My TMR1_INT Blinky is not blinking
+ Reply to Thread
Results 1 to 16 of 16
    Question My TMR1_INT Blinky is not blinking
    16F18877
    Mostly taken from:
    https://dt.picbasic.co.uk/INT14/TMR1INT
        __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_OFF & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    include "I:\Project_v2\PBP\PBP_Includes\DT_INTS-14_16F18877.bas"
    include "I:\Project_v2\PBP\PBP_Includes\ReEnterPBP.bas"
            INT_Handler    TMR1_INT,  _ToggleLED1,   PBP,  yes
    DEFINE OSC 32
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00000000
    T1CON = $31                ; Prescaler=8, TMR1ON
        toggle LatB.3
        PAUSE 1
    GOTO Main
    ToggleLED1:
        toggle LatB.4
    @ INT_RETURN
    My custom DT_INTS-14_16F18877.bas:
    '*  Name    : DT_INTS-14_16F18877.bas                                      *
    '*  Author  : Darrel Taylor (modified by Demon)                            *
    '*  Version : 1.15 (8/29/2024)                                             *
    '*  Date    : OCT 13, 2009                                                 *
    '* REV 1.15  Customized for 16F1885xx-7x (IOC, USART-RX, CCPx)             *
    '* REV 1.10  Fixes Duplicate label error when Handlers cross page boundary *
    '*           Fixes error with 16F1's and MPLAB 8.53 (high)                 *
    '* REV 1.00  Completely re-written, with optimization and F1 chips in mind *
    '* REV 0.93  Fixed CMIF and EEIF problem with older PIC's                  *
    '*           that have the Flags in PIR1 instead of PIR2                   *
    '* Rev 0.92  solves a "Missed Interrupt" and                               *
    '*           banking switching problem                                     *
    DEFINE  DT_INTS_VERSION  110
    DEFINE  INTHAND  INT_ENTRY
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    ;wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    ;wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    ;wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    ;wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    ssave       VAR BYTE    BANK0   SYSTEM      ' location for STATUS register
    psave       VAR BYTE    BANK0   SYSTEM      ' location for PCLATH register
    fsave       VAR BYTE    BANK0   SYSTEM      ' location for FSR register
    RetAddr     VAR WORD    BANK0
    INT_Bits    VAR BYTE    BANK0
      Serviced  VAR INT_Bits.0
      Vars_Saved VAR INT_Bits.1
    GIE         VAR INTCON.7
    PEIE        VAR INTCON.6
      ifdef PM_USED                             ; verify MPASM is the assembler
        "ERROR: DT_INTS does not support the PM assembler, USE MPASM"
      ifdef ReEnterUsed
        ifdef ReEnterVersion
          if (ReEnterVersion < 34)
            error "Wrong version of ReEnterPBP.bas - Ver 3.4 or higher required
        if (BANK0_END == 0x7F)
          ifdef BANK1_END
            if (BANK1_END == 0xEF)   ; doesn't find 12F683
              variable ACCESSRAM = 1
              variable ACCESSRAM = 0
    #define OrChange Or change to   wsave BYTE $70 SYSTEM
    AddWsave macro B
      if (B == 0)
        if (ACCESSRAM == 1)
          error   "                     Add:"       wsave VAR BYTE $70 SYSTEM
          error   "                     Add:"       wsave VAR BYTE $20 SYSTEM
      if (B == 1)
        if (ACCESSRAM == 1)
          error   "   Add:"       wsave1 VAR BYTE $A0 SYSTEM, OrChange
      if (B == 2)
        if (ACCESSRAM == 1)
          error   "   Add:"       wsave2 VAR BYTE $120 SYSTEM, OrChange
      if (B == 3)
        if (ACCESSRAM == 1)
          error   "   Add:"       wsave3 VAR BYTE $1A0 SYSTEM, OrChange
    #define WsaveE1(B) Chip has RAM in BANK#v(B), but wsave#v(B) was not found.
    ;#define WsaveE2(B) Uncomment wsave#v(B) in the DT_INTS-14.bas file.
