/4 Timer1 Clock
    '   bit 7-4 Unimplemented: Read as ‘0’
    '   bit 3-0 TxCS<3:0>: Timer1/3/5 Clock Select bits
    '               1111 = LC4_out
    '               1110 = LC3_out
    '               1101 = LC2_out
    '               1100 = LC1_out
    '               1011 = TMR5 overflow output(3)
    '               1010 = TMR3 overflow output(2)
    '               1001 = TMR1 overflow output(1)
    '               1000 = TMR0 overflow output
    '               0111 = CLKR output clock
    '               0110 = SOSC
    '               0101 = MFINTOSC                     ' 1.05msec @ 32MHz with no preload
    '               0100 = LFINTOSC                     ' n/a
    '               0011 = HFINTOSC                     ' 16.56msec @ 32MHz with no preload
    '               0010 = FOSC                         ' 16.54msec @ 32MHz with no preload
    '        ---->  0001 = FOSC/4                       ' 66.18msec @ 32MHz with no preload
    '               0000 = TxCKIPPS
        TOGGLE PortB.4
        TMR1H = 2 : TMR1L = 24
    '    TMR1H = 4 : TMR1L = 161
        PIE4.0 = 1                                  ' Activates Timer1
        TOGGLE PortB.5                              ' Heartbeat
    GOTO Main
    ToggleLED1:
        PIE4.0 = 0                                  ' Stops Timer1
        TOGGLE PortB.4
        T1CON.0 = 0                                 ' Resets Timer1 gate
        T1CON.0 = 1
        PIE4.0 = 1                                  ' Restarts Timer1
    @ INT_RETURN
    TMR1H = 2 : TMR1L = 24 gives 65.6mSec intervals according to Logic.
    I have to use TMR1H = 4 : TMR1L = 161 to get 65.05mSec (after a lot of trial and error).
    I must be doing something wrong...?
    internal osc, what is the error %...... xtal osc matches with multicalc calculations
    High-Precision Internal Oscillator:
    - Software selectable frequency range up to 32 MHz, ±1% typical
    I hadn't thought of that.
    Lets have a look at this
    ToggleLED1:
        PIE4.0 = 0                                  ' Stops Timer1  no it dosent
        TOGGLE PortB.4
        T1CON.0 = 0                                 ' Resets Timer1 gate no it dosent
        T1CON.0 = 1
        PIE4.0 = 1                                  ' Restarts Timer1 no it dosent
    @ INT_RETURN
    should be more like
    ToggleLED1:
        T1CON.0 = 0                                   ' Stops Timer1
        TMR1H = 2 : TMR1L = 18
        T1CON.0 = 1                        ' Restarts Timer1
        TOGGLE PortB.4
    @ INT_RETURN
  1. Replies: 3
    Last Post: - 15th April 2015, 05:58
  2. MIBAM blinky on 16f628
    By ShoKre in forum mel PIC BASIC Pro
    Last Post: - 11th December 2013, 09:58
  3. Replies: 6
    Last Post: - 25th April 2010, 05:45
  4. Blinky not working with TOGGLE
    By AndrewC in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 09:45
  5. My first Blinky!
    By nomad in forum mel PIC BASIC Pro
    Last Post: - 25th September 2007, 18:29