    #define WsaveCouldBe This chip has access RAM at $70
    #define WsaveError(B) error  WsaveE1(B)
      ifndef FSR0L     ; not a 16F1
        ifndef wsave
    ;      if (ACCESSRAM == 1)
            error wsave variable not found,
            AddWsave(0)
            variable wsave = 0 ; stop further wsave errors
    ;      else
    ;      endif
          if (wsave == 0x70)
            if (ACCESSRAM == 0)
              error This chip does not have AccessRAM at $70, change to   wsave VAR BYTE $20 SYSTEM
              if (wsave != 0x20)
                error wsave must be either $20 or $70
        ifdef BANK1_START
          ifndef wsave1
            ifdef wsave
              if (wsave != 0x70)
                WsaveError(1)
                AddWsave(1)
              if (ACCESSRAM == 1)
                if (wsave != 0x70)
                  WsaveCouldBe
        ifdef BANK2_START
          ifndef wsave2
            ifdef wsave
              if (wsave != 0x70)
                WsaveError(2)
                AddWsave(2)
        ifdef BANK3_START
          ifndef wsave3
            ifdef wsave
              if (wsave != 0x70)
                WsaveError(3)
                AddWsave(3)
    asm = 0
    Asm = 0
    ASM = 0
    pbp = 1
    Pbp = 1
    PBP = 1
    yes = 1
    Yes = 1
    YES = 1
    no  = 0
    No  = 0
    NO  = 0
    ;---[Original DEFINES]------------------------------------------------------
      #define ALL_INT      INTCON,GIE, INTCON,GIE      ;-- Global Interrupts   *
    ;  #define IOC_INT      INTCON,IOCIF, INTCON,IOCIE  ;-- Int On Change
    ;  #define RX_INT       PIR1,RCIF, PIE1,RCIE        ;-- USART Receive
    ;  #define CCP1_INT     PIR1,CCP1IF, PIE1,CCP1IE    ;-- CCP1
    ;  #define CCP2_INT     PIR2,CCP2IF, PIE2,CCP2IE    ;-- CCP2
    ;  #define CCP3_INT     PIR3,CCP3IF, PIE3,CCP3IE    ;-- CCP3
    ;  #define CCP4_INT     PIR3,CCP4IF, PIE3,CCP4IE    ;-- CCP4
    ;  #define CCP5_INT     PIR3,CCP5IF, PIE3,CCP5IE    ;-- CCP5
      #define IOC_INT      PIR0,IOCIF, PIE0,IOCIE      ;-- Int On Change
      #define TMR1_INT     PIR4,TMR1IF, PIE4,TMR1IE    ;-- Timer1
      #define RX_INT       PIR3,RCIF, PIE3,RCIE        ;-- USART Receive
      #define CCP1_INT     PIR6,CCP1IF, PIE6,CCP1IE    ;-- CCP1
      #define CCP2_INT     PIR6,CCP2IF, PIE6,CCP2IE    ;-- CCP2
      #define CCP3_INT     PIR6,CCP3IF, PIE6,CCP3IE    ;-- CCP3
      #define CCP4_INT     PIR6,CCP4IF, PIE6,CCP4IE    ;-- CCP4
      #define CCP5_INT     PIR6,CCP5IF, PIE6,CCP5IE    ;-- CCP5
    ;---[Returns the Address of a Label as a Word]------------------------------
    GetAddress macro Label, Wout
        CHK?RP Wout
        movlw low Label          ; get low byte
        movwf Wout
    ;    movlw High Label         ; get high byte  MPLAB 8.53 killed high
        movlw Label >> 8         ; get high byte
        movwf Wout + 1
    ;---[find correct bank for a BIT variable]----------------------------------
    CHKRP?T  macro reg, bit
        CHK?RP  reg
    ;---[This creates the main Interrupt Service Routine (ISR)]-----------------
    INT_CREATE  macro
      local OverCREATE
        L?GOTO OverCREATE
    INT_ENTRY
        ifndef FSR0L
          if (CODE_SIZE <= 2)
              movwf   wsave       ; 1 copy W to wsave register
              swapf   STATUS,W    ; 2 swap status reg to be saved into W
              clrf    STATUS      ; 3 change to bank 0
              movwf   ssave       ; 4 save status reg to a bank 0 register
              movf    PCLATH,W    ; 5 move PCLATH reg to be saved into W reg
              movwf   psave       ; 6 save PCLATH reg to a bank 0 register
          endIF
          movf      FSR,W         ; 7 move FSR reg to be saved into W reg
          movwf     fsave         ; 8 save FSR reg to a bank 0 register
          banksel 0               ; BANK 0 for F1 chips
        variable  PREV_BANK = 0
        MOVE?CT  0, _Vars_Saved
    List_Start
        ifdef LoopWhenServiced
          MOVE?CT  0, _Serviced   ; indicate nothing has been serviced
        INT_LIST                  ; Expand the users list of interrupt handlers
                                ; INT_LIST macro must be defined in main program
          BIT?GOTO  1, _Serviced, List_Start
        ifdef ReEnterUsed         ; if ReEnterPBP.bas was included
            CHKRP?T  _Vars_Saved
            btfss    _Vars_Saved  ; if PBP system vars have been saved
            goto     INT_EXIT
            L?GOTO   _RestorePBP  ; Restore PBP system Vars
    INT_EXIT
        ifndef FSR0L              ; if chip is not an F1 - restore context
          clrf    STATUS          ; BANK 0
          movf    fsave,W         ; Restore the FSR reg
          movwf   FSR
          movf    psave,w         ; Restore the PCLATH reg
          movwf   PCLATH
          swapf   ssave,w         ; Restore the STATUS reg
          movwf   STATUS
          swapf   wsave,f
          swapf   wsave,w         ; Restore W reg
        retfie                    ; Exit the interrupt routine
      LABEL?L OverCREATE
        bsf      INTCON, 6      ; Enable Peripheral interrupts
        bsf      INTCON, 7      ; Enable Global interrupts
    ;---[Add an Interrupt Source to the user's list of INT Handlers]------------
    #INT_HANDLER  macro  FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
      list
        local AfterSave, AfterUserRoutine, NoInt
          ifdef FlagBit
            CHK?RP   EnableReg
            btfss    EnableReg, EnableBit        ; if the INT is enabled
            goto     NoInt
            CHK?RP   FlagReg
            btfss    FlagReg, FlagBit            ; and the Flag set?
            goto     NoInt
              MOVE?CT  1, _Serviced
            if (Type == PBP)                     ; If INT handler is PBP
              ifdef ReEnterUsed
                btfsc  _Vars_Saved
                goto   AfterSave
                GetAddress  AfterSave, _RetAddr
                L?GOTO  _SavePBP                 ; Save PBP system Vars
                LABEL?L  AfterSave
                error ReEnterPBP must be INCLUDEd to use PBP type interrupts
            GetAddress  AfterUserRoutine, _RetAddr   ; save return address
            L?GOTO   Label                       ; goto the users INT handler
            LABEL?L AfterUserRoutine
            if (Reset == YES)
              CHK?RP   FlagReg
              bcf      FlagReg, FlagBit        ; reset flag (if specified)
            INT_ERROR  "INT_Handler"
    NoInt
          banksel  0
    PREV_BANK = 0
    #define INT_HANDLER(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
      ifndef INT_Handler
    #define INT_Handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define int_handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define Int_Handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define Int_handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    #define int_Handler(FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset)  #INT_HANDLER FlagReg,FlagBit, EnableReg,EnableBit, Label, Type,Reset
    ;---[Returns from a "goto" subroutine]--------(RetAddr must be set first)---
    #INT_RETURN  macro
          CHK?RP  _RetAddr
          movf    _RetAddr + 1, W  ; Set PCLATH with top byte of return address
          movwf   PCLATH
          movf    _RetAddr, W      ; Go back to where we were
          movwf   PCL
    ;_____________________________
    #define INT_RETURN  #INT_RETURN
      ifndef INT_Return
    #define INT_Return  #INT_RETURN
    #define int_return  #INT_RETURN
    #define Int_Return  #INT_RETURN
    #define Int_return  #INT_RETURN
    #define int_Return  #INT_RETURN
    ;----[Display not found error]----------------------------------------------
    INT_ERROR macro From
        error From -  Interrupt Flag ( FlagReg,FlagBit ) not found.
    ;---[Enable an interrupt source]--------------------------------------------
      ifndef INT_ENABLECLEARFIRST
        #define INT_ENABLECLEARFIRST 1             ; default to Clear First
      endif          ; use DEFINE INT_ENABLECLEARFIRST 0 to NOT clear First
    #INT_ENABLE  macro  FlagReg, FlagBit, EnableReg, EnableBit
          ifdef FlagBit
            ifdef INT_ENABLECLEARFIRST
              if (INT_ENABLECLEARFIRST == 1)       ; if specified
                MOVE?CT 0, FlagReg, FlagBit        ;   clear the flag first
            MOVE?CT  1, EnableReg, EnableBit       ; enable the INT source
            INT_ERROR  "INT_ENABLE"
    #define INT_ENABLE(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
      ifndef INT_Enable
    #define INT_Enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_Enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_Enable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_ENABLE FlagReg, FlagBit, EnableReg, EnableBit
    ;---[Disable an interrupt source]-------------------------------------------
    #INT_DISABLE  macro  FlagReg, FlagBit, EnableReg, EnableBit
          ifdef FlagBit
            MOVE?CT  0, EnableReg, EnableBit       ; disable the INT source
            INT_ERROR  "INT_DISABLE"
    #define INT_DISABLE(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
      ifndef INT_Disable
    #define INT_Disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_Disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    #define int_Disable(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_DISABLE FlagReg, FlagBit, EnableReg, EnableBit
    ;---[Clear an interrupt Flag]-----------------------------------------------
    #INT_CLEAR  macro  FlagReg, FlagBit, EnableReg, EnableBit
          ifdef FlagBit
            INT_ERROR "INT_CLEAR"
    #define INT_CLEAR(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
      ifndef INT_Clear
    #define INT_Clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define int_clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_Clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define Int_clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    #define int_Clear(FlagReg, FlagBit, EnableReg, EnableBit)  #INT_CLEAR FlagReg, FlagBit, EnableReg, EnableBit
    I end up with only the heartbeat pulse on B3.
    Does ENABLE only sets it up, or does it start the timer?
    Default Re: My TMR1_INT Blinky is not blinking
    there are a number of problems
    1, toggle LatB.4 is a no no. toggle or any other pbp high level command will not function correctly with LATx regs and can only be safely used with PORTx regs
    2. you have not selected a clock source for timer1 see T1CLK in data sheet
    3. dt ints will not enable intcon PEIE you need to
    this is PBP 2.6 and 20MHZ clock, and 10 times a second tmr1 interrupt....... on interrupt routine, need to, 1) stop timer... 2) reload tmr1 counters for timing period... 3) do something ( I set a flag so next loop in basic can see if something happened) .... turn tmr1 back on and leave int... of course you have to adjust for your stuff and PBP3
    include "D:\All_PIC\Project_18f2525 RTOS\A_18F2525_Setup.pbp"     'f2525 setup stuff
    include "D:\All_PIC\Project_18f2525 RTOS\A_TX_RX.pbp"
    output portc.2     ' LED on pin 13 of F2525
    T1CON = $31        ' Prescaler = 8, TMR1ON
    BH=11 : BL=190 '...MAIN INT TIMING PRELOAD FOR TIMER1 INT = 10X/SEC
    L0=0:B3=10
    '''' interrupts for T1 timeout (main timing loop), etc''''''''''''''''
            INT_Handler   TMR1_INT,      _T1int,   PBP,  yes
            INT_Handler   RX_INT,        _RCint,  PBP,  yes
            INT_Handler   TX_INT,        _TRint,  PBP,  no
    @ INT_DISABLE  RX_INT        ; enable RX interrupts
    @ INT_DISABLE  TX_INT       ;disable tx int
    ''''_________________________________________________
    ______'''
    ''''''''''''''''''''''-----END OF MAIN LOOP-------'''''''''''''''
    ''''''''''''''-----INTERRUPTS HERE----------''''''''''''''''''
    '''''''T1 main''Interrupt Routine''''''''''''''''''
    T1int:
    T1CON.0=0
    TMR1h=bh :TMR1l=bl  'load tmr1
    FLG1 =0
    T1CON.0=1
    @ INT_RETURN    ;RESET FLAG FOR BASIC LOOP
    '''-------------RCV INT ROUTINE----------------''''
    RCint:
    RCX=RCREG
    '@ bcf RCSTA,4
    '@ bsf RCSTA,4
    '''@ CLRF CREN     ;RESET RCV overrun
    '''@ SETF CREN
    Thanks both!
    I get 66.18msec intervals. I'd like to bring that down to 65msec.
    MultiCalc says 536 decimal pre-load gives 65mSec (32MHz, 16bits, 1:8)
    How do you store 536 in TMR1H and TMR1L?
    I manually get this in binary for 536:
    00000010 00011000
    In decimal, that gives 2 24.
    DEFINE OSC 32
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00000000
    T1CON = %00110001                                   ' 1:8 Prescale, Enables Timer1
    '   bit 7-6 Unimplemented: Read as ‘0’
    '   bit 5-4 CKPS<1:0>: Timer1 Input Clock Prescale Select bits
    '        ---->  11 = 1:8 Prescale value
    '               10 = 1:4 Prescale value
    '               01 = 1:2 Prescale value
    '               00 = 1:1 Prescale value
    '   bit 3   Unimplemented: Read as ‘0’
    '   bit 2   SYNC: Timer1 Synchronization Control bit
    '                   When TMR1CLK = FOSC or FOSC/4
    '                       This bit is ignored. The timer uses the internal clock and no
    '                       additional synchronization is performed.
    '                   When TMR1CS<1:0> = (any setting other than FOSC or FOSC/4)
    '               1 = Do not synchronize external clock input
    '               0 = Synchronized external clock input with system clock
    '   bit 1   RD16: Timer1 On bit
    '               1 = All 16 bits of Timer1 can be read simultaneously (TMR1H is buffered)
    '               0 = 16-bit reads of Timer1 are disabled (TMR1H is not buffered)
    '   bit 0   ON: Timer1 On bit
    '        ---->  1 = Enables Timer1
    '               0 = Stops Timer1 and clears Timer1 gate flip-flop
    T1CLK = %00000001                                   ' FOSC/4 Timer1 Clock
    '   bit 7-4 Unimplemented: Read as ‘0’
    '   bit 3-0 TxCS<3:0>: Timer1/3/5 Clock Select bits
    '               1111 = LC4_out
    '               1110 = LC3_out
    '               1101 = LC2_out
    '               1100 = LC1_out
    '               1011 = TMR5 overflow output(3)
    '               1010 = TMR3 overflow output(2)
    '               1001 = TMR1 overflow output(1)
    '               1000 = TMR0 overflow output
    '               0111 = CLKR output clock
    '               0110 = SOSC
    '               0101 = MFINTOSC                     ' 1.05msec @ 32MHz with no preload
    '               0100 = LFINTOSC                     ' n/a
    '               0011 = HFINTOSC                     ' 16.56msec @ 32MHz with no preload
    '               0010 = FOSC                         ' 16.54msec @ 32MHz with no preload
    '        ---->  0001 = FOSC/4                       ' 66.18msec @ 32MHz with no preload
    '               0000 = TxCKIPPS
        TOGGLE PortB.4
        TMR1H = 2 : TMR1L = 24
    '    TMR1H = 4 : TMR1L = 161
        PIE4.0 = 1                                  ' Activates Timer1
        TOGGLE PortB.5                              ' Heartbeat
    GOTO Main
    ToggleLED1:
        PIE4.0 = 0                                  ' Stops Timer1
        TOGGLE PortB.4
        T1CON.0 = 0                                 ' Resets Timer1 gate
        T1CON.0 = 1
        PIE4.0 = 1                                  ' Restarts Timer1
    @ INT_RETURN
    TMR1H = 2 : TMR1L = 24 gives 65.6mSec intervals according to Logic.
    I have to use TMR1H = 4 : TMR1L = 161 to get 65.05mSec (after a lot of trial and error).
    I must be doing something wrong...?
    internal osc, what is the error %...... xtal osc matches with multicalc calculations
    High-Precision Internal Oscillator:
    - Software selectable frequency range up to 32 MHz, ±1% typical
    I hadn't thought of that.
    Lets have a look at this
    ToggleLED1:
        PIE4.0 = 0                                  ' Stops Timer1  no it dosent
        TOGGLE PortB.4
        T1CON.0 = 0                                 ' Resets Timer1 gate no it dosent
        T1CON.0 = 1
        PIE4.0 = 1                                  ' Restarts Timer1 no it dosent
    @ INT_RETURN
    should be more like
    ToggleLED1:
        T1CON.0 = 0                                   ' Stops Timer1
        TMR1H = 2 : TMR1L = 18
        T1CON.0 = 1                        ' Restarts Timer1
        TOGGLE PortB.4
    @ INT_RETURN
    to get 65ms from my chip
    TMR1H = 0 : TMR1L = 18
    is required, so the int osc is not all that accurate
    with multicalc figure i get about 64.8mS
    ...PIE4.0 = 1 ' Restarts Timer1 no it dosent...
    Now I'm confused. I thought you said I had to handle it?
    ... dt ints will not enable intcon PEIE you need to
    This runs 50msec non-stop:
    DEFINE OSC 32
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISA = %00000000
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE = %00000000
    '               1111 = LC4_out
    '               1110 = LC3_out
    '               1101 = LC2_out
    '               1100 = LC1_out
    '               0110 = SOSC
    '               0000 = TxCKIPPS
                                    LatB.0 = 0
        TMR1H = 60 : TMR1L = 176                    ' 50msec interval (32MHz, 16bit, 1:8)
        PIE4.0 = 1                                  ' Starts Timer1
                                    LatB.0 = 1
        LatB.5 = 1                              ' Heartbeat
        LatB.5 = 0
    GOTO Main
    ToggleLED1:
                                    LatB.0 = 0
    '    PIE4.0 = 0                                  ' Stops Timer1
    '    PIE4.0 = 1                                  ' Restarts Timer1
                                    LatB.0 = 1
    @ INT_RETURN
    Name:  1 - Timer1 No PIE.png
    This starts it once (same defines and registers):
    ToggleLED1:
                                    LatB.0 = 0
                                    LatB.0 = 1
    @ INT_RETURN
    Name:  2 - Timer1 PIE 0.png
    This stops it, then starts it back up again (this is what I need for my project):
    ToggleLED1:
                                    LatB.0 = 0
                                    LatB.0 = 1
    @ INT_RETURN
    Name:  3 - Timer1 PIE 01.png
    yes with the newer chips some interrupt enable bits and flags have been relocated from INTCON reg into PIEx/PIRx regs
    I'm not convinced dt-ints14 will always set the PEIE bit in INTCON when needed in all cases so i do it manually.
    to set PEIE WITH GIE use
    INTCON=$C0
    for this chip and timer1 interrupts its not necessary dt-ints will set PEIE for you but this has no relationship with PIE4.0, i have no idea how you made that inference
    just how does PIE4.0 = 0 stop the timer ?
    writing to the timer like this when its still running is a very bad idea
    ...for this chip and timer1 interrupts its not necessary dt-ints will set PEIE for you but this has no relationship with PIE4.0, i have no idea how you made that inference...
    I think I got that originally from the datasheet:
    (16F18877 p.138)
    Note: Bit PEIE of the INTCON register must be set to enable any peripheral interrupt controlled by registers PIE1-PIE8.
    It looks to me like INTCOM is a master breaker; shutting that down shuts all interrupts.
    And individual interrupts can be managed via their PIE registers (ie: PIE4 alone manages 6 timers)
    ...just how does PIE4.0 = 0 stop the timer ?...
    (also p.138)
    bit 0 TMR1IE: Timer1 Overflow Interrupt Enable bit
    1 = Enables the Timer1 overflow interrupt
    0 = Enables the Timer1 overflow interrupt
    pic16 's have one level of interrupt , therefore an interrupt can never be interrupted
    disabling the timer1 interrupt inside an interrupt is a pointless exercises that accomplishes exactly nothing
    except to waste machine cycles
    disabling the timer1 interrupt does not in any way shape or form stop the timer from running.
    the only way to stop the timer is to either turn it off or stop its clock signal.
    pic16 's have one level of interrupt , therefore an interrupt can never be interrupted ...
    No, but any interrupt triggered while an ISR is running will be handled once the ISR finishes.
    (p.129 16F18877)
    Note
    1: Individual interrupt flag bits are set, regardless of the state of any other enable bits.
    2: All interrupts will be ignored while the GIE bit is cleared. Any interrupt occurring while the GIE bit is clear will be serviced when the GIE bit is set again.
    So you can have multiple Timers running at the same time (including USART interrupts and others).
    No...?
    of course you can, as many enabled as you see fit
    but one and only one can be serviced at a time, and it cannot be interrupted. first come first served.
    additional interrupts are serviced sequentially, one and only one at a time in the order the interrupt handler runs them.
    hence keep isr's short
  1. Replies: 3
    Last Post: - 15th April 2015, 04:58
  2. MIBAM blinky on 16f628
    By ShoKre in forum mel PIC BASIC Pro
    Last Post: - 11th December 2013, 08:58
  3. Replies: 6
    Last Post: - 25th April 2010, 04:45
  4. Blinky not working with TOGGLE
    By AndrewC in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 08:45
  5. My first Blinky!
    By nomad in forum mel PIC BASIC Pro
    Last Post: - 25th September 2007, 17:29
Members who have read this thread : 7
